| MazdaSpeed 3/6 - E85 Fueling Learn more about feeding your car corn |
![]() | | #41 | ![]() |
![]() Join Date: Mar 2010 Location: Memphis, TN
Rep Power: 315 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 621
| Not Ranked : 0 score
Also i dont think measuring the o ring would be that accurate, especially if we think oil is leaking by it. Oil will almost always swell the o ring or atleast deform it slightly. All this talk makes me want to jump on the band wagon, although i would need to move back home, there is no close stations near memphis
__________________ 2007 Speed 6 Liquid Platinum Metallic, DIY Duplicolor Graphite Wheel Paint, Clutchmasters FX100, Stock again with 91 ots tune | |
| The Following User Says Thank You to laxplayermjd For This Useful Post: | rfinkle2 (11-23-2011) |
![]() | | #42 | ![]() |
![]() Join Date: Jul 2009 Location: South Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,578
| Not Ranked : 0 score So what specifically do you guys use to clean the spill valve? I didn't see anything mentioned... I like brake cleaner, but I wouldn't use that by the o-ring part. Also, is the seafoam in the tank only necessary over 50/50? TIA EDIT: You guys have 2 maps handy in case you're on a trip and can't plan E85 stations? I plan on have 93 the a mix map. Not sure of mix, maybe E30.
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] |
![]() | | #43 | ![]() |
Groans: 189
| Not Ranked : 0 score Seafoam doesn't do a fucking thing. Trust me. Use 91 pump gas and a toothbrush/lint free cloth to wipe the sticky off of everything and you'll be good.
__________________ |
| The Following User Says Thank You to Enki For This Useful Post: | dougefresh_ (12-13-2011) |
![]() | | #44 | ![]() |
Rep Power: 11232 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,868
I have a 93 octane map, a 50/50 shitty map, an E70 (winter) map, and my E85 (summer) map ![]() I picked up a can of seafoam last time I was in town. I'm going to get a gunk specimen and see what the seafoam does to it, directly.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
| The Following 2 Users Say Thank You to phate For This Useful Post: | dougefresh_ (12-13-2011), rfinkle2 (12-14-2011) |
![]() | | #45 | ![]() |
| Not Ranked : 0 score Cool, thanks. What's a 50/50 shitty map? lol Something like my current 93 shitty map?
![]() | | #46 | ![]() |
![]() Join Date: Jul 2008 Location: Tucson, AZ
Rep Power: 739 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 517
| Not Ranked : 0 score kind of going along with the last sentence, when i had my engine apart, i had put a stock piston in a bowl of seaform and let it sit for a full day. SOME carbon deposits came off, not a whole lot/what i had hoped for.
__________________ JDMFresh.com 1990 Mazda Miata NASA Time Trials/Time Attack, Global Time Attack A miata may be gay, but its probably faster than your car around a track. That's pretty gay. |
![]() | | #47 | ![]() |
Groans: 136
(Thread Starter) | Not Ranked : 0 score I use gasoline and Qtips to clean my spill valve, and I keep a 93 Octane pump tune on my AP just in case I'm stuck in an area without an E85 pump. Tapadatass
| The Following 3 Users Say Thank You to silvapain For This Useful Post: |
![]() | | #48 | ![]() |
| lulz @Raider ![]() Join Date: Jun 2010 Location: St Louis Mo
Rep Power: 3779 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,132
| Not Ranked : 0 score subbed... for reference... thank you @silvapain !!!!
__________________ 2008 MS3 gt 470hp/463tq on GT35r at 29psi Wiseco Pistons/Molar Rods/ACT 6 Puck/ARP Head Studs/TurboXS FMIC DP and RP/TurboSmart BOV/Tial 38mm EWG/PERM 5th/6th port injectors HKS CBE/ Koni Yellows and H&R springs/ HTP Whale Penis Intake/ PTP Fuel internals/SteedSpeed Mani/CP-E SafeSeals/E85 Hypnotic Tuned |
![]() | | #49 | ![]() |
![]() Join Date: Jan 2010 Location: Downers Grove, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,309
Groans: 76
| Not Ranked : 0 score you're the best!
