| Approved MSF Vendor ![]() Join Date: Jun 2012
Rep Power: 178 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 128
(Thread Starter) | Not Ranked : 0 score What's included: Brand new Cobb AccessPORT for your Mazda. Custom RichTune for your Mazda The AccessPORT is the industry leading OEM ECU flashing, managing and monitoring assistant. Unlock power hidden within the ECU by replacing conservative factory settings with more aggressive calibrations. The result is impressive gains in torque and horsepower while maintaining a high degree of safety. The AccessPORT comes with pre-installed maps that are optimized for common performance modifications. Click here for Cobb AccessPORT Functions Results from RichTune Owner: Timothy aka Shadow Car: 2011 Mazdaspeed 3 Fully Bolted Stock Turbo 93 Octane Pre-Tuning Understand that if we start tuning your car with an existing problem it could cost you more in the end. Make sure your car is running good ie: no boost leaks, fresh oil, no coolant leaks, etc. We recommend you do a boost leak test, check your spark plug gapping (make sure they are all properly gapped). If you haven’t already I’d suggest buying a set of Denso ITV22 spark plugs. These plugs are 1 step colder which is needed for cars making over 300 hp. They are easy to find online but difficult to find at your local auto store. Boost leak testing is easy if you have an air compressor. It is extremely important that your car is free of boost leaks because it will allow unmonitored air in/out of the system. The 2.3 MZR is MAF dependent so any air not being seen by the MAF will not be seen by the ECU. This can cause a lean AFR condition and may result in detonation. Also be sure to clean your MAF sensor every 5-10k miles. If you don’t already have an upgraded fuel pump you will need one. GB Details: We need 5 people to get this group buy started. It will be $699 including the custom tune with Cobb AccessPORT shipped to your door. Once we get to 10+, there would be $20 discount applied to the GB. We are an authorized Cobb dealer, you will receive the same warranty and tech support as you would buying direct.
__________________ Sonic Tuning 18938 Bonanza Way Gaithersburg, MD 20879 Proudly Serving the NATOR DC Community! www.sonictuning.com We are an authorized COBB Dealer and carry HUNDREDS of other brands for your MAZDASPEED We also make our own Coilovers for the MS3/6 along with HID kits and Wheels Last edited by sonic tuning; 10-22-2012 at 04:26 PM. |
| The Following 9 Users Say Thank You to sonic tuning For This Useful Post: | alphasaur (12-04-2012), Caligula (03-29-2013), CWP_MS3 (11-13-2012), dantes5823 (10-25-2012), jack_hammer (01-17-2013), Menace1 (03-29-2013), RichieRichness (10-25-2012), surebOOst (10-27-2012), Vader (10-26-2012) |
![]() Join Date: Mar 2012 Location: Toronto,Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,065
| Not Ranked : 0 score This is genius.
__________________ 2007 Mazdaspeed 6 Black Mica Richtuned ~Some things have been bolted on~ [SIGPIC][/SIGPIC] |
| The Following 2 Users Say Thank You to johnredding For This Useful Post: | RichieRichness (10-25-2012), sonic tuning (10-22-2012) |
![]() Join Date: Feb 2012 Location: Gibsonville, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
| Not Ranked : 0 score Wish you had of done this 2 weeks ago. GREAT MARKETING!
__________________ [SIGPIC] [/SIGPIC] 2012 Black Mica W/Tech Cobb AP AutoTech Internals JBR 88DM RMMJBR Heavy Knob JBR 3" WP JBR Rear camber arms UR TP Ford MOFO Tranny juice Rotella T6 Self Tune - (Work in Process) NGK Step 1 colder 5/7 corn fed |
| The Following User Says Thank You to Printman For This Useful Post: | sonic tuning (10-22-2012) |
(Thread Starter) | Not Ranked : 0 score Thanks guys, spread the word!
__________________ Sonic Tuning 18938 Bonanza Way Gaithersburg, MD 20879 Proudly Serving the NATOR DC Community! www.sonictuning.com We are an authorized COBB Dealer and carry HUNDREDS of other brands for your MAZDASPEED We also make our own Coilovers for the MS3/6 along with HID kits and Wheels |
| Not Ranked : 0 score lets get this going!!!!!! this is a KILLER deal
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | RichieRichness (10-25-2012), sonic tuning (10-23-2012) |
![]() Join Date: Feb 2012 Location: Quantico, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,434
| Not Ranked : 0 score That is a great deal! Get up on this...Richtune FTW!
__________________ [SIGPIC][/SIGPIC] 2013 Scion FR-S (Whiteout) GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_Nameless Race Pipe_RBF600_Ferodo DS2500_PTUNING Tuned Less parking more racing |
| The Following 2 Users Say Thank You to leon78 For This Useful Post: | RichieRichness (10-25-2012), sonic tuning (10-23-2012) |
![]() Join Date: Mar 2010 Location: Manassas, VA
Rep Power: 2313 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,791
Groans: 35
| Not Ranked : 0 score Lets go people...can't beat this deal anywhere!
