![]() Join Date: Aug 2010 Location: BC, CANADA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 305
(Thread Starter) | Not Ranked : 0 score If you guys didn't know, Stratified does more than just E-tunes. They have access to a full shop for installs. This works out well for me since I live 15mins away from their shop. Picked up one of the BNR S3 V2's and a bunch of supporting parts and went over to Stratified's shop for the install. ![]() Pics stolen off Alex's FB page ![]() ![]() ![]() ![]() ![]() The install went very smoothly. Alex provided constant updates during the various stages of the install process. The car is running on a base map until I can book time with Alex for a street tune. Overall I'm very impressed with the job they did.
__________________ 2008 Mazdaspeed3 | Cobb AP | Cobb DP | Cobb FMIC | Cobb RSB | Cobb RSB | SURE 3" MAF full intake | CP-E Stage 2 RMM | CP-E HPFP | H&R Springs | Koni Yellows | TWM FR | MD OCC | Dashhawk | DO Methanol Injection | JBR PMM & TMM | JBR EGR Plate | Last edited by IMASA; 08-28-2014 at 02:57 PM. |
| The Following 4 Users Say Thank You to IMASA For This Useful Post: |
![]() Join Date: Sep 2012 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,205
| Not Ranked : 0 score Lucky you. Congrats on the Beaner.
__________________ 2010 Mazdaspeed3 w/tech Cobb AP V3 ║ JBR Tru 3" Wide Path ║ JBR Boost Tubes & BPV Hose ║ Cobb XLE BPV ║ CP-E TMIC ║ UR Racepipe ║ Magnaflow CBE ║ AutoTech Internals ║ GrimmSpeed EBCS ║ JBR RSB ║ SPC Camber Arms ║ KW V3 Coilovers ║ JBR IM+TB TIGs & TB Bypass ║ JBR SSP ║ E - Focus RMM ║ StopTech Slotted Rotors and EBC Yellow Stuff Pads ║ Techna-Fit SS Brake Lines |
| The Following User Says Thank You to [R]usty For This Useful Post: | Lex (08-28-2014) |
![]() Join Date: Nov 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,192
Groans: 33
| Not Ranked : 0 score @IMASA; How did the tune turn out? I'm reconsidering one of these again. Need to make sure I don't get stabbed by the wife.
__________________ 2012 Velocity Red Mica Fast: COBB AP | Autotechs | JBR 3'' WP | CS DP | CS ABE | MDM RMM | JBR RSB | NGK Plugs | JBR SSP | ETS TMIC Rice: Aeroforce Interceptor | AEM M 35psi | Konig Milligrams 18x8.5 + 35 | Z1 Star Specs | JBR Mudflaps ![]() |
(Thread Starter) | Not Ranked : 0 score I started my tune last fall with Lex but my clutch couldn't handle the BNR. I think my Vdyno was showing 320hp/330 ft lbs before the clutch started slipping. I got my new clutch installed at Stratified last winter. I'll probably hit up Lex for another tune session later in the spring when the weather gets better. It tends to rain a lot over here.
__________________ 2008 Mazdaspeed3 | Cobb AP | Cobb DP | Cobb FMIC | Cobb RSB | Cobb RSB | SURE 3" MAF full intake | CP-E Stage 2 RMM | CP-E HPFP | H&R Springs | Koni Yellows | TWM FR | MD OCC | Dashhawk | DO Methanol Injection | JBR PMM & TMM | JBR EGR Plate | |
| The Following User Says Thank You to IMASA For This Useful Post: | Lex (04-01-2015) |
![]() Join Date: Mar 2011 Location: Dallas, Texas
| Not Ranked : 0 score Need to see some logs or VD plots :-) |
(Thread Starter) | Not Ranked : 0 score I think this vd plot was from the last log from my tuning session with Alex before the clutch started to slip.
(Thread Starter) | Not Ranked : 0 score Took a log today. ![]() This is on an incomplete tune, before my stock clutch gave up. I'm quite happy with the results, dunno if I really need to finish the tune.
Rep Power: 1237 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,288
Groans: 111
| Not Ranked : 0 score Is this pump gas only or on some E mix? This makes me get even more eager to get some updates...
| Display Modes | |
| No beaner install for me this weekend | m4tic | Mazdaspeed3/6 General Discussion | 6 | 08-28-2013 07:27 AM |
