![]() Join Date: Mar 2012
Rep Power: 0 ![]() Thanks: 5
(Thread Starter) | Not Ranked : 0 score Thanks |
![]() Join Date: Nov 2016 Location: AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 549
Groans: 105
| Not Ranked : 0 score Buy new from Merzderr
__________________ Stockish |
![]() Join Date: Jun 2009
| Not Ranked : 0 score Doesn't anybody actually search anymore? There are multiple threads on this. Here is one I found in what . . . 30 seconds? Side skirt clips. Getting tired of doing searches for those too lazy to make even an attempt. This site is a goldmine, but shouldn't ask us to do the digging too. Geez, at least try. Might want to consider obtaining VIP membership so you can access the official Mazda service manual that will tell you the correct way to remove the skirt without breaking the remaining clips. And that manual will be very useful for a thousand other things. Not being a hard-ass. I am being frustrated at lack of effort, especially by someone who has been a member since 2012 and ought to know better.
| The Following User Says Thank You to MSMS3 For This Useful Post: | Db09ms3 (09-18-2019) |
![]() Join Date: May 2010 Location: SLC, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
__________________ 2009 MGM MS3 - / HTP 3"/ COBB AP, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, BSD, 51R Battery Box & Raider's AD / StopTech Brakes |
| Side skirt clips. | LowFlyin | Gen2 MS3 General Discussion | 11 | 11-08-2015 06:33 AM |
| Side skirt | levon.mark | Mazdaspeed3/6 General Discussion | 1 | 12-15-2013 08:57 PM |
| Mazdaspeed 3 2012 side skirt driver side | falconman17 | Gen2 MS3 General Discussion | 19 | 05-15-2013 08:02 AM |