__________________ CP-e Atmosphere GTX3076r w1.06 Tial | JMF IM | NATOR D.C. FMIC | JBR Wide Path | Autotech Internals | HKS SSQV2 | Ebay DP | Denso ITV24 | CP-e RDM | AutoExe Strut Tower Bar | Whiteline RSB | Sonic Tuning Coils | DSS Driver Side Axle | JMF OCC BT - 395 awhp 345 awtq @ Moore Automotive 4/12/2014 on 93 octane Stock Turbo - 331 awhp 397 awtq @ Moore Automotive 11/10/2012 on ~e48 12.263 @ 111.75 mph 1.669 60' 11/17/2012 |
| The Following User Says Thank You to RichieRichness For This Useful Post: | dantes5823 (10-25-2012) |
| Banned ![]() Join Date: Aug 2011 Location: Springfield/Union NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,560
Groaned at 52 Times in 48 Posts
| Not Ranked : 0 score Boom! Let's do this! |
| Not Ranked : 0 score Any bites? bump
| The Following User Says Thank You to leon78 For This Useful Post: | sonic tuning (10-30-2012) |
| Not Ranked : 0 score Bump |
![]() Join Date: Feb 2011 Location: Princeton, WV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,469
Groaned at 61 Times in 40 Posts
| Not Ranked : 0 score Free Bump for good tuning combo!
__________________ 2006 Evolution IX RS ER Built 2.3l On jackstands awaiting parts |
| The Following 2 Users Say Thank You to surebOOst For This Useful Post: | RichieRichness (11-10-2012), sonic tuning (11-23-2012) |
![]() Join Date: Mar 2012 Location: New Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 222
| Not Ranked : 0 score Great tune worth every cent. I got a 2012 ms3 btw ![]() Sent from my ADR6400L using Tapatalk 2
__________________ 2012 Black Mica MS3 w tech Cobb AP, CS SRI, CS TIP, Catless DP/TP, Autotech Internals, NGK Plugs 1 colder, Magnaflow CBE, HKS V2 BOV Recirc, ETS TMIC, CS SSP, CS RMM Inserts, CS RSB, CS Springs, Hankook ventus z214 c71 225/45r17 r comp tires for autocross, Stock doneflops for everything else |
| The Following 3 Users Say Thank You to Shadow For This Useful Post: |
| Not Ranked : 0 score BUMP! |
| The Following User Says Thank You to dantes5823 For This Useful Post: | sonic tuning (11-23-2012) |
![]() Join Date: May 2011 Location: Ft. Worth TEXAS
| Not Ranked : 0 score If i could go back, ap and a tune would be the FIRST mod I would do.
__________________ 07Speed3 TWM STS || Forge BPVv1 || Sure RMM || Cobb SRI || CNT DP || AP || Autotech || ITV22 || COBB/TR8L FMIC || JBR TB&IM TIG || HTP TIP || JBR PMM&TMM || JBR EGR DELETE || Cobb CBE || SONIC COs || Perm Plate & OCC || JBR OCC || PnP IM || DO Meth Inj. || |
| The Following User Says Thank You to radbrad For This Useful Post: | RichieRichness (11-21-2012) |
![]() Join Date: Sep 2012
| Not Ranked : 0 score I ran into a guy on 495N a few daysa ago. Black MS3. Dropped with black rims. Told him I loved the stance of the car. A couple questions about the tune... I'm new to this thing so pardon the ignorance but what does the AP and tune entail cuz really, after seeing that Black MS3, I WANT IN!! BTW, 2009 bonestock Metro Gry MS3 Last edited by Bantug; 11-23-2012 at 10:44 AM. Reason: info about my car |
| The Following 2 Users Say Thank You to Bantug For This Useful Post: | playero02 (03-19-2016), RichieRichness (11-24-2012) |
![]() Join Date: Apr 2009 Location: Somerset NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,706
| Not Ranked : 0 score Damn I wish I was ready. Sweet combo here
__________________ ~~~NJ Nator OG~~~Then AND Now, Just Better~~~ ![]() |
| The Following User Says Thank You to Kdawg207 For This Useful Post: | sonic tuning (12-03-2012) |
(Thread Starter) | Not Ranked : 0 score Thanks for the support guys!
![]() Join Date: Jan 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score nice!! |
| The Following User Says Thank You to BoominChu For This Useful Post: | sonic tuning (04-01-2013) |
| 5000lbs of voiceless fury ![]() Join Date: May 2012 Location: San Diego, CA
Rep Power: 2530 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,855
Groans: 185
Groaned at 124 Times in 81 Posts
| Not Ranked : 0 score Brilliant idea!
__________________ 2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN! SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs// |
| The Following 3 Users Say Thank You to Caligula For This Useful Post: |
![]() Join Date: Jul 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
Groaned at 4 Times in 1 Post
| Not Ranked : 0 score I know I am late but is this still going on? |
| The Following User Says Thank You to 07mica_blk For This Useful Post: | sonic tuning (07-15-2013) |
Groans: 35
| Not Ranked : 0 score I believe so. Sent from my iPhone using RichieTalk
| Not Ranked : 0 score The 699 price is only for the group buy right?
__________________ CP-E CBE, Injen CAI, HKS BOV, Alpine 1100watt Amp, 10in Rockford Fosgate T1, |
![]() | | #24 | ![]() |
Groans: 35
| Not Ranked : 0 score Just send a PM to Sonic Tuning Sent from my iPhone using RichieTalk
![]() | | #25 | ![]() |
