![]() | | #161 | ![]() |
![]() Join Date: Oct 2009 Location: Andersen AFB, Guam
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Not Ranked : 0 score
__________________ RichTuned Ultimate Racing DP V2 flange\35W 6000k DDM HID's\HKS SSQV3 VTA\GTX2867R\Tanabe STB\HTP 3.5" intake\PTP HPFP\UR FMIC\Ultimate Racing turbo-back exhaust\JBR RSB\JBR 80Duro Trilogy mounts\Cobb AP v3\Stage 2\22.5PSI \Sonic Tuning Coilovers\TWM full replacement shifter and SSP\PnP Intake Manifold/CP-e EWG Exhaust Manifold/Tial 44mm EWG 11/10/2012 NATOR DC DYNO day 304Whp/356 FT lbs Tqe Uncorrected 4/13/2013 Mega NATOR Meat Dyno Day 300WHP/ 344ft lbs/wtqe Corrected |
![]() | | #162 | ![]() |
![]() Join Date: Mar 2010 Location: San Francisco, CA
Rep Power: 295 ![]() Thanks: 14
| Not Ranked : 0 score Sonic Tuning, Can you comment on your shocks? Whether it's in-house or sourced from another manufacturer? If it's in-housed, how's the quality? |
![]() | | #163 | ![]() |
![]() Join Date: Apr 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 346
im still playing with swaybar endlinks to see if that was causing it. the awr's have quite a bit of adjustability.
__________________ Velocity Red Mica 06 Speed6 (ricer) #834 Some shitty; s300sx fmw turbo, home made fmic setup, home made 4" Intake, 3.5 blowthrough maf, home made downpipe, poorly self tuned. More motor mounts then necessary. Gay and coated white enkei rpf1s with stupid 245/45 tires. Pointless drilled and slotted rotors. Clunky coilovers. Ricer lips and lights. | |
![]() | | #164 | ![]() |
![]() Join Date: Sep 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 101
| Not Ranked : 0 score I hear clunks in the rear now going over bumps, I think its the perch but idk. Is there any specific way of installing the perch? I got it on max low with both locking rings tight at the top. I know the perch rests on this bolt within the whole assembly at the top, I think thats what's causing the noise because it shifts when hitting bumps.. but idk. Also if I wanted it more low in the back could I remove both locking rings to get more of a drop or would that be a bad idea? Currently my fronts can go alot lower than the rear, but im satified with the front, the back is just a tad higher in mm.. |
![]() | | #165 | ![]() |
![]() Join Date: Nov 2011 Location: Phoenix, AZ
Groaned at 5 Times in 1 Post
| Not Ranked : 0 score hello sonictuning, how do i become part of the GEN2 speed sonic tuning coil GB for may? :] I'm in no rush as well, sonictuning is the best option i have, otherwise its ksports (and every single asshole in this forum says ksport is a bad choice. lol) |
![]() | | #166 | ![]() |
I think the bolt is actually supposed to go through the perch in your case.
| The Following User Says Thank You to madspd6 For This Useful Post: | thatsmrgimp2u (05-05-2013) |
![]() | | #167 | ![]() |
| Not Ranked : 0 score |
![]() | | #168 | ![]() |
| Approved MSF Vendor ![]() Join Date: Jun 2012
Rep Power: 178 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 128
(Thread Starter) | Not Ranked : 0 score We just received news for the shipment, they should be here around 20th of May.
That is correct!
__________________ Sonic Tuning 18938 Bonanza Way Gaithersburg, MD 20879 Proudly Serving the NATOR DC Community! www.sonictuning.com We are an authorized COBB Dealer and carry HUNDREDS of other brands for your MAZDASPEED We also make our own Coilovers for the MS3/6 along with HID kits and Wheels | ||||
![]() | | #169 | ![]() |
![]() | | #170 | ![]() |
| Not Ranked : 0 score Got my stuff all figured out now, seems to be pretty solid, I will post a review and picture later this week! |
| The Following 2 Users Say Thank You to Mazdaspeed3KHP For This Useful Post: | PapaSmurf (05-14-2013), sonic tuning (04-25-2013) |
![]() | | #171 | ![]() |
Glad everything is resolved.
| The Following User Says Thank You to sonic tuning For This Useful Post: | nybe0010 (05-15-2013) |
![]() | | #172 | ![]() |
![]() | | #173 | ![]() |
![]() Join Date: Aug 2008 Location: Ashburn, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 305
| Not Ranked : 0 score Will you be providing end links for the ms6 this time around?
