| Start Here This will all be renamed once we compile everything |
(Thread Starter) | For those of you who need to decode some abbreviations, i present you, this sticky.
For all the goddamned letters that people use on this site. If it is a CAI SRI, TBE, TB, CB, FPDE, CDFP, SMIC, TMIC, FMIC, ETS, KR, MP, TP, DP, MBC, BPV, BOV, MM, CAE, AS, SLS RP, STS car then the KR is too high, the EGTs are too high, the PSIs are too high, LTFTs are between 1-8, MV is above 4.9, and the AFRs are at like 14:1, according to my CP&E SB, COBB AP, DH that I bought from PG, SU, CS, TRZ, RPMC. I mean FUCK yall are about to give me a anuerism trying to read some of this shit. My frickin head is spinning. I don't know maybe I'm not JDM enough or something, maybe I'm too old. Sometimes I swear yall abbreviate some shit just so you could be the first to come up with a catchy abbreviation. So please can a Mod like sticky a glossary or some shit so I can understand what WTF I am reading. I mean OMG TSB. Yall are speaking borderline Mandarin Chinese. ![]() | |
| The Following User Says Thank You to Haltech For This Useful Post: | darkstar5440 (08-11-2013) |
![]() Join Date: Jul 2008 Location: The Ocean State
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 709
| Not Ranked : 0 score I think you missed a few. most of the abreviations will make sense if you decode them in the context of the message. If you really want to spearhead such an effort, go for it, if there are a few you find and cant define, im sure people would be happy to jump in and tell ya, but my guess is that 95% of the people on this site know them already and dont need said sticky. not trying to be a douche, just putting it out there that this isnt the starter site. you graduate to MSF once ya go through all the grade school shit over at 24/7 and m3f again, if you make a list, im sure people will help out, but I dont see it happening, I know i got better shit to do like drinking beer, farting, surfing porn, etc again, I, unlike a certain canadian, dont say any of the above to be a dick
__________________ 07 CB Speed3 COBB AP S2+, MS CAI (shorty w/ straightener), RPMC inlet, ETS 3.25", Devils Own S2 Alchy Injection, PG Manifold V2, TXS DP (with Cobb highflow cat soon), TXS mid, MS CBE, HKS Plugs (1 step colder), Fidanza Flywheel, KMD CDFP internals, COBB Sways, Koni Dual Adjustable Shocks, AWR 88 trans mount, Hawk HP+ pads (F+R), Motul RBF 600 brake fluid, 18x8 +50 weds sa70's 245/40 falken rt-615's, V1 hardwired, Autometer ES Gauges (boost/vac, water, oil pres), Dashhawk, stock turbo with modified boost control system |
| Thermonuclear Skeet ![]() Join Date: Jul 2008 Location: Triad N.C.
Rep Power: 3875 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,765
Groans: 188
Groaned at 333 Times in 222 Posts
![]() Join Date: Feb 2011 Location: Keuka Park, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 119
Groaned at 30 Times in 14 Posts
__________________ mroclimbr AEM CAI, OCC, Turbosmart BPV, CP-e turbo downpipe, JBR rsb, JBR 80 duro rmm, 3" CNT CBE, upgraded hpfp, Guardian Angel, JBR heavy knob, Cobb ap, currently stage two on 93 octane, blose speakers and amps all replaced and upgraded, dash daq, full replacement shifter, new ko4 compliments of Mazda at 48k miles. | |
| Not Ranked : 0 score loil 2f2f rosetta ftmfw
![]() Join Date: Aug 2008 Location: Red Deer, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,362
__________________ |
| Jackal ![]() Join Date: Jun 2008 Location: Los Angeles Westside
Rep Power: 3078 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,754
Groans: 56
Short Ram Intake Turbo Back Exhaust Coordinated Baseline Flame-Photometric Detector Electrometer Cam Driven Fuel Pump Sidemount Intercooler Top Mount Intercooler Front Mount Intercooler Electronic Torque Split Knock Retard Mid Pipe Test Pipe Down Pipe Manual Boost Control Bypass Valve Blow Off Valve Motor Mount Chinese Academy Of Engineering Anti-Surge Swing Lifestyle Race Pipe Short Throw Shifter Knock Retard Exhaust Gas Temperature Pounds per Square Inch Long Term Fuel Trims milli volts Air/Fuel Ratio CP-E Standback COBB Accessport Dashhawk Protege Garage Street Unit Corksport The Real Zoom Rad Parts Misc. Corporation For Unlawful Carnal Knowledge Japanese Domestic Market What the Fuck Oh My God Transportation Safety Board get educated and elevate yourself. cha ching. | |
![]() Join Date: Jan 2009 Location: Lehigh Acres, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 824
