> Sonic Tuning
Like Tree7Likes
Closed Thread
 Old 02-23-2013, 07:46 AM   #121
ARES28's Avatar
Posts: 425   (View Stats)
ARES28 is the leader of the worldARES28 is the leader of the worldARES28 is the leader of the worldARES28 is the leader of the worldARES28 is the leader of the worldARES28 is the leader of the worldARES28 is the leader of the worldARES28 is the leader of the worldARES28 is the leader of the worldARES28 is the leader of the worldARES28 is the leader of the world
Is the hole saw used to access camber adjustment a 3"? Or will a 2 1/2" work?
Mile High. Silver genwon MS3. BNR S3, HTP 3" intake, 3 bar MAP with bit-wise harness, Grimmspeed 3 port ebc, AP with e-85 self tune, Autotech internals, CX racing FMIC, ST coilovers, gutted test, res deletes, turbo XS BPV, TRZ RMM, Jbarone SSP, Jbarone PMM, Moddiction anvil SK, Ultragauge, e-bay oil CC, some ebay drilled rotors, 10k hid kit, washered stock SS, 5MM spacers, Enkei Imola, and other shit i'm forgetting...
Daily driver- Piece of shit 1998 Chevrolet S-10 LS.
ARES28 is offline
 Old 02-23-2013, 10:38 AM   #122
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
Are the bolts for the strut mounts removable? I use torque dampener, and need to get bolts that are a bit longer.
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
thatsmrgimp2u is offline
 Old 02-23-2013, 10:43 AM   #123
dpolseno41's Avatar
Posts: 1,819   (View Stats)
dpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the world
Groaned at 41 Times in 16 Posts
You should be able to press/ hit them out without a problem.
dpolseno41 is offline
The Following 2 Users Say Thank You to dpolseno41 For This Useful Post:
superskaterxes (02-26-2013), thatsmrgimp2u (02-23-2013)
 Old 02-26-2013, 03:10 PM   #124
Woot!
Okay so total suspension noob here... If i wanted the car lower one inch do I make the total length of the shock/strut assemblies one inch shorter than stock? Then adjust the spring perches?
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 02-26-2013, 05:55 PM   #125
ARES28's Avatar
Woot!
I just set pre-load on the fronts, installed them with the top lock rings locked. Drop the car, let them settle. Then measure ground to fender and either turn the threaded body up to raise, or down to lower to reach your measurement. The bottom lock ring needs to be loose so the body can thread. Top rings do not need to be touched.....Rears were harder. I threaded the rings maxed to the metal sleeve thats sits at the top of the spring perch. Jack the arm that holds the spring untill you cant move it vertically or horizontally/ pre-load. Then bring up the rear control arm and bolt it to the spring arm. Once thats done, thread your strut to the spring untill you have tension. Then bolt the strut...... Im no suspension pro either but this has worked for me, no noise, and car rides like a dream...
ARES28 is offline
The Following 2 Users Say Thank You to ARES28 For This Useful Post:
superskaterxes (02-26-2013), thatsmrgimp2u (02-26-2013)
 Old 02-26-2013, 07:41 PM   #126
your best bet is to put them on the car and then adjust as necessary. its not always a 1:1 ratio with CO length and drop so u might need to play with it some.
superskaterxes is offline
sonic tuning (02-26-2013), thatsmrgimp2u (02-26-2013)
 Old 02-26-2013, 09:42 PM   #127
White Joint's Avatar
Posts: 125   (View Stats)
White Joint is a splendid one to beholdWhite Joint is a splendid one to beholdWhite Joint is a splendid one to beholdWhite Joint is a splendid one to beholdWhite Joint is a splendid one to beholdWhite Joint is a splendid one to beholdWhite Joint is a splendid one to behold
Will the mazdaspeed3 coils go as low as the BC BR coils?
