E-Tuners / Custom Hardparts
 Old 12-15-2012, 01:32 PM   #1
Default Tunes now bundled with the 3 Port Solenoid and Guardian Angel
Just updated the products on the site as promised to make one stop shopping easier and save you guys a few $$ for the support. When you purchase a Stratified Tune you can now choose to also buy a 3 Port EBCV or a Guardian Angel at a discount from listed price!
The Following 9 Users Say Thank You to Lex For This Useful Post:
Dimenus (02-13-2013), exentix (12-15-2012), Menace1 (01-31-2013), Mike@Stratified (12-15-2012), MS6 Sanchez (04-28-2013), NoRegrets (04-24-2013), obijack (04-24-2013), Pointless (12-15-2012), snailD (04-24-2013)
 Old 04-24-2013, 02:25 AM   #2
Sum1UDidntC's Avatar
Posts: 157   (View Stats)
Sum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond repute
what if we want both the GA and the EBCS with the tune? any more-special discount?
2011 Black Mica MazdaSPEED3 // CS SRI // CS TIP // HKS SSQV-IV VTA w/ CP-E flange // CP-E FMIC // CP-E Triton CBE // CP-E Catted DP // CP-E HPFP // CP-E Stage 2 RMM // COBB AP With Lex Tunes // JBR SSP // JBR 88DM TMM //JBR 80DM PMM // JBR custom cylindrical shift knob // JBR SSB's // Rally Armor Mudflaps // ISC Coilovers and front end links // Denso ITV-22's // SPC Camber Arms // Michelin Pilot SuperSports // STRATIFIED LEX TUNED FTMFW
Mustang Dyno Results:
301WHP 334WTQ on 35% E85
282WHP 325WTQ on 92oct
Sum1UDidntC is offline   Reply With Quote
The Following User Says Thank You to Sum1UDidntC For This Useful Post:
Lex (04-24-2013)
 Old 04-24-2013, 03:04 AM   #3
cletusb's Avatar
Posts: 488   (View Stats)
Does the GA work with a synapse bpv?
The Following User Says Thank You to cletusb For This Useful Post:
Lex (04-24-2013)
 Old 04-24-2013, 10:18 AM   #4
From what I saw, the Synapse is not a push type valve. It is similar to the HKS which does not work unfortunately due to the valve design.
 Old 04-28-2013, 01:13 AM   #5
cletusb's Avatar
I think it can be set up in either push or pull type if I remember correctly
Lex (04-28-2013)
 Old 04-28-2013, 01:32 AM   #6
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Synapse can be configured in push or pull, that is correct. To quote an old thread...
"Push vs. Pull mode - The Diverter Valve can be configured to run in either "Push" or "Pull" mode. In speaking with David from Synapse, he says Push mode is not recommended for high boost installations where the boost pressure could force the piston open resulting in a boost leak. "Pull" mode is recommended because as boost increases, it exerts more force onto the piston, making the seal even tighter.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
The Following 3 Users Say Thank You to mrmonk7663 For This Useful Post:
atvfreek (04-28-2013), cletusb (04-28-2013), Lex (04-28-2013)
 Old 04-28-2013, 02:52 AM   #7
cletusb's Avatar
What would be considered as '' high ''?
 Old 04-28-2013, 09:38 AM   #8
mrmonk7663's Avatar
20-21 psi...as this is right around where the factory push configured valve tends to have issues...that's how I personally would determine high when running this valve.
Guardian Angel VTA...how? iammike 2010 MS3 - Engine, Transmission & Driveline 21 11-23-2012 12:41 AM
A Guardian Angel Looking Over Me...... Novej Stratified Automotive Controls 3 09-07-2012 05:22 PM
Guardian Angel help? MS6FL Mazdaspeed3/6 General Discussion 2 04-28-2012 07:13 PM
How-To Install Guardian Angel Dano Stratified Automotive Controls 5 03-31-2012 03:04 PM
Guardian Angel Install the_rolex_guy Stratified Automotive Controls 7 03-25-2012 06:03 AM
Page generated in 0.28362 seconds with 23 queries