![]() BSD - balance shaft delete CBE - cat-back exhaust ECU - engine control unit EGR - Exhaust gas recirculation IMHO - In my honest opinion MF - magnaflow MM - Motor Mount OCC - Oil Catch Can RMM - rear motor mount RSB - Rear Sway Bar SPC BJ - Adjustable Ball Joints TBE - turbo-back exhaust TIP - Turbo Inlet Pipe TP - Test pipe (replaces 2nd Cat) WI kit - Water/Methanol Injection Kit 6i = 4 cylinder Mazda6 6S = V6 Mazda6 ABM/ Air Box Mod = The process of taking unwanted parts off the stock engine air box out to let the engine breath better AEM = Advanced Engine Management(Brand Name) AFAIK = As Far As I Know AJ = Mazda 6 with 3.0l V6 AR = After market Rims AT = Automatic Transmission ATX = Auto Trans axle Axle-back = Exhaust from rear axle AWD = All Wheel Drive BOV = A turbo engines blow off valve Bump = Brings post to top BPV = ByPass Valve BSD = Balance Shaft Delete BSF or B/S = Buy/Sell Forums BTW = By the way Cat back = An exhaust system that starts at the catalytic converter. CAI = Cold Air Intake CCC = Combustion Chamber Cleaner CEL = Check Engine Light CF = Carbon Fiber Cleansweep = A audio device made by JL Audio (Brand Name) DDE = Daylight Demon Eyes (Halos, Angel Eyes, etc) CD = Cross Drilled Rotors CP-E = Custom Performance Engineering(Brand Name) CRP = Commonly Reported Problem CSC = Centrifugal Supercharger CTS = Coolant Temp Sensor DIY = Do It Yourself DYI = Do Yourself Install ECU = Engine Control Unit EGR = Exhaust gas recirculation EMS = Engine Management System FMIC = Front Mount InterCooler FOB = The flip out key that your Mazda most likely uses FP = Fuel Power additive FS = For Sale FSM = Factory Service Manual FT = For Trade FTW = For The Win FWD = Front Wheel Drive GB = Group Buy GC = German Casterol(green 0w-30 engine oil) HID = High Intensity Discharge light HU = Head Unit IBTL = In Before The Lock I.C.E. = In Car Electronics/Entertainment IIRC = If I Recall Correctly IMO = In my opinion IRS = Independent rear suspension JDM = Japan Domestic Market JK = Joke or joking L3 = Mazda 6 with 2.3l I4 LED = Light-Emitting Diode LHD = Left Hand Drive LMAO = Laugh My Ass Off LOC = Line Output Converter LOL = Laugh Out Loud LSD = Limited Slip Differential MAF = Hot Wire Airflow Sensor MAFci = CP-e MAF Chip/CAI combo pack MF = MagnaFlow(Brand Name) MPI = Multiple port injection MPS = Mazda Performance Series MRI = Mazda Recall Information MS/MS6 = Mazdaspeed MT = Manual Transmition MTX = Manual Trans axle NA = North American NOS = Nitrous Oxide Systems(Brand Name) NSFW = Not safe for work NX = Nitrous eXpress(Brand Name) OEM = Original Equipment Manufacturer OP = Original Poster PCV = Positive crankcase ventilation PI = Performance increase PICS = Pictures PITA = Pain In The Ass PM = Personal Message PO = Previous owner POS = Piece of Sh*t PWNED = To be called out or simply made a fool of by another member of the board (owned). PVO = Performance Vehicle Operations RB = Racing Beat RHD = Right Hand Drive RMIC = Rear Mount Intercooler ROFL = Rolling on floor laughing RPM = Revolution Performance Manufacturing(Brand Name) RSB = Rear Sway bar R/T = Road/Track RTFM = Read the Freaking Manual!(Owners manual, FSM, or Instructions manual for part install) SC = Super Charged SMIC = Side Mount InterCooler SOL = S&@$ outta luck SOTP = Seat Of The Pants SR = Stock Rims SRI = Short Ram Intake SRT = Street and Racing technology STF = Search the forum STFU = Shut the f^ up STS = Short Throw Shifter SU = Streetunit.com TB = Throttle Body TBD = To be determined TC = Turbo Charged TCM = Transmission Control Unit TMIC = Top Mounted InterCooler TPS = Throttle Position Sensor Troll(ing) = A member that intentionally lurks around looking to act like an ass TSB = Technical Service Bulletin TT = Twin Turbo ttt = Brings post to the top (To The Top) TTUW0P = This Thread Useless Without Pics UCA/LCA = Upper control arm / Lower control arm UOA = Used Oil Analysis WTB = Wanted to buy WTF = What the F#@& WTT = Want to trade WOT = Wide open Throttle | |
![]() Join Date: Jun 2008 Location: Lynchburg, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
| Not Ranked : 0 score TSB=Technical Service Bulletin. |
Groans: 56
| Not Ranked : 0 score you need to read my post closer. |
| Not Ranked : 0 score ooo bronze star in the house!!! breakdown is da man! you forgot a new one that hal coined last night SAS I think the thread it was in got deleted, so maybe it never existed afterall...
