| Not Ranked : 0 score
| Fux Wit It ![]() ![]() Join Date: Mar 2008 Location: Li
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,795
Groans: 175
| Not Ranked : 0 score high boost, high timing it's either gonna unlock power or melt a piston. I think both will happen in or around the same time lol
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous |
![]() ![]() Join Date: Jun 2008 Location: Greenville, SC
Rep Power: 2562 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,586
Groans: 125
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 | |
Groans: 175
| Not Ranked : 0 score you didn't happen to know power increase vs lets say stock with just timing advance and what EGT's were at do you? I know it was a long time ago but its a long shot. Don't forget cars like the srt-4 run freaking 30-32 degrees advance stock granted they have a lower compression but I fell like that has something to do with them making easy power when push comes to shove and boost is raised plus having an iorn block to take the abuse. P.S thats a real general statement so don't go picking it apart....
Groans: 125
| Not Ranked : 0 score well, dont forget that i also had 8.8:1 pistons. the power increase was something like 360whp to 394whp, but im pretty sure that was after all the other optimization was done like fueling and fuel pressure, etc. i could be remembering this wrong, it was almost a year ago.
| Not Ranked : 0 score Sean had 8.8 : 1 compression as well, which probably helped with that much timing and no meth. When you start adding timing, the power will pick up real fast.... but eventually, it'll plateau. That plateau will last for a surprising amount of further advance... until you finally blow up the motor (rod usually). When i was tuning my car i was up to like 19 degrees (plateau started around 16 ish), on 91 octane and 50/50 wmi. I had no active knock sensor at those rpms so i decided it was only stupid to push it further. But i never saw any signs of detonation... just no more signs of power.
Groans: 125
| Not Ranked : 0 score yea, we saw it plateau around 20. jason (the tuner) said he had run as high as 27* on robbies car with no additional gains, so we stuck to 19-20*
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
| Not Ranked : 0 score Cant wait to see what 50% and a dyno comparison show, good stuff Anthony! |
Groans: 356
| Not Ranked : 0 score pish posh, enough tuning..lets see you run already anthony..i got $50 on you cracking 11s b4 anyone else
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1904 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
(Thread Starter) | Not Ranked : 0 score 19-20 huh! I dont see why my setup on 50% e85 couldnt handle that. I will play with it on the dyno when I go here soon. This tank is about gone so Im gonna add another gallon of e85 to my tank and see how it likes it. Even if I cant go farther than 25% e85, I will continue to run it. Car seems to like it and it gives me a little more peace of mind knowing my octane is around 96. 50% would have me over 100 octane. e85 is only 2.50 a gallon here in boise so at .80 cents cheaper than 93 octane, the mileage I lose will be countered by price difference. Im pretty excited about it. LOL Thats if I can get to sacramento soon enough. I see alot of guys right on the threshold. I hope to be the first 3 atleast. Would be fitting i was the first in the 12s. LOL
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp |
| Banned ![]() ![]() Join Date: Jul 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 126
| Not Ranked : 0 score Just use the e85 to lean the car even more. |
| Not Ranked : 0 score Anthony, you still running without meth? seems to me meth is a better way but what do I know...you are using gas 100% of the time whereas meth only at WOT... Does meth not add more octane/cooling than an e85 mix. not hating over here just axing.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 |
(Thread Starter) | Not Ranked : 0 score From what Ive seen over in the evo community, they can push e85 far past water/meth injection. I dont know from experience but I definately havent seen any of you guys do anything special on meth but clean your motor. LOL Just teasin, I know meth can do cool things past straight pump but I can get e85 right at pump and its way cheap. And all I know is everyone of my friends that have switched from meth to e85 is pushing there tuning way farther and detonation is non existent. From what I understand its damn near impossible to detontate on straight e85.
jussayin signed E85 hater LOL
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
| Not Ranked : 0 score does E85 have a much lower stoich? you should adjust your AFR accordingly to maximize power/fuel economy......
![]() Join Date: Dec 2010 Location: TX
| Not Ranked : 0 score Yeah, stoich for E85 is more like 6:1. |
| Not Ranked : 0 score Hater. Meth hater that is. LOL
(Thread Starter) | Not Ranked : 0 score I run 14 degrees on straight pump gas no problem.
| Not Ranked : 0 score Well I guess my car just sucks. Haha
| Not Ranked : 0 score Indeed e85 has a lower stoich point... but AFAIK the o2 sensor reads in labda... in terms of stoich, regardless what that ratio may be. So whenever it's reporting 14.7... it's basically just saying, "the mixture it stoich". The only reason it says 14.7 is cause mazda figures people will be running gasoline.
