![]() | | #41 | ![]() |
![]() Join Date: Sep 2011
Rep Power: 0 ![]() Thanks: 3
| Not Ranked : 0 score Thanks!
__________________ 2007 Mazdaspeed6 GT Titanium #8889 FUN STUFF: COBB AP | MS CAI | PG TIP | CPE TMIC| TurboSmart BPV |AWR RMM |SURE Anchors | SURE Counter Shift | TWM Short shift stage 1| SURE Charge Tubes| SURE Shortcut | Magnaflow cat back | test pipe | H&R Springs COOL STUFF: MP3 integration with Bluetooth | 20% tint | ENKIE 18X8 EKM3's hyper silver | Leather Shift boot | LED Interior and running lights | Sharkfin | The COBB Knob (The name alone sold it LOL). |
![]() | | #42 | ![]() |
they can retain the stock ride height.
the diameter of the perch is 62mm and the spring is 110mm in diameter we are looking into including these for the next batch we sell.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | ||||
| The Following 4 Users Say Thank You to superskaterxes For This Useful Post: |
![]() | | #43 | ![]() |
![]() Join Date: Feb 2011 Location: Vaughan, Ontario, Canada
Rep Power: 1135 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 977
| Not Ranked : 0 score I'm not sure how to ask this, so the ID on the rear spring on the small side is what? I really want to know if I can use a 2.5"ID race spring with that perch.
__________________ Fueled by the haters. |
![]() | | #44 | ![]() |
| Not Ranked : 0 score yes the ID of the spring on the small side is 62mm
![]() | | #45 | ![]() |
| Not Ranked : 0 score Ditto sent you a PM.
![]() | | #46 | ![]() |
![]() Join Date: Dec 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,777
Groans: 47
Groaned at 21 Times in 9 Posts
| Not Ranked : 0 score So in this gb there's no S1 for the MS3? I don't wanna cut holes either. Are the benefits really worth getting the camber plates?
__________________ 2010 Black Mica Mazdaspeed3 MODS in chronological order of installtion AEM CAI, JBR SSP Stage 2, JBR Heavy Shift Knob, JBR 80 Duro Billet Rear Motor Mount, CP-E NVISCID Turbo Inlet Pipe. & COBB AP Debating on Rear Sway Bars, Springs, or internals next... |
![]() | | #47 | ![]() |
there are no S1's in this GB because we diddent feel it was worth it. you dont have to use the camber plates if you dont want to but its nice to have the adjustment if u need it. you could always just drop the coilover down a little to adjust camber as well its just more of a PITA.
| The Following User Says Thank You to superskaterxes For This Useful Post: | WAHBAM (02-09-2013) |
![]() | | #48 | ![]() |
![]() Join Date: Dec 2008 Location: Toledo OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 324
| Not Ranked : 0 score What was the purpose of the block of wood when using the hole saw in that picture? Sent from my Galaxy Nexus using Tapatalk 2
__________________ | CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers |Fluids Rotella T6 A lot Rislone Engine Treatment Motorcraft XT-M5-QS(trans) VP Methanol ~Splash of E85~ |
![]() | | #49 | ![]() |
![]() Join Date: Feb 2011 Location: Goldsboro, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34,434
| Not Ranked : 0 score Cool. Thanks.
__________________ 2009 CWP MS3 GT Rally Armor Flaps | Gen Pu Wheels | JBR 80d v1 RMM/RSB/TIGs/Boost & Bypass Tubes TWM Full Replacement Shifter | CS SRI/TIP/Skid Plate | Koni FSD 4045 | Matt Damon OCC | Cobb DP/AP | CP-e TMIC/HPFP PTP VVT Actuator/Injector Seals & Studs | Samco Rad Hoses | Redline Leather Shift & E-Brake Boot BNR S3 | Stratified Boost Dial |
![]() | | #50 | ![]() |
![]() Join Date: Oct 2009 Location: Andersen AFB, Guam
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Not Ranked : 0 score Interested but won't have the money til tax return check comes in! How Lon this going on for?
