![]() | | #41 | ![]() |
![]() Join Date: May 2010 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 65
| Not Ranked : 0 score
__________________ 2008 MAZDASPEED 3 METRO GREY SOLD 2009 BMW 335i STOCK FOR NOW |
![]() | | #42 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
(Thread Starter) | Not Ranked : 0 score Not really, it doesn't spool as fast as the k04, it's just a gnats ass slower and drivability is just fine. It won't spool if you floor it at 2k rpm but that's not a minus in my book. My wife bitches about it, says it feels slower than the stock turbo, but thats because she refuses to downshift cause "it makes the engine make too much noise." Zigatapatalka
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
![]() | | #43 | ![]() |
| Not Ranked : 0 score Apparently with a little more funds you can get other turbos but this is the one I have my eyes set on...Big turbo but keeping stock location, manifold, my stock appearance, etc. seems to peak my interest.
![]() | | #44 | ![]() |
![]() Join Date: May 2011 Location: Las Vegas NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
| Not Ranked : 0 score Great write up.
__________________ 2007 MS3 Black Mica-Totaled @98500 on 09/2014 ![]() Current Car... 2009 MS3 Black Mica GT JBR TRU 3.0 Widepath full intake, BNR S3 v1, GS EBCS, 3 BAR , Forge BPV V2, Autotech internals , Denso Itv22, CNT Downpipe, CX-Racing piping with Cobb v2 core, Cobb AP v2, JBR RMM, JBR PMM, JBR TMM, JBR Oil Catch Can, EGR Delete, JBR TIG, Toyota Seals, HTP battery tray, DashHAWK Zoom Zoom |
![]() | | #45 | ![]() |
| Not Ranked : 0 score Awesome write up. Love this turbo...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
![]() | | #46 | ![]() |
I would be very interested in the EGT install info...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
![]() | | #47 | ![]() |
(Thread Starter) | Not Ranked : 0 score Step 1: Install EGT Lol, just PM me any questions you have. Its really pretty simple. My Bung location sucks, but puts the probe right in the middle of the collector. I ran the leads from the probe thru the hole in the firewall for the hood release. There are plenty of gauge install threads, I put mine in the vent pod, and used the 12V, ground & headlight switch harness I made for my oil pressure and temperature gauges.
![]() | | #48 | ![]() |
Check out Bucker and Blakkat's threads for some strange LTFT breakpoint talk. | |
![]() | | #49 | ![]() |
![]() | | #50 | ![]() |
(Thread Starter) | Not Ranked : 0 score I will grab a picture of it later. Its sticking out of the manifold directly towards the firewall so I had to cut a slit for it in that heatshield. As for where I would do it with another shot, I would have it stick out at an angle between where it is, and straight out the turbine side. Straight out the turbine side would be best, but the #4 runner makes that weld difficult to access. Zigatapatalka
![]() | | #51 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here is a picture of it, you can see how I had to cut a slit in my heatshield so the sensor will have room to move with the engine. If you were to move it towards the 02 sensor more you could avoid this. You can see the uninstalled bung location in this picture: Looking at it, the best EGT Bung location is pointing straight towards the compressor side of the turbo. I was worried about spacing to the compressor housing outlet (I didn't have my turbo yet when I specified the bung location) so I didn't put it over there, but there is plenty of room.
![]() | | #52 | ![]() |
| Not Ranked : 0 score What EGT's are you seeing?
![]() | | #53 | ![]() |
(Thread Starter) | Not Ranked : 0 score @22psi, redline, 8* timing and 11.3 AFR I was seeing 1750, at 20.5psi, 10.5* timing it's more like 1700. E85/Meth is in my future, from my tuning thread you can see BATs are getting out of hand, causing knock on the top end. I may have a leaky BPV though. Zigatapatalka
![]() | | #54 | ![]() |
| Not Ranked : 0 score I have added ~6° over the past couple of months. It is a shame I don't have EGT data to note the impact.
