 Old 04-22-2011, 06:37 PM   #281
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
Originally Posted by Ckmazdaspeed3 View Post
Come on dude, I'm swapping turbos in the morning. Don't say shit like that!
And, yes, I capped off the bottom nipple on the acuater.
Oh, and I dynod today! The ex mani and ebcs netted me about 6whp and 5wtq... It's too bad that I can't be sure which resulted in the power gain.
I will post in the dyno section, as well as the ex mani too.
thats it? only 6whp and 5wtq for the ex mani?
860whp/677wtq
2.7 V6 Ecoboost
PapaSmurf is offline
 Old 04-22-2011, 06:45 PM   #282
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
On a Ko4, yep. Although I wanted more of course, it had been mentioned earlier by wiser members not to expect too much.... The gains off of a bigger turbo will of course be greater, but I'm not sure if we are going to take the time to remove, dyno, reinstall, because it's a pita... once the 2871 is on, that is.
Now, I did not manipulate the tune to be more biased. This is ots tune (not designed for ex mani) with manipulation of wgdc, req load (to hit desired boost) and leaned out by like .5 (which I'm told does very little w/o timing). Timing and other more complicated parameters were not touched... who knows, maybe if I had worked with timing and other things before adding the ex mani, it would have had more effect on the redyno after the mani.
I have no idea if adding an ex mani would have given me more room to add power in other areas of the tune???
... sorry for the thread jack.
Ckmazdaspeed3 is offline
 Old 04-22-2011, 06:48 PM   #283
Ziggo's Avatar
Posts: 3,843   (View Stats)
When the flow restriction is the turbo, improving things like the ex mani is not going to make much of a difference.
Ask Me About My:
Ziggo is offline
 Old 04-22-2011, 08:25 PM   #284
I would never wish that on you, just using you as a working example...
I wish you nothing but the best of luck with your turbo swap.
I am really interested in seeing your new numbers and impressions.
rfinkle2 is offline
 Old 04-22-2011, 08:33 PM   #285
jwilkins88's Avatar
Posts: 3,675   (View Stats)
Groans: 126
His turbo swap is in good hands
jwilkins88 is offline
 Old 04-23-2011, 05:09 AM   #286
Lol, why not just use load based tuning.
IMO, i've seen alot of inconsistencies with boost based tuning in the car's i've been tuning. On quite a few, the TRL gear tables were indeed "limiting" the boost, and when set to 3's, all was well. Other cars, like many have said, have had no problems at all.
Another thing i've noticed on a few cars is lagging AFRs when initially going wot. They seem to linger around mid 12's before finally hitting target. I've even bumped that portion of the maf curve up twice on guy's map to help get them down faster, but it made no difference.
For what it's worth, i've returned to load based tuning, cause honestly, it was never really that difficult for me, and always much much more consistent.
Alright gen2 (and select 2009) guys...
First, I apologize for using the wrong terminology (I should have used "limit" rather than "cap")
(this is not in the interest of saying I told you so, but I feel like this point may be missed by gen2 guys who are using ots values in their throttle req load -x gear tables.)
YOU WILL have an easier time tuning your boost curve if you set the table values to either 2.3 or 3. (depending on your setup and observed calculated load.)
PLEASE LOWER YOUR WGDC TABLES AND TAKE THE NECESSARY PRECAUTIONS WHEN DOING THIS. IT WILL INCREASE YOUR BOOST LEVELS ON MANY CARS.
Some of you have already done this, and others have not. IMO, there is now solid evidence that the throttle requested load x gear values ARE affecting your boost levels if left OTS.
Please hear this out...
Above is a post from arguably THE most respected tuner on the forum.
Below is a collection of posts and data that back this up from the likes of Forzda, Fobio, DJ, Bluestreak etc.
http://www.mazdaspeedforum.org/forum/foru...tml#post817485
Gen 2 Cobb ATR discussion
http://www.mazdaspeedforum.org/forum/foru...tml#post820752
http://www.mazdaspeedforum.org/forum/foru...tml#post820330
http://www.mazdaspeedforum.org/forum/foru...tml#post817576
@Ckmazdaspeed3 was able to solve his problems after changing his throttle - req load x gear tables also.
