Like Tree40Likes
 Old 06-25-2012, 04:24 PM   #41
sallyspeed3's Avatar
Posts: 638   (View Stats)
sallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the world
Bolt ons beyond intake and downpipe are a waste with a K04 on E85, once properly tuned. Just go 5050, tune, and call it a day.
What about meth? I'm hoping its pointless cause thats the whole point of me using e85. Don't have the money for a kit but can't stand how sluggish my car is in this heat.
2008 Cosmic Blue Mazdaspeed 3 GT - COBB AP DIZZYTUNED for 30% E85//JBR Whale Penis//COBB TIP//COBB DP//COBB STS//COBB Knob//COBB shift weight//COBB Piping TR8L Core//Magnaflow CBE//Turbosmart BPV//PTP internals//SU RMM//TRZ tranny mount//Koni + H&R springs//Tinted 35% front, 20% rear//Lamin-X head-light & tail-light film//ASA GT1 18x8//Hankook Ventus V12 225/40//
sallyspeed3 is offline   Reply With Quote
 Old 06-25-2012, 04:26 PM   #42
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Ethanol direct injection is far more effective, and easier, and simpler, and cheaper
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 06-25-2012, 04:26 PM   #43
Speeden6's Avatar
Posts: 598   (View Stats)
Speeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the world
@phate
do you think a FMIC will make a difference with E85 for more aggressive tuning? or should i stay ETS TMIC? want to keep my BAT's low. also, do you know or think a FMIC over TMIC would be more beneficial running on BNR S3 + E85?
2007 MS6 -
CPE TMIC, CS HPFP Internals, CS Stage 2 Intake and Inlet, Turbo Smart 50/50 BPV / BOV, Catless DP
2006 Acura TL Fully bolted and Running Nitrous! 330WHP SOLD
SOLD 1992 Corrado VR6
268 Cams, air intake, cat back, upgrade plugs and wires, coilovers.
SOLD
2001 Audi Allroad
SOLD
2006 MS6 -
CAI, TIP, ETS TMIC, AutoTech Internals, TBE catless, E85 30%,
19PSI, Cobb AP, RMM, K04, HKS SSQ4 VTA,
TUNED BY LEX FOR 330 AWHP / 380 TQ
Custom tune by
The habits we form today are the ones that Define us tomorrow
Speeden6 is offline   Reply With Quote
 Old 06-25-2012, 04:31 PM   #44
Eth Fiend
phate's Avatar
Originally Posted by Speeden6 View Post
@phate
On the K04, no.
If you go after market with the S3, I would just go front mount. I suspect the stock top mount will become a restriction just beyond what the K04 can support. I recently worked with an S3/stock top mount and wasn't terribly pleased with the results. Top mounts are still prone to heat soak.
-06 MS6
 Old 06-25-2012, 04:43 PM   #45
Speeden6's Avatar
running aftermarket TMIC but still yeah, heat soak is a bad problem! just hard to justify the FMIC if i am not sure if i am going BT. so guess i hold and get one if i go BT.
2007 MS6 -
SOLD
2001 Audi Allroad
SOLD
2006 MS6 -
Custom tune by
 Old 06-25-2012, 10:05 PM   #46
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
It doesn't matter what kind of pre-cylinder setup you run; large quantities of E in the tank will cause boost pressure drop due to the sheer volume of air that gets sucked in due to the cooling effect.
Basically, once you max the turbo (which you don't really even need E for), adding more boltons won't net you more airflow; running ethanol will only let you max the turbo with fewer boltons than you would otherwise require to see the same airflow without E (volts at the MAF).
dead-zone (09-08-2012), Outlaw4shrt (11-29-2012), phate (06-25-2012)
 Old 06-26-2012, 07:10 AM   #47
so you're saying I'll see fewer gains with E since I'm already fully bolted whereas someone who just has intake/downpipe will get more benefit?
The Following User Says Thank You to sallyspeed3 For This Useful Post:
phate (06-26-2012)
 Old 06-26-2012, 08:30 AM   #48
Eth Fiend
phate's Avatar
Something like that.
On gas, you might see a gain from each bolt on. But, you would just be approaching what you could do with intake/dp/E85.
E85 is the shortcut to maxing out the K04 without worry of BAT's, AND being able to run max timing, lololol.
