| VersaTune VersaTuner tuning software by VersaTune. Available for Mazdaspeed3, Mazda 3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda 6 MPS, Mazdaspeed Atenza. Includes ECU reflashing/remapping, online tune database, custom tune editing ability, virtual dashboard, data logging, diagnostics/DTC code management, Launch Control, No Lift Shift, and stutter-free Smooth Shifting. |
![]() | | #41 | ![]() |
| Approved MSF Vendor ![]() Join Date: Nov 2011
Rep Power: 778 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| The Following 5 Users Say Thank You to Steve@VersaTune For This Useful Post: | derek13p (05-10-2016), Enki (05-10-2016), Mazdazilla6 (05-10-2016), SpeedRebirth (05-10-2016), xfeejayx (05-10-2016) |
![]() | | #42 | ![]() |
Groans: 189
| Not Ranked : 0 score I'll be waiting.
__________________ |
| The Following User Says Thank You to Enki For This Useful Post: | derek13p (05-10-2016) |
![]() | | #43 | ![]() |
![]() ![]() Join Date: Dec 2011 Location: San Marcos, TX
Rep Power: 691 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,138
Groans: 38
__________________ 06 MS6 & 06 MS6 [SIGPIC][/SIGPIC] The beauty is the beast Daily driven |
![]() | | #44 | ![]() |
![]() Join Date: May 2010 Location: Benton, AR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,028
| Not Ranked : 0 score One random thought I had today. It would be awesome to have themes. I use this word lightly. At night I would love to have a dark interface when logging. Heck, I would probably use the dark interface all the time. Sent from my iPhone using Tapatalk
__________________ 2010 Mazdaspeed 3 Liquid Silver Metallic HTA 3076 | HTP 4" Intake, battery tray, under mount piping | CPE Exhaust Manifold, downpipe, FMIC & Stage 2 RMM | MD TMM and PMM | Tial MV-R ewg w/ Kozmic dump tube | VCTS delete/Ported IM | JBR OCC, EGR delete, BSD w/ oil pan baffle & RSB | SP63 Oil Cap Breather | Synapse SB BPV | UR CBE | Autotech HPFP | H & R Coilovers | Whiteline Endlinks | Manley Pistons & Rods | L19 Head Studs | Kozmic 6th Port w/ DW65c ITFP | Snow Performance Stg 2 Meth | JMF Manifold | SouthBend Stg 3 Endurance Clutch | Tuned with |
| The Following 4 Users Say Thank You to jdmage_mx5 For This Useful Post: |
![]() | | #45 | ![]() |
| Yeah, i would love a dark themed Versatune as well. sent from my Nexus 6P
| The Following User Says Thank You to MS3Shadow For This Useful Post: | Enki (05-10-2016) |
![]() | | #46 | ![]() |
Groans: 189
| Not Ranked : 0 score Thirded. "I wear my sunglasess at night so I can so I can" (not be blinded by my tablet)
![]() | | #47 | ![]() |
| Approved MSF Vendor ![]() Join Date: Dec 2011
Rep Power: 189 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score OK guys, we will put the dark theme on our to-do list and prioritize it. |
| The Following 5 Users Say Thank You to Ugnius@VersaTune For This Useful Post: | derek13p (05-12-2016), Enki (05-12-2016), jdmage_mx5 (05-12-2016), mxlplx71 (05-12-2016), SpeedRebirth (05-12-2016) |
![]() | | #48 | ![]() |
![]() Join Date: May 2009 Location: Huntsville, AL
Rep Power: 1431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,522
Keep up the great work!
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // | |
| The Following User Says Thank You to nindoja For This Useful Post: | xfeejayx (05-12-2016) |
![]() | | #49 | ![]() |
Groans: 136
| Not Ranked : 0 score I haven't had a chance to try out the demo, but I have a quick question: can maps be exported to .CSV or similar, so they can be opened and manipulated in Excel? That would make writing scripts for comparing tunes and calculations for table edits so much easier.
__________________ Last edited by silvapain; 05-12-2016 at 09:30 AM. Reason: autocorrect sux |
| The Following User Says Thank You to silvapain For This Useful Post: | nindoja (05-12-2016) |
![]() | | #50 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yes! Sent from my SM-G935V using Tapatalk |
![]() | | #51 | ![]() |
![]() ![]() Join Date: Jun 2010 Location: Morton Grove, il
Rep Power: 1485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,886
Groans: 78
| Not Ranked : 0 score These fools are taking up Ugnius time to rice their tuning software. Smh Sent from my Nexus 5 using Tapatalk
__________________ "Well, Racecar=Broke. Other kinds of awesome may not, but racecar does. But racecar=best kind of awesome." -Wetz QFT |
![]() | | #52 | ![]() |
| Not Ranked : 0 score You know it. I don't want the rice on my car, I want it in my car.
![]() | | #53 | ![]() |
| Not Ranked : 0 score So I just bought VT and I already have the demo. I got this message after purchase, so will I have to download the full version of VT then once it's sent to me? Screen Shot 2016-05-12 at 2.25.39 PM.png
![]() | | #54 | ![]() |
![]() Join Date: Mar 2011 Location: Cambridge, Ontario, Canada
Rep Power: 221 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
__________________ 2011 MAZDASPEED3 Hypnotic Tuned - Rob CPE HPFP - CPE Catted Downpipe - CPE Catback Exhaust - 3" ETS TMIC - Cobb RMM - AEM Boost Gauge & Vent Pod - CANBus Triple - Corksport BPV - Corksport hood strut - Corksport RSB - Corksport Short Shifter - HTP 3.5" Intake - Damond TMM - Damond Vented CC - Vented Oil Cap - Tokay v2 Seals - GTX3067R - Damond PCV Plate - Built Engine (Manley Rods, 88mm Supertech 4032 Piston) - | |
| The Following 4 Users Say Thank You to Polish_Eagle For This Useful Post: |
| Display Modes | |
| Demo Software | NCspecV81 | VersaTune | 10 | 03-09-2016 10:16 AM |
| Versatuner GB | aviator79 | CX-7 > General Lounge + New Member Welcome | 5 | 03-12-2013 01:10 PM |
| EdgeAutosport.com Demo Car | JP@edgeautosport.com | EdgeAutosport.com | 44 | 04-30-2012 12:40 PM |
