| MazdaSpeed 3/6 - E85 Fueling Learn more about feeding your car corn |
![]() Join Date: Feb 2012 Location: Germany
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 74
(Thread Starter) | Not Ranked : 0 score Without having done any maf-recal my max calculated load jumped up from 2.3 to 2.5x and max maf increased by 40-50 g/s, so there are gains in air flow of roughly 10%. What I don't understand is that I don't notice any gains in tq / hp in VD!? Since there's much more air entering the combustion chamber I should also get more hp or am I totally wrong? I use VersaTuner as tuning tool (and thus lambda-tuning), so I do not necessarily have to adjust my fuel tables, moreover boost and timing are already set quite high (up tp 24-25 psi / 20°). Reported afr is varying around 11.5, but this is of course an internally transformed value based on pump gas assumptions. Do I have to increase / lean out target afr further (~12.0), and where's my expected, additional power? May this be due to insufficient fuel supply...?
__________________ Mods: BNR S4, 3" Ray cb, CP-E catted dp, CS 3" intake, CP-E tmic, D06-wmi, itv22/NGK IX plugs, Forge bov, hpfp-upgrade, JBR ebcs, 3 bar map sensor, egr block off kit, ACT 6 pad clutch with SL flywheel, Wiseco oem compression pistons, Manley H-Beam connecting rods, reworked head, CP-E SafeSeal injector seals, no E85, Cosworth thermostat |
![]() Join Date: Jun 2011 Location: australia
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score Guessing versatuner does MAF based fuel scaling rather than doing injector scaling... @Lex;?
__________________ OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPVNEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP |
| Not Ranked : 0 score Why would you see any power gain just by adding e85? The gains come from allowing for more advanced timing. Also the load and AFR are off because the fuel density is different. You're not getting more air.
| The Following 3 Users Say Thank You to btstarcher For This Useful Post: |
![]() Join Date: Aug 2008 Location: Pittsburgh, PA
Rep Power: 637 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,048
| Not Ranked : 0 score Try doing the runs all back to back adding a degree of timing each time. Use the same stretch going the same direction. Once you notice minimal gains or a little knock use the previous map. It's not gonna do miracles, but it's an easy 20hp. |
| The Following User Says Thank You to Mistersix For This Useful Post: | btstarcher (09-01-2014) |
(Thread Starter) | Not Ranked : 0 score This was an epic fail: I used an old E85-map as template which had the maf cal already adjusted by 10% - I just didn't notice this fact... So, no miracles at all and everything as expected ;-)
| The Following User Says Thank You to EmPeEs6 For This Useful Post: | btstarcher (09-01-2014) |
Groans: 189
| Not Ranked : 0 score You may flow more air due to the cooling effect, but alcohols burn slower, thus requiring more timing in order to make the same or more power.
__________________ |
| The Following 3 Users Say Thank You to Enki For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Well, that was my original intention - since I already ran extremely aggressive values, as mentioned above up to 25 psi and 18° (on pump gas!) there's not much headroom for power gains from boost and/or timing...
__________________ Mods: BNR S4, 3" Ray cb, CP-E catted dp, CS 3" intake, CP-E tmic, D06-wmi, itv22/NGK IX plugs, Forge bov, hpfp-upgrade, JBR ebcs, 3 bar map sensor, egr block off kit, ACT 6 pad clutch with SL flywheel, Wiseco oem compression pistons, Manley H-Beam connecting rods, reworked head, CP-E SafeSeal injector seals, no E85, Cosworth thermostat Last edited by EmPeEs6; 09-28-2014 at 07:20 AM. |
![]() Join Date: Aug 2012 Location: Toronto, Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 165
Groaned at 7 Times in 4 Posts
I'm using 94 octane and in the process of dialing in a nice pump gas tune but still want to be safe. What's your approach to dialing timing in on pump gas?
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) | |
(Thread Starter) | Not Ranked : 0 score This was on 95 (US) octane (=102 EU octane), i.e. the best fuel quality avaiable. Now, using 93 octane gas + ~4-5 gallons E85, I can run up to 27 psi and 20° at redline.
