| MazdaSpeed 3/6 - E85 Fueling Learn more about feeding your car corn |
![]() | | #81 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Honestly, I'd be ok with once a month. Once a day on the other hand....not so much.
__________________ |
![]() | | #82 | ![]() |
Groans: 136
| Not Ranked : 0 score Had to search for it. Tons of information in the E85 section.
| The Following 2 Users Say Thank You to silvapain For This Useful Post: | Constantin (08-31-2012), Haltech (08-31-2012) |
![]() | | #83 | ![]() |
![]() Join Date: Dec 2011 Location: Fort Lauderdale, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,358
Groaned at 18 Times in 16 Posts
| Not Ranked : 0 score Can you do a quick "how to"? That would help a lot!
__________________ 2008 MS3 Tuned by rfinkle2 on 93 - 321whp / 365wtq Cobb AP, SRI, TIH, DP, BPV | Autotech FP Internals | Treadstone TR8L + PG Pipe Kit | Grimmspeed EBCS | JBR TIGs, RSB, SSP & Bushings, EGR Delete, RMM (88dm), TMM (88dm), PMM (80dm) | MD OCC | KW V2 | SPC Camber Arms | GTSPEC Trunk Cage | Goodridge Break Lines + StopTech PowerSlot Rotors + Hawk HP+ | Whiteline End Links (front) | MOOG End Links (rear) | DDM 55w 5k Head Lights and Fog Lights | Speedline Mirrors |
![]() | | #84 | ![]() |
![]() Join Date: Nov 2010 Location: Kaunas, Lithuania
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 144
| Not Ranked : 0 score |
![]() | | #85 | ![]() |
![]() Join Date: Nov 2011 Location: Minooka, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, FREEK TUNED, HTP full 3" intake/TIP, HKS SSQV 4 full VTA, Corksport catless downpipe, Corksport catless Racepipe, Cobb AP V3, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 80duro PMM, JBR cylindrical shift knob, Fidanza aluminum flywheel, EBC green brake pads, Centric high carbon rotors, Nitto NT555 tires, Gorilla spline lug nuts, DDM tuning HID's lows, Resonator Delete. | |
| The Following User Says Thank You to GODspeed7 For This Useful Post: | Enki (09-02-2012) |
![]() | | #86 | ![]() |
![]() Join Date: Oct 2011 Location: Salt lake city, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21
This thread really is a good read. I have learned alot about E85 reading it. Hopefully we can figire this out.
2013 CWP MS3- CS 3" SRI, CS Catted DP, CS 80 Duro Race RMM, GFB BPV, CS STS, AutoTech FP Internals, CS FMIC piping w/TR-6 Core, Res Delete 304 Whp 371 Wtq DYNOJET 3 Gal E85 Purple Drank Tuned 2007 Ms3- Mazda speed CAI, gutted 2nd CAT, AccessPORT (SnailTooned), CorkSport RMM Inserts, flat black gen 1 wheels. 298 WHP 320 WTQ Sold but not forgotten | ||||
![]() | | #87 | ![]() |
![]() | | #88 | ![]() |
![]() Join Date: Aug 2010 Location: Honolulu
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 424
Groans: 54
Groaned at 42 Times in 32 Posts
| Not Ranked : 0 score I forgot to ask this earlier - Are the seals being used in the pump Viton based seals? The seals look to be black in color so I assume not. (Viton seals are green) Basically; Viton seals are far more heat resistant and are better at blocking oils/fuels/whatever. They are also more resistant to caustics. If the seal being used in the HPFP is a traditional seal then sourcing a Viton based equivalent would improve (Or potentially resolve) this situation IMO. http://www.dupontelastomers.com/Prod...n/techInfo.asp Also, I forgot where the thread was located but I remember someone on here (Phate?) doing some tests on the seals and with different fuels to see swell, etc. Was a Viton based gasket/seal used in this test?
__________________ Mods - Six (6) Kenny Loggins albums in each position in my 6 disc changer. HOW-TO Tune a car - http://youtu.be/5ET9YXP1M04 Last edited by Mchart; 09-11-2012 at 01:09 AM. |
| The Following 2 Users Say Thank You to Mchart For This Useful Post: | Constantin (09-11-2012), dot584 (09-11-2012) |
![]() | | #89 | ![]() |
Groans: 54
| Not Ranked : 0 score I pulled a very relevant table of data from the product brief. Unless i've entirely misconstrued the nature of the problem we are discussing; I beleive it to be worth switching to a Viton o-ring and seeing if that improves the situation or not. If someone does go out and decide to use a Viton O-Ring make sure you actually get an official Viton o-ring. There are many o-rings out there that are 'Viton' but do not have the official Dupont formulation. Thus, they are inferior in real world usage. Official Viton rings are a solid green color, or black with green markings on it.
