Datalog File Trimming Software! 3 Attachment(s) V1.1.2 released and attached! TL;DR Attached is a program ("DaFT", Datalog File Trimmer) I made that will filter and highlight your datalogs for you! WHAT YOU CAN DO WITH THIS:
The default behavior is to
You can change the filters and highlights to whatever you want and save them as your defaults. Background: A little while ago I got an AP and started logging. I got tired of filtering them down to just the WOT run and also of highlighting the columns I actually cared about. Being a software engineer, I decided to make a little piece of software to do this for me. Then I figured other people might appreciate it as well, so I cleaned it up a bit and now here it is. To install, just unzip the attached ZIP folder and run setup.exe. You can then run the program from the Start menu (it's not in a folder and is called "DaFT"). I've only used this with AP logs, but, in theory, you should be able to use this to filter and highlight any CSV file. Note that minimum, maximum, and average of each column is also included if you choose to output to XLSX (see the second sheet in the XLSX file). Oh yeah, and don't forget to click Help -> About :wiggle:. Don't have Excel to view the output XLSX files? Download Open Office. Screenshot: http://www.mazdaspeedforum.org/forum/foru...6&d=1339986155 Sample Output (using "factory default" filters and highlights): http://www.mazdaspeedforum.org/forum/foru...7&d=1339986155 |
Domo Arigato kind sir you rock! |
Just downloaded and tested it out. Thanks for sharing. |
I just wish you'd come up with this while I was still logging and tuning. With all the zoom zoom boom going on around here lately, I'm too chicken to drive the thing. :biglaugh: Thanks a lot. J |
Sweet Program! DL'd! |
Quote:
Quote:
So you are the guy who logs your 20min drive to work in stop and go traffic...Nah...Good shit man….thanks. This will help out guys trying to trouble shoot shit here. |
Stuck in ECU Tuning Section. @Brennan, look for MSF Bucks |
Quote:
I'm not sure how big of a single log the AP will let you store though. And this wouldn't be desirable if you had a multi-gear log, but you could just disable the option for that log. I'm probably overthinking this... :tired: Quote:
I don't know much about the XLSX format, other than it's a zip file of XML basically, but could you add in conditional formatting? I'd love to be able to filter to WOT logs and then have conditional formatting set for some columns (KR > 2 = yellow, KR > 5 = red, HPFP pressure < 1600 = red, etc.). Come to think of it, I've done this before just not with CSV files. Not sure if you could get the UI right or if it would overcrowd it, but it'd be sweet. Also, this would be sweet to combine with @Enki's Kalibrator program. Do a bunch of long logs to feed into that, but use this for when you only want to look at the WOT sections. |
Quote:
Edit: It also doesn't like anything other than raw AP logs at this time, so is fairly limited. |
Quote:
This same thing applies to the filtering: you get to set whatever filters you want; it is not limited to only trimming throttle position to get a WOT run. I'm updating the original post to be clearer and show the default behavior. |
Quote:
Quote:
I'll hopefully get some good logs done this week for you Enki, sorry for the delay. |
Quote:
Quote:
As for the log file, the requirements for the alpha test are listed here: http://www.mazdaspeedforum.org/forum/foru...9/#post1368989 |
Any interest in updates to the software? I haven't worked on it since I released it, mainly because I don't want to waste time if there's little interest, and I've been busy with other things. |
@Brennan: Just got around to using this and I'm impressed. Any chance we could get more advanced highlighting/filter rules? For example, I'd like to only trigger HPFP Act. pressure < 1600 when APP > 90%? Just saw the min/max/avg sheet that gets output when doing xlsx, freaking awesome! I usually look for max KR, min FP, so that's an awesome feature. |
subbed for knowledge and updates. Good work dude! |
Quote:
1. Freeze top row in XLSX. 2. Make min/max/avg calculated by Excel so that if you modify the datalog sheet, the values are recalculated... 3. Multiple highlights in single column. For example, you could set KR > 0.0 yellow, and KR > 2.0 red. Currently, DaFT will only use one of these. 4. Shouldn't need write access to original CSV files... Currently DaFT cannot process them if they're being used by another process (e.g. open in Excel). As for a time frame, I'm not really sure. I'll see what I can get done this week. |
2 Attachment(s) Quote:
To be honest, I don't see the need for adding this same thing for filtering since the filter specifications are all "AND"ed together anyway. But please let me know if I'm overlooking something in thinking that. Screenshot of the new highlight tab is format: http://www.mazdaspeedforum.org/forum/foru...5&d=1339734715 http://www.mazdaspeedforum.org/forum/foru...6&d=1339734715 #1 should really only take a half hour tops, and I entirely plan on releasing V2 this weekend. So far, the entirety of the software, including these V2 updates, has probably taken me about 40 hours. Please let me know what "factory defaults" you guys would like to see, although changing those forever is just a simple click of the "Save" button. I'll update the original post and add a post in the thread when I get V2 all squared up. Cheers, Brennan |
looking awesome @Brennan. Agreed with the filters part, so no worries there. Can't wait to try V2. |
very cool looking forward to the update |
