![]() | | #241 | ![]() |
(Thread Starter) | Not Ranked : 0 score If i used a 1/8" (0.125) hole, it would reduce the area by just over half. I guess i'll try that first.
![]() | | #242 | ![]() |
| Not Ranked : 0 score Good work as always! How ironic that we were just talking about the intake mani and uneven flow yesterday... |
![]() | | #243 | ![]() |
![]() ![]() Join Date: Jun 2008 Location: Greenville, SC
Rep Power: 2562 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,586
Groans: 125
I'd go for 1/16th, thats the smallest bit i have in my set.
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 | |
![]() | | #244 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
Groaned at 31 Times in 16 Posts
| Not Ranked : 0 score i think the pic is deceiving... dustin did you measure the orifice with calipers by any chance? Or just guessing off the tape? If you have a set of calipers they may reach in there (from the reverse side) and give you exact measurement |
![]() | | #245 | ![]() |
(Thread Starter) | Not Ranked : 0 score LOL, i can't even count tick marks on a measuring tape, much less use calipers, haha. definitely 3/32, and yeah, 1/16" would probably work fine, lol. Oh and 1/16" is down to 62 thousandths, so were approaching the 50 thou mark i originally mentioned, which hopefully isn't too small to function. 3/32 to 1/16 results in an area reduction of .006903 to .00306, or again, just over half.
![]() | | #246 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 492
| Not Ranked : 0 score looks like 3/8" to me. oops, you were talking about the hole inside the hole! |
![]() | | #247 | ![]() |
Groans: 125
| Not Ranked : 0 score dustin, did you see any markings on that valve? I'm really hoping as a permanent solution we can find a suitable replacement. I dont like ghetto as far as permanent goes.
![]() | | #248 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'll check when i get home.
![]() | | #249 | ![]() |
| Not Ranked : 0 score Relief Valves, Thermal Relief Valves, Safety Relief Valves, Cryogenic Relief Valves, Pressure Relief Valves, Needle Valves, Control Valves, Cryogenic Relief Valves, Check Valves, Releif Valves, Bi-Lok Tube Fittings, Needle Valves, Thermal Relief Valv Im sure dustin can find a number on it somewhere... "UPDATE (11/10/09) Even MORE LNF Goodies Another Trifecta first, last week we unlocked the fuel rail pressure tables in the LNF ECM so customers requiring raised fuel rail pressure for upgraded turbos can get all the fuel they need! " Unlocked By djuosnteisn kthx http://www.carsponsors.com/420576 ^another direct injection car (GT35r) stuck @ 400whp... hrmm i see a trend here lol. trifecta is working with the sky to unlock fuel tables and rail pressures etc i do believe |
![]() | | #250 | ![]() |
(Thread Starter) | Not Ranked : 0 score That inline one looks awesome, but our relief valve isn't NPT. Doesn't mean we can't use adapters tho.
![]() | | #251 | ![]() |
| Not Ranked : 0 score dustin does the valve come off the line or is it 1 piece with the line itself? It looks as if the inline valve could possibly work.. That is if you cant find a part number on the oem. |
![]() | | #252 | ![]() |
(Thread Starter) | Not Ranked : 0 score It's not attached to the line. I posted some pics of it a few pages back. It threads into the fuel rail with like a 10mm x 1mm pitch (or 1.25mm), and has a line that connects to it similar to the connections on the hpfp low pressure side. Here's the only writing on the valve: 7.G9.
![]() | | #253 | ![]() |
| Not Ranked : 0 score need to check mcmastercarr or someone i suppose... im sure this valve is out there somewhere |
![]() | | #254 | ![]() |
(Thread Starter) | Not Ranked : 0 score We have a McMaster carr at work, i can check tomorrow i guess. That book is huge though... might take a few years. I'm gonna play with disks tonight maybe.
![]() | | #255 | ![]() |
| Not Ranked : 0 score ya... i mean i wish i had the piece in hand, i think modifying it is gonna be the easiest thing to do at this time. I checked mcmasters website and did not see anything, and yea i have the book @ work and its huge haha |
![]() | | #256 | ![]() |
| Not Ranked : 0 score why cant we just machine something that threads into the rail (male end), with a 50thou hole in it and then the female end threads into the stock spill valve. kinda like a spark plug non fouler but with a tiny tiney(sp?) hole in it.
![]() | | #257 | ![]() |
| Not Ranked : 0 score You don't want it to bleed pressure all the time. |
![]() | | #258 | ![]() |
| Not Ranked : 0 score well this wouldent bleed pressure all the time it would only slow down how fast the spill valve saw the actual pressure right?
![]() | | #259 | ![]() |
![]() Join Date: Oct 2008 Location: Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 761
Groans: 190
| Not Ranked : 0 score The angles on the fitting look like the custom threads I used to cut on oil field tools. The threads we cut were on more of an angle through. We used the angles as sealing surfaces. Ive been looking at the profiles of various fittings, but I can find one that matches this.