2009 Mazdaspeed3. Yellowspeed Racing Coils, Dominant Engineering Camber Arms, Cp-E Manifold, Tial MVS38, SSP Dumptube, Turbo XS Downpipe, Turbo XS RP with SPracing Boost Activated Cutout, Turbo XS CBE, Turbo XS CAI, Turbo XS hybrid BOV, Turbo XS FMIC, TWM Short Shifter, CP-E Rear mount Stage1, Cp-E Driverside Motor Mount, Cp-E Passengers Motor Mount, COBB AP V2, Grimmspeed Boost solenoid, Cobb TIP, Bnoon Banjo Bolt, PTP Smokey turbo Fix Pill
RICHTUNE.... ??? WHP.... ??? WTQ =
White Joint is offline
 Old 02-26-2013, 10:33 PM   #128
Pseudonym's Avatar
Posts: 1,429   (View Stats)
why arent there even basic instructions for n00bs when you get these coilovers?
Pseudonym is offline
 Old 02-26-2013, 10:41 PM   #129
Javi's Avatar
Posts: 589   (View Stats)
Javi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the world
Too bad MS6 coilover set-up sold-out.. I will definitely buy a set next shipment..
Javi is offline
 Old 02-27-2013, 06:23 AM   #130
3" is the minimum i believe. It also fits nicely into the hole.
theres plenty of how to's on here for CO's for the time being. We are working on a specific set of instructions for these but if your going to install them yourself i would hope you would be smart enough to search MSF or call us up.
thanks!
yes we are planning on making the newer version able to drop your car even lower for the gen 1. The MS6 and gen 2 sets can already go nice and low.
Last edited by superskaterxes; 02-27-2013 at 06:23 AM. Reason: MSF Database - Automerged Doublepost
 Old 03-15-2013, 06:33 PM   #131
Mazdaspeed3KHP's Avatar
Posts: 273   (View Stats)
Mazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond repute
Hello Sonic,
Says you guys have one set left in the s1 for gen2 ms3? If I dont plan on running camber, but rather stock specs, do you think I would have use for the s3? I want to pick a set of these up for spring break if available, pm price please!
If I ran 17x9 rpf1s +35 do u think I would need adjustable rear camber arms?
Thanks in advance.
Mazdaspeed3KHP is offline
 Old 03-15-2013, 07:00 PM   #132
I used a 3 and 1/8th inch holesaw. It fit perfectly enough inside the inner diameter of the strut brace that I didnt need a block or guide. Everything is buttoned up and set at 4 clicks all the way around. Really love the way the car feels now that its been aligned and corner balanced. The guy who did my balancing complimented the setup. Said they were premium tier stuff
About those studs...
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
The Following 2 Users Say Thank You to thatsmrgimp2u For This Useful Post:
sonic tuning (03-17-2013), superskaterxes (03-15-2013)
 Old 03-15-2013, 07:07 PM   #133
Ray Danger 2020's Avatar
Posts: 768   (View Stats)
Ray Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the world
About what studs? I'm waiting on a set and I'm trying to understand?
Power: BORG WARNER S360 TURBO w/ .70A/R SINGLE SCROLL HOTSIDE HTP 3.5" WHALE PEEN TIAL 44mm EWG (red) FJ PERFORMANCE TUBULAR MANIFOLD w/ VBAND EWG OUTLET/VBAND CATLESS DP/VTA EWG TUBE/FMIC PIPING - HOTSIDE ROUTED UNDER CAR/AN OIL FEED/DRAIN LINES ULTIMATE RACING CBE TREADSTONE TR1035 FMIC CORE AUTOTECH HPFP INTERNALS COBB TUNING ACCESSPORT GO FAST BITS TMS RESPONS BOV NGK LTR7IX-11
Handling: JAMES BARONE RACING RSB/88aRMM/88aTMM/80aPMM SONIC TUNING S3 COILOVERS STOPTECH SPORT STOP CROSS DRILLED ROTORS BRIDGESTONE POTENZA RE-11 235/40/18 SPC REAR CAMBER ARMS