Groans: 188
| Not Ranked : 0 score TSB=This shit blows FTMFW You get a fucking thank you Break Down |
![]() Join Date: Jun 2008 Location: Villa Park
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score In an aviation related forum that I check daily (airliners.net), there is a feature where all the airport and airline abbreviations such as KLAX, KPRC, KPHX, US, and CO are hot (or whatever you would call it) so that when you move your mouse over them, they the actual name will appear (ex. Los Angeles Int. for KLAX). That way, if you know the abbreviation, you're good, if you dont, then you just go over it with your mouse and it'll tell you... As an example, check this thread out: UA Flight JFK To Bangkok Civil Aviation Forum | Airliners.net This feature may come exceptionally handy with all of our growing abbreviations.. Funky |
Groans: 188
![]() Join Date: Jul 2010 Location: Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
Groaned at 5 Times in 2 Posts
| Not Ranked : 0 score me to man...
__________________ 2010 Mazdaspeed 3 |
![]() Join Date: Jul 2008 Location: Edgewater, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
![]() Join Date: Sep 2011 Location: New York City
Rep Power: 916 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 442
Groans: 93
Groaned at 27 Times in 16 Posts
| Not Ranked : 0 score Are you a poster on a.net? I've been there for years (same username). In addition to an abbreviations guide, a glossary in general may be super useful. I've seen one of sorts floating around here, but there are still some terms I can't get my head around and Google hasn't proven helpful since they're things specific to Mazda or this forum sometimes. TIS
__________________ TOTS 2012 Mazdaspeed3, CWP, Tech Package. COBB AccessPort V3, AUTOTECH HPFP Internals, JBR 3" Wide-path SRI+TIP, CP-E TMIC, UR 3" Test Pipe, CP-E Triton CBE, FORGE V2 BPV, DENSO ITV22 Plugs, JBR RMM 88a, JBR OCC, JBR RSB Kit, JBR Solid Shifter Bushings, CP-E Tow Plate, CorkSport ECU Relocation, TSW Nurburgring Bronze 18x7.5 ![]() alphasaur: "Fuck I just beat it to surprise tranny porn. Saw the dick right when I came fml" |
![]() Join Date: Mar 2008 Location: 203
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 43
| Not Ranked : 0 score lol f&f ftmfw
__________________ MAZDAMAN13 - 2.221, 9.378 @ 78.89, 14.309 @ 99.72 (CBE) no power-shifting DON'T SLEEP ON THE MAZDA...:phillyb: JDM PARKING LOL |
![]() Join Date: May 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,642
Groans: 78
Groaned at 48 Times in 31 Posts
| Not Ranked : 0 score LMFAO FTMFR
__________________ In reality I love lenny |
Groans: 188
__________________ El Fantasmo Del Negro Helicopter Cat LIVES ![]() |
Groans: 188
| Not Ranked : 0 score I'm going to start posting people's sig mods in here to get them translated.
