![]() | | #281 | ![]() |
| Not Ranked : 0 score Literally as soon as I go off idle, everything straightens out perfect and the intake is perfect from then on. I originally suspected a part issue; I checked/rechecked everything from filter to downpipe multiple times. I checked/tested purge valve and did a bunch of other tests. It was when I swapped in another maf sensor and let it learn for a while that I realized this issue has to do with the MAF reading. The 2nd sensor learned and LTFTs got around -3 or so at idle even though STFTs were still bouncing around. With the 2nd sensor at idle, the idle stumbled around and AFRs were biasing leaner this time at around the same voltage. I changed the condition just by changing the MAF sensor. Why? My two MAF sensors are having a hard time reading good flow with the 3.5" intake below and around 1V. I hypothesize that the MAF sensor curve is probably not linear below 1v and it's kind of a crap shoot down there. So, it's either up the idle to get the MAF reading out of the weeds or go back to the 3" intake.
__________________ 2006 MS6 WWP Sport - 340whp/350wtq JBR 3"- BNRS3V2 - GS EBCS - CUSTOM FMIC - CS IM - LTR7IX - CMGS WMI & D07 GA - TURBOXS HEADER - FIDANZA FW - CP-E CATTED DP - 3" CATBACK BILSTEIN - H&R SPRINGS - 18x8.5 +48 ROTA SVN - 265/35R18 HTR ZIII MINI H1 6.0 - CAR LED TAILS SEE MORE USING !SHOUTTAG.COM - ENTER: !6SPEED6 |
![]() | | #282 | ![]() |
| The Following User Says Thank You to Lex For This Useful Post: | snailD (05-25-2015) |
![]() | | #283 | ![]() |
![]() Join Date: Apr 2011 Location: Chesapeake,VA
Rep Power: 901 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 672
| Not Ranked : 0 score Raise the idle rpm and you shouldn't have a problem. i DD on a 4" HTP (also have tuned a bunch of these intake now) have now for 8 months. My idle rpm is 950.
__________________ |
![]() | | #284 | ![]() |
![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
| Not Ranked : 0 score I have a htp 3.5" intake and my car idles great. I just have freeks base map. No maf cal yet. Idle is stock 700rpm.
__________________ 3rd rebuild on the way...maybe... |
![]() | | #285 | ![]() |
| Not Ranked : 0 score What turbo do you have cheapspeed. Also, I think the vcts delete didn't help me.
![]() | | #286 | ![]() |
| Not Ranked : 0 score Still k04 with a 3076 waiting to go in.
![]() | | #287 | ![]() |
![]() Join Date: Oct 2014 Location: Glen Carbon, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 316
Groaned at 12 Times in 2 Posts
| Neutral : -2 score subbed
__________________ '11 speed3 non tech | Turbosmart Hybrid BOV | AP v3 | Corksport Power series stage II intake and TIP | Cp-E X-Flex RMM | Autotech Internals | Speed Daddy Catback | Manzo Race Pipe | Denso ITV20's | Freek OTS+ | 33% E85 | |
![]() | | #288 | ![]() |
![]() Join Date: Dec 2014 Location: Saint Johns, FL
Rep Power: 213 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 143
| Not Ranked : 0 score It's threads like this that remind me why I donated. Thank you, @Lex;.
__________________ 2007 MS3 GT Autotech CDFP Internals || Cobb AP, SRI, TIH, DP, CB, BPV, EBCS, FSB & RSB || cp-e Injector Seals, EGR Delete|| JBR OCC, Shifter Plate, PMM & TMM, TB & Intake TIG, Coolant Bypass|| Mazdaspeed Coilovers || TRZ RMM|| TWM Bushings || MOOG Front & Rear Endlinks 2006 MS6 GT (ZZB Rebirth) Autotech CDFP Internals || BNR Stage 3 || Bosch 3 Bar || Cobb AP || cp-e Injector Seals, CBE, DP || ETS TMIC || Full Race EM || H&R Coilovers || JBR Mounts, 3.5" WP Aluminum Intake || Matt Damond OCC, Shifter Plate, EGR Delete || Racing Beat Rear Endlinks || Relentless PnP IM || SPC Balljoints || Whiteline RSB || The Company of Which I Will Not Name Front & Rear Diff Mounts 1990 Miata I like it raw |
| The Following User Says Thank You to sporkbomb For This Useful Post: | Lex (02-24-2015) |
![]() | | #289 | ![]() |
![]() Join Date: Apr 2012 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 392
| Not Ranked : 0 score I just used the HTP 4" data on mine and it works great. I'm running a stock k04 and idle and driveability is good so far. Stft is all over the place, but it got me very close all things considered.
