| Approved MSF Vendor ![]() Join Date: Jun 2012
Rep Power: 178 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 128
(Thread Starter) | Not Ranked : 0 score Rotary Forged Flow Forming is a production procedure that turns the wheel (or rim section) over a special mandrel and three hydraulic rollers using tremendous pressure. The pressure and turning then force the rim area to form against the mandrel, creating the shape and width of the rim. During Flow Forming, the rim actually "flows" down to create the full rim width. During Flow Forming, pressure applied to the cast rim actually changes its mechanical properties, so its strength and impact values become similar to those of a forged rim. That translates to up to 15% less weight when compared to a standard cast wheel. Our technological breakthroughs in heat treating allow us to increase dent resistance without having to make the wheel heavier. Forgestar Performance Wheels proprietary Rotary Forged Flow Forming technology allows the customers to choose between a range of offsets for every wheel width that is offered. The end consumer is able to choose a wheel that will perfectly fit their own individual vehicle. - Rotary Forged Flow Formed Barrel - Lightweight - Clears big brake kit - Great range of offsets - Same Technology Used on Formula 1 and Indy Cars SEMI CONCAVE 18" 18×8.5 offsets from +10 to +50 18×9.0 offsets from +16 to +56 18×9.5 offsets from +22 to +62 19" 19x8.5 offsets from +10 to +50 19x9.0 offsets from +16 to +44 20" 20×8.5 offsets from +10 to +50 20×9.0 offsets from +16 to +56 20×10 offsets from +29 to +69 20×11 offsets from +42 to +82 DEEP CONCAVE 18" 18×10 offsets from +10 to +50 18×11 offsets from +23 to +63 18×12 offsets from +36 to +75 19" 19x9.5 offsets from +10 to +50 19x10 offsets from +16 to +56 19x11 offsets from +29 to +69 19x12 offsets from +42 to +82 20" 20×9.5 offsets from +2 to +42 20×10.5 offsets from +15 to +55 20×12 offsets from +34 to +74 - Rotary Forged Flow Formed Barrel - Lightweight - Clears big brake kit - Great range of offsets - Same Technology Used on Formula 1 and Indy Cars SEMI CONCAVE 19" 19x8.5 offsets from +14 to +52 19x9.0 offsets from +20 to +60 20" 20×8.5 offsets from +10 to +50 20×9.0 offsets from +16 to +56 DEEP CONCAVE 19" 19x9.5 offsets from +2 to +42 19x10 offsets from +8 to +48 19x11 offsets from +21 to +61 19x12 offsets from +34 to +74 20" 20×10 offsets from +15 to +55 20×11 offsets from +27 to +67 20×12 offsets from +40 to +80 - Rotary Forged Flow Formed Barrel - Lightweight - Clears big brake kit - Great range of offsets - Same Technology Used on Formula 1 and Indy Cars SEMI CONCAVE 18" 18×8.5 offsets from +26 to +50 18×9.0 offsets from +20 to +55 18×9.5 offsets from +26 to +60 19" 19x8.5 offsets from +26 to +48 19x9.0 offsets from +20 to +55 20" 20×8.5 offsets from +26 to +50 20×9.0 offsets from +18 to +56 20×10 offsets from +31 to +69 20×11 offsets from +48 to +81 22" 22x8.5 offsets from +12 to +51 22x9.0 offsets from +18 to +57 22x10 offsets from +31 to 70 DEEP CONCAVE 18" 18×10 offsets from +16 to +42 18×11 offsets from +23 to +55 18×12 offsets from +36 to +68 19" 19x9.5 offsets from +4 to +42 19x10 offsets from +20 to +44 19x11 offsets from +23 to +55 19x12 offsets from +36 to +68 20" 20×9.5 offsets from +7 to +43 20×10.5 offsets from +20 to +55 20×12 offsets from +39 to +75 22" 22x10.5 offsets from +10 to +49 22x12 offsets from +29 to +68
__________________ Sonic Tuning 18938 Bonanza Way Gaithersburg, MD 20879 Proudly Serving the NATOR DC Community! www.sonictuning.com We are an authorized COBB Dealer and carry HUNDREDS of other brands for your MAZDASPEED We also make our own Coilovers for the MS3/6 along with HID kits and Wheels |
![]() Join Date: Jun 2009 Location: Old Bridge, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,044
Groans: 125
| Not Ranked : 0 score how much do they weigh? |
| The Following User Says Thank You to TWOptSL0W For This Useful Post: | Downmented (08-11-2012) |
(Thread Starter) | Not Ranked : 0 score Approx F14 Weight 18×8.5 +48 17.6 lbs or in metric 7.98kg 18×9.5 +48 19.4 lbs or in metric 8.80kg 18×10 +42 19.2 lbs or in metric 8.70kg 18×12 +68 20.0 lbs or in metric 9.07kg
| The Following User Says Thank You to sonic tuning For This Useful Post: | MonstaSpeed6 (08-13-2012) |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
| Not Ranked : 0 score WTB some 17"
__________________ |
(Thread Starter) | Not Ranked : 0 score If there are alot of interest in 17", we can suggest Forgestar to produce them. All PMs replied!
![]() Join Date: Jan 2010 Location: charles co, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,295
| Not Ranked : 0 score How much $$ for the CF5 and also how much do they weight in a 19x9.5.. Any pics on a car?
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport |
(Thread Starter) | Not Ranked : 0 score You have PM.
| Display Modes | |
| Forgestar F-14's | Baloo | MazdaSpeed 3/6 - Wheels & Tires | 13 | 06-10-2012 01:35 PM |
| New light weight rims,pilot super sports, and a new 60-100 log | dturboman | Mazdaspeed3/6 General Discussion | 4 | 02-25-2012 07:02 PM |
| Light weight flywheel with several staged clutch options? | ptperformance | Mazdaspeed3/6 General Discussion | 97 | 04-10-2009 01:36 PM |