![]() Join Date: Oct 2008 Location: Houston,Tx
Rep Power: 429 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
Groaned at 16 Times in 14 Posts
| Not Ranked : 0 score Well to put a light on this BS i had a chick, in a store, who was helping me the other day actually looked at me and said "o"-"m"-"g" after I asked her a question she didnt know ... she freakin said the txt language ... rEtArDeD .... nice rack and ass though so I gave her a pass .. just wait .. that shit is coming on a permanent basis .... |
![]() Join Date: Nov 2008 Location: Roanoke, Va
Rep Power: 0 ![]() Thanks: 26
| Not Ranked : 0 score ok, being a total dweeb, what the heck do FTM and FTMFW stand for? |
![]() | | #24 | ![]() |
![]() Join Date: Mar 2008 Location: Navarre, FL
Rep Power: 4956 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,585
Groans: 370
| Not Ranked : 0 score FTW = for the win FTMFW = for the mother fuckin win |
![]() | | #25 | ![]() |
Groans: 188
| Not Ranked : 0 score I may start a new thread called the mod to complaint to Mazda timeline. How long does a modification take to cause a complaint and that complaint ultimately being blamed on Mazda. Something like this; Week 1
Week 2
__________________ El Fantasmo Del Negro Helicopter Cat LIVES ![]() | ||||
![]() | | #26 | ![]() |
![]() Join Date: Sep 2008 Location: Lynchburg, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,559
| Not Ranked : 0 score are those real or did you make them up?
__________________ 09 MGM MS3 BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s |
![]() | | #27 | ![]() |
Groans: 188
| Not Ranked : 0 score We will even have a little fancy abbreviation of MCMP (Mod to Complaint to Mazda Period) the above example will have a MCMP of three weeks.
![]() | | #28 | ![]() |
Groans: 188
| Not Ranked : 0 score Made them up. Funny thing is you had to ask, probably because it happens so much.
![]() | | #29 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 908
| Not Ranked : 0 score again..another hilarious thread or AHT... |
![]() | | #30 | ![]() |
Groans: 188
| Not Ranked : 0 score QTF? Need translation please
![]() | | #31 | ![]() |
| Not Ranked : 0 score QFT=quoted for truth |
![]() | | #32 | ![]() |
![]() Join Date: May 2008 Location: Long Island, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score |
![]() | | #33 | ![]() |
| Not Ranked : 0 score Well, you get the same meaning both ways... so sure, why not. |
![]() | | #34 | ![]() |
![]() Join Date: May 2008 Location: Lehigh Valley, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 376
| Not Ranked : 0 score really?? I always thought it meant "Quit Fucking Talking"... always been wondering why nobody blows their stack when somebody tells them QFT |
![]() | | #35 | ![]() |
![]() Join Date: Aug 2008 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 60
| Not Ranked : 0 score This thread delivers. WTF OMG! |
![]() | | #36 | ![]() |
| Not Ranked : 0 score Figured this might help. found it on google.....wow that was vague of me lol BSD - balance shaft delete CBE - cat-back exhaust ECU - engine control unit EGR - Exhaust gas recirculation IMHO - In my honest opinion MF - magnaflow MM - Motor Mount OCC - Oil Catch Can RMM - rear motor mount RSB - Rear Sway Bar SPC BJ - Adjustable Ball Joints TBE - turbo-back exhaust TIP - Turbo Inlet Pipe TP - Test pipe (replaces 2nd Cat) WI kit - Water/Methanol Injection Kit 6i = 4 cylinder Mazda6 6S = V6 Mazda6 ABM/ Air Box Mod = The process of taking unwanted parts off the stock engine air box out to let the engine breath better AEM = Advanced Engine Management(Brand Name) AFAIK = As Far As I Know AJ = Mazda 6 with 3.0l V6 AR = After market Rims AT = Automatic Transmission ATX = Auto Trans axle Axle-back = Exhaust from rear axle AWD = All Wheel Drive BOV = A turbo engines blow off valve Bump = Brings post to top BPV = ByPass Valve BSD = Balance Shaft Delete BSF or B/S = Buy/Sell Forums BTW = By the way Cat back = An exhaust system that starts at the catalytic converter. CAI = Cold Air Intake CCC = Combustion Chamber