![]() Join Date: May 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 22
Groaned at 52 Times in 16 Posts
| Not Ranked : 0 score Ive been running 93oct mixed 50/50 with 110leaded racegas. and its beautiful. everybody is scared but gas is f**king gas.......just dont put 87. lol. leaded gas just burns dirty thus failing cats and 02 sensors. other then that. up the f**kin timing n quit crying. wana go fast? experiment.....i never posted it, cause who wants to hear discouragement? anyway. point is dont be afraid ppl.
__________________ ;Injen Intake, Turbo Inlet; 3in Custom catless DP; Cobb AP- Street Tuned by me at 20psi; HKS Bov Vta; EGR delete; 5w 30 Mobil 1; Hawk Hp Pads; 800k HID; SU rear Motor Mount NGK 1step colder spark plugs. Custom Front Mount Intercooler. AEM Meth Kit-315cc nozzle (Cobb's new Jacket.) (Cobb Shift Knob.) |
| gonads and strife ![]() Join Date: Jul 2009
Rep Power: 241 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 210
| Not Ranked : 0 score I like the sounds of this. So, you guys running e85, any fears of fuel line degradation or excessive CDFP wear? My only concern would be ending up in the middle of nowhere someday with only 91 octane gas available. If it happened to also be a hot day your ECU would be pissed. Creating separate maps for such an occasion would be ideal. |
![]() | | #24 | ![]() |
lol kinda like owning a PTP pump haha
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score You aint bullshitting, LOL Thats why I keep an extra pump with me at all times now. LOL HOw sad. Hopefully I dont have to use it. I got one even better for you. Im gonna be putting a ptp rail valve on my car this weekend and try to get my car to hold 2000psi across the board. Ill put that info in its own thread though. God knows how thatll spiral!!!
![]() | | #26 | ![]() |
![]() Join Date: Nov 2009 Location: las vegas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 711
| Not Ranked : 0 score PTP started doing some cool stuff, different stuff that was very needed...... just sucks they went down like that! wish the shit was legit!
__________________ T3 Steed Speed twinscroll manifold- GT35R- CPE HPFP- COBB AP- DO METH- PTP BSD/WIN- CPE FMIC 2.5 piping- Twin Gates- CorkSport Exhaust- Full Mounts |
![]() | | #27 | ![]() |
Groans: 356
| Not Ranked : 0 score i just want to say this.... PEEEEEE TEAAAAAAAAAA PEEEEEEEEEE
![]() | | #28 | ![]() |
And ask erich about the rail valve... he's been running one for a while, and is seeing a lil weird stuff... He was running more pressure than the pressure sensor could even read (maxed out basically), and was actually disrupting the injectors from opening properly, and leaning way the fuck out. He's fine with doin it cause he has a spare motor sitting around, and he's not making anywhere near the power you are (which means less fuel demand). Just be careful being PTP's "learning" car. Esp if your so concerned about your block. Just cause he gets all excited and talks all loud about how fucking cool his products are, doesn't mean he's thought them through entirely, or tested em out thoroughly. That's essentially what you'll be doing, haha. But shit... who knows... maybe he's running that valve on his srt...
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score Sooooo your saying theres a chance???? LOL Quote the movie????
![]() | | #30 | ![]() |
![]() Join Date: Mar 2010 Location: Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 778
| Not Ranked : 0 score Dumb&Dumber So How many maps are you running Anthony? I thought you were @20 psi last time I checked, How does Tim feel with e85 on this car?
__________________ 2009 MS3 COBB AP COBB INTAKE COBB/TURBOXS TBE DNP TURBO MANIFOLD CXRACING FMIC TURBOSMART BPV JBARONE RMM TURBOSMART BPV JBARONE SHIFTERPLATE COBB RSB KONIG WHEELS/HANKOOK TIRES TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO* |
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score He doesnt know lol. I have 3 maps. I just posted two vids of me at 18psi and 19psi. I can set me boost where ever I want. My tune allows me to put my boost where ever I want with my mbc and its dialed in.
![]() | | #32 | ![]() |
nice to see you trying new things There is shell station near by with e-85, might have to give it a shot.
__________________ 2009 MS3 COBB AP COBB INTAKE COBB/TURBOXS TBE DNP TURBO MANIFOLD CXRACING FMIC TURBOSMART BPV JBARONE RMM TURBOSMART BPV JBARONE SHIFTERPLATE COBB RSB KONIG WHEELS/HANKOOK TIRES TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO* | |
![]() | | #33 | ![]() |
![]() Join Date: May 2009 Location: Clw/ NPR Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,516
Groans: 89
| Not Ranked : 0 score what kinda MBC do you use ?