![]() Join Date: Apr 2014 Location: The Netherlands
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 512
| Not Ranked : 0 score Yup, that RON 102 octane is amazing stuff, glad we have that quality of fuel over here in europe, costs a fair dime (currently ~1.80 euro per liter ), but worth every penny in my opinion.Starting from my RON98 octane tune, i could easily add 5* timing up top. Still no knock to be found untill now.
__________________ MazdaSpeed3 GT '07 CP-e Xcel Nano 3" Air Intake - CP-e Nviscid 3" TIP - CP-e HPFP - CP-e DeltaCore FMIC - CP-e Stage 1 RMM - ACT clutch kit - ATP Race Pipe - SU DualPort Turbosmart BPV - COBB anti swaybars - COBB Sport Springs - Goodridge Brakelines - Whiteline Swaybar endlinks - JBR SSP - Damond Motorsport OCC AccessPort V2 Self tuned |
![]() Join Date: Sep 2011 Location: Stockholm Sweden
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,687
Groans: 33
| Not Ranked : 0 score Well, you ran a 102 octance fuel. Then went back to (US93/EU98??) + E85... E85 has a EU octane of 104. Mixing that with EU98 might get you ~100 octane So your current octane is actually lower than before. The only advantage now is that E85 cools your chamber better. But octane is actually worse ![]() I don't see that there is much gain to be had. I.E you need a bigger turbo
__________________ Mazdaspeed6 -06 Tuned with by Alex@StratifiedCP-E Atmosphere Kit GTX3076 Tial 0.82AR / EWG / 3,25" MAF / Catless DP Simons 3" Catback CP-E Diff Mount HDI FMIC HTP Battery Relocation Corksport: Rear Brace Bar - Front Strut Bar - Stubby Antenna - Interior + Underhood LED Kit JBR: TMM+PMM+RMM - Short Shift Kit /w Bushings - TIG Throttle - Coolant Bypass - EGR Delete - JBR OCC Stage 2 Whiteline Rear Swaybar SPC Camber Joints Turbosmart BPV Autotech Internals SURE Juggernaught Stratified Guardian Angel & Boost Dial NGK IX @ 0.025 Bosch 3 bar MAP w/ PNP Harness Block8Head Dual Gauge Pod Defi Racer Boost & Oil Pressure & Oil Temp Techna-Fit Clutch Line + Brake Lines ATE Super Blue Racing ProSport Oil Filter Adapter Mazda Spin-On Conversion + NPT/BSPT adapter Not installed yet: SP63 longblock, FreekTune 4" Intake, JBR TIG IM, DM Meth Spacer 290 AWHP / K04 370 AWHP / GTX3076 @ 23 psi |
Groans: 189
__________________ | |
| The Following User Says Thank You to Enki For This Useful Post: | SpeedRebirth (12-23-2014) |
![]() Join Date: Aug 2013 Location: Manitowoc, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,312
| Not Ranked : 0 score Noticing your mods this is probably pretty irrelevant- but I have observed MBT on limited flow setups at 14-15* at the low end as opposed to the "norm" of 20ish* with an e40 mix. An example is a car that only had an intake and test pipe (HPFP internals also of course).
__________________ https://www.youtube.com/user/JustinBieberVEVO |
| The Following User Says Thank You to Gr8Speed For This Useful Post: | Enki (12-23-2014) |
| Power gains from hf downpipe | EmPeEs6 | MazdaSpeed 3/6 - ECU Computer Tuning | 2 | 01-30-2013 05:25 PM |
| Acura RDX gains power, loses weight for '13 | Haltech | Automotive News | 0 | 02-07-2012 09:40 PM |
| Are power gains cumulative with bolt on's? | ganderson | 2010 MS3 - Engine, Transmission & Driveline | 9 | 03-01-2011 06:34 AM |
| Ford leads Detroit 3 quality gains over rivals, J.D. Power says | Haltech | Automotive News | 0 | 06-17-2010 10:10 PM |
| Power gains with just an air intake and catback. | 06kr | Mazdaspeed3/6 General Discussion | 7 | 09-09-2008 03:09 PM |