__________________ 2006 WWP Mazdaspeed 6 #00694 Built 09/05 Stock K04 50/50 E85 mix 304/349 Central Florida Turbo Mustang Dyno 4/18/15 Tuned by NISHAN |
| The Following User Says Thank You to Cheese5.0 For This Useful Post: | Lex (03-11-2015) |
![]() | | #290 | ![]() |
(Thread Starter) | Not Ranked : 0 score Glad it helped out!
![]() | | #291 | ![]() |
| Not Ranked : 0 score I've since had some issue dialing in the maf cal. Idle is a bit choppy initially then smoothes out. STFT at idle likes to start our somewhere deep into the negative, then slowly work its way up to +24.8. I cleaned up a bunch of boost leaks and I'm looking at a bad pcv as another potential culprit. I'll post up some logs once I get that sorted.
![]() | | #292 | ![]() |
![]() | | #293 | ![]() |
![]() Join Date: Mar 2013 Location: North Brunswick, NJ
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,645
Groans: 143
| Neutral : +1 score I was working with @sleeveless; who was attempting to copy and paste Lex's values into ATR so he can get a base MAF curve for his new 3" intake. He was doing everything correctly as far as I could tell (I even saw a video he took of him doing it), but for some reason it just wouldn't work for him. The only thing I could think of is that I have ATR installed on Windows XP and Windows 7, and he has Windows 8.1. Even when I was trying to copy and paste them into Openoffice just now (that's all I have installed on my laptop), for some reason they wouldn't paste correctly and I had to paste them into ATR, then copy them into the spreadsheet. Really odd. Therefore, I have copied all of the curves from the OP into spreadsheets which I have attached in .ods and .xls format for your convenience. edit: The ods wouldn't upload. I zipped it and it's in the .zip file.
__________________ 2007 Mazdaspeed3 GT |
| The Following 3 Users Say Thank You to MD1032 For This Useful Post: |
![]() | | #294 | ![]() |
![]() Join Date: Mar 2015 Location: Conshohocken
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 72
__________________ 2012 black Mica MS3 sold 06 Mazdaspeed 6 LED turns, front switchbacks, 7000 lumen fogs, fancy boost gauge, dipped ms3 wheels | |
![]() | | #295 | ![]() |
(Thread Starter) | Not Ranked : 0 score This is a formatting issues - from the web browser to ATR and or excel. If it doesn't work I always attempt going through another software or medium first. Notepad is sometimes an option.
| The Following User Says Thank You to Lex For This Useful Post: | Awal (05-22-2015) |
![]() | | #296 | ![]() |
![]() Join Date: Sep 2013 Location: Vancouver, BC
Rep Power: 303 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,298
| Not Ranked : 0 score Posting as a reminder to update the OP's Corksport's section to include their '3.5" Mazdaspeed 3 Power Series Intake System'. I'm going to measure the MAF ID with calipers before install to double check, but according the CS's site: "True 3.5" MAF: The Power Series 3.5" system is a true 3.5" inner diameter for maximum flow to get the most out of you performance mods" Also, for the MS3 they list a few different SRI/MAF housing or SRI to stock TIP. Here's what they are selling as of today: -CORKSPORT Stage I Power Series Short Ram Intake/stock TIP for Mazdaspeed 3 (after checking all reviews, I eventually found the ID @ 68mm [2.68"] for the MAF housing, but it runs fine without MAF adjustments/tune) -CORKSPORT Stage II Power Series Short Ram Intake for Mazdaspeed 3 (same results as the Stage I for actual MAF ID size [68mm/2.68"], just an added TIP @ the same time) -CORKSPORT 3" Power Series 2007-2013 Mazdaspeed 3 Intake (true ID of 3" for MAF, Cobb AP MAF re-calibration needed) Okay, so those are just CS's offerings in terms of SRI or SRI/TIP kits at this point in time for MS3, both gens. There are some CS CAI systems that use the same CNCed MAF housings as the SRI kits as far as I can tell. No rush on any of this, just thought it would be good to fill in any blanks.