__________________ RichTuned Ultimate Racing DP V2 flange\35W 6000k DDM HID's\HKS SSQV3 VTA\GTX2867R\Tanabe STB\HTP 3.5" intake\PTP HPFP\UR FMIC\Ultimate Racing turbo-back exhaust\JBR RSB\JBR 80Duro Trilogy mounts\Cobb AP v3\Stage 2\22.5PSI \Sonic Tuning Coilovers\TWM full replacement shifter and SSP\PnP Intake Manifold/CP-e EWG Exhaust Manifold/Tial 44mm EWG 11/10/2012 NATOR DC DYNO day 304Whp/356 FT lbs Tqe Uncorrected 4/13/2013 Mega NATOR Meat Dyno Day 300WHP/ 344ft lbs/wtqe Corrected |
![]() | | #51 | ![]() |
till they sell out!!!
![]() | | #52 | ![]() |
| Not Ranked : 0 score K. Hopefully the ms3 s3 kits are still available when I get my money. I think I am gonna replace my HKS suspension instead of getting a Pablo motor.
| The Following User Says Thank You to BlueDmnSpeed For This Useful Post: | superskaterxes (02-08-2013) |
![]() | | #53 | ![]() |
![]() Join Date: Nov 2011 Location: Naples, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 68
| Not Ranked : 0 score Are the adjustments on the dampers changing rebound only, or compression and rebound at the same time?
__________________ - 2012 MS3 - CS- SRI & TIP - Autotechs - AP v3 - Denso Iridiums - CP-E S2 RMM/TMIC/Catted-DP - 17x9 +45 RPF-1 - 245/40-17 Michelin PSS - Koni Yellows - Whiteline RSB - - 2011 CX-7 - Soccer mom machine. |
![]() | | #54 | ![]() |
| Not Ranked : 0 score both compression and rebound at the same time
| The Following User Says Thank You to superskaterxes For This Useful Post: | xpystchrisx (02-08-2013) |
![]() | | #55 | ![]() |
![]() Join Date: Nov 2012 Location: New Haven, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 232
| Not Ranked : 0 score Hmmm.. I was leaning towards corksports... I may go this route..... My bnr build may just have to wait.. I like
__________________ 09 MS3: Cobb AP; Autotech HPFP; HTP 3" Intake; CP-E TMIC; GFB Respons; NGK Iridium IX; M2 Catless DP; TurboXS cbe; JBR 88a; JBR SSP; Ralco RZ STS; Aeroforce Interceptor; Defi Red Racer; Racelands v2(until I have issues); SPC camber arms; 18x8.75 +35; 215/40/18; Freek Tune; 50/50 Corn |
| The Following User Says Thank You to NICKELL666 For This Useful Post: | superskaterxes (02-09-2013) |
![]() | | #56 | ![]() |
![]() Join Date: May 2009 Location: San Antonio, TEXAS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 416
| Not Ranked : 0 score Damn, I wish I had the corn for these. Beautiful parts. Is there a chance of these coming around again?
__________________ 2008 Cosmic Blue Mica ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ |
![]() | | #57 | ![]() |
![]() Join Date: Mar 2010 Location: New Eagle, PA
Rep Power: 2281 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,142
Groans: 324
| Not Ranked : 0 score Any spring / damper dynos? |
![]() | | #58 | ![]() |
we do have a dyno but the entire sheet is in japanese because it was done by our engineers overseas.l it also only includes 1 or 2 damper settings so we requested they send us a new one with multiple damper settings over the whole range.
![]() | | #59 | ![]() |
Groans: 47
| Not Ranked : 0 score What are your opinions on combining the S3 with swift springs? I want these to be the first & last coilovers I buy for my genpu.
![]() | | #60 | ![]() |
![]() Join Date: Jan 2010 Location: Denver, Colorado
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 174
| Not Ranked : 0 score Very nice. My stock shits blown at 80k amazingly, and I'm in dire need of some coil-overs.....will order tomorrow if still available......
__________________ Mile High. Silver genwon MS3. BNR S3, HTP 3" intake, 3 bar MAP with bit-wise harness, Grimmspeed 3 port ebc, AP with e-85 self tune, Autotech internals, CX racing FMIC, ST coilovers, gutted test, res deletes, turbo XS BPV, TRZ RMM, Jbarone SSP, Jbarone PMM, Moddiction anvil SK, Ultragauge, e-bay oil CC, some ebay drilled rotors, 10k hid kit, washered stock SS, 5MM spacers, Enkei Imola, and other shit i'm forgetting... Daily driver- Piece of shit 1998 Chevrolet S-10 LS. |
![]() | | #61 | ![]() |
we def have some left in stock!!! just give us a call. the number is in the OP.
