![]() | | #41 | ![]() |
![]() Join Date: Apr 2012
Rep Power: 0 ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score |
| The Following User Says Thank You to mariomspeed For This Useful Post: | Revolv0 (06-26-2016) |
![]() | | #42 | ![]() |
![]() Join Date: Mar 2012
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score I want a good suspension for occasional autoX and drag, but cant see myself putting out more than $1000 for it, seeing that its not my living, just occasional fun... I dont want BC though... possibly Sonic Tuning? def looking for rear sway bar kit to go with it also.
__________________ COBB AccessPort | HKS SSQ v4 | INJEN Cold Air Intake | CORKSPORT Turbo Inlet Pipe | EBAY (m2) Catless Long Downpipe | HKS Hi-Power Catback Exhaust | PTP Fuel Pump Internals | Grimmspeed EBCS | TWM Short Shifter | JBR 815 gram knob| SURE Short Shift Plate/Counterweight | STREETUNIT Shifter Bushings | STREETUNIT Rear Motor Mount | CORKSPORT SuperWhite interior LED Kit | HALO Angeleyes 7000k | DDM 6000k 35w (switching to 55w) HID Headlights | DDM 3000k 35w HID Fogs | Flat Black Evil M | Side Door Guard Removal | Evo Mod Grille| Tenzo-R dc-10 wheels| BC COILS| KENWOOD eXcelon Headunit (4v preouts) | ALPINE MRP-M500 Mono Amp (500w RMS) | ALPINE MRP-F300 4-way Amp (75w RMS x4) | ALPINE Type-R 12" Woofer | ALPINE Type-R 6.5 Door Speakersru |
![]() | | #43 | ![]() |
![]() Join Date: Jan 2010 Location: El Cajon, CA.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,323
| Not Ranked : 0 score KW V1
__________________ www.MOTOIQ.com Beater Titan |
![]() | | #44 | ![]() |
![]() Join Date: Jan 2010 Location: Austin, TX
Rep Power: 778 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,717
Groans: 44
| Not Ranked : 0 score Question.. Does the OEM Struts off of a Pu fit the Wons.. Reason I ask: Thinking of getting coil-overs in the next month or so, and I have a buddy with his struts going out. If they fit I was just going to give him my OEM ones and save him some money. Thanks.
__________________ ![]() ZOOM ZOOM left the Room ![]() 2013 SPW STi // COBB SRI w/Box // COBB BPV // UR Catless DP// UR CBE // COBB Lowering Springs // COBB Sway Bars // +1 NGK // DW65c FP AWDTuning Tuned |
![]() | | #45 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
| Not Ranked : 0 score I believe the struts are directly interchangeable. The shocks are not.
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
![]() | | #46 | ![]() |
![]() Join Date: Sep 2011
| Not Ranked : 0 score I'm new to the modding scene, I just want to confirm that the prices on the COBB and hotchkis sway bar is in fact both FSB and RSB. Seeing that the hotchkis says "kit" that it is in fact F and R. |
![]() | | #47 | ![]() |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 895
| Not Ranked : 0 score ^if it says kit then yes it is both but pass on the FSB |
![]() | | #48 | ![]() |
Groans: 44
| Not Ranked : 0 score what makes the shocks not interchangeable?
![]() | | #49 | ![]() |
| Not Ranked : 0 score ^the pu's rear end has a slightly different setup from what i remember...but i cant tell how genone ![]() gen2 |
![]() | | #50 | ![]() |
Groans: 44
| Not Ranked : 0 score hmm i would just assume they would fit cause the springs are matched.
![]() | | #51 | ![]() |
| Not Ranked : 0 score The rear shock lower attachment point is different on the Pu than on the Won. I know you need a longer bolt to put Won shocks on a Pu, so you'd probably need some sort of machined spacer or longer shock eye bushing to make a Pu shock work on a Won...
