> VersaTune
Like Tree31Likes
 Old 12-09-2014, 11:51 AM   #1
Putin 2.3T's Avatar
Posts: 1,040   (View Stats)
Well MoTEC and the ProEFI live both use the cruise control button/stock. But I don't know if that's possible with the MS3.
2011 Mazdaspeed 3 [Sold]
The Following User Says Thank You to Putin 2.3T For This Useful Post:
RE-ACTIONENGSPEED3 (12-09-2014)
 Old 12-09-2014, 11:58 AM   #2
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
If it's going to be increased, might as well go to 10k.
SpeedRebirth (12-09-2014)
 Old 12-09-2014, 01:08 PM   #3
Enki's Avatar
Groans: 189
I wasn't aware our valvetrain could handle 7500 RPM. I thought the limit for float was around 7200.
 Old 12-09-2014, 01:11 PM   #4
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
Steve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the world
There are lots of checks at 8k in the ECU. I have not spent much time investigating what actually happens at 8k since not many have had the aux fuel needed to spin that high till recently.
Steve
Lead Tuner
Steve@VersaTune is offline   Reply With Quote
The Following 2 Users Say Thank You to Steve@VersaTune For This Useful Post:
Micha (01-12-2015), phate (12-09-2014)
 Old 12-09-2014, 02:27 PM   #5
Enki's Avatar
Groans: 189
Well he's clearly hitting a rev limiter. What's it set to?
phate (12-09-2014), RE-ACTIONENGSPEED3 (12-10-2014)
 Old 12-10-2014, 12:18 AM   #6
RE-ACTIONENGSPEED3's Avatar
Posts: 401   (View Stats)
It is set to 8000rpm
2008 speed3
True red.
Pte 6466 & AWD Mode on !!!!
The Following 3 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
Enki (12-10-2014), Micha (12-10-2014), phate (12-10-2014)
 Old 12-17-2014, 10:09 PM   #7
Enki's Avatar
Groans: 189
If possible, requesting access to hpfp spill valve duty cycle for logging/testing.
 Old 12-20-2014, 02:40 PM   #8
Enki's Avatar
Groans: 189
Export to CSV default filename: replace / with either - or _
phate (12-20-2014)
 Old 12-20-2014, 02:56 PM   #9
Enki's Avatar
Groans: 189
Current default export format: XML
/Datalog/Data/PID[@ID = #]/Record
@Time = #
@Value = # /
Alternate export format: XML
/Datalog/Data/Record
@PID = #
@Time = #
@Value = # /
It will be extremely easy to split this data format out into separate PIDs versus having to join all the separate PIDs together in a concise format.
I can do the XSLT work for the requested export format.
 Old 12-22-2014, 08:04 AM   #10
Ugnius@VersaTune's Avatar
Posts: 41   (View Stats)
Ugnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the world
@Time = #
@Value = # /
@PID = #
@Time = #
@Value = # /
What's the purpose of having this XML format? What are you going to use it for?
Ugnius@VersaTune is offline   Reply With Quote
 Old 12-22-2014, 09:48 AM   #11
Enki's Avatar
Groans: 189
It would be much easier to spit it out as a single dataset using XSLT, and it should also be easier to write for VT, seeing as how each individual PID will be written in the order it arrives.
The way it is now, I'm not sure you could use XSLT to spit out a CSV (just as an example) without probably a large amount of code in the XSLT file, whereas the structure I've outlined above would take about 15 minutes.
If the data is already in a pile, it's easier to break it up than it is to re-consolidate it.
 Old 12-22-2014, 02:41 PM   #12
XSLT won't be enough to convert to CSV, because CSV implies that every record (set of values of all PIDs) was taken at a certain fixed point in time. Whereas in reality, PIDs are requested sequentially, one by one. We also request slowly changing PIDs at a lower rate to save bandwidth for fast changing ones. So it's a pool of data streams with different resolutions.
What we do is interpolate values of all PIDs at fixed intervals and spit out CSV.
*.vtlog is a proprietary format for sharing logs between two VersaTuner instances. It would be interesting for me to find out what the potential uses for our raw data would be. Maybe we are missing some features in our log viewer.
Ugnius
Lead Developer
 Old 12-22-2014, 02:59 PM   #13
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Pivoting, averaging, trending over multiple logs compiled into one view or data set. I have to export to CSV top do these. Viewing logs over time as the x-axis isn't as helpful as viewing things over rpm or maf or load, etc.
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 12-22-2014, 08:13 AM   #14
torquemaniac's Avatar
Posts: 733   (View Stats)
Access to the automatic transmission tables for the CX-7...