It truly is a case of having your cake and eating it
-06 MS6
The Following 5 Users Say Thank You to phate For This Useful Post:
Enki (06-26-2012), jayspeed3 (06-27-2012), mazdaspeed916 (08-20-2012), sallyspeed3 (06-26-2012), Twofer (02-15-2013)
 Old 06-26-2012, 08:41 AM   #49
Well thats awesome, I can't wait to get the 1st map from bucker.
phate (06-26-2012)
 Old 06-26-2012, 09:50 AM   #50
Speeden6's Avatar
In all the mentions here about bolt ons not beeing needed and just intake / DP I think we keep overlooking HPFP internals! weather they be upgraded which is best or be replacement stock as the E85 helps gum them up if they have high millage on them doesnt it?
2007 MS6 -
SOLD
2001 Audi Allroad
SOLD
2006 MS6 -
Custom tune by
 Old 06-26-2012, 11:39 AM   #51
Enki's Avatar
Groans: 189
I hope more people take this to heart and understand that it really *IS* this awesome of a fuel.
 Old 07-02-2012, 01:11 PM   #52
Speeden6's Avatar
Can I just say I LOVE E85!!!!!!
Screen shot attached, 1.5 Map was of no E85. the other is tuned with E85! Freaking LOVE THIS STUFF!
2007 MS6 -
SOLD
2001 Audi Allroad
SOLD
2006 MS6 -
Custom tune by
 Old 07-02-2012, 03:17 PM   #53
Just got my 1st revision from Bucker. Absolutely loving this shit. My car feels like it did back in the winter when my bats were 60 degrees cooler. Can't wait to see what else he can get out of it.
@Bucker
dead-zone and Bucker like this.
The Following 3 Users Say Thank You to sallyspeed3 For This Useful Post:
Boost_creep (07-04-2012), Bucker (07-02-2012), phate (07-02-2012)
 Old 07-06-2012, 01:39 PM   #54
Speeden6's Avatar
hitting the Dyno today for the real deal! got the E85 mixed right and fresh tune from @Lex COME ON 300AWHP!
2007 MS6 -
SOLD
2001 Audi Allroad
SOLD
2006 MS6 -
Custom tune by
 Old 07-25-2012, 11:02 AM   #55
Mfinlay04's Avatar
Posts: 827   (View Stats)
Now that ATR has a scaler we should use that instead of adjusting MAF cal for E85 correct? I'm running equivalent E20 and changed and increased my MAF by 6%. I think I should undo that and just use the scalers.
Can anyone comment on this? Wondering the same thing
2006 MS6 Titanium Grey
Tuned with
 Old 07-25-2012, 11:04 AM   #56
Eth Fiend
phate's Avatar
Either method will work fine.
-06 MS6
Mfinlay04 (07-25-2012)
 Old 07-25-2012, 11:27 AM   #57
Mfinlay04's Avatar
http://blogs.cobbtuning.com/2012/03/...for-big-power/
Thanks Phate. So I should just use the scalar and density to get me started and then slowly up timing and boost for more power correct?!
Tuned with
 Old 07-25-2012, 11:32 AM   #58
Eth Fiend
phate's Avatar
Yeah, use the scalars to set up for the mix. You will still need a MAF Cal, though it is likely to be only minor changes. From there it's normal tuning.
-06 MS6
 Old 07-25-2012, 01:13 PM   #59
Mfinlay04's Avatar
Beautiful. Thanks for clarifying for me. Gonna try my first 50/50 tank today and see how she runs.:thumbup:
Tuned with
 Old 07-26-2012, 05:47 AM   #60
buckeyepost's Avatar
Posts: 295   (View Stats)
buckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond repute
Finally got my 3 gallon E85 mix tune finished up and my car pulls for DAYS! And I told him I didn't want to get real aggressive with the tune since I was already pleased with it, it's got 93k miles on it and it's my DD. It truely is amazing at what you can do with just 3 gallons per tank of E. Guess I'll be tires a lot more often now. Can't wait to get her out at mid-Ohio next month and show my buddy's Suby what's up!
Thanks Jason/Dizzy!
dead-zone and sarm1084 like this.
