![]() Join Date: Feb 2018 Location: Burlington, NC
Rep Power: 0 ![]() Thanks: 1
![]() Join Date: Apr 2015
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score Pop off the speaker garnish and make sure the bolts are tight and check for any breaks or cracks that may make it loose. |
Groans: 211
| Not Ranked : 0 score My front wheel is loose/shaking. Would I have to rig something up behind it to fix it? Dude.....
| Replacement passenger side mirror | Paradidler | Mazdaspeed3/6 General Discussion | 5 | 11-08-2012 11:38 AM |
| CP-E Released driver-side/passenger-side Engine mounts for the GenPu | AZRushki | 2010 MS3 - Engine, Transmission & Driveline | 19 | 06-10-2011 09:48 AM |
