| VersaTune VersaTuner tuning software by VersaTune. Available for Mazdaspeed3, Mazda 3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda 6 MPS, Mazdaspeed Atenza. Includes ECU reflashing/remapping, online tune database, custom tune editing ability, virtual dashboard, data logging, diagnostics/DTC code management, Launch Control, No Lift Shift, and stutter-free Smooth Shifting. |
| Approved MSF Vendor ![]() Join Date: Dec 2011
Rep Power: 189 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score Initially a special tune is flashed that is identical to OEM in terms of performance, but can accept performance tunes and has launch control, no lift shifting and other special features available. That tune is not in the list, but you can recreate that tune if necessary by clicking "New Tune" and saving the Tune Editor without making any other changes. |
(Thread Starter) | Not Ranked : 0 score The base tune is already part of the software. Why not just make it visible? I suppose I'm one of the few who want to learn the program before jumping right into an OTS map.
Groans: 189
| Not Ranked : 0 score ...Because it's not something anyone is going to stay on longer than they have to? I mean, nobody buys a tuning solution to stay on the stock map for any real length of time.
__________________ |
(Thread Starter) | Not Ranked : 0 score I don't entirely disagree with you. I do plan to self tune, and I also want to know where I'm starting from and compare it to an OTS tune to see what changed and read about what that change does and how it interacts with other tables, etc. I'm starting from zero instead of being a nice little sheep and jumping into an OTS map that I have no knowledge of how it differs from the previous tune. I'm not trying to take any credit away from the OTS tune developers as I'm sure they know what they're doing. I want to learn, for my own sake, what each thing does. Just clicking download and flash doesn't teach me anything.
| The Following User Says Thank You to Fstrnyou For This Useful Post: | Enki (09-19-2016) |
Groans: 189
| Not Ranked : 0 score I'll be redoing the TITS guide in VT, and I'll probably go over the stock vs OTS stuff.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | desync0 (09-20-2016), KiwiFlavor (09-20-2016) |
| Not Ranked : 0 score If you want to see what was changed in an OTS tune compared to stock, that can be very easily done with the tune editor. Click "From stock tune" in the "Show changes" panel at the top. All tables that have been changed will be marked in bold. VT.png If you want to start from scratch, just click "New..." in the "My Tunes" area of the "Tunes" tab. The Tune Editor will open with all tables set to stock values. You can then start applying your changes, flashing periodically and checking the effects. |
(Thread Starter) | Not Ranked : 0 score Ah, awesome. Thank you very much.
![]() Join Date: May 2009 Location: Huntsville, AL
Rep Power: 1431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,522
| Not Ranked : 0 score To expand on that, after you do that, you can select a cell/row/table and click the undo button (the circular arrow pointing counter-clockwise) to revert that value to whatever the stock map had. That feature is also useful to compare changes you made between maps too.
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // |
| Display Modes | |
| Base tune, what does it do? | Kor3y101 | Gen2 MS3 General Discussion | 4 | 04-12-2015 02:03 PM |
| Boost Tune - Only running base WGDC | MattJackson86 | MazdaSpeed 3/6 - ECU Computer Tuning | 10 | 05-08-2014 05:13 PM |
| Initial log...how's it look? | AKmac11 | Mazdaspeed3/6 General Discussion | 2 | 07-31-2013 06:24 PM |
| In need of BT Base Map Tune | myfirstturbo | MazdaSpeed 3/6 - ECU Computer Tuning | 18 | 07-28-2013 02:34 PM |
| Not boosting even on base tune | KRheeder | MazdaSpeed 3/6 - ECU Computer Tuning | 0 | 02-09-2012 01:27 PM |