07 MS3 GT {DD} \\ 295whp 328wtq (pre E mix) \\ Cobb AP {Stage 2} \\ MS CAI & CBE \\ ATP DP/MP {catless} \\ Corksport TMIC \\ SURE TIH \\ TurboSmart Kompact BPV \\ AutoTech FP internals \\ Denso ITV22's \\ SU RMM \\ Ralco STS\\ Hawk HPS pads \\ StopTech rotors \\ Sensen dampers \\ Moog swaybar links \\ DashHawk \\ 225/45 Kuhmo Ecsta XS's on 18x7.5 Momo S-five's \\ 205/60-16 Dunlop Winter Sport 3D's on steelies
1:3 E85 mix Dizzy tuned by Boost_creep
...... sold :-(
buckeyepost is offline   Reply With Quote
The Following 4 Users Say Thank You to buckeyepost For This Useful Post:
boostdmazda3 (11-10-2012), Boost_creep (07-26-2012), phate (07-26-2012), Speed_j23 (11-09-2012)
 Old 08-17-2012, 07:12 PM   #61
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
So if we adjust the SFG and the injector scalar, we should just leave the AFRs as they are right?
 Old 08-17-2012, 08:27 PM   #62
Enki's Avatar
Groans: 189
SFG and scalar are the ONLY changes. That's why this thread is so important to those on corn.
 Old 08-18-2012, 09:30 PM   #63
car is extremely happy running 4 gallons of Eth. Averaged around 34 mpgs driving into the city today and VD shows around 320 to the wheels. Fuck hybrids.
The Following 5 Users Say Thank You to sallyspeed3 For This Useful Post:
Jhornbrook (08-18-2012), phate (08-18-2012), sadak (11-03-2013), sidekick (03-03-2013), Twofer (03-05-2013)
 Old 11-09-2012, 11:13 AM   #64
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
This is an interesting thread... I'll share my corn story in the weeks to come, converting next Friday .
 Old 01-15-2013, 05:22 AM   #65
Vegasspeeed's Avatar
Posts: 274   (View Stats)
Vegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond repute
Groaned at 8 Times in 7 Posts
Man I really want to join in on the experience but I have no clue how to tune for e85 nor do I know anyone out here that can help but I have everything needed to start converting. Any kind of advice or point me to someone that can help me make a street tune would be awesome!
sure test pipe, both resonators deleted, RL coilovers, XXR 521's machined silver, muteki gold lug nuts
Vegasspeeed is offline   Reply With Quote
 Old 01-15-2013, 11:41 AM   #66
Enki's Avatar
Groans: 189
There are plenty of e-tuners here that can do the tuning for you. Hell, if you asked nicely they might even train you.
Dahouse702 (01-15-2013), Twofer (02-15-2013)
 Old 02-06-2013, 08:32 PM   #67
Azspeed's Avatar
Posts: 26   (View Stats)
Azspeed is a jewel in the roughAzspeed is a jewel in the roughAzspeed is a jewel in the rough
I am sold on e85 can't wait to get a tune. This thread has been a real help
Azspeed is offline   Reply With Quote
The Following User Says Thank You to Azspeed For This Useful Post:
phate (02-06-2013)
 Old 03-03-2013, 05:18 PM   #68
Printman's Avatar
Posts: 300   (View Stats)
Printman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the world
After changing gravity and scaler will I need to let the ECU learn trims with the maf curve from a previous map where it was dailed in with a maf cal?
[SIGPIC]
[/SIGPIC]
2012 Black Mica W/Tech
Cobb AP
AutoTech Internals
JBR 88DM RMM
JBR Heavy Knob
JBR 3" WP
JBR Rear camber arms
UR TP
Ford MOFO Tranny juice
Rotella T6
Self Tune - (Work in Process)
NGK Step 1 colder
5/7 corn fed
Printman is offline   Reply With Quote
 Old 03-03-2013, 05:38 PM   #69
sidekick's Avatar
Groans: 47
You may need to adjust the MAF calibration, but it isn't always necessary. Just keep an eye on your LTFTs after making the switch.