__________________ Mods - Six (6) Kenny Loggins albums in each position in my 6 disc changer. HOW-TO Tune a car - http://youtu.be/5ET9YXP1M04 Last edited by Mchart; 09-11-2012 at 02:11 AM. |
| The Following User Says Thank You to Mchart For This Useful Post: | Constantin (09-11-2012) |
![]() | | #90 | ![]() |
![]() Join Date: Jul 2011 Location: Elk Grove Village, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,411
Groans: 124
| Not Ranked : 0 score ^^ Good info..... Enki, spill valve started to take a shit....pretty sure I got about ~500 miles on it since Aug 23..... I don't drive the car that much, it does sit usually for 4 days every week, rest is going out over the weekend, going to the g.fs and w.e else.....plus I'm in need of another oil change, I'm still sure I have t6 in the motor still since I switched to vr1 oil.
__________________ DBB Gen2 Pte6266, kozmic pte top mount manifold kit, Kozmic 4'' Intake, kozmic hood exit Dp+Dump, 11:1 Custom Wiesco Pistons + Monlar rods, Freek PnP head w/Supertech springs&retainers, L19 Head Studs, JMF PI Intake Manifold W/ custom single Walbro 450+ Fuelab Inline Pump, HKS BOV, Cp-e Stage2 RMM, Trz Tranny Mount, MD PMM, JBR Egr Block Off Plate, Cp-e Fuel Pump, Sheepey Built Fmic Core, 3.5 Bar Map Sensor, Precision Wastegate, TWM Shifter bushings, Freak Tuned! 713whp/569wtq! FIRST MS3 IN 10s! 10.963 @ 136.79 (8/12/2015) 10.72 @ 139.44! (10/1/2015) 10.43 @ 140.95! 10/9/2015 10.35 @ 140.86 (10/30/2015) New Time! Fastest Ms3 to date 10.27 @ 141.55 (5/22/2016) |
| The Following User Says Thank You to mazdafreak For This Useful Post: | Enki (09-11-2012) |
![]() | | #91 | ![]() |
![]() Join Date: Dec 2009 Location: San Antonio, TX
Rep Power: 5051 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,143
Groans: 146
![]() | | #92 | ![]() |
Groans: 136
| Not Ranked : 0 score Tapadatass
__________________ | |
| The Following User Says Thank You to silvapain For This Useful Post: | mazdafreak (09-11-2012) |
![]() | | #93 | ![]() |
Groans: 136
Tapadatass
![]() | | #94 | ![]() |
Groans: 54
This place looks like a good bet. You'd need to call them though. They offer x-rings in all the same standard sizes as their o-rings and all the same material choices as well. Also, make *sure* you order the 'Viton Extreme'. I've looked at some more data and the Viton Extreme is able to withstand ethanol (Or any alcohol for that matter) far better then normal Viton types and Buna-N. http://www.marcorubber.com/compatibility.htm
__________________ Mods - Six (6) Kenny Loggins albums in each position in my 6 disc changer. HOW-TO Tune a car - http://youtu.be/5ET9YXP1M04 Last edited by Mchart; 09-11-2012 at 11:33 AM. | |
![]() | | #95 | ![]() |
![]() Join Date: Feb 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30
| Not Ranked : 0 score Great Work Dudes! |
![]() | | #96 | ![]() |
Groans: 146
![]() | | #97 | ![]() |
Groans: 136
| Not Ranked : 0 score There's a huge thread about testing E85 with the HPFP. Read. I have cleaned my HPFP more times than many on here have wiped their asses. Tapadatass
| The Following 6 Users Say Thank You to silvapain For This Useful Post: | codykemmet (09-21-2012), Enki (09-11-2012), GLORIFIEDBOZO (09-20-2012), Haltech (09-20-2012), mazdafreak (09-11-2012), pzr2874 (09-11-2012) |
![]() | | #98 | ![]() |
Groans: 124
| Not Ranked : 0 score Okay, this is weird.....So my fuel pressure dropped going to work on the highway, and got fuel pressure back after I got off the highway......I parked the car, since I had to work.....I went home, and my fuel pressure has not dropped for at least 30 miles so far. So wtf happened?? I haven't had a chance to pull the spill valve yet....But I'm holding pressure.
![]() | | #99 | ![]() |
Rep Power: 11232 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,868
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
| The Following 4 Users Say Thank You to phate For This Useful Post: |
![]() | | #100 | ![]() |
Groans: 124
| Not Ranked : 0 score ^^Ahh makes sense.....I guess the vr1 oil works good.....When I ran t6, fp would drop right away and be gunked up. This is the pic of the spill valve.....It wasnt super sticky, just a tad bit, it looked/felt like that gummy/sticky shit from a sticker.