![]() | | #52 | ![]() |
Groans: 44
hmm.. well if i get the coils i guess it wouldnt hurt to check it out and maybe do a quick write up on the matter. Im sure he wouldn't care.thanks for the help
__________________ ![]() ZOOM ZOOM left the Room ![]() 2013 SPW STi // COBB SRI w/Box // COBB BPV // UR Catless DP// UR CBE // COBB Lowering Springs // COBB Sway Bars // +1 NGK // DW65c FP AWDTuning Tuned | |
![]() | | #53 | ![]() |
| Not Ranked : 0 score That what I figured. I'm not sure if I can bass on the FSB it's rattling fucking annoyingly as of now, so I have to make sure it's not anything more than the bushings or end links, I may have to replace it if it's more than that. Thanks for the heads up of not needing to change it though. Much appreciated. |
![]() | | #54 | ![]() |
| Not Ranked : 0 score That isn't necessarily true. It all depends on how you like to setup your suspension. Most people skip the front bar because its a huge PITA to install not because its not needed. Again it depends on the type of driving you do and your preference for setup.
![]() | | #55 | ![]() |
| Not Ranked : 0 score I have had both for years. The handling is better with both than just the rear, as I had the rear for a month until I did the front. Well worth it imo. Front just sucks to install. |
| The Following User Says Thank You to Raider For This Useful Post: | Familyguy427 (01-19-2013) |
![]() | | #56 | ![]() |
| Not Ranked : 0 score while im sure there are benefits in steering response you cant argue the fact that sway bars reduce traction in the area they are installed rsb lifts the inside wheel decreasing the traction in the rear inducing oversteer fsb again attempts left that inside wheel...decreasing front traction and inducing understeer personally in auto cross my biggest issues came from understeer and general lack of front traction through turns heavy rsb and disconnecting my fsb during runs solved this im not saying that this is the end all be all setup and of course you need to decide what is best for what kind events you run, but my personal opinion is to run no or a lighter fsb....im actually looking to source a regular 3 fsb to run always |
![]() | | #57 | ![]() |
A large front bar can also reduce camber loss under roll which increases traction, all I'm getting at is a larger front bar is a preference depending on your preferred style and setup. In a heavy FWD camber limited Macpherson strut car a larger FSB can actually increase lateral front grip.
__________________ www.MOTOIQ.com Beater Titan | |
![]() | | #58 | ![]() |
| Neutral : +1 score
| The Following 2 Users Say Thank You to Todd98SE For This Useful Post: | Familyguy427 (01-19-2013), license2ill (02-05-2015) |
![]() | | #59 | ![]() |
![]() Join Date: Sep 2012 Location: Louisville, Ky
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score I couldn't find anything in this thread that was related to this.. Does anyone know if the KW V3 front c/o has an adjustment for the camber? |
![]() | | #60 | ![]() |
| Not Ranked : 0 score None of the KW setups for the MS3 include any type of camber adjustment, but they can be used with Corksport's camber plates.
![]() | | #61 | ![]() |
| Not Ranked : 0 score I was leaning toward KW but now that I see the BCs include this camber plate, I'm leaning that way. Does anyone have those on their MS3? If so, did it require modifying the strut tower itself? |
![]() | | #62 | ![]() |
| Not Ranked : 0 score KW >>>>>>> BC All day, every day. The option of included camber plates isn't worth choosing BC over KW.
| The Following User Says Thank You to Nliiitend1 For This Useful Post: | SKiZ0TT (10-30-2012) |
![]() | | #63 | ![]() |
![]() | | #64 | ![]() |
![]() Join Date: Mar 2012 Location: Soviet Russia
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score I think it's time to add CorkSport coilovers CorkSport Mazdaspeed 3 Coilovers |
![]() | | #65 | ![]() |
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
| Discuss Here: The Official MS3 Suspension Thread
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f627/official-mazdaspeed-3-suspension-thread-125063/ | ||||
| Top 5 coilover ??? - Mazda 3 Quebec | This thread | Refback | 12-31-2013 12:33 PM | |
| Display Modes | |
| The Official MS6 Suspension Thread | RhoadBlock | MazdaSpeed 3/6 - Suspension & Brakes | 182 | 07-24-2018 11:38 AM |
| The Official MS3 Suspension Thread | RhoadBlock | MazdaSpeed 3/6 - Suspension & Brakes | 199 | 07-02-2018 11:27 AM |
| Official: Mercedes-Benz offers new Ride Control suspension on SLS AMG | Haltech | Automotive News | 1 | 04-13-2012 09:28 PM |
| Another.. is my suspension shot thread | amc5 | MazdaSpeed 3/6 - Suspension & Brakes | 14 | 01-20-2012 08:16 AM |
| Another suspension noise/sound thread-Strut Bearing? | Raider | MazdaSpeed 3/6 - Suspension & Brakes | 8 | 12-07-2011 09:57 PM |