__________________ All Go, No Show 2013 LSM W/ Tech CORKSPORTFull Race RMM CORKSPORTPMM CORKSPORTTMM CORKSPORTTMIC(temporarily uninstalled for Warranty BS) CORKSPORTECU RELOCATION BATTERY BOX(temporarily uninstalled for Warranty BS) CORKSPORTSSP CORKSPORTSHIFTER BUSHINGS CORKSPORT3.5" POWER SERIES SRI/TIP(temporarily uninstalled for Warranty BS) CORKSPORTBPV(temporarily uninstalled for Warranty BS) CORKSPORTRSB @ Full Stiff CORKSPORTMid Chassis Brace CORKSPORTHood Struts + decals for 20whp CORKSPORTLicense Plate Frames COBBAP v3 w/ Window Mount AUTOTECHHPFP INTERNALS ToBeInstalled: CORKSPORTFull Catless TBE, Rear Trunk Brace, Adjustable FELs, Cold Air Box (modified for 3.5") dbaDBA42962S Front and Rear Rotors StopTechRear Braided SS brake lines JBROCC & VTA OCC kit, EGR BO, Boost Tubes Cooling MistWMI kit StratifiedCustom Tune (as soon as TBE is on) On Deck wilwoodFastbrakes DP4front Caliper kit (w/ bp-10 pads and braided SS fr lines) Hawk PerformanceHB478F.605 or HB478Z.605 rear pads BilsteinB16s |
| The Following User Says Thank You to Awal For This Useful Post: | Lex (05-23-2015) |
![]() | | #297 | ![]() |
| Not Ranked : 0 score Well, after a nightmarish Corksport 3.5" SRI/TIP install with a basic craftsman socket/ratchet set (the one I carry in my trunk) and an assortment of really shitty and short pliers/screwdrivers in my GF's driveway, she dropped my phone into the fender well.. I few pop-clips and some fecking around later I retrieved my phone and cleaned up the tools/parts etc. I had ealier reflashed my car with Cobb's OTS "safe 91 oct" map and i was blocking her car in, so I tried to fire it up... It started, and died, which is what I expected, but it was enough to move the car to let her out. I took my AP to my PC, used the 3.5" tru flow JBR MAF calibration values from Alex's OP, loaded them into my ATR on top of the same OTS map I used earlier, renamed it "safe 91 oct + 3.5 SRI", loaded it to the AP, flashed it to the car, and Boom, fired right up. Let it warm up to a regular idle, and it settled down nicely, took it for a rip (sooo glad to have that familiar turbo whine back) and it's running quite well. TC came on in 3rd and 4th many o times, and I wasn't even pushing her.. I love the cool night air up here ![]() Thanks again Alex and Stratified!
| The Following User Says Thank You to Awal For This Useful Post: | Lex (05-25-2015) |
![]() | | #298 | ![]() |
| The Following User Says Thank You to Lex For This Useful Post: | Awal (05-25-2015) |
![]() | | #299 | ![]() |
| Not Ranked : 0 score Indeed we do, internals and TBE 1st though! I know there's a bunch of power lurking in my mods so far, especially on 94 octane, but best to get everything installed 1st.
![]() | | #300 | ![]() |
![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 99
| Not Ranked : 0 score question about the Corksport maf cal table posted in the first post. Those numbers look quite a bit larger than the Corksport numbers in Cobbs Corksport cal included in thier maps. These numbers look bigger than the ones for the other 3" systems listed as well. is this done on purpose or is it a typo or is it for a different intake system? thank you.
__________________ 06 Speed6, camber balljoints and alignment, HankookV12 Evos, Konigs, Corksport full intake system, PTP pump internals, Cobb Ap, Forge BPV. Daily driver 91 Talon TSi, 5spd AWD, GT3076R, fmic, 3" exhaust, Jackal EMS, methanol injection, JIC C/O and more. Looking at 10's |
![]() | | #301 | ![]() |
![]() Join Date: Jul 2013 Location: Spokane, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 94
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score Back from the dead. Im currently running a 3.5 Jrb wide. im using versa tuner. I started to change the MAF settings, but I got to the point where it wouldnt go past 105.8. So what do I do? |
![]() | | #302 | ![]() |
![]() Join Date: May 2012 Location: Austin TX
Rep Power: 342 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 343
| Not Ranked : 0 score Holy shit 105 POUNDS of air per minute? Lol check your units homie |
![]() | | #303 | ![]() |
![]() | | #304 | ![]() |
| Not Ranked : 0 score So do i have to go from lb/min to grams/lb |
![]() | | #305 | ![]() |
Groans: 143
![]() | | #306 | ![]() |
| Not Ranked : 0 score And multiply by 60, the guideline numbers are for grams/sec |
![]() | | #307 | ![]() |
| Not Ranked : 0 score I changed my settings in my tuner. Now I'm able to see grams/sec Sent from my SAMSUNG-SGH-I337 using Tapatalk
__________________ 2007 Mazda CX-7: Custom FMIC, Forge V1 BPV, Grimmspeed 3 port EBC, BNR S3 turbo, 3 inch Catless DP, Muffler Delete, JBR 3.5 intake, Autotech HPFP Internals, JBR OCC, Vogland Springs. Stereo: Two Memphis 10" Subs, 2 Memphis 1.500 Amps. Memphis 4.50 Amp, Image Dynamics Components and Coaxials. |
![]() | | #308 | ![]() |
![]() Join Date: May 2011 Location: Portland OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,451
Here in Portland, OR with 40-50F temps.
