![]() | | #121 | ![]() |
![]() Join Date: Jun 2009 Location: Riverside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,560
Groans: 50
| Not Ranked : 0 score
__________________ 08 Mazdaspeed 3 Fucking FREEK TUNED and shit |
![]() | | #122 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
(Thread Starter) | Not Ranked : 0 score I am mostly OK with where it is now. Only thing I might change is to add some kind of a shim to stand it off the fuse box better to get better airflow over the heatsink on the bottom.
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
![]() | | #123 | ![]() |
![]() Join Date: Dec 2010 Location: TX
| Not Ranked : 0 score That's a funny looking ECU mounting. You would be able to free up the harness enough that the ECU isn't all cock-eyed. What would be sweet is if a company made an ECU harness extender so we could put that bitch wherever we wanted. It would be $$$$ though.
__________________ 2007 CTS-V - Trying to sell 2009 CTS-V - Not getting a cam. Ever. |
![]() | | #124 | ![]() |
| Not Ranked : 0 score Have you had a chance to quantify how much the larger intake has helped k n terms of airflow and power?
![]() | | #125 | ![]() |
| Not Ranked : 0 score If I had to guess...over 9000.
| The Following User Says Thank You to bmylez For This Useful Post: | Gitcherex (12-04-2015) |
![]() | | #126 | ![]() |
(Thread Starter) | Not Ranked : 0 score Not yet, had to turn a couple MAFCAL revisions first, then have to evaluate the effects on WGDC. I dropped it by 10 across the board to start with, but need to make sure I am spike free. Butt Dyno says the turbo spools even earlier now, which at this point is just stupid. I'll have some information up in the next couple days. Unfortunately the HD on my tuning laptop died, so the only comparisons I will be able to make are to stuff that was uploaded here.
![]() | | #127 | ![]() |
(Thread Starter) | Not Ranked : 0 score @Lex @jbarone So I the fueling isn't nearly as stable as it was on the CAI, but I have not gone in depth on the MAFCAL either, this is just 2 global multiplier revisions so I may be able to dial it in with a Cell by Cell MAFCAL. Could also be an indicator of needing an airflow straightener in front of the MAF, but its too early to say for sure. Airflow is pretty much identical to my last posted log with the CAI, but the ambient temperature was 20* lower on the CAI log so I can say with certainty that this will increase airflow significantly if compared at an equal ambient temperature. Note* to obtain actual absolute massflow you need to multiply the number in the Logs by .775 to correct for scaling for my e85 mixture. Both logs are using the same e85 mix, and thus the same correction factor applies to both. JBR WP Log: http://www.mazdaspeedforum.org/forum/foru...1&d=1341687489 Last CAI Log: http://www.mazdaspeedforum.org/forum/foru..._4th_60112.csv Virtual dyno results are not really comparable since they were taken on different stretches of road, but attached it for reference anyway. Red is JBR WP, blue MSCAI
![]() | | #128 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 492
![]() | | #129 | ![]() |
(Thread Starter) | Not Ranked : 0 score Doubtful, back to back logs of the intakes on the same stretch of road would be the only way o directly compare power.
![]() | | #130 | ![]() |
![]() put ECU back where is was and still have room. IIRC a different group battery will fit in their tray without going to a "slim" bat and you gain 2" of space.... ziggo do you think that would be enough space? I want a 3 or 3.25 intake and am making my plans. I like the JBR 1 piece idea but think some straighteners would be a + looking forward to your results and to see if you stabilize your AF curve.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
![]() | | #131 | ![]() |
(Thread Starter) | Not Ranked : 0 score I would put the battery in the trunk first. Not that the HTP isn't a decent piece, just that if I am going to make space, I REALLY want to make space, and shifting a few pounds to the rear wouldn't hurt either.
![]() | | #132 | ![]() |
| Not Ranked : 0 score yeah well I haul stuff in my car all the time w seats down, so bat in hatch is not an option for me at this point. I don't see needing any more than 2 extra inches....lol.... that's what she said anyway
![]() | | #133 | ![]() |
| Not Ranked : 0 score @Dano now I see why you're eager to see my 3" results. I will be doing some back to back testing this coming week. @Ziggo thanks for the info. The earlier spool alone must be very nice.
![]() | | #134 | ![]() |
| Not Ranked : 0 score Yes. Get off ur ass man!! Tappin
![]() | | #135 | ![]() |
| 5000lbs of voiceless fury ![]() Join Date: May 2012 Location: San Diego, CA
Rep Power: 2530 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,855
Groans: 185
Groaned at 124 Times in 81 Posts
| Not Ranked : 0 score Subd
__________________ 2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN! SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs// |
![]() | | #136 | ![]() |
![]() Join Date: Nov 2010 Location: Manchester, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
| Not Ranked : 0 score Freekn tappin
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
![]() | | #137 | ![]() |
1. Go with a 3" or larger but go all the way to the turbo. 2. Use an AEM dryflow filter. It outflows the cotton gauze filters. Over the SRI alone that should give you 10-20 g/s better airflow up top - it lowers the pressure ratio on the turbo.
