![]() | | #41 | ![]() |
![]() Join Date: Sep 2009 Location: CREVE COUER, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 263
Groans: 75
| Not Ranked : 0 score |
![]() | | #42 | ![]() |
![]() Join Date: Oct 2008 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,135
Groans: 234
Groaned at 154 Times in 122 Posts
| Not Ranked : 0 score fuck fuel
__________________ '08 MazdaSpeed3 - sold |
![]() | | #43 | ![]() |
| Banned ![]() Join Date: Sep 2009 Location: Columbus,Oh
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score We will have some results of what the MAzdaEdit software can do in about 3 days. 08 MS3 with an intake and turbo-back. Did have some decent luck with it on a 07 2.5 n/a car today. Even though it wasn't developed for that ecu. Good results nonetheless. Still needs some work. But I have more positive aspirations about the MS3's. |
![]() | | #44 | ![]() |
![]() | | #45 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah man. I've had enough secrets and hype for this car. I can't stand it anymore. If this can control the fuel injectors, let us know. Can it control timing? Or rail pressure? Both? How well are the tables defined?
![]() | | #46 | ![]() |
Groans: 75
![]() | | #47 | ![]() |
![]() Join Date: Feb 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
| Not Ranked : 0 score I've been looking around, and there are a number of 3000 psi sensors that may be candidates for replacing the stock sensor. I think because of the electrical headroom issue with the stock sensor, a 3000 psi sensor with an electrical scaling circuit may be a best final solution. Of course, if the pump can't make 2200+ psi, or the injectors don't function properly at excessive pressures, it may be a moot point. |
![]() | | #48 | ![]() |
(Thread Starter) | Not Ranked : 0 score I've heard that the pump can make up to 6000psi, and blow up the fuel rail, lol, so pressures should not be an issue, but injector function is a definite concern. I'm sure it would be fairly easy to make an adapter plug to run a different sensor. And if the new sensor was on a 3000psi scale, it may not even need a scaling circuit, just some tuning. I think baby steps are important though, hahaha. I built 2 circuits last night, need to get a few more parts tonight and build 3 more. I think the likely candidates are: Socks JJ Superskater Mark (if he wants one, not sure if he does since his stand back already does it) ... and who else do you guys think?
![]() | | #49 | ![]() |
![]() Join Date: Jan 2009 Location: Space Coast, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 343
| Not Ranked : 0 score Socks JJ Superskater Mark Yoichi..although he may be close to maxing out the 2871 SS..isnt he close to running? is he using the sb? and wtf is randy up to these days? there used to be so much DCR hype..just another mirage i guess. thats about all i can think of. |
![]() | | #50 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yoichi is SB AFAIK, so is SS. They're welcome to them if they want it. Speedsixx guy is going BT and getting built right? don't think he's running yet though. Lex, you want one to play with? I know your not super BT power hungry mofo, but you'd probably like to play with one, right?
![]() | | #51 | ![]() |
![]() Join Date: Oct 2008 Location: Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 761
Groans: 190
| Not Ranked : 0 score samsel450r might be a good candidate as well.
__________________ My mission is to go fast. ![]() Currently Designing: The golden girdle of the gods The CF "fuck your face" IM |
![]() | | #52 | ![]() |
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock ![]() Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | ||
![]() | | #53 | ![]() |
(Thread Starter) | Not Ranked : 0 score Hey hal, you want one?
![]() | | #54 | ![]() |
| You should give them to the big power guys first bro. But i commend you on pulling this off... its going to be the start of something good DJ.
![]() | | #55 | ![]() |
![]() ![]() Join Date: Jun 2008 Location: Greenville, SC
Rep Power: 2562 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,586
Groans: 125
| Not Ranked : 0 score Kevin, i was curious if you saw that. DJuosnteisn, let me know when your ready to send it out, ill cover parts and shipping at the least.
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 |
![]() | | #56 | ![]() |
(Thread Starter) | Not Ranked : 0 score Part's are pretty cheap man, i almost consider this beta batch a gift to our platform in hopes that indeed something good comes from it. I'll take you up on the shipping though . Probably ship in a day or two.
![]() | | #57 | ![]() |
| I havent had much time to hit the forums and read much with 16 hr days at work and family. My jaw pretty much dropped when i saw that post.
![]() | | #58 | ![]() |
| Not Ranked : 0 score Dustin, won't need this now as my car has a stock turbo and is going away for the winter as we discussed. If the beta tests go well, I have some good ideas on refining the product. |
![]() | | #59 | ![]() |
| Driver ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1986 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,158
Groans: 44
| Not Ranked : 0 score looking forward to results!
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
![]() | | #60 | ![]() |
![]() Join Date: Sep 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 145
| Not Ranked : 0 score I can volunteer my car.....when i get some time.. I have standback and all the flashes, big MAF, 3076, built motor, port injected meth
__________________ All wagon, No traction |
![]() | | #61 | ![]() |
Groans: 125
| Not Ranked : 0 score you dont need it if you have the standback...