__________________ My mission is to go fast. ![]() Currently Designing: The golden girdle of the gods The CF "fuck your face" IM |
![]() | | #260 | ![]() |
I think an adapter like this would be okay, right lex? No different that me shoving a custom restrictor in the hole? Or do you have a change of heart about this approach. Still though, i'm with sockerdoodles, best options is a complete replacement with a valve that opens at higher pressure, like 2300 or 2500 psi.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
![]() | | #261 | ![]() |
| Not Ranked : 0 score It might be easier to drill out the valve and thread the rubber hose end for metal tubing and then find an inline valve.
![]() | | #262 | ![]() |
but +1 if we can find a replacement
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
![]() | | #263 | ![]() |
Groans: 125
Its fine when you have the relief valve there, because it doesnt pass rail pressure on. Thus it can pass into a rubber line (such as the stock one). If you drill that valve out, your gonna have to make whatever you put past that capable of dealing with 2000psi of fuel.
![]() | | #264 | ![]() |
| Not Ranked : 0 score An adapter with a hole drilled out will work - obviously you'd have to have the threads machined properly. If those are not sealing threads (NPT or similar) you will need whatever is sealing that valve on the rail duplicated. Drilling out the valve is not the best idea as socks mentioned IMO. I was thinking the disc with a hole against the flat end of the valve might be cheap/easy way to do it. |
![]() | | #265 | ![]() |
(Thread Starter) | Not Ranked : 0 score This valve seems to seal on the surface, not on the threads. It's straight threaded. I'll make a disc soon, and see if it fits in there, but if it's too thick the sealing surface may not touch. We'll see soon. I feel sick as shit today tho. Swine flu. I'm fucked.
![]() | | #266 | ![]() |
| Not Ranked : 0 score Get better man, the Mazda can wait. |
![]() | | #267 | ![]() |
| Not Ranked : 0 score i think i might have found something that could work with an adapter fitting. the good thing about this is that it's adjustable. relief valves - direct operated part number 62299169 or 62299144 |
![]() | | #268 | ![]() |
![]() Join Date: Aug 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 126
Groaned at 20 Times in 10 Posts
| Not Ranked : 0 score oh man swine flu.... well it was fun while it lasted!
__________________ 2010 Black Mica speed3] Cobb SRI, Turbosmart BPV, Jbarone ssp, 6k lows, 20% tint all around, Corksport TP |
![]() | | #269 | ![]() |
![]() Join Date: Apr 2009 Location: Bethpage, New York
Rep Power: 4481 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,850
Groans: 778
__________________ 2003 SilverStone Grey Honduh S2000 ![]() ![]() | |
![]() | | #270 | ![]() |
![]() Join Date: Feb 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
| Not Ranked : 0 score |
![]() | | #271 | ![]() |
Groans: 125
| Not Ranked : 0 score thats a drop in the bucket bro, especially if it will open up the potential as much as we think it might.
![]() | | #272 | ![]() |
Groans: 60
| Not Ranked : 0 score $350 to get the extra 100~300 hp some of these turbo's and built motors have left in them, that's a bargan..
![]() | | #273 | ![]() |
| Not Ranked : 0 score yah but that 350 dollar valve isent gona change shit if you cant scale the sensor more.
![]() | | #274 | ![]() |
| Lurkers
Posts: n/a
![]() | | #275 | ![]() |
I'm just gonna keep up on liquids and ride it out. I think i'll be fine, but yeah, if it gets worse i'll def get checked out. As far as the valve goes, yeah, if we planned on running higher and higher pressures, eventually we'd have to upgrade to a higher pressure sensor, cause the stock is only good for 400~500 more psi. And honestly beyond that, i think the injector operation might become a lil iffy. Personally i don't want to spend 350 on a new valve, i'll probably try the disk first. Still tho, great find Mass!
![]() | | #276 | ![]() |
| Not Ranked : 0 score Ide buy that valve, that isnt a bad price for a valve if it is high enough quality to hold a consistent pressure for a few years etc, it would suck if it lost or gained pressure.
![]() | | #277 | ![]() |
| Not Ranked : 0 score In the end we might not need a valve at all. This is why starting with a cheap disk to test is best. You can also put a restrictor pill in the hose that is low pressure downstream of the valve. As long as you don't make the pill very small, it should restrict enough flow. |
![]() | | #278 | ![]() |
| Not Ranked : 0 score i would not recommend putting in a restrictor pill downstream. that will increase pressure in the low pressure line and could make it burst. |
![]() | | #279 | ![]() |
| Not Ranked : 0 score somewhere someone has to make this exact piece... hrmmm |
![]() | | #280 | ![]() |
Ideally however it should be on the high pressure side, I agree. I don't think it would take much of a restriction to bump the rail pressure up. | |
| 0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? | AFcadet | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 26 | 08-02-2019 11:09 PM |
| TIRE PRESSURE SENSOR... | redneckrecon | MazdaSpeed 3/6 - Wheels & Tires | 12 | 01-21-2011 07:23 PM |
| How to scale the HPFP pressure sensor | djuosnteisn | MazdaSpeed 3/6 - ECU Computer Tuning | 521 | 04-07-2010 08:39 AM |