Happy boosting!
rfinkle2 is offline
 Old 04-23-2011, 08:57 AM   #287
Todd98SE's Avatar
Posts: 1,077   (View Stats)
Did you go to 2.3 load from 3k-7k in all the gears or just 2-5 or something? What about the high BAT TRL X gear tables, did you keep them OTS?
Thanks,
www.MOTOIQ.com
Beater Titan
Todd98SE is offline
 Old 04-23-2011, 09:03 AM   #288
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
I changed mine from 3rd up. Traction issues in 1 - 2, don't need more power there.
Leave the high BAT tables alone, they are to keep your car safe in hot weather.
If you have some really hot days, you may be able to fine tune those though.
wolly6973 is offline
 Old 04-23-2011, 09:07 AM   #289
Todd98SE's Avatar
Thanks Wolly, I'm in the east county of San Diego, it can get to 100+ on the worst days in the summer.
www.MOTOIQ.com
Beater Titan
Todd98SE is offline
 Old 04-23-2011, 09:47 AM   #290
PapaSmurf's Avatar
[IMG][/IMG]
Happy boosting!
I just want to say I have done this and my target boost was spot on, within .5 psi and in some cases exactly what was targeted.
860whp/677wtq
2.7 V6 Ecoboost
 Old 04-23-2011, 10:58 AM   #291
Groans: 134
Thanks,
Yeah, I left one alone for sure. For some reason (and I could just be rememberingtgis wrong (I'm on my phone, or I would check atr)) I think that I raised 2nd gear, which would mean another table was responsible for keeping power to the tarmec, because I'm not having issues w too much power in second.
For all gears that I changed, I raised 3000rpm-6500rpm up to 3. I did not change 7000, but I'm guessing that wouldn't really matter either way.
 Old 04-23-2011, 11:04 AM   #292
PapaSmurf's Avatar
i also changed 2-6 from 3000 rpm on.
I should have some logs tonight sometime, i still think im going to have to tweak my WGDC a little. Maybe ill get lucky with my first revision. haha
860whp/677wtq
2.7 V6 Ecoboost
 Old 04-23-2011, 11:11 AM   #293
If you change all to the same values, you can get your boost dialed in perfect.
changing those values will allow you to have an easier time hitting targets.
@Nataphen has used the APP translation to then limit his boost per gear.
rfinkle2 is offline
 Old 04-23-2011, 11:15 AM   #294
PapaSmurf's Avatar
your talking about WGDC right?
This I know ive only tweaked 5500 rpm up since it was targeting 50 from the OTS map, I now have it down to 40 and slowly decreasing with less throttle position. I think i might need to lower it some more, but well see.
860whp/677wtq
2.7 V6 Ecoboost
 Old 04-23-2011, 11:17 AM   #295
No lol. First, I would change all of your Throttle - load x gear tables to the same.
Then, I would get your boost dialed in 3rd and 4th gear.
After that I would use the APP translation tables to limit boost in first and second gear (if you choose).
rfinkle2 is offline
 Old 04-23-2011, 11:39 AM   #296
Nataphen's Avatar
Posts: 2,704   (View Stats)
Make sure that your CL max throttle is a little lower than what you set your APP to in 1-2, or your car will never enter OL fueling and you will be very rich. Also make sure that your AFR targets are where you want them in those ranges.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
Nataphen is offline
 Old 04-23-2011, 11:45 AM   #297
Nate, how do you have your first and 2nd gear app tables set up?
rfinkle2 is offline
 Old 04-23-2011, 11:55 AM   #298
Nataphen's Avatar
I'm not at that point now because I sort of started over on my tune. I tried 50 max for 1st and 75 max for 2nd. I went from right at 20psi max to ~14 in 1st and ~17 in 2nd. I wanted to play with it some more, but I switched focus. At the drag strip, I'd probably go 100% in 2nd because I did fairly well with traction there. For the street, I may go even lower than 75% in 2nd.