2011 CX-7 AWD 2.3 turbo
The Following User Says Thank You to torquemaniac For This Useful Post:
Micha (01-12-2015)
 Old 12-22-2014, 01:40 PM   #15
undecided's Avatar
Posts: 9   (View Stats)
undecided will become famous soon enough
I don't have VT but it would be awesome if you could make it so the ECU doesn't cut power when the brakes are applied the same time as the accelerator on +2011's. It would be nice to be able to trail brake and brake boost without the ECU cutting the power. Not sure if it's possible since it is some safety code in the ECU but you were able to disable the boost limiter and SWAS so I have hope.
undecided is offline   Reply With Quote
 Old 12-22-2014, 02:49 PM   #16
Enki's Avatar
Groans: 189
I'm just a raw data kind of guy; the number of squiggly lines and the side scales are a bit distracting.
Hell, duplicating values in the logs would be fine if the data has not updated yet; pretty sure that's what the AP does.
 Old 01-11-2015, 03:39 PM   #17
You should also add a log pid , for injector duty cycle %
2008 speed3
True red.
 Old 01-12-2015, 01:07 AM   #18
EmPeEs6's Avatar
Posts: 642   (View Stats)
EmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the world
You can log inj. pulse width and calculate idc very easily.
Mods: BNR S4, 3" Ray cb, CP-E catted dp, CS 3" intake, CP-E tmic, D06-wmi, itv22/NGK IX plugs, Forge bov, hpfp-upgrade, JBR ebcs, 3 bar map sensor, egr block off kit, ACT 6 pad clutch with SL flywheel, Wiseco oem compression pistons, Manley H-Beam connecting rods, reworked head, CP-E SafeSeal injector seals, no E85, Cosworth thermostat
EmPeEs6 is offline   Reply With Quote
 Old 01-12-2015, 05:11 AM   #19
I know that. but when you are in the road and tune sometimes is usefull just to watch it without calculations...
2008 speed3
True red.
The Following 2 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
Micha (01-12-2015), SpeedRebirth (01-12-2015)
 Old 02-14-2015, 08:13 PM   #20
Enki's Avatar
Groans: 189
Don't make vt software automatically start full screen. Some of us have bigass monitors and don't need to be blinded when opening it up lol
 Old 02-15-2015, 03:10 PM   #21
Enki's Avatar
Groans: 189
Cruise/max timing isn't being obeyed. All my tables are topped out at 40 degrees, yet I regularly see 55+.
 Old 02-27-2015, 04:35 AM   #22
Polish_Eagle's Avatar
Posts: 408   (View Stats)
@Steve@VersaTune; @Ugnius@VersaTune;
I have a question about disabling codes and the ready monitors. If I disable for example the EGR code because I deleted the EGR, is it possible to have VersaTune set the monitor as READY? It would be nice if the monitor could be set to ready, but only once the car finishes the required drive cycle.
 Old 02-27-2015, 10:22 AM   #23
Enki's Avatar
Groans: 189
Disabling the code sets them as permanently not ready. There is no way to make them read as ready via tune; it's an emissions legality thing.
 Old 02-27-2015, 10:31 AM   #24
Technically speaking though, flash tuning a vehicle is considered illegal too because you're modifying the factory tune which is approved under emissions. So I don't see why this can't be implemented.. Lol
 Old 02-27-2015, 10:38 AM   #25
Enki's Avatar
Groans: 189
Because it can't.
Find me one example of stock ecu tuning solution that can fully set any code as ready and reporting properly.
 Old 02-27-2015, 12:06 PM   #26
Because it can't.
If you search google you can see the Evolution (See here) has a "Force OBD inspection patch". It's possible to do since developers of flash tuners are modifying the ECU software. The problem is legality, but in most places any type of tampering with the emissions systems is illegal and the ECU false under emission control.
So since flash tuning technically is illegal, I don't see why this feature would matter since you've already ventured into the illegal domain.
Ideally you'd have the ECU monitor everything as usual, but when it goes to report a status it just reports READY.
Anyways, I'll just leave it up to the software developers to figure out if they want to do it or not. It definitely would be a nice to have feature.
 Old 02-27-2015, 12:18 PM   #27
Mfinlay04's Avatar
Posts: 827   (View Stats)
@Steve@VersaTune;
Anyway we can make the Tuner Customizer menu scrollable? On me netbook I'm not able to access ther bottom of the menu =/
2006 MS6 Titanium Grey
Tuned with
The Following User Says Thank You to Mfinlay04 For This Useful Post:
Enki (02-27-2015)
 Old 02-28-2015, 05:58 AM   #28
Originally Posted by Mfinlay04 View Post
@Steve@VersaTune;
I have the same issue and i bought a biger 15.6 inch laptop....
2008 speed3
True red.
 Old 03-01-2015, 12:50 PM   #29
Enki's Avatar
Groans: 189
Rolling antilag triggers on second honk.
(LOL)
Micha (03-22-2015), RE-ACTIONENGSPEED3 (03-01-2015)
 Old 03-01-2015, 01:01 PM   #30
NCspecV81's Avatar
Posts: 2,867   (View Stats)
I really want to switch from the AP to versatuner. Get those logging rates and the ease of logging in line with the AP and I'll make the switch.
2013 CWP and Stock
Enki (03-01-2015)
 Old 03-05-2015, 07:52 AM   #31
Jarods7920's Avatar
Posts: 1,415   (View Stats)
I really think it would be awesome to have the rolling anit lag.