![]() | | #55 | ![]() |
![]() Join Date: Jul 2008 Location: Syracuse, NY
Rep Power: 2506 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,527
| Not Ranked : 0 score Good work and thanks for the write up. :tup:
__________________ ![]() Anthony D. Christiano - Co-Owner at Inspiration Studios Photography 2008 CosmicBlue Mazdaspeed3 294whp/335wtq - Stock K04 370whp/370wtq - BNR stage 3 FreekTuned, BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, Devil's Own Meth Injection D10 Nozzle, 3-Bar Map & Plug & Play Connector, PTP Injector Seals & Studs, KritzSpeed 3-Port BCS, Sure Return, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back, CP-E FMIC, TWM STS, TWM A6 Leopard Shift Knob, TWM Leather Shift Boot, AutoTech Fuel Pump Internals, JBR trinity, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 + 5/16" spacer (ET40), SPC camber arms, Cobb Rear Sway Bar, Nitto NT05 235/40/18 (front) BF Goodrich g-Force Sport 235/40/18 (rear), MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
![]() | | #56 | ![]() |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Not Ranked : 0 score das turbo
__________________ [01:31 PM] SoAgg159: my dick is called "quarter mile" it's about 1/4" long and i can give about 14secs of pleasure [07:06 PM] DarkHeartMS6: yeah. I actually hope i catch my wife with another dude. gives me an excuse to open the emergency door and bail. LOL [09:13 PM] Pu Manchu: i like to take my gf through the drive thru so i can prove that i can pleasure a woman |
![]() | | #57 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1904 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
| Not Ranked : 0 score Give us some updates chief. Logs, VD, etc etc
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp |
![]() | | #58 | ![]() |
(Thread Starter) | Not Ranked : 0 score As you saw I have not updated this thread or the tuning one recently. I found that premium gas was not up to snuff @ 22psi so I have been using a 3/9 mix of ethanol. I will post logs in the tuning thread, but leave this here. Initial torque "bulge" was due to a slight downhill at the start of the log. Tuned using load with a 22psi boot (cap) that results in a flat 400wtq curve. You can see it spools slightly before 3000RPM and between the extra timing from ethanol, and the VVT changes I made, throttle is VERY responsive.
![]() | | #59 | ![]() |
| Not Ranked : 0 score IMO, with the positive results that e-85 is getting, and the creep issues (and necessary adjustments *ahem*) of the gtx3071, this is an all around great option. Thanks again for the thread Ziggo. |
![]() | | #60 | ![]() |
This turbo is likley capable of maxing the stock maf if BATs are much below 80* so I will have to keep an eye on it.
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk | |
![]() | | #61 | ![]() |
![]() Join Date: Jul 2010 Location: Chicago IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 135
Groaned at 7 Times in 3 Posts
| Not Ranked : 0 score thanks again for this write-up mang. BNR s3 is currently en-route by tuesday, installed by thursday/friday/ saturday pending no hiccups in the removal/installation. lately this fucker has been fighting me on everything i do to it... |
![]() | | #62 | ![]() |
![]() Join Date: Nov 2010 Location: Lido Beach,NY
Rep Power: 8624 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,845
Groans: 95
| Not Ranked : 0 score MT seems to be a good way to go for the d.d. thanks for the great write up with your trials and tribs! @Ziggo
__________________ Nator is what it does. |
![]() | | #63 | ![]() |
![]() Join Date: Jan 2010 Location: Greece, Thessaloniki
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
| Not Ranked : 0 score Tomorrow Im going to swap mine. I hope everything goes well.