__________________ 2006 Black Mica MS6 - Sold 10/15 |
![]() | | #174 | ![]() |
![]() Join Date: Dec 2008 Location: Toledo OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 324
| Not Ranked : 0 score This was a noob mistake on my part, but just so others dont have the same issue... Make sure that when you are setting spring preload either the entire front half of the car is in the air, or your sway bar endlinks are disconnected from the strut. i set my preload one side at a time and didnt pay attention to the sway bar, so they were super loose for a while. like three inches too loose. Made me think all sorts of crazy stuff was happening. Now that everything is dialed in how i want it.... These are amazing. I have zero complaints about daily driving characteristics and im at 7/8 clicks (f/r). Love these coils. Thanks sonic tuning!
__________________ | CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers |Fluids Rotella T6 A lot Rislone Engine Treatment Motorcraft XT-M5-QS(trans) VP Methanol ~Splash of E85~ |
![]() | | #175 | ![]() |
| Not Ranked : 0 score ^ I did the same thing! I still have issues when going slow or over bumps going slow in the front right side. I'm pretty sure it’s the endlink either not tight enough or not measured out right. I had the preload so low that the height of the car was super low. I do think that Sonic should provide shorter springs for the front to match how low the rear can go. My fronts are maxed out and there is still two to 1 1/2 finger gap. The rear I had maxed out and it was like 1 finger to 1/2 a finger. The option to go low is nice that's why the shorter spring would be better. I think the ride height is perfect with the way I have it now. I am waiting for my friend to get the pictures we took off his camera and then I will post them up. Car handles really well, even with bald stock tires. I did notice in the front that when you are maxed out, you will still have an inch of threads showing between the top two collars and the bottom collar. From what I understand, when the coilovers are maxed out, there should be no threads showing, but I could be wrong. I tried threading the top collar down and it is too tight to even use a hammer to hammer down on. When you are installing the rear you don’t have to remove the sway bar completely. Just loosen the 4 14mm bolts that hold the sway bar up and let it swing down to release the pressure on the spring carrier piece. I did have one issue with one of my sway bar bolts, I think I made it too tight and now when I loosen the bolt it doesn’t come out and when you tighten it goes tight and then loose again, so be careful with those. Tools that I didn’t have that would have made this install a breeze: Huge steel mallet to get front struts out. I used 2x4s and a hammer. Ended up going through like 4 piece of wood because I split them. I hammer each side for like an hour. PB BLASTER is a MUST. It is also a MUST to spray everything the night before! BREAKER BARS, short and long to break tight ass bolts such as the rear perch bolt, and bottom endlink bolt. Power snap on drill to save time, it might save you a good 30 mins if not more. Overall, Take your time; it took me a good three days to get everything installed and then another 2 weeks to get everything properly installed. These coilovers are really really good quality. The struts are super beefy at the bottom compared to k sport which I like. 12 way adjusting is perfect for noobs like me that don’t want to fiddle with a knob for 5 mins. What I really loved about the Rear adjustment is that I could jack up the car and squeeze my arm in the wheel well and adjust the damper. All other coils have you adjust from the trunk which is a pain in the ass. On the rear strut, I forgot to put the OEM ugly cover back over the top of the strut, but it’s not really needed unless you are going to drive in the snow or extreme weather. I might throw them on winter time. I am very satisfied with all the customer support sonic has provided me while attempting this install. I kept called and called and they helped me through the most difficult parts of the install. Great coilovers!! Highly recommended!!! |
![]() | | #176 | ![]() |
![]() Join Date: May 2010 Location: Homestead, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,375