![]() | | #62 | ![]() |
![]() Join Date: Apr 2009 Location: Bethpage, New York
Rep Power: 4481 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,850
Groans: 778
If my set up is anything like 18PSIWhiteMs3 i will make more then 400 whp and that scurred the crap outta me. seeing how I have 50k on the dot as of tonight and 18psi has 8k? lol when I do the install I plan on driving to Akuma ASAP to get dyno tuned. I trust stock bottom end with 400whp is safe enough with a good tune but lets say I install this new sensor and have Akuma tune for it?.. I don't wanna be the first guy to find out how much power a 2.3mzr can make before I go boom on stock block!...lol I suggest 18PSIwhitems3 and or samsel....they both have gt3076's on stock motors and maybe one will be willing to see how much more power they can make with the new sensor and tune. If you can get this sensor out to one of them and we see well over 400whp on stock bottom blocks then I'll deff be down for the senor. as of now I'll do my install (hope to make 400whp) and when I feel the time is right i'll build my motor. I hope installing the 3071 with 50k I won't blow a hole in the block if anything goes wrong..lets just hope for a fried piston ring and low compression then I will have the will to build..if hole in block...I'll have to think real hard on what I wanna do. again...contact 18psi and samsel and lets hope they are down for makin 500 whp on stock bottom. if they can I will.... ty for thinking of me as "that speedsixxx guy" lol =)
__________________ 2003 SilverStone Grey Honduh S2000 ![]() ![]() | |
![]() | | #63 | ![]() |
(Thread Starter) | Not Ranked : 0 score Okay, cool! GL, your brave to run that setup on 50k, might wanna start saving a bit month to month for a build just in case. Look forward to your tune.
![]() | | #64 | ![]() |
Groans: 778
| Not Ranked : 0 score are you Canadian Dj?
![]() | | #65 | ![]() |
![]() | | #66 | ![]() |
(Thread Starter) | Not Ranked : 0 score I am not canadian. I'm a cowboy.
![]() | | #67 | ![]() |
Groans: 190
| Not Ranked : 0 score We have cowboys in Canada. I just finished working the Canadian Finals Rodeo... Bullfighters are pussies.
![]() | | #68 | ![]() |
Groans: 778
| Not Ranked : 0 score 18psi will pop in t-minus 400 hours!
![]() | | #69 | ![]() |
![]() Join Date: Aug 2008 Location: jersey
Rep Power: 609 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 388
| Not Ranked : 0 score so now that weve established 18psi is a pussy, who has the balls to try this? |
![]() | | #70 | ![]() |
Groans: 778
when i get tuned i'll leave it off and see what i make.. then i;'ll add it and re tune same day and see what i can get out of it.. fuck if i blow i blow. then i'll build.. up to you DJ wanna send me a unit?... my goal is to make more whp then 18psi so when i roll race him i rape him...im not pussy!
![]() | | #71 | ![]() |
but he wont race yet anyway his car is a garage queen lol | |
![]() | | #72 | ![]() |
| Lurkers
Posts: n/a
| garage queen till the spring : O ) |
![]() | | #73 | ![]() |
Groans: 778
| Not Ranked : 0 score ill be waiting till then.....hope ur 8k motor holds compression when u restart it after months of sitting...
![]() | | #74 | ![]() |
(Thread Starter) | Not Ranked : 0 score Sure i'll send one. I've got to finish em up and test it out. Hopefully have em done manana, and ship on friday. PM me your addy speedsixxx.
![]() | | #75 | ![]() |
(Thread Starter) | Not Ranked : 0 score Double post merge will probably kill my bump, but oh well All ckts are built. I need to test them one more time in their housings, and will probably ship them tomorrow (sat) or next monday. I'm leaning towards monday, cause that will give me a chance to at least list the tables that will likely require tuning. I also want to stress that this is completely experimental on all our part. Install at your own will, and nobody's responsible for any damage incurred if there is any. If you guys want to wait till my pump shows up, and let me do all the guinea work, i will, and i'll post up any issues as they pop up. Right now i'm just sending out 4 units, to Socks, Super, JJ, and speedsixxx. Only concern i can think of right now, is that the circuit's output (since it's a single supply op-amp) clips at a lil above 4V and just below 1V (on the output, ecu side). But from what i understand, the ecu would never be commanding for >4V or <1V, since idle is 1.4V or so, and 1600psi is 3.8V. Again, i'll guinea this shit if you guys want to wait.
![]() | | #76 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
Groaned at 31 Times in 16 Posts
| Not Ranked : 0 score great news dude.... things are beginning to get interesting! |
![]() | | #77 | ![]() |
| Not Ranked : 0 score shits cracka lackin'!!!!!!!!!!! on another note, dustin did make these for free and isent charging for shipping or parts cause hes that chill a dude but i threw him 10 bux anyway to cover it all. dont be a jewbert and send the boy some $$$
![]() | | #78 | ![]() |
(Thread Starter) | Not Ranked : 0 score Send me lots of moneyz, then put these mini bombs on your carz. Each scalar circuit comes with moth ballz for the gas tankz! I'm down for pitch-ins on the shipping, but wouldn't ever charge for a "beta" circuit. This is purely R+D in my mind.
![]() | | #79 | ![]() |
ROFL
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
![]() | | #80 | ![]() |
Groans: 190
| Not Ranked : 0 score DJ, Do you have a schematic of these available? I wouldn't mind making one up and testing it.
| Display Modes | |
| 0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? | AFcadet | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 26 | 08-02-2019 11:09 PM |
| TIRE PRESSURE SENSOR... | redneckrecon | MazdaSpeed 3/6 - Wheels & Tires | 12 | 01-21-2011 07:23 PM |
| How to scale the HPFP pressure sensor | djuosnteisn | MazdaSpeed 3/6 - ECU Computer Tuning | 521 | 04-07-2010 08:39 AM |