![]() | | #62 | ![]() |
![]() Join Date: Jul 2010 Location: Riverside,CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 917
| Not Ranked : 0 score Sorry guys I'm gonna have to back out at the moment... ![]() Sent using my EVO LTE on tappy
__________________ [SIGPIC][/SIGPIC] 2008.5 CWP Speed3 GT - SOLD / ![]() 1991 Ford Mustang LX 5.0 SSP 331 Stroker 9:1 compression - AFR 185 Heads ported to 205 specs - 1.6 Roller Rockers - Comp Turbo Cam - Edelbrock RPM Performer II Upper and Lower intake mani - 24# injectors - 70mm throttle body and EGR spacer - C&L Intake - BBK Headers - MSD Billet Distributor - MSD Coil - Ford Racing Wires - MSD Ignition - A/C delete - Built 3 spd With reverse manual valve body - B&M Shifter - Aluminum driveshaft - 3.55 gears - Moser 31 spline Axles - Nitrous Express 125 shot - 5 lug conversion With SN95 Brakes |
![]() | | #63 | ![]() |
| Not Ranked : 0 score I'm still dead serious about ordering these just so you know. I'll put a deposit down until next Friday when I have the scrap for them of necessary. Sent from my Galaxy Nexus using Tapatalk 2
![]() | | #64 | ![]() |
| Not Ranked : 0 score Hope some are left in a week or so!
![]() | | #65 | ![]() |
| Raider's Homie ![]() Join Date: Jul 2012 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 67
| Not Ranked : 0 score I will definitely be getting these closer to the end of this GB, haven't found a negative review on these yet, keep up the great work.
__________________ Liquid Silver Metallic 2011 MAZDASPEED 3 Tech Mods:Cobb Access Port | KMD Internals | Corksport SRI | Corksport TIP | Corksport Racepipe | Corksport Short Shift Plate | Corksport Shifter Bushing Kit | JBR Cylindrical Shift Knob | Sure S3 Torq Driver side motor mount | Sure S3 Torq Passenger side motor mount | JBR 88 RMM | Forged V1 BPV (blue spring) Looking into: Corksport CBE Exhaust, DownPipe, FMIC
| The Following User Says Thank You to Wings_Fan_1986 For This Useful Post: | superskaterxes (02-13-2013) |
![]() | | #66 | ![]() |
| Not Ranked : 0 score DocuSign complete! Hoping the extra $38 is for shipping?
| The Following User Says Thank You to ARES28 For This Useful Post: | superskaterxes (02-14-2013) |
![]() | | #67 | ![]() |
| Not Ranked : 0 score So if we miss the group buy, is the price just 100 more like on the website? Are there more of these actually in inventory apart from what is in this gb? Sent from my Galaxy Nexus using Tapatalk 2
![]() | | #68 | ![]() |
![]() Join Date: Feb 2013 Location: Brookfield, Ct
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 98
| Not Ranked : 0 score interested in a set for an ms6. |
| The Following User Says Thank You to Pseudonym For This Useful Post: | superskaterxes (02-14-2013) |
![]() | | #69 | ![]() |
| Not Ranked : 0 score whats in the OP is how many total sets we have in inventory. The price will remain the same regardless of how many sets we have left
| The Following User Says Thank You to superskaterxes For This Useful Post: | thatsmrgimp2u (02-14-2013) |
![]() | | #70 | ![]() |
![]() Join Date: Jul 2012 Location: Aberdeen, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 313
| Not Ranked : 0 score Quite possibly interested. Gonna think on it more and send a PM if I decide to take the plunge. Not a question of quality, because these will definitely work just fine, but of the timing.
![]() | | #71 | ![]() |
![]() Join Date: Sep 2012 Location: Farmington, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 49
| Not Ranked : 0 score YOU STAY AWAY YOU. Damn you Tire Rack for making my wheels so cheap at the same time as a GB on coilovers.