| Not Ranked : 0 score Wei, Did y'all come out with a how-to or directions for install yet? Would be nice so everyone knows exactly what they need to do to install these correctly. Sent from your girlfriends tapabedroom
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost |
![]() | | #177 | ![]() |
![]() Join Date: Aug 2008 Location: Orange County NY
Rep Power: 2267 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,484
| Not Ranked : 0 score I'm working on one. It's pretty straight forward and easy if you've done coilovers before. The only difference is the rear spring collars, you have to remove a subframe bolt in order to get it installed, that was the only pain in the ass and not because of the coilovers itself, but the bolt was just really hard to get off. Otherwise it's a 3 hour install with height adjustment. I've been on these for a few days and I can say it's leaps and bounds above the H&R coilovers. I've almost got these dialed in, just need to fine tune it, but the ride is nice and the handling is amazing. Now I just need some new tires lol
__________________ cp-e-FMIC/cp-e-HPFP/cp-e-Xcel Nano Intake/cp-e-Nviscid TIP/cp-e-BOV Kit/cp-e-Stage2 RMM/cp-e-xFlex Passanger & Driver Motor Mounts/cp-e-catted DP/cp-e-Nexus cat-back exhaust/cp-e-tow plate/cp-e-Tripple Gauge Pod/Rally Armor-Mud Flaps/TWM-Base Bushings/TWM-Shift Weight/Street Unit-Washer Fluid Cap/Street Unit-Oil Cap/Konig-Milligram/Corksport-Rear Sway Bar/Corksport-Aluminum Skidplate/StopTech-Sport Brake Kit/GTSpec-rear v-brace/GTSpec-link reinforecement panel/GTSpec-rear lower tie bar/GTSpec-4 points ladder brace/Lamin-x-Headlight film/Lamin-x-Taillight film/TWM-Full replacement shifter/TWM-Big Type R knob & Hybrid Knob/TWM-Shift boot/3M-1080 Matte Dark Grey Wrap/3M-1080 Brushed Steel Wrap/Tial-BPV/DG Motorsports-CF front lip/DG Motorsports-CF Rear wing extention/Sonic Tuning-Coilovers/COBB Tuning-AccessPort/ |
![]() | | #178 | ![]() |
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost | |
![]() | | #179 | ![]() |
| Not Ranked : 0 score Yeah basically the same as the H&Rs height adjustment is different, damper adjustment obviously and spring preload. Oh and drilling the hole bigger on the front upper strut mount. All in all a really good set of coilovers. I can;t wait to get these on the track
![]() | | #180 | ![]() |
| Not Ranked : 0 score What's different about the damper adjustment and spring preload? Sent from your girlfriends tapabedroom
![]() | | #181 | ![]() |
| Not Ranked : 0 score There was no adjust ment for them on the H&R. Just height adjustment
| The Following User Says Thank You to Grumpyjap For This Useful Post: | PapaSmurf (05-15-2013) |
![]() | | #182 | ![]() |
| Not Ranked : 0 score Guess I'll figure it out, Ive never done either, but I know the damper adjustment you just spin the thing on top to what you want. Not sure about the spring preload.
![]() | | #183 | ![]() |
| Not Ranked : 0 score Preload is kind of tricky, too much it will be bouncy too little and it will be soft. Whenever you do damper adjustment always remember to turn it to full hard then go softer from there.
![]() | | #184 | ![]() |
| Not Ranked : 0 score quick recap on how to pre load? lol
![]() | | #185 | ![]() |
| Not Ranked : 0 score Can you elaborate more on how these Sonics Tuning coilovers are better than the H&R coilovers in your opinion? Thanks! |
![]() | | #186 | ![]() |
;@superskaterxs With your power, what is the squat like with 5k springs in the rear on hard launches?
__________________ 2006 Black Mica MS6 - Sold 10/15 | |
![]() | | #187 | ![]() |
| Not Ranked : 0 score squat is def reduced like crazy. havent had any problems breaking anything with these on if thats whats your asking!
![]() | | #188 | ![]() |
![]() Join Date: Feb 2013 Location: Brookfield, Ct
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 98
| Not Ranked : 0 score are endlinks even necessary for a 6?
__________________ Cobb AP JBR SSP/SSB's AWR PMM/RMM Autotech Internals Sonic Tuning Coilovers ETS TMIC HTP 3 Incher Forge V2 BPV eBay Test Pipe SCUBA TUNED |
![]() | | #189 | ![]() |
![]() Join Date: Mar 2012 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
| Not Ranked : 0 score @superskaterxes; Get ur shipment yet man? I'm so damn anxious waiting for these damn things. I feel like a crack head going through withdrawal. Needz moar lowz nahw!