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. | |
| The Following User Says Thank You to breakfstincluded For This Useful Post: | Lex (01-27-2016) |
![]() | | #309 | ![]() |
(Thread Starter) | Not Ranked : 0 score Glad it has helped! Thanks for the kind words.
| The Following User Says Thank You to Lex For This Useful Post: | breakfstincluded (02-01-2016) |
![]() | | #310 | ![]() |
![]() Join Date: May 2016
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Hi all, Ive recently copied the table for a htp 3" intake onto my map. However, now when i go to reflash the ecu via my APA V3 it says the map is locked (grey in colour). How do i unlock the map?? |
![]() | | #311 | ![]() |
Rep Power: 3748 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,746
| You need to update your AP to the latest firmware, update ATR to the latest revision, open the relevant map in ATR, save it, load it on the AP, and then flash the map.
![]() | | #312 | ![]() |
Also, just wanted to say thank you @Lex;! Used your template for my 4" intake on my new setup and fuel trims at idle are within 3%. I'll get around to doing some maf cals after my exhaust isn't scraping the ground.
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings | |
![]() | | #313 | ![]() |
| Not Ranked : 0 score So i did update ATR and it still didnt work. Maybe theres an uapdate for the AP im not to sure. Ill check it out later tonight. Thanks for all your help. |
![]() | | #314 | ![]() |
| Not Ranked : 0 score Hi all, ive update the atr software and the AP itself and it still wont work. Ive just realised that the serial number for the map (when about to save) doesnt match the serial number on my AP. Does anyone know how to change the S/N as i think thats why the map gets locked and i cant reflash the ecu |
![]() | | #315 | ![]() |
![]() Join Date: Apr 2012 Location: port orchard, w.a
Rep Power: 501 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
| Not Ranked : 0 score Resave the map
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned |
![]() | | #316 | ![]() |
| Not Ranked : 0 score Ive been trying to, but when i go to save the map it doesnt give me the option to change the serial number?? |
![]() | | #317 | ![]() |
| Not Ranked : 0 score When you request a copy of ATR from Cobb you need to supply the serial number for your AP as part of the request. Cobb sets the serial number as part of the working key in ATR then provides you the special download link. Every time you save a map it links to that serial number. If the serial number was incorrect as part of that initial request, or if you're using ATR from any other source than directly from Cobb, it's most likely that the serial number that is saved to the map is not one that matches your AP. That means saving or resaving the map in ATR will not match the serial to your AP, and when you try to flash the map to your ECU it will appear grayed out and you will get the message that the map is "Locked to Serial XXXXXX" The only way to correct that would be to make a new request to Cobb with the correct serial number. Currently Cobb is "retooling" ATR and it is not available via the website. You can call them directly and let them know what's up- they may hook you up.
![]() | | #318 | ![]() |
(Thread Starter) | Not Ranked : 0 score Also keep in mind that if this is an OTS map or a map you made you will be able to save and modify it. If it was built by a tuner using ATP, you won't be able to open or modify it using ATR.
![]() | | #319 | ![]() |
Groans: 438
| Not Ranked : 0 score If you need a 2010-2013 version of ATR I can help you out. PM me with your email and I'll send you over the ATR install file.
__________________ All good things must come to an end... |
![]() | | #320 | ![]() |
Groans: 143
| Not Ranked : 0 score Yeah but the problem is that your ATR has your serial number locked to it. He still won't be able to flash any maps using it.
| AccessTUNER and Stage2 Calibrations Available for 2010 MAZDASPEED3! | Travis@Cobb | 2010 MS3 - ECU Computer Tuning | 173 | 03-25-2011 08:31 AM |
| Video: Fórmula Truck - The bigger they race, the bigger they crash | Haltech | Automotive News | 0 | 08-02-2010 09:50 AM |
| Copying MAF calibrations between maps | smakdown61 | Cobb ATR Support | 3 | 04-21-2009 02:52 PM |
| V1.03 Calibrations Now Available for Mazdaspeed3 AccessPORT | Cobb Tuning | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 01-09-2009 05:54 PM |
| Spy Shots: Next Pagani Zonda packing big engine, bigger intakes | Haltech | Automotive News | 1 | 05-14-2008 05:02 PM |
