Like Tree40Likes
 Old 10-22-2013, 08:48 PM   #121
maxspeed's Avatar
Posts: 180   (View Stats)
maxspeed has much to be proud ofmaxspeed has much to be proud ofmaxspeed has much to be proud ofmaxspeed has much to be proud ofmaxspeed has much to be proud ofmaxspeed has much to be proud ofmaxspeed has much to be proud ofmaxspeed has much to be proud ofmaxspeed has much to be proud of
Remember that the Pu has a 16 gallon tank and the Juan is only 14.5 gallons, so how much you add at what gauge level depends on your MY.
Yeah I was going off my 14.5 tank. I filled up today but just went with the dummy proof way of adding 5 gallons of e and rest of tank 93 giving me the 31% mix with the season blend being e70. Afr's seemed good but its raining here so I am gonna get some logs tomorrow. I do have a noob question though I was trying to get a log got some wheelspin and when I looked at the log there was high KR spike after I left of the gas. Im guessing this is nothing but maybe there is something to be changed?
Casanova likes this.
AP|RMM|TP|HPFP|E40
maxspeed is offline   Reply With Quote
 Old 10-22-2013, 10:34 PM   #122
maxspeed's Avatar
Here is the an Idle log, the wheelspin KR after I let of that I was talking about above, and the best 4th gear log I could get tonight. I am not sure if the e has mixed well already if I filled up with a quarter tank?
File Type: csv Wheelspin KR after letting of throttle.csv (3.2 KB, 12 views)
AP|RMM|TP|HPFP|E40
 Old 10-22-2013, 10:51 PM   #123
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
It mixes immediately, if not within a minute or two. It will only separate if you have a ton of water in your tank too.
maxspeed (10-22-2013)
 Old 10-22-2013, 10:54 PM   #124
maxspeed's Avatar
Thanks for the peace of mind. If you don't mind do you see anything out of order in my initial logs I just posted.
AP|RMM|TP|HPFP|E40
 Old 10-22-2013, 11:26 PM   #125
Enki's Avatar
Groans: 189
There's two things wrong with that post.
1. You've posted logs to this thread, which is a how-to for E85.
2. There's no APP being logged.
Fix the logs, then post a new diagnostic thread with those logs please.
El_Diablo (10-23-2013), maxspeed (10-23-2013)
 Old 10-23-2013, 07:54 AM   #126
sallyspeed3's Avatar
Posts: 638   (View Stats)
sallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the world
Originally Posted by maxspeed View Post
I though you put the e85 first but if you know your own tank I guess it doesn't matter.
Oops, you're right. It's been a while since I've had any E. I'll be getting some on Saturday, so excited.
2008 Cosmic Blue Mazdaspeed 3 GT - COBB AP DIZZYTUNED for 30% E85//JBR Whale Penis//COBB TIP//COBB DP//COBB STS//COBB Knob//COBB shift weight//COBB Piping TR8L Core//Magnaflow CBE//Turbosmart BPV//PTP internals//SU RMM//TRZ tranny mount//Koni + H&R springs//Tinted 35% front, 20% rear//Lamin-X head-light & tail-light film//ASA GT1 18x8//Hankook Ventus V12 225/40//
sallyspeed3 is offline   Reply With Quote
 Old 11-16-2013, 08:25 AM   #127
nukepilot's Avatar
Posts: 333   (View Stats)
nukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the world
Groaned at 32 Times in 12 Posts
the most accurate way to fill for me is a gallon per gallons. so right now I put 1 gallon of e per 5 of gas. so 1.2 e for 6 91... ie ie. if i want more corn i could move to 1 per 3 and so on and so on. no relying on inaccurate gauges and what not
100% stock aftermarket parts!!
323whp 367lbs
nukepilot is offline   Reply With Quote
 Old 11-16-2013, 10:28 AM   #128
turbo test's Avatar
Posts: 798   (View Stats)
turbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the world
Groaned at 9 Times in 5 Posts
Meh I just guess based on how long my range meter has read 0.
I know prolly not the best way but I couldnt take calculating shit out all the time.
Usually 3.3 gallons of E when empty then fill the tank till the pump stops 10.5ish gallons of 91
Sent from my EVO using Tapatalk
sarm1084 likes this.
