| Enter the 36 Chambers ![]() Join Date: May 2009 Location: Beverly Hills, FL
Rep Power: 1632 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,746
(Thread Starter) | Not Ranked : 0 score I ordered a tune and ebc last night. I'm looking forward to working with the guys at Stratified to make a good reliable street tune to wake this car up safely. When it's done, I will hit up a dyno for some camparisons and final numbers and post up in here.
GTX3071r : Tial MV-S 38mm ewg : COBB AP : Stratified ebc : CP-E HPFP : CP-E Safe seals : COBB fmic v2 : HKS bov : HTP 4" intake w/battery tray : DNP turbo mani : ATP catless dp : Mazdaspeed cbe : JBR trilogy : TWM sts : MattDamond occ v2 : NGK6510's : Eibach Prokit : Koni Yellow's : Corksport front endlinks : Corksport RSB : JBR EGR Delete : Kozmic Motorsports Primary EGR Delete : TB coolant bypass : Relentless Customs PnP intake mani : Bosch 3 Bar Map Sensor : Bitwise Motorsports Bosch MAP Sensor Connector : South Bend stg3 endurance clutch : 17x8 Enkei TSP5 : Hankook v12 245/45 SP63 Longblock Head= Mild bowl work as well as mild porting on intake/exhaust. Bottom end= SP63 Weisco 9.5:1 - 87.5mm : Head Studs 10mm L19 : Manley H-Beam : Rod Bolts ARP Custom Age 625 : Coated Clevite Main & Rod Bearings Last edited by NoRegrets; 08-16-2014 at 12:12 PM. | |
| The Following 2 Users Say Thank You to NoRegrets For This Useful Post: | Lex (10-29-2013), Mike@Stratified (10-29-2013) |
![]() Join Date: Nov 2011 Location: Lex. Park, Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 866
| Not Ranked : 0 score You're in good hands man. I haven't met Alex yet, but Mike is a really cool dude.
__________________ '12 MS3 Black Mica w/ Tech COBB AP V3 >> AUTOTECH HPFP >> HTP 3.5" >> ATP DP (catless) >> AXLEBACK (no mufflers) >> COBB PIPING/TR6 CORE >> JBR RMM >> SSP/BUSHINGS >> RSB >> STG. 2 OCC >> HYPNOTIC TUNED: tehmadscientist & senor finkle |
| The Following User Says Thank You to manila For This Useful Post: | Lex (10-29-2013) |
(Thread Starter) | Not Ranked : 0 score alex just contacted me last night. going to get some datalogs for him today to get this thing started!
GTX3071r : Tial MV-S 38mm ewg : COBB AP : Stratified ebc : CP-E HPFP : CP-E Safe seals : COBB fmic v2 : HKS bov : HTP 4" intake w/battery tray : DNP turbo mani : ATP catless dp : Mazdaspeed cbe : JBR trilogy : TWM sts : MattDamond occ v2 : NGK6510's : Eibach Prokit : Koni Yellow's : Corksport front endlinks : Corksport RSB : JBR EGR Delete : Kozmic Motorsports Primary EGR Delete : TB coolant bypass : Relentless Customs PnP intake mani : Bosch 3 Bar Map Sensor : Bitwise Motorsports Bosch MAP Sensor Connector : South Bend stg3 endurance clutch : 17x8 Enkei TSP5 : Hankook v12 245/45 SP63 Longblock Head= Mild bowl work as well as mild porting on intake/exhaust. Bottom end= SP63 Weisco 9.5:1 - 87.5mm : Head Studs 10mm L19 : Manley H-Beam : Rod Bolts ARP Custom Age 625 : Coated Clevite Main & Rod Bearings | |
(Thread Starter) | Not Ranked : 0 score It's finally done, and I'm very happy with the way the car runs now. It took a while because the ms3 was being a bit difficult, but Alex was able to figgure the issues out and now she runs like a champ. I will post up some before, during, and finall datalogs so you guys/gals can see the progress that was made. Eventually, I will hit up the track and a dyno to get some numbers as well... granted, my track times won't be all that grate since I only get to go once, maybe twice a year. But I'm sure you all will get the idea of how well she's running. Once again, thank you very much for putting in the time and effort to give me a good, strong, safe tune Alex.
| The Following 3 Users Say Thank You to NoRegrets For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Ok, I have some virtual dynos. 1, is just the final Stratified tune. 1, is a comparison of the Cobb ots Stg2 93oct, Stratified, and MPT tunes. 1, is a comparison of the above as well as the MPT dd tune, and the Stratified base map we started off with. As you can see, the Stratified tune isn't the most powerful, but it's the cleanest and safest. I will post up the datalogs as well for everyone to look at and compare. Ignore the fact that the MPT race tune has zero kr, the sensor is turned off so the car doesn't pull timing when used. Don't even ask why the Cobb tune is so ridiculous... I did 2 pulls and it came out like this both times. Please keep in mind, I have 86k miles on the car and have yet to do a valve cleaning. Which could be the cause of the kr and the lack of performance. I use Mobil 93oct fuel and Rotella T6 oil. I'm going to clean my valves this weekend. So I will try to get some new datalogs with just the Stratified tune to see if it helped. Thanks for looking.