__________________ '12 speed 3 CWP w/tech: DIZZY Tuned by Phate!,cobb AP,Autotech internals, cp-e nano, cp-e TIP, JBR 88 dogbone, JBR SSP/bushings, JBR rear sway bar, UR test pipe RIP '08 speed 3 silver cp-e 75 duro RMM, cp-e intake, cp-e TIP, Jbarone SSP and bushings. |
![]() | | #50 | ![]() |
| Banned ![]() Join Date: Sep 2012 Location: Arlington, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 271
| Not Ranked : 0 score I broke the plastic connector off the top of the spill valve when replacing my internals with Autotechs. Help! Do you think the dealer will have it in stock? Does any one know a fast, cheap fix? |
![]() | | #51 | ![]() |
![]() | | #52 | ![]() |
| Not Ranked : 0 score |
![]() | | #53 | ![]() |
![]() Join Date: Dec 2009 Location: layton, UT
| Not Ranked : 0 score So this is the only part u need to clean when going 100% e85... Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna |
![]() | | #54 | ![]() |
![]() Join Date: Aug 2012 Location: San Mateo, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,022
__________________ CRMetallic 2019 Mercedes C43 AMG SOLD MNBlue 2012 S4 Prestige... a few mods SOLD IB 2015 3.8 Gencoupe Ultimate BLOWED UP DIB 2014 Mustang 5.0... a few mods SOLD - LS 2012 MS3 Cobb AP//SF//CAB Autotech HPFP Corksport TMIC//BPV//TIP//BTbs JBR 88a RMM Sure M3 TP OBX CBE Tanabe NF210's ADVAN RG-D 18x8 +38 Freektuned 50/50 E85 |
![]() | | #55 | ![]() |
| Not Ranked : 0 score | |
![]() | | #56 | ![]() |
| Not Ranked : 0 score Just out bid you by $1
| The Following 5 Users Say Thank You to djuosnteisn For This Useful Post: | ABSpeed3 (12-13-2012), burn813 (12-23-2012), socks (09-09-2013), speed14 (12-20-2012), Stangcobra (12-15-2012) |
![]() | | #57 | ![]() |
![]() Join Date: Dec 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
![]() | | #58 | ![]() |
| Not Ranked : 0 score The spill valve controls the high pressure rail pressure. The relief valve on the high pressure rail is the last line of defense to prevent an excessive overpressure scenario that could result in bursting of parts in the high pressure rail if the spill valve isn't controlling pressure adequately.
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
![]() | | #59 | ![]() |
| Not Ranked : 0 score Thank u .. That info was great.. But how do I know it's mess up |
![]() | | #60 | ![]() |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
| Not Ranked : 0 score if you notice your car wont go above like 60 psi of fuel(meaning only the intake pump is pumping) and the HPFP pump is not working seems to only happen to people using E85 |
![]() | | #61 | ![]() |
| Not Ranked : 0 score Ok thank u I learn something new .. I appricated |
![]() | | #62 | ![]() |
| Not Ranked : 0 score I'm gonna switch to 100% e85 once i'm done with my new fuel setup. Just reviving the thread in case there's been any new results from the various theories. As it stands now, am i right in thinking that oil seeping past the o-ring is still the primary culprit?
![]() | | #63 | ![]() |
Groans: 189
| Not Ranked : 0 score I'll be able to confirm it in a couple of months.
| The Following User Says Thank You to Enki For This Useful Post: | djuosnteisn (01-15-2013) |
![]() | | #64 | ![]() |
| Not Ranked : 0 score Are you running the secondary scraper?
![]() | | #65 | ![]() |
| Not Ranked : 0 score Its still the best theory we have.
| The Following User Says Thank You to phate For This Useful Post: | djuosnteisn (01-15-2013) |
![]() | | #66 | ![]() |
Groans: 189
| Not Ranked : 0 score No, I took it out as the pump had issues immediately again after; I probably tightened it too much and it retracted from the internals themselves, losing the scraping capability.
![]() | | #67 | ![]() |
| Not Ranked : 0 score What's e85??? |
| The Following User Says NO Thank You to Island mazda For This Un-useful Post: | SWAY (01-15-2013) |
![]() | | #68 | ![]() |
| Not Ranked : 0 score Search |
| The Following 3 Users Say Thank You to Raider For This Useful Post: |
![]() | | #69 | ![]() |
| Not Ranked : 0 score Thanks for nothing!! |
![]() | | #70 | ![]() |
| Not Ranked : 0 score Search google.