__________________ Cobb AP // JBR 88d Trilogy // JBR 3.5" WP // JBR RSB // MS Coils // SPC Camber Arms // Autotech Internals // eBay Catless DP // ACT-ZX5-HDSS // TRM C3 17x9 +48 // 255/40/17 NT05 [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to Bobforapples For This Useful Post: | bislag (02-14-2013) |
![]() | | #72 | ![]() |
| Approved MSF Vendor ![]() Join Date: Jun 2012
Rep Power: 178 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 128
(Thread Starter) | Not Ranked : 0 score Yes, it is. Your coil is going out today! Last set of the S3 Gen1 left.
__________________ Sonic Tuning 18938 Bonanza Way Gaithersburg, MD 20879 Proudly Serving the NATOR DC Community! www.sonictuning.com We are an authorized COBB Dealer and carry HUNDREDS of other brands for your MAZDASPEED We also make our own Coilovers for the MS3/6 along with HID kits and Wheels |
| The Following User Says Thank You to sonic tuning For This Useful Post: | ARES28 (02-14-2013) |
![]() | | #73 | ![]() |
| Not Ranked : 0 score So what are we looking at time wise for them to be back in inventory?? Sent from my Galaxy Nexus using Tapatalk 2
![]() | | #74 | ![]() |
__________________ Mile High. Silver genwon MS3. BNR S3, HTP 3" intake, 3 bar MAP with bit-wise harness, Grimmspeed 3 port ebc, AP with e-85 self tune, Autotech internals, CX racing FMIC, ST coilovers, gutted test, res deletes, turbo XS BPV, TRZ RMM, Jbarone SSP, Jbarone PMM, Moddiction anvil SK, Ultragauge, e-bay oil CC, some ebay drilled rotors, 10k hid kit, washered stock SS, 5MM spacers, Enkei Imola, and other shit i'm forgetting... Daily driver- Piece of shit 1998 Chevrolet S-10 LS. | |
| The Following User Says Thank You to ARES28 For This Useful Post: | sonic tuning (02-14-2013) |
![]() | | #75 | ![]() |
![]() Join Date: Nov 2011 Location: Caldwell, ID
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,042
| Not Ranked : 0 score Just got my sweet Sonic Tuning CO's from UPS today. Everything looks very nice. Great customer service and quick shipment of item. If today weren't Valentines Day, they would be installed on my car tonight. Guess tomorrow night will do
__________________ Old stuff: Stock k04 12.301 @ 113.20 New Stuff: PTE 5858 and Built, not bought, by ME ![]() |
| The Following User Says Thank You to h.h.sk1nny For This Useful Post: | sonic tuning (02-14-2013) |
![]() | | #76 | ![]() |
(Thread Starter) | Not Ranked : 0 score We have another shipment May~June.
![]() | | #77 | ![]() |
![]() Join Date: May 2010 Location: Homestead, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,375
| Not Ranked : 0 score How many S3 genpus left Anthony? Sent from my flying tapadildo
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost |
![]() | | #78 | ![]() |
| Not Ranked : 0 score i believe 4-5 sets ill make sure to update the OP today.
![]() | | #79 | ![]() |
| Not Ranked : 0 score should be getting my reenlistment bonus on the 1st of March, hopefully there is a gen2 S3 set left for me.
![]() | | #80 | ![]() |
![]() Join Date: May 2011 Location: South Africa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30
| Not Ranked : 0 score Dont know if im just retarded but i dont see a price... Can anyone maybe help me wit a price plz |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f596/gb-v2-sonic-tuning-coilovers-137331/ | ||||
| GB V2: Sonic Tuning Coilovers!!! - Mazdaspeed Forums | This thread | Refback | 01-17-2014 10:27 AM | |
| If interested. Coil overs GB available at MSF - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 02-05-2013 08:58 PM | |
| Display Modes | |
| GB: Sonic Tuning Coilovers!!! | sonic tuning | Sonic Tuning | 142 | 03-03-2014 03:55 AM |
| Anyone in Wilmington, DE area with Sonic Tuning Coilovers? | MPSpd3 | MazdaSpeed 3/6 - Suspension & Brakes | 5 | 11-05-2012 06:51 PM |
| Sonic Tuning Coilovers | superskaterxes | MazdaSpeed 3/6 - Suspension & Brakes | 181 | 07-17-2012 06:08 AM |
| Sonic Tuning ST8s | MS3inDC | Wheels & Tires - BLACK | 7 | 09-07-2011 09:50 AM |