![]() | | #138 | ![]() |
Groans: 50
| Not Ranked : 0 score I found that using the the specture filter gained me around 5g/s over the aem. I'm running a cai and am on stock turbo
![]() | | #139 | ![]() |
| Not Ranked : 0 score could that 5gs be attributed to a brand new clean specture vs a dirty AEM
![]() | | #140 | ![]() |
Groans: 50
| Not Ranked : 0 score You would think but both of them were brand new.
![]() | | #141 | ![]() |
| Not Ranked : 0 score I will be trying something that "should" be better than AEM as well - we will see. With the OEM turbo its easy to see the difference since the WG is pegged but with a BNR you are not as boost limited unless you're running it up against its limits as well. In any case you will at least see a reduction in WGDC if you're not pegging it already in which case you will see an increase in boost, airflow, and spool.
![]() | | #142 | ![]() |
Groans: 50
| Not Ranked : 0 score Everything was the same except airflow. But its so small of a difference I doubt one will prefer one over the other.
![]() | | #143 | ![]() |
yeah! lex is official! hey BTW what is your take on the Amsoil filters? are they cotton weave? Their surface area appears to trump all others but I don't know if they flow more for sure.
![]() | | #144 | ![]() |
(Thread Starter) | Not Ranked : 0 score Trouble is brewing...
![]() | | #145 | ![]() |
| Not Ranked : 0 score yesssssss, it tis....
![]() | | #146 | ![]() |
(Thread Starter) | Not Ranked : 0 score @djuosnteisn LOGS!, We had a freak cold snap, and it was only 78* at 7am this morning. Note my MAF is scaled 22.5% for my E85 mixture so while I peak a 470g/s in the logs, its actually only 369g/s (49lb/min).. which should be plenty for 400whp.. go go beaner turbo. Seems to be working great. First log is just letting it pop on and drag me rich to verify its functional. Second and Third logs are with closed loop enabled, but no MAF adjustments. I am going to need to soften the turn-on somehow, though in 2 stroke with a minimum pulsewidth of 1ms it has some surge. Calculations got me close to my desired maximum DI IDC of 80%, but there is a bit of lag in the system so I need to turn it on a bit earlier, so an earlier softer turn on seems like a good idea. Then its time to adjust the MAF curve as needed.
![]() | | #147 | ![]() |
| Not Ranked : 0 score Are your cruising BATs always about 30 degress above IAT? Kinda high no?
__________________ |
![]() | | #148 | ![]() |
(Thread Starter) | Not Ranked : 0 score If you are referring to log 2 it was a very short roll in from siting for 20 minutes. I had a failed flash and had to recover and was inspecting all the lines. Zigatapatalka
![]() | | #149 | ![]() |
Groans: 185
| Not Ranked : 0 score This makes me want an S3 so bad... sigh but I need new tires soon
![]() | | #150 | ![]() |
Rep Power: 3167 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score how are you liking the swaintech coating on the turbine housing/mani?
![]() | | #151 | ![]() |
(Thread Starter) | Not Ranked : 0 score It has discolored from it's pearly white state, but no cracks or flaking so I am pretty happy. I don't think there is a measurable benefit in performance spool wise, I was after the the thermal insulative properties to protect other things in the engine bay since all the heat shields are gone. Since it has always been on there I couldn't take before and after measurements, but nothing has in the area has melted and plastics appear to be holding up well, not showing any signs of embrittlement. Zigatapatalka
![]() | | #152 | ![]() |
(Thread Starter) | Not Ranked : 0 score My maf curve is so retarded. Scale up 67% for JBR intake, then another 22.5% for 5/7 mix E85, then subtract 115 from 4.1V and up for AIC1, curve reduction between 3.6 and 3.8 for start of 5th port and flatline between 3.8 and 4.1 as the 5th port becomes fully operational
![]() | | #153 | ![]() |
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
| Discuss Here: BNR S3 Swap How To
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f626/bnr-s3-swap-how-125223/ | ||||
| Turbo ausbauen?? - Seite 2 | This thread | Refback | 10-21-2014 02:18 AM | |
| Display Modes | |
| BNR S3 Swap How To | Ziggo | MazdaSpeed 3/6 - Big Turbo Builds | 244 | 12-13-2016 09:07 PM |
| LSD Swap out | Tomas | MazdaSpeed 3 - How-To's | 81 | 10-08-2012 09:16 PM |
| BNR GTX Swap Possible? | Kydizzle | MazdaSpeed 3/6 - Turbo Induction | 12 | 03-28-2012 12:24 PM |
| HID swap | TXspeed3 | MazdaSpeed 3/6 - Appearance | 19 | 06-28-2009 05:04 PM |