| The Following User Says Thank You to NoRegrets For This Useful Post: | Lex (02-02-2014) |
I am glad we were able to get a tune for you that is safe for the car. Even on the ST final tune you can see you are right on the edge of knock where it should be. With the MPT tune and 22psi of boost, 16* of timing and the knock sensor turned off, the poor motor must have been knocking like crazy.
| The Following User Says Thank You to Lex For This Useful Post: | NoRegrets (02-02-2014) |
(Thread Starter) | Not Ranked : 0 score I believe the Cobb run acted up becuase I didn't give it a couple of days to settle in.
(Thread Starter) | Not Ranked : 0 score Oh I'm sure the MPT race tune knocks like a guy with ocd lol. Lots of power at the cost of the life of the engine/turbo. Becuase if you look at the dd tune from them, it's filled with knock.
(Thread Starter) | Not Ranked : 0 score And here it is. 86k on the car. Did OCC around 5-10k and did an egr delete at 65k. My valves were pig filthy with gunk. The pic of the crud on a napkin was just from 1 runner. Car runs smoother now. I'm going to wait for everything to settle back in then take some new datalogs to show how it has helped the car. also, did an compression test. 1 - 180 2 - 180 3 - 172 4 - 180
| The Following User Says Thank You to NoRegrets For This Useful Post: | Lex (02-09-2014) |
| Not Ranked : 0 score Very nice results sir! Also very interested to see the after logs.
(Thread Starter) | Not Ranked : 0 score And here it is folks. A before and after vd chart from cleaning valves. You can see I did manage to pick up some extra hp but lost a little tq.
| Not Ranked : 0 score How did the intake and bat temperatures in the two pulls compare?
(Thread Starter) | Not Ranked : 0 score I knew i should have uploaded the datalogs as well. I'm away from my computer at the moment, but when i have a chance I will post both datalogs so people can compare them.
| The Following User Says Thank You to NoRegrets For This Useful Post: | Lex (02-16-2014) |
(Thread Starter) | Not Ranked : 0 score ok, so here are the datalogs from before and after the valve cleaning
(Thread Starter) | Not Ranked : 0 score So I went a snagged a PnP intake mani from Relentless Customs and then had a touch up tune done. Here are the end results. Keep in mind, when I did these current datalogs, it was a little warmer and a bit windy compared to when I did my datalogs for the last tune after I had cleaned my valves. So my HP numbers are probably lower than they would have been if I was able to do them in the same exact conditions... cooler/calmer.
(Thread Starter) | Not Ranked : 0 score Yep, good ol' wind strikes again But I went ahead with the datalogging because temperature wise, this was closer to my initial loggs before the PnP manifold. I could feel it pushing me around and it felt like it took a little longer to hit redline. But that's why i just went ahead and posted this up. Even though I was fighting the wind, I still was able to show some gains. We will see what she does on an actual dyno when a dyno day comes up around here in Florida. Thanks for your time Alex.
| The Following User Says Thank You to NoRegrets For This Useful Post: | Lex (03-30-2014) |
(Thread Starter) | Not Ranked : 0 score Hey @Lex; If I go from a high flow catted dp to a catless one, would I need a refresh tune or just have you turn off a CEL?
| The Following User Says Thank You to Lex For This Useful Post: | NoRegrets (04-12-2014) |
(Thread Starter) | Not Ranked : 0 score Thanks Alex. I haven't done it yet, just entertaining the notion. I've had my current dp for about 5 years and i'm sure the high flow cat is getting pretty gunked up. I will make sure to send you some logs if I do bite the bullet and get a new dp.
(Thread Starter) | Not Ranked : 0 score @Lex; I'm about to bite on upgrading to an gtx3071r. I'm on stock block still and want to run internal wastgate. What spring rating do you recommend? 8, 14, or 22? Thanks, Damian
You can also port the wastegate but do so carefully. Overdoing it can kill response.
(Thread Starter) | Not Ranked : 0 score So it's better to have a high flow cat than catless dp when running iwg?
![]() | | #24 | ![]() |
| Not Ranked : 0 score If you are running a big intake and nice flowing intercooler a cat will prevent creep from the ATP IWG.
| The Following User Says Thank You to Lex For This Useful Post: | NoRegrets (07-03-2014) |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score I never knew that a catless dp would cause boost creep with an IWG ATP turbo. You just saved me some money because I was going to swap out my CP-E catted for an ATP catless. As you know I'm currently running the v2 Cobb fmic, so I'm good there. I will be upgrading my intake to the HTP 3.5 sri. Do you know if the current ATP turbo kits have everything I need, as in oil/water lines or are they still lacking and need to be bought seperately? Will i still need to swap out the elbow that goes from turbo into intercooler pipeing, or does that come with the curent kit as well? I know these are a lot of questions, but I would like to get all I need in 1 order instead of finding out I needed other things. Thank you for your time Alex.