One question i have. Rumor has it that when you get into high horsepower 600+ load only tuning becomes difficult to manage. Whats say you to that?
 Old 03-05-2015, 07:57 AM   #32
I have never had any trouble load tuning all the way to the IDC limit. I dyno'd around 500AWHP on a mustang dyno. It could be that people are having trouble with tuning with supplemental fueling.
Rolling anti-lag is on the list. We need to find a good way to trigger it. There is not much integration with driver interface buttons and the ECU. Most of that stuff is wired to the other modules.
Steve
Lead Tuner
The Following User Says Thank You to Steve@VersaTune For This Useful Post:
RE-ACTIONENGSPEED3 (03-05-2015)
 Old 03-06-2015, 09:06 AM   #33
Jarods7920's Avatar
Yes, that could be an issue. If only there was someway to integrate that via the stock ecu. I think you and i have discussed this before though.
 Old 04-21-2016, 04:32 AM   #34
Juschiln19's Avatar
Posts: 160   (View Stats)
Juschiln19 is a glorious beacon of lightJuschiln19 is a glorious beacon of lightJuschiln19 is a glorious beacon of lightJuschiln19 is a glorious beacon of lightJuschiln19 is a glorious beacon of light
Talking
Can we get a update on when this will be coming???
06 MS6 GT / Black \ Moonroof - Sure Torq Motor Mounts All(Aggressive) - Sure Diff Mounts - Sure Thermal Gaskets - DM Stage 3 Dual OCC'S - DM Pcv Vent Plate - Magnetic Oil Plug - BNR S4 V2 - Speed Proformence Tranfer Case Bearing Caps - Guardian Angel - Grimmspeed EBCS - JBR Egr Delete - Turbosmart Dual Port BOV(100% To Air) - HTP 3.5" Full Intake W/Recir. Hose Blocked - Strut Tower Bar Front - Whiteline Rear Sway Bar W/Adjustable Links - EBC Stage 4 Brake Kit F&B - Bosch 3.5 Bar Map -Autotech HPFP - CX Racing FMIC Pipe Kit W/ Tr6 Core FMIC - South Bend /Stage 2 Daily Clutch W/ Lightweight Flywheel - Continental Extreme Contact DWS06 - Block8Head Custom Triple Vent Gauge Pod - 3in1 Glow Shift Gauge (Boost/Oil Temp/Oil Pressure) - Glow Shift Gauge (Oil Pressure W/Alarm) - One Step Colder Denso Plugs - Escort Max Radar Detector - Mazda 3(S6 Oil Cooler Delete) Oil Filter Housing - Rev 5 Front Mount Oil Cooler - Thermostatic Controlled Oil Filter Sandwich Plate W/Sensor and Oil Cooler Connections - Rotella T6 Oil - Versatuner w/Tablet - Reinforced Clutch Pedal Assembly
Juschiln19 is offline   Reply With Quote
 Old 03-05-2015, 10:19 AM   #35
Enki's Avatar
Groans: 189
It would be rather nice if the table headers floated (kind of like split or freeze in Excel). Would make it easier to mod the lower values on the extended tables for sure.
phate (03-05-2015), RE-ACTIONENGSPEED3 (03-06-2015)
 Old 03-05-2015, 10:25 AM   #36
It's on the list.
Mfinlay04 likes this.
Steve
Lead Tuner
Mfinlay04 (03-11-2015)
 Old 03-11-2015, 01:12 AM   #37
Mfinlay04's Avatar
@Steve@VersaTune;
Anyway to add P2096 to the list of CEL that we can disable.
I prefer to run @ 1.05 Lambda at cruising load/RPMs and need to be able to disable this code. I know this request would be very personalize but it'd be awesome if you guys could do it.
Thanks
Tuned with
 Old 03-11-2015, 05:33 AM   #38
@Steve@VersaTune;
Thanks
From the main screen, go to settings, Edit Tune Customizer Profile, then in the Tune Customizer window, go to the Disabling DTCs tab, then hit the Advanced button. All available DTCs on the vehicle should be listed there. If P2096 is not on the list there, and the ECU is throwing that code, let me know.
Steve
Lead Tuner
 Old 03-12-2015, 12:08 AM   #39
Mfinlay04's Avatar
I'm not seeing it. My car is a 2006 mazdaspeed 6 if that matters?!
Tuned with
 Old 03-19-2015, 06:14 AM   #40
@Steve@VersaTune;
Is there a way to put a battery volt indicator due to the time we flash our car?Also if it easy to put a safety limit(such under 11.9v) so that can not let us flash our cars ....or a warning...
2008 speed3
True red.
The Official AP v3 Landscape Request Thread hnda etr Cobb Tuning 41 03-18-2014 01:19 PM
atr feature request : dual monitor support someguyondrugs
Cobb ATR Support
7 11-26-2013 02:04 PM
Page generated in 0.67645 seconds with 34 queries