2010 Velocity Red MS3-Eibach PRO-KIT-EVO X Rims-SU RMM-SU solid shifter bushings-CP-e HPFP-CP-e tip-CP-e cai-CP-e hks ssqv bov kit-ddm slim hid kit 35w-5000k-JBR Heavy Shift Knob-JBR RSB-AQ Motorsports catted downpipe-Magnaflow full 3in CBE- SPC camber arms (Stratified tuning) 91/e85 tuned
turbo test is offline   Reply With Quote
 Old 11-16-2013, 11:29 AM   #129
maxspeed's Avatar
Run a 50/50 mix. Makes it easier less planning involved for filling up and all you have to do is make sure you don't overfill.
AP|RMM|TP|HPFP|E40
 Old 11-16-2013, 06:53 PM   #130
Enki's Avatar
Groans: 189
Right now I do e31 ish which comes out to 1:2 ratio of e85:91 due to spring/fall blending. I might loosen that mix up a bit depending, though, to get more fuel headroom.
 Old 11-17-2013, 02:53 PM   #131
maxspeed's Avatar
Why not 50/50? mpg?
AP|RMM|TP|HPFP|E40
 Old 11-17-2013, 10:04 PM   #132
Enki's Avatar
Groans: 189
Why not 50/50? mpg?
I'm big turbo now. I ran out of spray window at 15 PSI. At 20 PSI, I'm at/near the limit again on E30-31.
silvapain (11-18-2013)
 Old 11-18-2013, 07:57 PM   #133
maxspeed's Avatar
Oh nice I guess thats a good problem to have to bad though our fuel system has small aftermarket support.
AP|RMM|TP|HPFP|E40
 Old 03-26-2014, 08:36 AM   #134
Jap11g's Avatar
Posts: 287   (View Stats)
Jap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond repute
Groaned at 7 Times in 5 Posts
@couldahadadodge enjoy. It
Tapa Tapa Tapa
JP
Jap11g is offline   Reply With Quote
The Following User Says NO Thank You to Jap11g For This Un-useful Post:
faeker (03-26-2014)
 Old 06-02-2014, 11:06 PM   #135
maas173's Avatar
Posts: 9   (View Stats)
maas173 is on a distinguished road
Groaned at 3 Times in 1 Post
Can someone help me out? I don't know anything about doing MAF calibrations. I just bought an accessport v3 and the guy I bought it from had an e85 tune on his 2010/11 mazdaspeed 3. can I use his map for the e85 in my 07 mazdaspeed 3?? trying to save some money on a tune.
maas173 is offline   Reply With Quote
 Old 06-02-2014, 11:08 PM   #136
Jap11g's Avatar
I wouldn't. Timing could be way off. Among other thangsss
Tapa Tapa Tapa
JP
 Old 06-02-2014, 11:39 PM   #137
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
MAF Calibration Tutorial Check that out...
Make sure there is no more e85 in the tank, flash to an OTS map until you get linked in a with a tuner.
OTS - A Noob's Guide to Tuning Acronyms
Then read through the rest of the KB threads...
Mazdaspeed Forums Knowledge Base (Gen1 - Gen 2) - Mazdaspeed Forums
Hit up these fellas for a tune... you won't be disappointed.
@Justin@Freektune; @Rob@Freektune;
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
The Following 5 Users Say Thank You to ms6mil For This Useful Post:
Benis (06-03-2014), ItsNox (06-03-2014), Jap11g (06-02-2014), Rob@Freektune (06-04-2014), sarm1084 (01-03-2018)
 Old 06-26-2014, 12:17 AM   #138
Emew's Avatar
Posts: 217   (View Stats)
Emew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond repute
Quick question. Looking to start a 50/50 blend and I got my scalar/gravity values ready on a map. My e85 station is 1 maybe 2 miles from my shell 93 station. I'm at 25% of a tank of 93, can I safely/reasonably get my 8 gallons of e85 then drive the short distance to the 93 and finish filling up without any major problems or risks or do I need to buy a 2nd 5 gallon gas can?
Flow Student
'07 Speed6 TiGrey: SURE ID300/Shift Plate+Weight/Breather Hose, Forge BPV v2, CX-7 Antenna, ProSport Boost Gauge, Block8Head's MS6 Pod, Cobb AP v3, ITV22 1SC Plugs, TWM Short Shift, Stage 2 Clutch, JBR Shifter Bushings/Shift Knob/RMM/EGR Delete, Euro LED Tails, AutoTech FP Internals, M2 DP, ETS TMIC, Techna-Fit SS Brake Lines/Clutch Line, Hawk HPS Pads, ATE 200, MD OCC VTA v2, 3-Bar MAP, AWR TMM, CP-E RDM, Whiteline RSB, RB Rear Endlinks, Moog Front Endlinks, Bilstein HD6 Shocks, Corksport Springs.