Cleaner CEL = Check Engine Light CF = Carbon Fiber Cleansweep = A audio device made by JL Audio (Brand Name) DDE = Daylight Demon Eyes (Halos, Angel Eyes, etc) CD = Cross Drilled Rotors CP-E = Custom Performance Engineering(Brand Name) CRP = Commonly Reported Problem CSC = Centrifugal Supercharger CTS = Coolant Temp Sensor DIY = Do It Yourself DYI = Do Yourself Install ECU = Engine Control Unit EGR = Exhaust gas recirculation EMS = Engine Management System FMIC = Front Mount InterCooler FOB = The flip out key that your Mazda most likely uses FP = Fuel Power additive FS = For Sale FSM = Factory Service Manual FT = For Trade FTW = For The Win FWD = Front Wheel Drive GB = Group Buy GC = German Casterol(green 0w-30 engine oil) HID = High Intensity Discharge light HU = Head Unit IBTL = In Before The Lock I.C.E. = In Car Electronics/Entertainment IIRC = If I Recall Correctly IMO = In my opinion IRS = Independent rear suspension JDM = Japan Domestic Market JK = Joke or joking L3 = Mazda 6 with 2.3l I4 LED = Light-Emitting Diode LHD = Left Hand Drive LMAO = Laugh My Ass Off LOC = Line Output Converter LOL = Laugh Out Loud LSD = Limited Slip Differential MAF = Hot Wire Airflow Sensor MAFci = CP-e MAF Chip/CAI combo pack MF = MagnaFlow(Brand Name) MPI = Multiple port injection MPS = Mazda Performance Series MRI = Mazda Recall Information MS/MS6 = Mazdaspeed MT = Manual Transmition MTX = Manual Trans axle NA = North American NOS = Nitrous Oxide Systems(Brand Name) NSFW = Not safe for work NX = Nitrous eXpress(Brand Name) OEM = Original Equipment Manufacturer OP = Original Poster PCV = Positive crankcase ventilation PI = Performance increase PICS = Pictures PITA = Pain In The Ass PM = Personal Message PO = Previous owner POS = Piece of Sh*t PWNED = To be called out or simply made a fool of by another member of the board (owned). PVO = Performance Vehicle Operations RB = Racing Beat RHD = Right Hand Drive RMIC = Rear Mount Intercooler ROFL = Rolling on floor laughing RPM = Revolution Performance Manufacturing(Brand Name) RSB = Rear Sway bar R/T = Road/Track RTFM = Read the Freaking Manual!(Owners manual, FSM, or Instructions manual for part install) SC = Super Charged SMIC = Side Mount InterCooler SOL = S&@$ outta luck SOTP = Seat Of The Pants SR = Stock Rims SRI = Short Ram Intake SRT = Street and Racing technology STF = Search the forum STFU = Shut the f^ up STS = Short Throw Shifter SU = Streetunit.com TB = Throttle Body TBD = To be determined TC = Turbo Charged TCM = Transmission Control Unit TMIC = Top Mounted InterCooler TPS = Throttle Position Sensor Troll(ing) = A member that intentionally lurks around looking to act like an ass TSB = Technical Service Bulletin TT = Twin Turbo ttt = Brings post to the top (To The Top) TTUW0P = This Thread Useless Without Pics UCA/LCA = Upper control arm / Lower control arm UOA = Used Oil Analysis WTB = Wanted to buy WTF = What the F#@& WTT = Want to trade WOT = Wide open Throttle |
![]() | | #37 | ![]() |
Groans: 56
| Not Ranked : 0 score you have too much good information in yours. |
![]() | | #38 | ![]() |
![]() Join Date: Apr 2009 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 607
Groans: 36
![]() | | #39 | ![]() |
Groans: 188
| Not Ranked : 0 score No he hasn't. He has saved me from sinking aboard the US Failboat Constipation. I am now enlightened. This is still not over though, this is still the internet and we still drive a sub 30K four banger turbo car. Our people will come up with something new to befuddle me in the near future I garuantee it.
![]() | | #40 | ![]() |
ROFL ::high-five:: | |
| how to decode vin? | burntmushu | Mazdaspeed3/6 General Discussion | 5 | 12-13-2013 05:02 PM |
| Back to School: Learning the ZR1 at the Ron Fellows Performance Driving School | Haltech | Automotive News | 0 | 05-02-2011 10:20 AM |
| 25 School districts now offering Autonet Wifi on school buses | Haltech | Automotive News | 0 | 05-18-2010 05:10 PM |
| G45 has HD decode problems | Haltech | Computers & Technology News | 0 | 04-16-2008 10:50 AM |