13 5.0
Wife's 13 Focus ST
Nataphen is offline
 Old 04-23-2011, 12:02 PM   #299
I there any relationship between the boost targets table throttle positions axis and the throttle position you chose to set your max values @?
rfinkle2 is offline
 Old 04-23-2011, 12:22 PM   #300
Nataphen's Avatar
The only thing that I know for sure so far is that the CL max throttle has to be set right. I'll post up when I start to mess with it again.
13 5.0
Wife's 13 Focus ST
Nataphen is offline
 Old 04-23-2011, 05:00 PM   #301
xsilent13x's Avatar
Posts: 479   (View Stats)
xsilent13x is the leader of the worldxsilent13x is the leader of the worldxsilent13x is the leader of the worldxsilent13x is the leader of the worldxsilent13x is the leader of the worldxsilent13x is the leader of the worldxsilent13x is the leader of the worldxsilent13x is the leader of the worldxsilent13x is the leader of the worldxsilent13x is the leader of the worldxsilent13x is the leader of the world
[IMG][/IMG]
Happy boosting!
I have been frustrated searching for answers to why my car puts such low numbers on the dyno compared to friends MS3's and this completely cured it. Thanks to all the people involved. Car is a new beast.
-- 2010 MS3 Black Mica --
Ultimate Racing TP w/ Res delete, Corksport SRI+TIP, Turbosmart DP BOV, Autotech Fuel Pump Internals, Denso ITV22's, AP Tuned StagePu, custom painted headlights & decals.
From Southern New England? Check out our local club! www.nescc.net
xsilent13x is offline
 Old 04-23-2011, 11:47 PM   #302
PapaSmurf's Avatar
Ok so i feel like im hitting boost cut in first gear now, but i did not change my req load first gear norm table... thoughts?
860whp/677wtq
2.7 V6 Ecoboost
 Old 04-24-2011, 12:03 AM   #303
Nataphen's Avatar
Is your boost spiking above your fuel cut boost limit in 1st?
EDIT: I gotta get to sleep, man. If someone else doesn't help you resolve the issue first, I'll get back with you tomorrow sometime.
13 5.0
Wife's 13 Focus ST
Nataphen is offline
 Old 04-24-2011, 04:33 AM   #304
Do you have a first gear log mica?
What values do you have in your boost limit- fuel cut tables?
The fuel cut limits are usually about 2 psi above target boost, and if you have upped the boost target, you may be near the threshold.
One thing to try is to give the right hand side of your boost dynamics table in the 1-3 psi overboost region (MAKE SURE TO RE-ENTER NEGATIVE SIGNS) a few % more authority.
rfinkle2 is offline
 Old 04-24-2011, 05:20 AM   #305
atvfreek's Avatar
Posts: 7,787   (View Stats)
I belive you are hitting some type of load cut and not boost cut. I experience the same thing but only intermitantly and not when logging of course. But last time it happened I had boost on my screen and only hit 19psi.
I had a feeling when ATR first came out that requested load per gear was affecting boost. Looks like it really is that way.
AccessTUNER and Stage2 Calibrations Available for 2010 MAZDASPEED3!
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
atvfreek is offline
 Old 04-24-2011, 07:08 AM   #306
@atvfreek ... You were definitely onto the idea a LONG time ago. FWIW, In the past, when my load tables were unaltered I hit a good .25 above requested load and didn't experience any cut.
The one time I hit fuel cut was @ 4 consecutive data points of around 20.43 psi, with a 20 psi boost fuel cut in the tables.
rfinkle2 is offline
 Old 04-24-2011, 08:40 AM   #307
Todd98SE's Avatar
After changing to 2.3 in the TRL X gear tables my problem with slowly building boost completely disappeared. I'm almost finished tweaking my WGDC table to hit boost targets with the BD table zero'd out. When that's done I am going to experiment and bring the TRL X gear loads back down to what I am logging calc. load at and see what effect it has.