__________________ Power: BORG WARNER S360 TURBO w/ .70A/R SINGLE SCROLL HOTSIDE HTP 3.5" WHALE PEEN TIAL 44mm EWG (red) FJ PERFORMANCE TUBULAR MANIFOLD w/ VBAND EWG OUTLET/VBAND CATLESS DP/VTA EWG TUBE/FMIC PIPING - HOTSIDE ROUTED UNDER CAR/AN OIL FEED/DRAIN LINES ULTIMATE RACING CBE TREADSTONE TR1035 FMIC CORE AUTOTECH HPFP INTERNALS COBB TUNING ACCESSPORT GO FAST BITS TMS RESPONS BOV NGK LTR7IX-11 Handling: JAMES BARONE RACING RSB/88aRMM/88aTMM/80aPMM SONIC TUNING S3 COILOVERS STOPTECH SPORT STOP CROSS DRILLED ROTORS BRIDGESTONE POTENZA RE-11 235/40/18 SPC REAR CAMBER ARMS Extra Shit:SURE SHORTCUT/COUNTERSHIFT/ANCHORS JAMES BARONE RACING SPHERICAL HEAVY KNOB/51r BATTERY TRAY/STAGE II OCC CORKSPORT LED REAR BUMPER REFLECTORS/LED INTERIOR KIT/URETHANE EXHAUST HANGERS/GAS HOOD PROP STRUTS BOSCH 3-BAR MAP SENSOR BITWISE PnP MAP HARNESS COBB TUNING 3-PORT EBCS DDM TUNING 8000K LOWS/3000K FOGS O.Z. RACING ULTRALEGGERAS 18x8 +48 MUTEKI SR48 OPEN ENDED LUGS NUTS ARP 100-7708 EXTENDED WHEEL STUDS HELLA SUPERTONES RALLY ARMOUR MUDFLAPS (BLACK WTH RED LETTERS) [SIGPIC][/SIGPIC] K04 POWER FIGURES 277HP/325TQ SixTuned On 93 314HP/356TQ Rfinkle2 Tuned With 33% Corn S360 POWER FIGURES 365HP/356TQ Purple Drank Tuned ON 93 421HP/392TQ Purple Drank Tuned w/ 3 GAL E85 MIX NUMBERS LIMITED BY STOCK BLOCK ON STOCK FUELING TILL SPRING |
| The Following User Says Thank You to Ray Danger 2020 For This Useful Post: | 780mps3 (05-22-2013) |
![]() | | #190 | ![]() |
| Not Ranked : 0 score end links are needed whenever you drop the car, its just a function of the suspension geometry that you should account for.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
| The Following 4 Users Say Thank You to superskaterxes For This Useful Post: | 780mps3 (05-22-2013), jreiden1 (05-23-2013), Ray Danger 2020 (05-22-2013), thatsmrgimp2u (05-22-2013) |
![]() | | #191 | ![]() |
| Not Ranked : 0 score Ur killing me man
![]() | | #192 | ![]() |
(Thread Starter) | Not Ranked : 0 score Cleared custom today! Should have the shipment end of this weekend or early of next week! Will post the new group buy thread soon.
![]() | | #193 | ![]() |
| Not Ranked : 0 score How many sets for ms6?
![]() | | #194 | ![]() |
(Thread Starter) | Not Ranked : 0 score We have 12 sets coming in, few of them are paid and reserved. If you are interested in locking in a set for your self please contact us ASAP!
![]() | | #195 | ![]() |
| Not Ranked : 0 score Been waiting so long. It's killing me...lol
![]() | | #196 | ![]() |
| Banned ![]() Join Date: Feb 2013
Groaned at 116 Times in 29 Posts
| Not Ranked : 0 score I need these |
![]() | | #197 | ![]() |
| Not Ranked : 0 score I need these Once again I need these Last edited by Shorty_Meeks; 05-28-2013 at 09:53 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #198 | ![]() |
| Not Ranked : 0 score Would end-links help with too much camber at all?
![]() | | #199 | ![]() |
![]() Join Date: Aug 2012 Location: Cape Girareadu Missouri
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 232
| Not Ranked : 0 score No. Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
__________________ Sonic Tuning CO's//JBR rear camber arms//JBR 3.5" WP//Cobb FMIC piping w/ Treadstone TR6 core//Turbosmart dual port bpv//Autotech HPFP//(unbranded) DP//straight pipe axleback// Cobb AP V3// FREEKTUNE |
![]() | | #200 | ![]() |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
| Not Ranked : 0 score Any thoughts from people that actually push their car? I understand they're a new product, but I am looking for opinions on weekend warrior activities(especially 3's) Auto-x, twisties, etc
| The Following User Says Thank You to helmetface For This Useful Post: | sonic tuning (05-29-2013) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f596/gb-v2-sonic-tuning-coilovers-137331/ | ||||
| GB V2: Sonic Tuning Coilovers!!! - Mazdaspeed Forums | This thread | Refback | 01-17-2014 10:27 AM | |
| If interested. Coil overs GB available at MSF - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 02-05-2013 08:58 PM | |
| GB: Sonic Tuning Coilovers!!! | sonic tuning | Sonic Tuning | 142 | 03-03-2014 03:55 AM |
| Anyone in Wilmington, DE area with Sonic Tuning Coilovers? | MPSpd3 | MazdaSpeed 3/6 - Suspension & Brakes | 5 | 11-05-2012 06:51 PM |
| Sonic Tuning Coilovers | superskaterxes | MazdaSpeed 3/6 - Suspension & Brakes | 181 | 07-17-2012 06:08 AM |
| Sonic Tuning ST8s | MS3inDC | Wheels & Tires - BLACK | 7 | 09-07-2011 09:50 AM |