Extra Shit:SURE SHORTCUT/COUNTERSHIFT/ANCHORS JAMES BARONE RACING SPHERICAL HEAVY KNOB/51r BATTERY TRAY/STAGE II OCC CORKSPORT LED REAR BUMPER REFLECTORS/LED INTERIOR KIT/URETHANE EXHAUST HANGERS/GAS HOOD PROP STRUTS BOSCH 3-BAR MAP SENSOR BITWISE PnP MAP HARNESS COBB TUNING 3-PORT EBCS DDM TUNING 8000K LOWS/3000K FOGS O.Z. RACING ULTRALEGGERAS 18x8 +48 MUTEKI SR48 OPEN ENDED LUGS NUTS ARP 100-7708 EXTENDED WHEEL STUDS HELLA SUPERTONES RALLY ARMOUR MUDFLAPS (BLACK WTH RED LETTERS)
K04 POWER FIGURES
277HP/325TQ SixTuned On 93
314HP/356TQ Rfinkle2 Tuned With 33% Corn
S360 POWER FIGURES
365HP/356TQ Purple Drank Tuned ON 93
421HP/392TQ Purple Drank Tuned w/ 3 GAL E85 MIX
NUMBERS LIMITED BY STOCK BLOCK ON STOCK FUELING TILL SPRING
Ray Danger 2020 is offline
 Old 03-15-2013, 08:41 PM   #134
I use an etd so I need some longer studs on the passenger side. That's all.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 03-17-2013, 05:36 PM   #135
sonic tuning's Avatar
Posts: 129   (View Stats)
Thanks for the kind words!
We are expecting another shipment early May, we will post more details once we have exact ETA.
Thanks for the support folks!
Sonic Tuning
18938 Bonanza Way
Gaithersburg, MD 20879
www.sonictuning.com
sonic tuning is offline
The Following 2 Users Say Thank You to sonic tuning For This Useful Post:
Javi (03-20-2013), turbo test (03-17-2013)
 Old 03-18-2013, 10:00 AM   #136
Hello Sonic again,
My Post count is too low to reply to your PM. Shipped would be to 98296. I will try and see if I can get my post count up so I can reply back. I am always on this website, just never interacted with anyone, only read.
 Old 03-20-2013, 08:04 PM   #137
Just got these ordered! I will be installing them with some SPC camber arms as well on the stock wheels. Hopefully when I go lower I wont end up rubbing with the stock wheels.
The Following User Says Thank You to Mazdaspeed3KHP For This Useful Post:
sonic tuning (03-24-2013)
 Old 03-26-2013, 10:16 PM   #138
KusteLokal's Avatar
Posts: 2,664   (View Stats)
KusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the world
Groans: 124
@predapio;
KusteLokal is offline
 Old 03-27-2013, 04:44 PM   #139
Pseudonym's Avatar
Are the damper adjustment knobs to be left on or taken off after adjustments have been made? I'm referring to the ms6 versions.
 Old 03-27-2013, 11:38 PM   #140
madspd6's Avatar
Posts: 1,009   (View Stats)
madspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the world
It might be installer error but these are clunking like a motherfuckker for me. I'm going to go tighten up all the nuts n bolts again tomorrow to make sure it's not just my mistake. But how loud are yours Anthony? Every bump sounds like a wheel is about to fall off. I did spc's at the same time.
I did 1/4" of preload up front.
Velocity Red Mica 06 Speed6 (ricer) #834
Some shitty; s300sx fmw turbo, home made fmic setup, home made 4" Intake, 3.5 blowthrough maf, home made downpipe, poorly self tuned. More motor mounts then necessary.
Gay and coated white enkei rpf1s with stupid 245/45 tires. Pointless drilled and slotted rotors. Clunky coilovers. Ricer lips and lights.
madspd6 is offline
 Old 03-28-2013, 12:01 AM   #141
Pseudonym's Avatar
What is preloading and why did u do it? I just installed my fronts today and left the tops alone. I mounted them 10 spins from the tallest setting and only heard clunks once or twice immediately afterward.
 Old 03-28-2013, 12:21 AM   #142
madspd6's Avatar
I tightened the spring by hand till it was touching. Then added a 1/4 inch more. This does not really explain clunking because I can hear it in the rear too. And those don't have the same install procedure or any possible preload.
madspd6 is offline
 Old 03-28-2013, 12:26 AM   #143
Pseudonym's Avatar
How long did it take to do the rears?