__________________ CX-7 2008 awd manual bnr s3 [SIGPIC][/SIGPIC] |
![]() | | #64 | ![]() |
![]() Join Date: Jun 2009 Location: Riverside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,560
Groans: 50
| Not Ranked : 0 score Very nice write up Chris
__________________ 08 Mazdaspeed 3 Fucking FREEK TUNED and shit |
![]() | | #65 | ![]() |
![]() Join Date: Nov 2010 Location: Moscow, Russia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 208
| Not Ranked : 0 score Just FYI I have a BNR S3 installed on my ms6 for more than 10k miles and it is very nice for a dd car. The car pulls pretty well and makes no smoke. My friend's Infiniti g37s stays behind in a traffic light race (I launch at 2-2,5k rpm). With a very conservative tune it makes 300 hp at 1bar of boost and 91 octane instead of 93 stock. Later, with carillo rods installed, I'll try to push the limits of the setup of mods I have.
__________________ Mazda 6 MPS Velocity Red, cp-e nano, cp-e TIP, BNR Stg3, Custom FMIC, cp-e HPFP, HKS Twin Power DLI2 ignition, HKS M35LF spark plugs, EGR block-off, catless 3" dp with welded in resonator, AutoExe Grounding Earth System, Grimmspeed BCS, AWR competition radiator, JBR SSP, 355mm 4-piston JBT Big Brake Kit, Rays RE30 wheels, Advan v103 tires, etc.. |
![]() | | #66 | ![]() |
| Not Ranked : 0 score I had various problems with the swap of BNR3. First I couldnt approach underneath the turbo, oil drain line and bracket because it is the transfer case there. I did most of work from above. Also at my stock turbo, the routing of the oil feed line is different than ms3/6. The metal line is embracing the stock compressor and I had to cut and fab this line. I used 6mm reinforced oil hose and double clamps. Do you think is it a safe connection? ![]() ![]()
![]() | | #67 | ![]() |
![]() Join Date: Dec 2010 Location: TX
| Not Ranked : 0 score Picture of custom oil feed line? Clamps aren't gonna cut it. You're talkin 95psi of oil pressure at red line. It's going to leak if it's just clamps. Maybe you can order an OEM feed line for an MS3/6 and if it doesn't bolt up, have a shop cut it in half and weld a -4AN fitting on it, then run a -4AN steel braided line to the turbo. You can use the factory feed banjo bolt but you'll need a -4AN banjo fitting.
__________________ 2007 CTS-V - Trying to sell 2009 CTS-V - Not getting a cam. Ever. |
![]() | | #68 | ![]() |
![]() ![]() ![]() ![]() The length of the oil hose is about 4 inches. I used 2 triple clamps to secure on the metal line. Is it required the uninstallation of the alternator in order to remove the stock oil feed line?
__________________ CX-7 2008 awd manual bnr s3 [SIGPIC][/SIGPIC] | |
![]() | | #69 | ![]() |
| Not Ranked : 0 score Interesting. I wonder if there is something in the way on the CX-7 to prevent the use of the regular oil feed line. Anyway, it's a really bad idea to use clamps with rubber hose for a high pressure line. It's going to leak. Yes, our motors hit about 95psi oil pressure at red line. It is technically not necessary, but you would be an idiot not to remove the alternator to work on the stock oil line. Getting the alternator out really isn't that hard. You need a 14mm wrench for the belt tensioner and then I think 12mm socket for the alternator nuts. Just make sure you disconnect both connections from the alternator before trying to remove it.