![]() | | #101 | ![]() |
![]() Join Date: Apr 2010 Location: Des Plaines, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 234
Groaned at 53 Times in 17 Posts
| Not Ranked : 0 score That looks way better. |
| The Following User Says Thank You to dead-zone For This Useful Post: | mazdafreak (09-15-2012) |
![]() | | #102 | ![]() |
Groans: 124
| Not Ranked : 0 score @phate @Enki this is my buddies @justinspeed3 spill valve on 50/50 on t6 for maybe half the summer till now. He was having problems with afr going crazy and would randomly full cut, ap clint said to check spill valve, and well, u can see the results. I'm on 100% and my spill valve never looked this bad lol.
![]() | | #103 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Fuck man MINE never looked that bad. Most of that is either from before adding corn (not cleaned prior to going mid-mix; probably should be a requirement, really) or hes right on the edge of ratio that causes issues. How is he calculating his mix? Is he putting in the same amount of e85 to 91 per tank or just the same amount of corn each tank and topping off?
![]() | | #104 | ![]() |
Groans: 124
Yeah same here, mine has NEVER looked that bad, and I'm on 100% E lol.....I don't kno the exact details, but I kno he fills up at every half a tank and puts ~6/6 gallons of 85/93. Idk if he adds a lil more 85 or not....Maybe @justinspeed3 can help answer?? So I think 50/50 down the road actually gunks up, or its the t6 oil.... I see nothing but problems with ppl running E and t6.
__________________ DBB Gen2 Pte6266, kozmic pte top mount manifold kit, Kozmic 4'' Intake, kozmic hood exit Dp+Dump, 11:1 Custom Wiesco Pistons + Monlar rods, Freek PnP head w/Supertech springs&retainers, L19 Head Studs, JMF PI Intake Manifold W/ custom single Walbro 450+ Fuelab Inline Pump, HKS BOV, Cp-e Stage2 RMM, Trz Tranny Mount, MD PMM, JBR Egr Block Off Plate, Cp-e Fuel Pump, Sheepey Built Fmic Core, 3.5 Bar Map Sensor, Precision Wastegate, TWM Shifter bushings, Freak Tuned! 713whp/569wtq! FIRST MS3 IN 10s! 10.963 @ 136.79 (8/12/2015) 10.72 @ 139.44! (10/1/2015) 10.43 @ 140.95! 10/9/2015 10.35 @ 140.86 (10/30/2015) New Time! Fastest Ms3 to date 10.27 @ 141.55 (5/22/2016) | |
![]() | | #105 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Could be the gas. I use 91. Ultimately, he should make a thread on it.
![]() | | #106 | ![]() |
Tuned on 5050 MONTHS ago by yours truly. So I talked to him about this today and got some info, which is why the spill valve was pulled ![]() He hasn't switched back to 93 since the 5050 tune, which is a ton of miles for him - I would guess 7-10k miles. Way back when we did the tune, he wanted to always top off the car because he drives it so much. I told him to always err on the high side with E85, which is exactly what he was doing. Over time, this has led to a higher than intended concentration. He is approaching 13:1 AFR's on his current tank, due to too much ethanol. In terms of AFR's, it's fine, that's why we tune them conservatively (target 11.48). BUT, I think this extra ethanol put him in the 'danger zone' for black death build up. Couple that with lots of miles, and bam, you have buildup and the E85 woes we've come to know and love. @justinspeed3 - can you verify the miles? @mazdafreak - thanks for posting those pics.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | ||
| The Following 3 Users Say Thank You to phate For This Useful Post: |
![]() | | #107 | ![]() |
![]() Join Date: Jul 2011 Location: Clarksville, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,279
| Not Ranked : 0 score This thread makes me miss my car
__________________ "Intelligence isn't the ability to store information, but to find it" - Albert Einstein "When I read about the evils of drinking, I quit reading" - Henry Youngman |
| The Following 4 Users Say Thank You to GLORIFIEDBOZO For This Useful Post: |
![]() | | #108 | ![]() |
| Not Ranked : 0 score you guys and your high concentration E85...lol good thread...will need to read up. I am currently running E42/5050 but am not seeing any gains over E35 as of yet. The 42 needs about .5* more timing to reach the same WHP so IDK what I think yet. zero issues with FP...well if you don't count pegging the FP sensor with a PTP 2150 RV...lol note to self...put 1850RV back in while motor is torn down for oiling issues.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 |
| The Following User Says Thank You to Dano For This Useful Post: | mazdafreak (09-21-2012) |
![]() | | #109 | ![]() |
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock ![]() Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | ||
| The Following User Says Thank You to Haltech For This Useful Post: | Dano (09-21-2012) |
![]() | | #110 | ![]() |
| Not Ranked : 0 score isn't' it your bedtime?