Emew is offline   Reply With Quote
 Old 06-26-2014, 07:34 AM   #139
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
You'll be fine.
-06 MS6
-Corn fed 07 MS3 - Sold
MZRSPEED (06-28-2014)
 Old 09-03-2014, 09:12 AM   #140
william.fletcher2's Avatar
Posts: 248   (View Stats)
william.fletcher2 is the leader of the worldwilliam.fletcher2 is the leader of the worldwilliam.fletcher2 is the leader of the worldwilliam.fletcher2 is the leader of the worldwilliam.fletcher2 is the leader of the worldwilliam.fletcher2 is the leader of the worldwilliam.fletcher2 is the leader of the worldwilliam.fletcher2 is the leader of the worldwilliam.fletcher2 is the leader of the worldwilliam.fletcher2 is the leader of the worldwilliam.fletcher2 is the leader of the world
Alright, so I have done a bunch of reading throughout this thread and others that are on the topic of E85. I am looking at running E85 on my 08.5 (freektune e-tune). I will list my mods below. But onto my questions... 1) is the only hardware upgrade I need to go with is new plugs properly gapped? 2) My car has under 19k miles, should I bother going through the fuel cleaning process? 3) Anything crazy that I may have not seen that would tell me to NOT E85?
-Performance mods.
Autotech HPFP Internals
AEM CAI
COBB DP
COBB CBE
COBB TIH
COBB BPV
COBB APv3 Currently running a Cobb SoCal custom Dyno Tune that was done by previous owner
cp-e FMIC w/ 2.5inch piping
2008.5 CWP Mazdaspeed3 GT w/Tech
Enkei RPF1 17x9 +35 | Cobb AP v3 | CBE | DP | TIH | BPV | Sport Springs | FSB | RSB | cp-e FMIC | RMM S2 | Tow Plate | Bilstein Struts
Cobb Tuning SoCal 91 Dyno Tune 289/315 | Freektune E85/93 tune in progress
william.fletcher2 is offline   Reply With Quote
 Old 11-09-2015, 10:01 AM   #141
littleloogy's Avatar
Posts: 4,005   (View Stats)
Default How to e85
SPEEDO90 likes this.
SPEEDO90 (11-09-2015)
 Old 11-09-2015, 10:03 AM   #142
SPEEDO90's Avatar
Posts: 79   (View Stats)
SPEEDO90 is a jewel in the roughSPEEDO90 is a jewel in the roughSPEEDO90 is a jewel in the roughSPEEDO90 is a jewel in the rough
LMAOOO I will keep pumping 93 till its diluted for my options hahaha
SPEEDO90 is offline   Reply With Quote
 Old 02-12-2016, 07:14 AM   #143
TORQUERULES's Avatar
Posts: 283   (View Stats)
TORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond repute
Okay, so I have a few questions...
I am looking at going to a Stratified E85 tune (with a 93 tune as backup) and an AP for my setup. The issue I have is that I really do daily drive my car. How do you guys keep the mixtures correct in daily driving or a trip? Do you just switch to a 93 tune on a trip? Do you just let it run almost empty for daily driving and mix it like that each time or do you have any tricks to keep the mixture correct without running it near empty each time?
Thanks.
(SOLD) 2013 Crystal White MS3--JBR 3.5" intake, very minor PNP intake manifold, CS TMIC, CS HPFP internals, CS BPV, JBR EGR delete and block-off, CFM RMM, CS TM insert, Cobb AP V3 with Stratified Stage 3 tunes (93 and E85 mix), VTCS delete, coolant bypass, 1 step colder plugs, CS shifter bushings, CS short shifter, Damond OCC, Ultra Gauge, Progress RSB, Koni dampers, Eibach Pro-Kit springs, JBR rear spacers, 235/40/18 Nitto Motivo tires, Drag DR-49 18x8" wheels, CNT cat-less DP, CNT cat-back, DDM HIDs, etc.
2017 Mazda CX-3 Meteor Gray
TORQUERULES is offline   Reply With Quote
 Old 02-12-2016, 07:31 AM   #144
zjnspeed3's Avatar
Posts: 1,436   (View Stats)
I have a Stratified E85 tune and I love it. I just go off of this cheat sheat from Hypnotic. ImageUploadedByTapatalk1455287472.661336.jpg
The Following 2 Users Say Thank You to zjnspeed3 For This Useful Post:
sarm1084 (01-03-2018), TORQUERULES (02-12-2016)
 Old 02-16-2016, 11:17 AM   #145
Speed3GoHard's Avatar
Posts: 17   (View Stats)
Speed3GoHard will become famous soon enoughSpeed3GoHard will become famous soon enough
Anybody running full E85 or a 50/50 mix tune these days without any issues ??? What's more reliable for our cars full E85 or 50/50 ??? What needs to be done (besides the tune) to run ful E85l or 50/50 ? Thanks guys.
