> 2010 MS3 - Appearance > Exterior
  • 1 Post By SyntheticAtmosphere
 Old 02-14-2020, 11:14 AM   #1
Noah99's Avatar
Posts: 32   (View Stats)
Noah99 will become famous soon enoughNoah99 will become famous soon enough
Groaned at 8 Times in 4 Posts
Neutral  +1 score
Angry Is it possible to remove and clean headlight lens?
Driver side headlight lens has moisture in the inside 24/7 even after it's been dry weather for a few days. Gunk is built up by the clasps which has separated the lens from the headlight assembly allowing moisture to get in...I think
If I remove the headlight assembly, is it possible for me to remove and clean the lens? Thanks
Noah99 is offline   Reply With Quote
 Old 02-14-2020, 01:29 PM   #2
Police - Grammarhead
Vansquish's Avatar
Yes. You'll need a heat gun or an oven on low heat to soften the butyl glue that is used to seal the lens to the housing. There are probably some additional clips (including metal clasps) that you'll need to remove or at least "unlock." You'll also have to insert something like a screwdriver, a paint scraper or putty knife, or the like between the lens and the housing to separate them. Be very gentle, and work slowly and methodically. You can easily crack the housing, the lens, or both if you try to force them apart too quickly or aggressively.
Noah99 (02-14-2020)
 Old 02-14-2020, 02:45 PM   #3
Noah99's Avatar
Thank you! I'll buy a heatgun or use a blow-drier and start working on it tomorrow.
Before I crack this baby open, do replacement lenses exist or am I just screwed if I break the lens?
 Old 02-14-2020, 03:18 PM   #4
Posts: 2,233   (View Stats)
body repair shop may have lens suppliers to propose if needed.
 Old 02-14-2020, 05:49 PM   #5
Vansquish's Avatar
Yes. Replacements exist, but you'll be hard-pressed to find one from a dealer.
I'd suggest doing what I did and replacing with an aftermarket lens from China. I've had a set on my car for 2.5 years, and they're clean, clear, and fog-free. I also got a set of them for about $40 USD shipped.
Here's what I bought:
https://www.ebay.com/itm/Replacement...cAAOSwUM5Z6wvs
. . . And here's an option for you, I can't see anything for quite as cheap as the Mazda6 units I bought though.
https://www.ebay.com/itm/R-L-Headlig...0AAOSwlf9dhF~W
Here's a cheaper option on Aliexpress, if you can bring yourself to trust it.
https://www.aliexpress.com/item/3298...archweb201603_
Or, for the cheapest possible solution:
https://www.aliexpress.com/item/4000...archweb201603_
 Old 02-15-2020, 03:12 PM   #6
SyntheticAtmosphere's Avatar
Posts: 193   (View Stats)
SyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond repute
I also did the ebay china lens. I'd do it again as well. Go to NAPA and get replacement butyl rope to replace what you remove and get it good and warm before putting it back together. I also purchased automotive seam sealer and put a layer around the seam after I had reassembled the lenses.
File Type: jpg 19025281_904247113049120_7254328948706519647_o.jpg (190.6 KB, 3 views)
Vansquish likes this.
SyntheticAtmosphere
'06 Speed6 Whitewater Pearl (COBB AP v2, CS s2 SRI/TIP, Autotech HPFP, Cp-e RMM&RDM, Fidanza/LuK, homebrew Testpipe&OCC) next...meth habit
If it feels good, do it...Even if you shouldn't!
SyntheticAtmosphere is offline   Reply With Quote
« LED DRL? | - »
Condensation forming on inside of headlight lens indianaryan 2010 MS3 - Troubleshoot/Diagnostics 31 04-20-2015 11:36 AM
Clean diesels not so clean, apparently Haltech Automotive News 0 04-11-2015 01:10 PM
remove or paint orange reflector in headlight trioskater Appearance - SILVER 12 05-10-2011 11:50 PM
Page generated in 0.27545 seconds with 24 queries
