![]() Join Date: May 2011 Location: Greenville, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
Groaned at 6 Times in 3 Posts
(Thread Starter) | Not Ranked : 0 score Sure says Full3 needs a tune, so I'm just wondering if I'm OK to go ahead and install the 3" intake/inlet and drive on this tune or the Stage2+SUR2+TIH 93 OTS (https://static.cobbtuning.com/cobbtu...093%20v200.ptm) for however long needed waiting for an e-tune? "This MAF size WILL require MAF calibration from the AccessPort via a custom tune, otherwise the car will not run." Obviously I don't want to custom tune myself just so I can install the 3" and drive a bit waiting for someone else to custom tune! I'm just wondering what order I need to do things in.
__________________ 2007 Speed6 GT - LPM RMM 88 | JBR SSP, SSB & Heavy Knob | NGK Iridiums | Cobb AP SURE Full3 3" Aeros | M2 Downpipe | Autotech Internals | Forge BPV MagnaFlow CBE | SURE Dreadnaught / Juggernaught | Whiteline RSB | H&R Sports E85 Stratified Last edited by LilGator; 08-23-2012 at 10:07 AM. |
| The Following User Says Thank You to LilGator For This Useful Post: | Lex (08-23-2012) |
| The Following User Says NO Thank You to LilGator For This Un-useful Post: | Monotonous ONE (08-23-2012) |
![]() Join Date: Nov 2010 Location: Manchester, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
| Not Ranked : 0 score Don't want to speak for Lex, but I would 1) Sign up for a tune, and he can get you a base map or 2)scale the maf curve yourself by 20% (1.2) and that will get you in the ballpark until he is able to tune you. I believe you can go on his website and see if he has a spot open for a tune.
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
I will then follow up with a map for your 3" intake that this is where we start from.
| The Following User Says Thank You to Lex For This Useful Post: | LilGator (08-23-2012) |
| Not Ranked : 0 score For those of you with the SURE 3" here's a MAF cal for the intake. It may need tweaks on individual cars but it's a good starting point and will get the car up and running. Just copy and paste it into your MAF A and B tables (gen1, ms6) and MAF A table for gen2. Code: 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.02 0.05 0.07 0.12 0.17 0.25 0.32 0.41 0.51 0.63 0.76 0.91 1.05 1.23 1.41 1.63 1.85 2.10 2.37 2.66 2.98 3.33 3.74 4.16 4.58 5.09 5.66 6.25 6.80 7.65 8.24 8.88 9.60 10.41 11.23 12.16 13.18 14.21 15.32 16.82 18.03 19.27 20.60 22.03 23.55 25.17 26.84 28.62 30.48 32.42 34.46 36.57 38.75 41.02 43.37 45.82 48.35 50.99 53.71 56.55 59.51 62.55 65.70 68.89 72.12 75.44 78.83 82.31 85.89 89.56 93.36 102.19 106.46 110.85 115.34 119.96 124.67 129.46 134.30 139.27 144.36 149.57 154.90 160.38 166.01 171.78 177.78 183.99 190.36 196.90 203.59 210.44 217.46 224.63 231.98 239.48 247.11 254.89 262.85 270.98 279.27 287.74 296.40 305.24 314.27 323.50 332.91 342.52 352.32 362.32 372.51 382.93 393.53 404.35 415.38 426.61 438.06 449.74 461.63 473.74
| The Following 10 Users Say Thank You to Lex For This Useful Post: | 08.5MS3 (08-23-2012), atvfreek (08-23-2012), Dmurray06 (08-23-2012), Don06speed6 (08-23-2012), IMASA (10-24-2012), LilGator (08-23-2012), MarkyMark (08-24-2012), Monotonous ONE (08-23-2012), Onelovesoccer (08-23-2012), rfinkle2 (08-23-2012) |
![]() Join Date: May 2010 Location: West Palm Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,842
Groans: 819
| Not Ranked : 0 score You quoted the part where it says the car will not run. Then you still asked if you can drive on it until a proper tune. What part of "will not run" is so difficult to understand?
__________________ |
| The Following User Says Thank You to Monotonous ONE For This Useful Post: | rfinkle2 (08-23-2012) |
Regardless, the question remains the same and I appreciate Justin & Lex letting me know what I need to do. This makes things easy.
__________________ 2007 Speed6 GT - LPM RMM 88 | JBR SSP, SSB & Heavy Knob | NGK Iridiums | Cobb AP SURE Full3 3" Aeros | M2 Downpipe | Autotech Internals | Forge BPV MagnaFlow CBE | SURE Dreadnaught / Juggernaught | Whiteline RSB | H&R Sports E85 Stratified | |
| The Following User Says Thank You to LilGator For This Useful Post: | atvfreek (08-23-2012) |
Groans: 819
You got solid answers from atvfreek and lex cause they are overly nice (and physically attractive) guys.
__________________ | |
(Thread Starter) | Not Ranked : 0 score I can work with that.
| SURE Aeros SRI | G26 | 2010 MS3 - Turbo Induction | 10 | 05-02-2011 07:15 AM |