__________________ [SIGPIC][/SIGPIC] 2013 EVO X GSR Wicked White w/Areo H&R springs/H&R 15mm spacers MAP modified 3" Magna Flow cat back MAP catless testpipe MAP UICP Grimmspeed 3 port Cosworth filter SSP relay kit TWM Desert Eagle shift knob AEM wideband gauge Prosport boost gauge EvoX piller pod 30%Tint Slowpoke Tuned 339hp/336tq **** SOLD ***** 2006 speed6 " A woman's asshole is like a 9-volt battery..U know its wrong, but sooner or later ur gonna put ur tongue on it !! " |
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score Turbosmart but looking to experiment with hallman pro. My car didnt have any spikes when temps were above 50 degrees but now that its cold it spikes a few when i shift. I doubt the hallman will fix that. Its just the nature of the beast(cold weather)
![]() | | #35 | ![]() |
| Not Ranked : 0 score Apparently there's already some guy in Everette WA that's running 100% E85 at 26.5 PSI on stock internals. He lists his mods as "CS FMIC kit / Turbosmart - BOV , Eboost Street 40 EBC , ProGate 50 EWG / DNP header / CS power catless exhaust w/ a straight cutout in the race pipe / GT3076R / CP-e - Standback 2 , Profuel / Walbro 255 x2 / HKS twin power ignition / water meth kit / SS braided fuel line." I asked him if he's adding lubricant to the fuel, but he doesn't have very much info yet. He's having MSP in Arlington WA (Subie shop) build the car while he's deployed in Iraq. |
![]() | | #36 | ![]() |
Groans: 113
| Not Ranked : 0 score Anthony any updates homie? |
![]() | | #37 | ![]() |
Groans: 78
| Not Ranked : 0 score For what its worth, I added two gallons of e85 with a tank of regular gas, and a bit of marvels oil, and the car is just as slow as ever.
![]() | | #38 | ![]() |
![]() Join Date: Dec 2008 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score shit not my car man. I put 3 gallons of e85 in and the rest 91 and after about 25 miles my shit was crazy fast. Not to mention I got 0 knock while monitoring on the AP. I rarely got any knock the entire take of gas. I'll put more e85 in again at some point. You just need your shit tuned ASAP and you wont be slow no moooooo
__________________ Eric Schlaht - Arizona Phoenix Photographer http://www.esimaging.net - http://www.facebook.com/esimaging [SIGPIC][/SIGPIC] 2007 MS3 Sport, gtx3071r, Full-Race Exhaust Manifold, SP PNP Intake Manifold, SP 88mm Pistons 9:5:1, Manley H Beam Rods, 10mm H11 Head Studs, ARP Main Studs, 4" HTP TIP + Small Battery Tray, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E Nexus CBE, Tokay Injector Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DIY Perm Plate with dual OCC, Corksport Radiator Shroud, Southbend Stage 3 Clutch, DO Stage 2 Meth D10, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **463whp/409lb-ft via Mustang Dyno as of 3/28/14** **9/19/13** Zoom Zoom Boom ** Currently Rebuilding with goal of 475whp **11/19/13** Forged engine built and started up the car for the first time, success! **3/28/14** Dyno results from build 463whp / 409lb-ft Mustang Dyno **6/24/15** Sold the Mazdaspeed 3 **7/4/15** Purchased 2015 F150 Ecoboost Lariat FX4 with Sport Package |
![]() | | #39 | ![]() |
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp | |
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thats what Im talking bout. Thanks for breaking it down. The shits legit for real. Just takes more than internet racers to know that. LOL My first tank was 2.5 gallons and no issues. This tank was 3 gallons and car runs just as good. Next tank will be 3.5 gallons. im gonna slowly work my way up and make adjustments as needed. But thus far none have been needed. Car is just straight up ripping.
| Display Modes | |
| My second attempt on a Datalog. | ARES28 | MazdaSpeed 3/6 - ECU Computer Tuning | 9 | 03-30-2012 06:04 AM |
| 1st attempt at vd | tooslow10 | 2010 MS3 - ECU Computer Tuning | 5 | 01-13-2012 05:25 AM |
| Drivers attempt at E85 | driver311 | MazdaSpeed 3/6 - Big Turbo Builds | 448 | 09-29-2011 07:21 AM |
| British study suggests that older drivers are safer drivers | Haltech | Automotive News | 0 | 05-01-2008 05:50 AM |