![]() | | #71 | ![]() |
Groans: 189
| The Following 2 Users Say Thank You to Enki For This Useful Post: | djuosnteisn (01-15-2013), Raider (01-15-2013) |
![]() | | #72 | ![]() |
| Not Ranked : 0 score I do not care where you are in the world. You were sent this when you signed up: http://www.mazdaspeedforum.org/forum/foru...-email-132738/ This key advice you have ignored repeatedly:3
Start Here - Mazdaspeed Forums So stop your whining and do some reading. | |
![]() | | #73 | ![]() |
So, you guys that have repeatedly had to disassemble and clean spill valves, does my experience fit the MO? I'm hoping it's just this spill valve. And this is all I can expect, not having to do the same to the internals too, over and over? If all of this is indeed caused by a silly o-ring, gosh, what a pain! The powa is definitely worth it, though! | |
| The Following User Says Thank You to Redline143 For This Useful Post: | phate (01-15-2013) |
![]() | | #74 | ![]() |
![]() Join Date: Nov 2010 Location: Houston Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,763
Groans: 190
Groaned at 60 Times in 43 Posts
__________________ ~2011 Liquid Silver MS3~ ---->> ZZB TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN | |
![]() | | #75 | ![]() |
As I appraised all of the data prior to running ethanol, though, I had no idea that regular spill valve cleanings were part of the picture. Like I said, I was under the impression that all issues were averted at 50/50 and below mix levels... Lots of what's been said strongly suggests this. Oh well, you live and you learn. I'm fully warrantied until 100k anyways, so I may just get tired of dealing with it and take the car/fuel pump to a dealer at an "opportune" time That is, if all the suggestions that new fuel pumps won't encounter these issues is accurate... | |
![]() | | #76 | ![]() |
| Not Ranked : 0 score Yeah, every once in a while someone running a 5050 or so mix will get a sticky spill valve. It usually takes quite a while between cleanings, unlike how it is with straight e85. I think it's dependent on just how much oil is getting past the O-Ring, and how much ethanol you're actually putting in (it fluctuates, no biggie).
| The Following User Says Thank You to phate For This Useful Post: | djuosnteisn (01-16-2013) |
![]() | | #77 | ![]() |
Groans: 136
(Thread Starter) | Not Ranked : 0 score Yes. Even with a second normal O-ring wedged in with the quad ring, I still had my spill valve stick when I was doing MAF calibration logs. I've stated in other threads on here that the likelyhood of the spill valve sticking increases significantly when the engine is running in high RPM, low load conditions. I believe it's oil leaking past the piston seals and coming back up into the spill valve due to the high HPFP cycle rate and low fuel demand.
| The Following User Says Thank You to silvapain For This Useful Post: | djuosnteisn (01-16-2013) |
![]() | | #78 | ![]() |
| Not Ranked : 0 score It's obvious that the spill valve is sticking in it's "deenergized" state, since fuel pressure drops, rather than sky rockets. I know this is all common knowledge already.. but i'm just kinda recapping to refresh my thoughts on it. Here's the spill valve operation: When the solenoid is energized, it allows the spill valve to operate like a check valve, forcing the compressed fuel into the rail, building pressure. When the spill valve is de-energized, the check valve never seals, and allows the compressed fuel to flow back up stream, reducing pressure. There are two opposing springs, one on the top of the plunger, and one below the check valve. Obviously the one on the plunger is much more stiff than the one below the check valve, otherwise the check valve would still seal in the de-energized state. One option may be playing with the spring stiffness to see if we can help avoid the sticking. Either by making the spring under the check valve a lil bit stiffer (in a sense helping the solenoid drive the piston upward), or making the spring on top of the plunger a lil weaker. Dunno. Another option would be potentially increasing the current flow through the solenoid giving it more power to break loose. This could be a pita, and might risk damaging the solenoid. Obviously the ideal solution is to avoid the oil contamination... but if that's too difficult, then maybe we can work around it. I remember some people were talking about coating the plunger or whatever pieces get sticky with some sort of super slick coating. Anyone ever try that yet? Hmmm.... i dunno, gotta get busy at day job. I'm kinda excited to run 100% e85 now. If this is our only real problem, and cleaning it periodically works... then that's not a huge deal imo. But i bet we can all come up with a proper solution.
![]() | | #79 | ![]() |
![]() | | #80 | ![]() |
| Not Ranked : 0 score I'm happy for you too.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f567/how-remove-disassemble-hpfp-spill-valve-96970/ | ||||
| engine tappping (sorry i know its been done before).... ? Mazda MPS Owners Club | This thread | Refback | 02-25-2015 04:24 PM | |
| engine tappping (sorry i know its been done before).... | This thread | Refback | 02-27-2014 09:26 AM | |
| speed3 wont accelerate past 4k - Page 4 - DFW Mazdas | This thread | Refback | 05-10-2013 03:25 PM | |
| My project: Non-boosted DISI motor - Page 7 - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 12-06-2012 02:45 PM | |
| Okay, WTF was this? - Page 5 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Refback | 05-12-2012 02:31 PM | |
| How do you disassemble a forge? | red07 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 9 | 03-29-2009 10:28 AM |
| Cleanup on I-80: Oreo spill snarls traffic in IL | Haltech | Automotive News | 0 | 05-19-2008 11:10 AM |