Original post updated with version 1.1! VERSION NOTES: 1. A log is now created in a "logs" directory every time DaFT is run. Logs older than one week will automatically be deleted. 2. Top row is now frozen in XLSX. 3. Min/max/avg are now calculated using Excel formulas, so they will be correct if you modify the datalog sheet. 4. DaFT no longer needs write access to the original CSV in order to process it. 5. You can now have multiple highlights for a single column (with different colors/conditions for highlight). 6. Advanced highlighting rules; highlights are now unique by column name and color instead of just column, and up to five conditions may be specified. A condition consists of a column, min value for that column, and a max value for that column. You can also specify whether the highlight column's value has to meet "any" or "all" of the specified conditions in order for the highlight color to be applied. 7. Fixed an issue with filters getting confused between Boost and Boost Air Temp. 8. Filters are now inclusive of the min/max specified. They were exclusive in version 1.0.0.0. |
Good stuff! Haven't downloaded yet, but definitely will! Since people are throwing out "wishes" how about adding the ability to graph your logs using Excel's graphing (or pivot chart?) function... Would need to be able to select values for each axis as well as pick and choose what values to include in graph. Also, different color for each value... Just throwing it out there ;-) |
Windows 7 x64: See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.UnauthorizedAccessException: Access to the path 'logs' is denied. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.Directory.InternalCreateDirectory(String fullPath, String path, DirectorySecurity dirSecurity) at System.IO.Directory.CreateDirectory(String path, DirectorySecurity directorySecurity) at DaFT.Logger.getWriter() at DaFT.Logger.logError(String msg) at DaFT.DaFTForm.browseButton_Click(Object sender, EventArgs e) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5456 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/Microsoft.NET/Fra...7/mscorlib.dll ---------------------------------------- DaFT Assembly Version: 1.1.0.0 Win32 Version: 1.1 CodeBase: file:///C:/Program%20Files%20(x86)/DaFT/DaFT.exe ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5460 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL...dows.Forms.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5456 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL...089/System.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5462 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL...em.Drawing.dll ---------------------------------------- System.Core Assembly Version: 3.5.0.0 Win32 Version: 3.5.30729.5420 built by: Win7SP1 CodeBase: file:///C:/Windows/assembly/GAC_MSIL...ystem.Core.dll ---------------------------------------- System.Data Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_64/S...ystem.Data.dll ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL...System.Xml.dll ---------------------------------------- Microsoft.Office.Interop.Excel Assembly Version: 14.0.0.0 Win32 Version: 14.0.4756.1000 CodeBase: file:///C:/Windows/assembly/GAC_MSIL...erop.Excel.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box. |
Excellent work I'll give this a shot when I do some logs. Sent from my DROID RAZR using Tapatalk |
Quote:
Very likely this would correct the issue: check the "Security" tab on the "C:\Program Files (x86)\DaFT" folder properties, and enable write access for the user/user group you wish. Could this just be a result of choosing to install "Just for this user" as opposed to for "Everyone"? Maybe. Perhaps I should change the default to "Everyone"... In any event, please let me know if that works for you. I hadn't tested anything with multiple user accounts/permissions. Thanks. |
Might I suggest writing the logs to the user profile, specifically the documents folder? |
Quote:
Quote:
@honda etr Well, that blows nuts. Try the attached version. A "DaFT\logs" folder should now be created in "C:\Users\<userrname>\Documents" as recommended. The odd thing is that I tested DaFT on Windows 7 x64, though it was under an administrator account. Anyway, please let me know how this works out. Should only take a few seconds to test. Thanks! Edit: Removed attachment to attach in the original first post. See first post for v1.1.1. |
Just tested for you (as local admin, but with uac enabled) in 7x64. Installed via doubleclicking the MSI (skipping the exe), prompted to allow admin access, and it installed without issue. Running also worked just fine. Out of curiosity, are you hard-coding the path for NT os or are you using the %userprofile% system variable? |
Quote:
Code: string logDir = Environment.GetFolderPath(Environment.SpecialFolder.Personal) + "\\DaFT\\logs"; |
Loads and works well on W7x32. Thanks. |
Quote:
This is going to be a life saver when it comes to reading my logs. Bravo sir! |
Nice Microsoft Stackin Skillz brah! What 3.5* spark adv at 4500rpms? Is that all she'll take or are they kinda like demo numbers? |
Quote:
I was just messing w you man, yeah I run 9* at 4.5k, close enough. REALLY I posted because I was impressed with your programming skills. What are you using? VS2010? C# or VB or ? |
Quote:
I'm just glad it's helping people out :05:. If you have anything you'd like to see changed or added, let me know! And I might eventually get around to adding graphs to a spreadsheet tab as suggested... :sly: |
| All times are GMT -7. The time now is 09:05 PM. |