 Old 04-01-2013, 10:52 PM   #144
You can leave the adjustment knobs on the strut after adjustment.
Please check your PM, need more info regarding your setup.
Sonic Tuning
18938 Bonanza Way
www.sonictuning.com
 Old 04-06-2013, 09:19 PM   #145
Steve6's Avatar
Posts: 268   (View Stats)
Steve6 is the leader of the worldSteve6 is the leader of the worldSteve6 is the leader of the worldSteve6 is the leader of the worldSteve6 is the leader of the worldSteve6 is the leader of the worldSteve6 is the leader of the worldSteve6 is the leader of the worldSteve6 is the leader of the worldSteve6 is the leader of the worldSteve6 is the leader of the world
I'm in the exact same position as you. Let me know if you get it solved.
SURE Full3 AEROS, Autotech Internals, Turbosmart Dual port BPV, Test pipe, Magnaflow CBE, RMM, Sonic Tuning Coilovers, 3" Corksport TMIC, Shift Anchors, COBB AP, Rich Tune, Boost Tubes, CAR-LED Tails, Denso ITV22, CP-E TowPlate, Prosport Boost Gauge w/Defrost Vent Pod, Corksport LED Fog Lights, 18x8 Enkei M52 on 225/40ZR18 BFGoodrich g-Force Sport COMP-2
Waiting to be installed:...
Steve6 is offline
 Old 04-06-2013, 09:33 PM   #146
madspd6's Avatar
So i put them full soft and they still clunk but its much less then on full hard.
I see you pm'd me but since there are more people having issues it would be easier to brainstorm as a group then just with me.
Did i set too much preload?
I loosened all the bushings and torqued them back down with all at what is ride height. and they still look good.
I ordered awr swaybar links to try to get the swaybar back to a more stock position to see if thats the issue.
madspd6 is offline
 Old 04-07-2013, 06:41 PM   #147
I'm thinking it has to do with your endlinks. I installed these coils on my mazdaspeed 3 and Sonic provided new adjustable endlinks, I installed everything and I heard clunking noises immediately after the install. My enklink bolts were too loose so I tightened them up and the noises went away. Remember that when you install new endlinks, they are prone to making more noise than the stock. You are going to hear noises because of the design in the endlink. The noises should not be constant but rather; when you have your wheel turned and are backing out of the hump at the bottom of your driveway, you will hear a noise briefly, but it will go away. Make sure everything is super tight, that’s where my issues came from.
(BTW I had loosened the pre-load at bit to achieve a lower height and it caused no noise either. I had my preload the way you mentioned above and the spring was too tight)
 Old 04-07-2013, 07:27 PM   #148
madspd6's Avatar
The endlinks have not been installed. awr has just shipped them.
i checked the stock links, still tight.
i'm going to retry the preload then. just enough so the spring is pinched at full droop, is that what you reccomend?
madspd6 is offline
 Old 04-07-2013, 07:35 PM   #149
trixms3's Avatar
Posts: 424   (View Stats)
trixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the world
Awesome coilovers. I've had mine installed for about 2 months now and love em. If I had another ride to install these on I would purchase another set. *wooowhooo*
Sonic Tuning CO's//JBR rear camber arms//JBR 3.5" WP//Cobb FMIC piping w/ Treadstone TR6 core//Turbosmart dual port bpv//Autotech HPFP//(unbranded) DP//straight pipe axleback// Cobb AP V3// FREEKTUNE
trixms3 is offline
 Old 04-08-2013, 06:29 AM   #150
i never had any clunking on mine. but my car is also racecar status so i sort of learned to ignore some clunks here and there lol.
let us know what you come up with. im still on stock end links and im pretty low and havent had any problems. how tight do you make your endlinks?