Speed3GoHard
Speed3GoHard is offline   Reply With Quote
 Old 02-16-2016, 03:02 PM   #146
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
50/50 shouldn't give you any problems. E85 is still giving people issues.
 Old 02-16-2016, 03:22 PM   #147
Enki's Avatar
Groans: 189
Both of you need to read more.
SnailSpeed3 (02-17-2016)
 Old 02-16-2016, 04:43 PM   #148
Cheapspeed's Avatar
Last I read somebody's unicorn internals was making contact with some part it shouldn't be.
 Old 02-16-2016, 04:50 PM   #149
Enki's Avatar
Groans: 189
I don't recall anything like that, but the IE internals failed for a completely different reason. Myself, and many others have been running full E85 without issue for upwards of a year or more.
 Old 02-17-2016, 04:56 PM   #150
Great... What did you do to fix the E85 issue we had with our cars?
Speed3GoHard
 Old 03-03-2016, 06:06 AM   #151
Question
How long do you guys wait between fill-ups in order to get the proper mix? I have only one E85 station locally so I do not feel comfortable letting it run near empty before filling. I guess my issue is how to do this all to keep the proper mixture in a daily driving situation? Or do you guys just keep the E85 for fun and run a pure 93 tune most of the time?
 Old 03-03-2016, 06:20 AM   #152
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
The mixture doesn't have to be exact. Just give it your best guess and use your fuel trims to make sure your mix is in the ballpark of where it needs to be, then add more E85 as needed, or if you overshoot on E85, just keep an eye on your WOT AFR's and as long as they're OK, just roll with it. Many of us switch back and forth between straight gas and mixes all the time since straight gas is better for commuting (fuel economy is way better).
2007 Mazdaspeed3 GT
sarm1084 (01-03-2018), TORQUERULES (03-14-2016)
 Old 03-03-2016, 06:22 AM   #153
Jakeypoo's Avatar
Posts: 226   (View Stats)
Jakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond repute
At 1/4 tank I add 3gal E85 + 6gal 93.
Or 4 + 8 if I go below empty.
2009 Mazdaspeed with 134,000 miles, Corksport Turbo, AT internals, CNT Turbo Back, AP, fully mounted, 3 bar, Freaktuned E25.
Jakeypoo is offline   Reply With Quote
 Old 08-28-2016, 09:19 AM   #154
Smus's Avatar
Posts: 35   (View Stats)
Smus has a spectacular aura aboutSmus has a spectacular aura about
It took me about 2-3 hours of reading to get 100% up to speed with zero e85 knowledge, but it's all in the stickys, just do some reading and follow some of the quoted threads. The guys here did all the research and literally risked their health to get the info. All you need is in the stickys at the top.
Smus is offline   Reply With Quote
The Following User Says Thank You to Smus For This Useful Post:
 Old 12-22-2017, 07:03 PM   #155
KJL
KJL's Avatar
Posts: 1   (View Stats)
KJL is an unknown quantity at this point
Hey all I know this is an old post but I have one question. I have a tune from pd tuning. If I wanted to do a e30 mix what would I have to change in order to run it. My maf Cal is dialed in perfect according to my stft. Thanks in advance. If I am in the wrong post for this please let me know where to go. Again thanks and sorry for being a new.
2011 velocity red mica PU, JBR short shift plate, Corksport short ram, Ebay turbo inlet, corksport tmic, KDM HPFP internals, Ebay long tube downpipe, resonator and muffler delete. itv22 spark plugs, HKS bov. Tuned by Ryan at Purple Drank.
KJL is offline   Reply With Quote
 Old 12-23-2017, 12:01 PM   #156
shamie's Avatar
Posts: 952   (View Stats)
Call PD tuning since your tune is probably locked by them.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f567/how-e85-98590/
How to e85 mazdaspeed - 1Q5A This thread Refback 10-02-2014 07:27 AM
how to make a mazdaspeed 6 run on E85 This thread Refback 04-23-2013 10:54 AM
Page generated in 0.54448 seconds with 41 queries
