![]() Join Date: May 2008 Location: Brandon, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 667
Groaned at 7 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score Here is a comprehensive list of all suspension systems and components available for the MS3. SPRINGS AutoExe Low Down Spring Drop: 1.2" front, 1.2" rear | Part Number: MBA700 | ~$500 Straight from Japan and designed for the Mazdaspeed "Axela"! The roll is placed under control by the spring rate intensified within the range that has less impact on a ride quality, so that the vehicle height can be brought down by approx. 30 mm. For the riding taste, the car stability is improved by bringing its center of gravity down, which provides a desired tendency to the “person who enjoys driving.” Moreover, the clearance of tire house becomes reduced, which makes the whole car look low. As a result, a dynamic feeling is provided to the styling. =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Corksport MS3 Lowering Spring Set Drop: 1.2" front, 1.0" rear | Part Number: Axl-3-288-10 | ~$210 Approximately +25% increase in spring rate over OEM Give your car the performance appearance and edge you have been looking for with the CorkSport Lowering Springs. By reducing ride height approximately 1.2"" in the front and 1.0"" in the rear, adding the CorkSport Lowering Springs to your Mazdaspeed 3 will result in a quicker turning response, crisper road feel, a more aggressive appearance, and a firmer spring rate, while maintaining excellent ride quality. The CorkSport Advantage: • Lower your car by approx. 1.2"" front and 1.0"" rear for improved handling and less wheel gap • Crafted from high tensile strength spring steel for long lasting quality and performance • OEM finish to ensure lasting durability and rust protection • Average 25% increased spring rate over stock spring rate • Backed by CorkSport limited two-year warranty • CorkSport Service and Support: Receive full color installation instructions, all of the needed installation hardware, and knowledgeable telephone installation support. =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Eibach Pro-Kit Drop: 0.8" front, 0.7" rear | Part Number: 5549.140 | ~$205 The Eibach Pro-Kit lowering spring set improves your vehicle's looks and performance. Pro-Kit springs lower the vehicle's center of gravity, reducing body roll in the turns, dive under braking, squat during acceleration and give the car a more solid secure feel at all times. Pro-Kit Springs also minimize the ugly fender gap that makes a car look "lifted." Eibach Pro-Kit Springs..." The look that performs." =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Eibach Sport Line Drop: ~2.0" front, ~2.0" rear | Part Number: 4.4955 | ~$240 Eibach Sportline is the extreme-performance spring set created for the extreme enthusiast - the one who craves a race-car attitude for maximum street performance - with the lowest possible drop, but with the exceptional ride quality you expect from Eibach. Engineered with the same care as our Pro-Kit springs, Eibach Sportline springs achieve legendary handling by aggressively lowering your car’s center of gravity, using our precision engineered progressive spring rates. By radically lowering your car’s center of gravity, our Sportline springs dramatically reduce squat during acceleration, body roll in corners and nose-dive under braking. By using our proprietary, progressive spring design, our Sportline springs provide the ultimate balance between high performance, extreme lowering and comfortable ride quality. When combined with today’s wild 18, 19 or 20 wheels and tires, the result is a car that handles just as white-hot as it looks. =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= H&R Sport Springs Drop: 1.3" front, 1.2" rear | Part Number: 51643-2 | ~$230 H&R Sport Springs are designed and engineered for each particular application and are the correct spring rate for low aggressive looks, high performance handling and no ride harshness! The most popular spring in H&R's line-up, Sport Springs will lower your vehicle an average of 1.5 - 2 inches (depending upon the make and model of your vehicle) for a lower center of gravity, improved handling and a more aggressive appearance. Sport springs feature more control than that of the OE Sport spring, but is still comfortable for daily use. Sport springs are an excellent choice for street and occasional track use. =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Mazdaspeed Lowering Springs & Rear Camber Kit Drop: 0.6" front, 0.6" rear | Part Number: GRMS-8M-L25 | ~$440 OE+30% spring rate Mazdaspeed designed lowering springs specifically made for the Mazdaspeed3. The springs will provide a 15mm drop over stock. They will increase the stock spring rate by 30%. This also includes a camber kit for the rear wheels. |
| The Following 2 Users Say Thank You to RhoadBlock For This Useful Post: | dh5077 (04-23-2016), dsdblock12 (10-31-2018) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f627/official-mazdaspeed-3-suspension-thread-125063/ | ||||
| Top 5 coilover ??? - Mazda 3 Quebec | This thread | Refback | 12-31-2013 12:33 PM | |
| The Official MS6 Suspension Thread | RhoadBlock | MazdaSpeed 3/6 - Suspension & Brakes | 182 | 07-24-2018 11:38 AM |
| The Official MS3 Suspension Thread | RhoadBlock | MazdaSpeed 3/6 - Suspension & Brakes | 199 | 07-02-2018 11:27 AM |
| Official: Mercedes-Benz offers new Ride Control suspension on SLS AMG | Haltech | Automotive News | 1 | 04-13-2012 09:28 PM |
| Another.. is my suspension shot thread | amc5 | MazdaSpeed 3/6 - Suspension & Brakes | 14 | 01-20-2012 08:16 AM |
| Another suspension noise/sound thread-Strut Bearing? | Raider | MazdaSpeed 3/6 - Suspension & Brakes | 8 | 12-07-2011 09:57 PM |