 Old 04-08-2013, 09:01 AM   #151
madspd6's Avatar
Torqued probably to 40 lbs, just with a wrench only.
madspd6 is offline
 Old 04-08-2013, 09:10 AM   #152
865ms3's Avatar
Posts: 2,602   (View Stats)
try to tighten the crap out of the pinch bolt for the rear struts. i put some coilovers on my wife's old 3 sedan and they clunked. i took out the breaker bar and torqued them down. problem solved.
Brent
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
865ms3 is offline
 Old 04-08-2013, 09:47 AM   #153
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
I think you mean "rear shock lower mount bolt."
This car has no rear struts (except for the ones that hold the hatch open ) and the bolts that attach the bottoms of the shocks to the car are not "pinch bolts."
865ms3 likes this.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
Nliiitend1 is offline
 Old 04-08-2013, 11:28 AM   #154
865ms3's Avatar
Yea yea. U know what i ment lol.
Sent from my SCH-I535 using Forum Runner
Brent
Dragon Slayer Setup
FreekTuned
865ms3 is offline
 Old 04-09-2013, 11:31 AM   #155
I dont think its your pre-load. I would just try to tighten them as much as you can. That's what I did and it seemed to work. I figured since it was so hard to get the stock endlink bolt off the swaybar, I figured it must have to be just as tight when putting it back on. My torque wrench doesnt fit back there so Idk how many pounds its tightened to.
 Old 04-09-2013, 02:23 PM   #156
radbrad's Avatar
Posts: 538   (View Stats)
Mine currently clunks when I am reversing out of my driveway while the wheels are turned all the way. It is the only time they make noise though. I want to say its because i dont have the correct length on the front endlinks. I am dedicating this weekend to solve it.
07Speed3
radbrad is offline
The Following User Says Thank You to radbrad For This Useful Post:
superskaterxes (04-16-2013)
 Old 04-10-2013, 01:55 PM   #157
jreiden1's Avatar
Posts: 237   (View Stats)
jreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the world
any news of next group buy?
2006 WWP Mazdaspeed 6
KILLAH BUILT 700+ AWHP TUNED BY NISHAN
jreiden1 is offline
 Old 04-14-2013, 08:01 PM   #158
Mine do this too when I go fast, but If im going super slow theres no noise down the driveway. Sometimes going around cul-de-sacs as well if I hit a bump. My endlinks werent "even" from side to side, but they are even top to bottom on each side. They will make more noises than stock, it says that on corksports website in their instructions for their endlinks.
 Old 04-15-2013, 10:36 AM   #159
Say Chi Sin Lo's Avatar
Posts: 872   (View Stats)
Say Chi Sin Lo has disabled reputation
Second that...
Say Chi Sin Lo is offline
 Old 04-15-2013, 11:18 PM   #160
Any detail where the clunks are coming from?
Make sure the spring are compressed, so that it's not loose. We had few folks had rubbing with their current wheel set due to the car height being low.
PM us more information, we will get them resolved!
Good news for everyone, our third batch just finished production.
Shipping confirmed already, we should be posting details in two weeks about payment and exact shipping time frame.
Sonic Tuning
18938 Bonanza Way
www.sonictuning.com
The Following User Says Thank You to sonic tuning For This Useful Post:
jreiden1 (04-16-2013)
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f596/gb-v2-sonic-tuning-coilovers-137331/
GB V2: Sonic Tuning Coilovers!!! - Mazdaspeed Forums This thread Refback 01-17-2014 10:27 AM
If interested. Coil overs GB available at MSF - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 02-05-2013 08:58 PM
GB: Sonic Tuning Coilovers!!! sonic tuning Sonic Tuning 142 03-03-2014 03:55 AM
Anyone in Wilmington, DE area with Sonic Tuning Coilovers? MPSpd3 MazdaSpeed 3/6 - Suspension & Brakes 5 11-05-2012 06:51 PM
Sonic Tuning Coilovers superskaterxes MazdaSpeed 3/6 - Suspension & Brakes 181 07-17-2012 06:08 AM
Sonic Tuning ST8s MS3inDC Wheels & Tires - BLACK 7 09-07-2011 09:50 AM
Page generated in 0.60146 seconds with 39 queries