The Following 2 Users Say Thank You to sidekick For This Useful Post:
phate (03-03-2013), Printman (03-04-2013)
 Old 03-04-2013, 05:26 PM   #70
Printman's Avatar
Thanks, Trims look good I must have scaled it correctly on my 20% mix. Just did a 3rd gear pull with an aggressive 93 map I had with the inj. scaler and gravity adjusted and no KR. I am loving just a taste of Ethenol. I never felt the potential of that map because always had KR 4,000 + and it would just pull timing and richen my AFR. now to work on the tune a little and see just what I can do with such a small percentage of E then move towards a 40% goal.
Thanks for all the info throughout the E85 fueling database, you guys are great.
sidekick likes this.
[SIGPIC]
[/SIGPIC]
Cobb AP
AutoTech Internals
JBR 88DM RMM
JBR Heavy Knob
JBR 3" WP
UR TP
Rotella T6
NGK Step 1 colder
5/7 corn fed
 Old 03-21-2013, 10:39 PM   #71
Mfinlay04's Avatar
Haven't seen it mentioned in any E85 thread that I've read, but how important is runner a step colder plugs with e85? Since it's a slower burn does one still need to a step colder plugs?
 Old 03-21-2013, 11:22 PM   #72
Enki's Avatar
Groans: 189
Should read a bit more. Running colder plugs on full e causes that not so fresh feeling under boost.
Mfinlay04 (03-21-2013), phate (03-22-2013)
 Old 03-22-2013, 06:07 AM   #73
Mfinlay04's Avatar
Default Re: How to e85
To be fair it makes sense that we would need colder plugs with e85 bit I've never site it on this site and I've read quiet a bit and searched for 30+ mins this week looking for some definitive answers. On other platforms people have even ran 1 step HOTTER plugs with e85 and e85 mixing with good/better results. Has anyone experimented with this on the MS platform?
Sent from my Nexus 7 using Tapatalk 2
ms6mil likes this.
Tuned with
 Old 03-22-2013, 09:10 AM   #74
Eth Fiend
phate's Avatar
We covered it a few times in the main E85 thread.
-06 MS6
silvapain (03-24-2013)
 Old 03-22-2013, 04:33 PM   #75
mariomspeed's Avatar
mariomspeed is a jewel in the roughmariomspeed is a jewel in the roughmariomspeed is a jewel in the rough
what is everones opinion on how harsh e85 is on the motor/stock clutch? i understand the fuel pump issues and when i do e85 ill be doing a 3 galloin blend so im not that worried about it plus i will run 93 daily and E for fun
mariomspeed is offline   Reply With Quote
 Old 03-23-2013, 07:41 AM   #76
Mfinlay04's Avatar
Thanks @phate; didn't think about looking in the lubrication thread
Tuned with
 Old 03-23-2013, 09:49 PM   #77
navyspeed3's Avatar
Posts: 115   (View Stats)
navyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond repute
Is anyone running straight E85? I haven't seen someone mentioning running just straight E85. I also thought someone mentioned a E85 fuel pump coming out for the car.
navyspeed3 is offline   Reply With Quote
The Following User Says NO Thank You to navyspeed3 For This Un-useful Post:
Enki (03-23-2013)
 Old 03-23-2013, 10:22 PM   #78
ABolewski's Avatar
Posts: 1,279   (View Stats)
@phate; is. And I believe the general consensus was that the E-85 specific pump was bull shit, and you don't need it. Although I have read that even on a k04 you will run out of fuel on 100% E which means you need some form of port injection (5th port or one of the new JMF mani's).
I plan on running strait E pretty soon here myself.
(sold)
phate (03-24-2013)
 Old 03-24-2013, 10:44 AM   #79
Eth Fiend
phate's Avatar
This thread covers about 99% of the questions about E85:
E85 Discussion - HPFP lubrication and Flow issues
sarm1084 likes this.
-06 MS6
Wicked (03-24-2013)
 Old 03-24-2013, 10:56 AM   #80
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
The HPFP spill valve will gun up and stick on 100% E85, and the performance benefits of 100% E85 over a 50/50 mix with 93 pump gas are minimal.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f567/how-e85-98590/
How to e85 mazdaspeed - 1Q5A This thread Refback 10-02-2014 07:27 AM
how to make a mazdaspeed 6 run on E85 This thread Refback 04-23-2013 10:54 AM
Page generated in 0.57664 seconds with 34 queries