Thanks to rfinkle2 and everyone else for this tip, it worked perfectly on my car.
www.MOTOIQ.com
Beater Titan
Todd98SE is offline
 Old 04-24-2011, 12:27 PM   #308
We all had input and figured it out together.
I'm just glad to see that everyone's car is running well.
rfinkle2 is offline
 Old 04-24-2011, 02:35 PM   #309
Hey guys,
A heads up. When I go to download the Cobb SF intake 93 octane map (stage 2), the 91 octane map downloads.
rfinkle2 is offline
 Old 04-24-2011, 04:50 PM   #310
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
Hey guys,
Gay. Thanks for the heads up.
403whp/451ft/lb Dry Shot
Bucker is offline
 Old 04-24-2011, 07:24 PM   #311
PapaSmurf's Avatar
Ok so thanks to @rfinkle2 my fuel cut problem is fixed, just a little boost dynamic tweaking.
But here are my latest logs a 3rd and 4th gear pull.
The map Targets 20psi and drops to 17.50 by redline, my boost is literally spot on and my WGDC isnt pegging 100, i think the highest it got was 94, which i could lower but im content with where its at.
enjoy!
Ambient temp was around 85.
860whp/677wtq
2.7 V6 Ecoboost
 Old 04-25-2011, 08:55 AM   #312
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
I couldn't find my solenoid. I found an evo 8 one, but then gave it away to a guy with an evo 8 who i was mounting an ic core for.
I'll look more this week, and try to kill it.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
djuosnteisn is offline
 Old 04-25-2011, 09:00 AM   #313
I have a ton of stuff to install this weekend, and when I put my Grimmspeed in, I'll send you my stocker.
rfinkle2 is offline
 Old 04-25-2011, 09:04 AM   #314
Captain
And then i will kill it, muhahahahaha.
If i find mine before then, i'll let you know i don't need it.
www.permtuning.com
 Old 04-25-2011, 09:16 AM   #315
Sounds good. Videos of a smoky death would be nice. LOL
rfinkle2 is offline
 Old 04-25-2011, 09:22 AM   #316
PapaSmurf's Avatar
i actually have one with a broken nipple, id just have to find it.
860whp/677wtq
2.7 V6 Ecoboost
 Old 04-25-2011, 09:35 AM   #317
Does anybody know how Ck made out this weekend installing his turbo?
@Ckmazdaspeed3 , where are you????
We need impressions dammit!
rfinkle2 is offline
 Old 04-25-2011, 10:40 AM   #318
jwilkins88's Avatar
Groans: 126
We were met with fail.
His car is still in my garage on jack stands. I couldn't get the shit that I needed because of the fucking fail ass holiday known as Easter.
Basically, we ran into some fucking issues with the install. I'm hoping that we can resolve them tonight. The install was slightly more retarded than I had anticipated. I'm almost starting to think that the genpu oil feed line is slightly larger than the gen 1s
 Old 04-25-2011, 10:43 AM   #319
Ahhh. I don't consider that fail @ all. I consider that Easter Bunny intervention.
rfinkle2 is offline
 Old 04-25-2011, 10:46 AM   #320
Captain
Oil feed? Are you talking about the banjo bolt? Or the line itself? You need a different banjo bolt for the Garret chra, but it would have come with the turbo likely.
And depending on how everything is clocked, you may need to grind down one of the bolts that holds the compressor on (or hotside, i don't remember), in order for it to clear the banjo bolt. This is all from memory though, so take it with a grain of salt.
www.permtuning.com
Gen 2 Cobb ATR discussion Nataphen 2010 MS3 - ECU Computer Tuning 2261 05-12-2015 12:09 PM
Cobb Tuning Inlet Review Discussion Haltech Review Discussion 62 06-03-2011 06:16 AM
Cobb AP Dyno Graph/Discussion NYpest MazdaSpeed 3/6 - ECU Computer Tuning 212 05-13-2008 02:13 PM
Page generated in 0.60958 seconds with 32 queries