![]() | | #111 | ![]() |
Groans: 124
| Not Ranked : 0 score Np clint, I'm awesome . I was surprised to see that, I was like Wtf! Anyways, idk if this matters, but justin says he's overdue for an oil change by like 4000 miles...pretty sure he changes it every ~3000....Guess t6 is starting to break down, idk, which I would guess why the oil is so black/dark......Just something to figure in too I guess.
![]() | | #112 | ![]() |
| Not Ranked : 0 score The high concentrations will be put to better use soon enough
| The Following 8 Users Say Thank You to phate For This Useful Post: | Dano (09-21-2012), Enki (09-21-2012), GLORIFIEDBOZO (09-21-2012), mazdafreak (09-21-2012), Ms3_Miami (12-26-2012), rfinkle2 (12-26-2012), silvapain (09-21-2012), Todd98SE (09-21-2012) |
![]() | | #113 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score In before new stock turbo record.
![]() | | #114 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 263
__________________ Justinspeed3 is a huge faggot with a slow car!!! --mazdafreak was here. | |
![]() | | #115 | ![]() |
| The Following 2 Users Say Thank You to justinspeed3 For This Useful Post: | mazdafreak (09-21-2012), rfinkle2 (12-26-2012) |
![]() | | #116 | ![]() |
| Not Ranked : 0 score @silvapain 400hp stock turbo
![]() | | #117 | ![]() |
Groans: 136
If we were NA, I would only expect about a 2-3% increase in WHp. With FI and E85 I don't know what to expect. We'll find out soon enough though. Pistons are at the shop.,. Tapadatass
| The Following 5 Users Say Thank You to silvapain For This Useful Post: | Dano (09-22-2012), Enki (09-22-2012), GLORIFIEDBOZO (09-22-2012), mazdafreak (09-22-2012), Nliiitend1 (09-23-2012) |
![]() | | #118 | ![]() |
| Not Ranked : 0 score Back to the original topic... I would gum up my spill valve in ~50 miles when trying to run 7.5-8 gal/tank E85 (~E50) when using Walmart SuperTech 5w-30 synthetic. I could reduce the E85 concentration to 6-7 gal/tank and clean the spill valve in place enough to control again. This was repeatable as it checked it 2-3 times. I have never had any issues with this oil at E20-E40 during the past 1.5 years.
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
| The Following 3 Users Say Thank You to cld12pk2go For This Useful Post: |
![]() | | #119 | ![]() |
![]() Join Date: Oct 2011 Location: Boone, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 694
__________________ 2006 Mazdaspeed 6 WWP Mods: Cobb ap, Freektune ots+, rebuilt ko4(hhskinny), Autotechs, AEM CAI, ETS tmic, Sure sidewinder, JBR RMM, Cpe diff mount, sure charge tubes, Corksport strut tower, catless test pipe, Magnaflow CBE, Forge BPV(v1), JBR shift bushings, corksport rear sway bar, VTCS delete, Dba 4000 slotted rotors, ebc red stuff Interior: Block Vent pod, Prosport boost gauge, Redline leather boots, Mazdaspeed E-brake, Ipod integration, Corksport LEDs Looks: 15% tint all around, 40% entire windshield, Corksport LED fogs, Corksport stub Fluids: Rotella T6, Motorcraft XT-M5-QS, Redline 75w90 waiting to install (in garage): Cpe catted dp | |
![]() | | #120 | ![]() |
| Not Ranked : 0 score Correct, zero issues below E50.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f567/kings-corn-hpfp-oil-122082/ | ||||
| 2014 Ford Fiesta ST project - Page 9 | This thread | Refback | 08-03-2014 08:28 AM | |
| What happened to the e85 blend thread? - Page 4 | This thread | Refback | 02-15-2014 09:29 PM | |
| What happened to the e85 blend thread? - Page 3 | This thread | Refback | 01-08-2014 09:42 PM | |
| BNR Stage 3 Turbo Upgrade - Page 7 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 02-01-2013 03:06 PM | |
| Resolving HPFP corn woes (black death/sticking spill valve) | Enki | MazdaSpeed 3/6 - E85 Fueling | 467 | 10-26-2014 03:50 AM |
| Another Corn Fed PU | trf5000 | 2010 MS3 - ECU Computer Tuning | 73 | 08-12-2012 09:07 AM |
| 2 gal's of corn + chinacharger | dooderek | MazdaSpeed 3/6 - ECU Computer Tuning | 15 | 01-10-2012 01:52 AM |
| Make hate part 10ish. - negative camber kings check in | IshiKage | MazdaSpeed 3/6 - Suspension & Brakes | 30 | 05-02-2010 11:08 PM |
| Dale Earnhardt lives on... as 305-foot roller coaster at Kings Dominion?! [w/VIDEO] | Haltech | Automotive News | 0 | 08-21-2009 09:20 AM |