![]() | | #70 | ![]() |
| Not Ranked : 0 score thanks to your write-up, my BNR swap went as smooth as two half drunk guys could do. only issue so far is I am only hitting 14psi with my OTS tune set at 19psi. I know I know, ATR right? I've got some reading to do... |
![]() | | #71 | ![]() |
![]() Join Date: Feb 2011 Location: Lusby, MD
Rep Power: 496 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 119
| Not Ranked : 0 score WGDC tables^^
__________________ 06 MS6 |SP Built motor - Weisco Pistons .020" over, Manley H-Beam Rods, Ported Head, Ported Intake, VTCS Delete, BS Delete, VVT Actuator, Keyed Crank, 6th Port Fuel Injection | ACT 6 Puck w/ Streetlite Flywheel | Bullseye S259 .70 A/R Single Scroll | 3.5" Intake/MAF Housing | Steedspeed Twin Scroll T3 Top Mount Manifold | Tubosmart 40mm EWG | Custom DP | Custom TBE | Custom LTA Intercooler | HKS Type IV TT | Dashhawk | COBB AP | AWR RMM | PTP HPFP Guts | KILLAH BUILT |
![]() | | #72 | ![]() |
| Not Ranked : 0 score For those who have the same problem than me I modified the stock oil feed line and I solved the issue.
![]() | | #73 | ![]() |
| Not Ranked : 0 score |
![]() | | #74 | ![]() |
| Not Ranked : 0 score That's why when I do go BT I'm going to sit down with a tuner and have him walk me through it. Because I'd like to understand how to do this for myself.
![]() | | #75 | ![]() |
| Not Ranked : 0 score honestly its not that difficult. download and read through abilor's tuning guide and he explains everything pretty well. enough to where you can start tweaking and not be afraid of blowing shit up. http://www.mazdaspeedforum.org/forum/foru...e-noobs-83959/
![]() | | #76 | ![]() |
| Not Ranked : 0 score I learn SO much more and SO much easier with visual aid. I can gernally do anything if I've seen it done once.
![]() | | #77 | ![]() |
| Not Ranked : 0 score his guide has screen shots of ATR in it for help. its not just a bunch of words. if anything its a good read just for the knowlege in case something stupid goes wrong so you can fix it yourself and not have to wait on someone else to help you.
![]() | | #78 | ![]() |
__________________ ![]() Anthony D. Christiano - Co-Owner at Inspiration Studios Photography 2008 CosmicBlue Mazdaspeed3 294whp/335wtq - Stock K04 370whp/370wtq - BNR stage 3 FreekTuned, BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, Devil's Own Meth Injection D10 Nozzle, 3-Bar Map & Plug & Play Connector, PTP Injector Seals & Studs, KritzSpeed 3-Port BCS, Sure Return, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back, CP-E FMIC, TWM STS, TWM A6 Leopard Shift Knob, TWM Leather Shift Boot, AutoTech Fuel Pump Internals, JBR trinity, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 + 5/16" spacer (ET40), SPC camber arms, Cobb Rear Sway Bar, Nitto NT05 235/40/18 (front) BF Goodrich g-Force Sport 235/40/18 (rear), MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz | |
![]() | | #79 | ![]() |
| Not Ranked : 0 score no problem man. let us know how it goes.
![]() | | #80 | ![]() |
![]() Join Date: Mar 2011 Location: Bastrop, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,208
Groans: 273
| Not Ranked : 0 score subbed
__________________ 2011 Black Mica - Daily JBR SSP and heavy knob and SSB | Sure RMM | Corksport SRI/TIP/RSB/TMIC | Tanabe FSTB | Cobb AP getting PERM'd | Autotech internals | H&R springs | DDM HID | pussy delete - catless ebay dp and tp |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f626/bnr-s3-swap-how-125223/ | ||||
| Turbo ausbauen?? - Seite 2 | This thread | Refback | 10-21-2014 02:18 AM | |
| Display Modes | |
| BNR S3 Swap How To | Ziggo | MazdaSpeed 3/6 - Big Turbo Builds | 244 | 12-13-2016 09:07 PM |
| LSD Swap out | Tomas | MazdaSpeed 3 - How-To's | 81 | 10-08-2012 09:16 PM |
| BNR GTX Swap Possible? | Kydizzle | MazdaSpeed 3/6 - Turbo Induction | 12 | 03-28-2012 12:24 PM |
| HID swap | TXspeed3 | MazdaSpeed 3/6 - Appearance | 19 | 06-28-2009 05:04 PM |