| The Following User Says Thank You to NoRegrets For This Useful Post: | Lex (07-03-2014) |
![]() | | #26 | ![]() |
| Not Ranked : 0 score I have a customer right now with the following modifications: Mods. ATP GTX3071, JBR 3.5" SRI old aluminum, Cobb AP V3, Autotech HPFP, 3 Bar Map Sensor, GrimmSpeed 3 Port EBCS, Guardian Angel, eBay Downpipe catless Tokay V2 Injector Seals, Treadstone TR8 Intercooler, CX Racing FMIC Piping Kit, CP-E Triton CBE, NGK Plugs, PNP Intake Manifold, DO Stage 2 WMI kit D10 Forge V1 BPV On spring pressure alone he gets above 23psi in hot weather and 3rd gear. So he is getting some major creep. You can port the wastegate but if the cat in your current DP is fine, I would stick with it. If you want to run catless I recommend going EWG. I am pretty sure you still need the extension for the elbow on the ATP turbos. Are you buying your parts from Edge? The vendors who handle these turbo kits everyday would be able to have the latest updates on what they include.
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score I messaged the guys at Edge, But I'm sure they're flooded due to the sale going on. So I was hopeing you might have known how the current kits are thrown together since you guys tune a lot of our cars. I realy appreciate your time and look forward to our tuning process when I get all this together and installed.
![]() | | #28 | ![]() |
ATP Turbo GTX3071R Bolt On Turbo Kit Upgrade Mazdaspeed 3 MS3 I don't think anything has changed since this good install article was posted but when placing the order definitely check with Edge: Cld12pk2go's ATP GTX3071 Build On top of the odds and ends to bolt the turbo and the other modifications you mentioned you will also need: - A 3 port solenoid to control boost - A 3 bar MAP sensor and PNP harness for going above 21.5psi of boost We have the 3 port on a slight discount if bought together with the tune.
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score ATP Turbo External Wastegate Bolt On Turbo Kit Mazdaspeed 3 MS3 My friend just pointed out this kit. Never noticed it before. It has the housing on the hotside for an external wastegate and it allows you to keep your exsisting turbo manifold. I think I will try this out. Hopefully it works out. Have you ever done any tuning for this specific setup before @Lex;?
![]() | | #30 | ![]() |
Yes I have tuned a good number of these. Boost creep and control were not an issue with this setup which is a positive. However I am not the biggest fan of the placement of the EWG in terms of flow through the exhaust housing and turbine. I do like the simplicity and cost effectiveness of the setup and the fact that creep is not a problem.
| The Following User Says Thank You to Lex For This Useful Post: | NoRegrets (07-04-2014) |
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score I went ahead and placed my order with edgeautosports. This is what I purchased: ATP Turbo GTX3071R EWG Bolt-On Turbo Kit OEM Downpipe Gasket (Upper) OEM Manifold Turbo Gasket Bosch 3 Bar TMap Map Sensor with IAT Bitwise Motorsports Bosch MAP Sensor Connector HTP 3.5" Intake System + 51R Battery Tray Combo Kit Kozmic Motorsports Primary EGR Delete Kit @Lex; When should I order a fresh tune for the new setup? About a week before the install?
| The Following User Says Thank You to NoRegrets For This Useful Post: | Lex (07-04-2014) |
![]() | | #32 | ![]() |
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score Most of my stuff showed up. Just waiting on my turbo kit. @Lex; When I hook up the ebcs, is it best to stay in 2 port or switch over to 3 port with this new set up?
![]() | | #34 | ![]() |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score OK, thank you Alex. Like I said, I will contact you for the tune a week before I do the install.
| The Following User Says Thank You to NoRegrets For This Useful Post: | Lex (07-16-2014) |
![]() | | #36 | ![]() |
| Not Ranked : 0 score Sounds great, looking forward to it.
![]() | | #37 | ![]() |
![]() | | #38 | ![]() |
![]() Join Date: Dec 2008 Location: FLORIDA
Rep Power: 1419 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,235
| Not Ranked : 0 score That looks nice.
__________________ 2008 Mazdaspeed3 GT GTX2867r ![]() |
| The Following User Says Thank You to Scare Dem For This Useful Post: | NoRegrets (07-18-2014) |
![]() | | #39 | ![]() |
(Thread Starter) | Not Ranked : 0 score Sorry Alex. I was informed by my manager that I'm going to have to work that weekend because he will be out of town. So the new date will be August 9th. I will purches my BT tune around the 1st, that way it gives you time to give me a base map to break in the turbo with. How many miles do you suggest for a break in period?
![]() | | #40 | ![]() |
| The Following User Says Thank You to Lex For This Useful Post: | NoRegrets (07-20-2014) |
| Nap Time to Lap Time: 74-year-old James Hylton to race at Daytona | Haltech | Automotive News | 0 | 11-27-2008 04:40 PM |
