![]() Join Date: Sep 2011 Location: New York City
Rep Power: 916 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 442
Groans: 93
Groaned at 27 Times in 16 Posts
(Thread Starter) | Neutral : +3 score With @Raider's blessing, this has officially become the "Ultimate Guide to Parameter Monitoring" thread. Basically, I am a noob when it comes to using things like UltraGauge, DashHawk, AccessPort, Torque, etc. After ordering my first such tool (I went with the UG), I needed to decided what to monitor. I searched a ton and decided what parameters I wanted to track, but I couldn't very well know if the car was running normally if I didn't know what the normal range of values should be. This thread is, therefore, a list of commonly monitored parameters and what their acceptable values are. Please add/modify as you see fit. Boost: Should be in the negatives (vac) while at idle. With A/C on it will fluctuate a bit as the compressor turns on and off. As you accelerate it will raise closer to zero and eventually go in to positive numbers (building boost) if you continue to accelerate. (@Sid3wayS) Engine Temp (Coolant Temp): I believe normal operating temps are between 180-200 but Ive seen as much as 220 sitting in a parking spot and as low as 160 cruising down the highway on a cold night. (@Sid3wayS) Intake Temp (IAT): When moving should be at or within a few degrees of ambient. When stopped obviously you're sucking in hot engine bay air so it will raise considerably, but will return to ambient quickly when moving again. (@Sid3wayS) Fuel Pressure: at idle will be around 420, give or take 30psi. With A/C on it will fluctuate a lot. If you ever see under 100 chances are there is something wrong with the CDFP (fuel pump) and you are running off in-tank pressure only. At WOT it should never drop under 1600, if it does there is an issue with the CDFP, period. (@Sid3wayS) Air-Fuel Ratio (AFR): Stoichiometric is 14.7 and that is what your car is always trying to achieve under normal driving. At WOT it will drop, generally around 11.8, since this is what most OTS maps shoot for. With tuning AFR can be leaned out further. When you lift your foot off the gas and coast it will normally jump to 29.xx (@Sid3wayS) Mass Air Flow (MAF): Very basically, how much air the car is sucking in. This changes all the time as you move and unless you are tuning, not really something you have to monitor. (@Sid3wayS) Engine Load: Battery Voltage: With the stock battery mine is generally at 13.7. (@Sid3wayS) Knock Retard (KR): In an ideal world, this should always be zero but with engine noise, shitty roads and a thousand other things you will almost always register something when driving. Generally as long as it is under 2.0*, not consistent, and not during WOT, ignore it. (@Sid3wayS) Long-term and Short-term Fuel Trim (LTFT/STFT): Basically, how much fuel your motor takes and adds to reach your targeted AFR. These numbers vary but on an OTS map should be +/- 8 of each other, and on a custom tune will be generally be +/- 4. The closer these numbers are the better because your ECU is not going crazy trying to keep things in check. Environment, weather and fuel quality are just some things that affect the numbers. (@Sid3wayS) Boost Air Temperature (BAT): the temperature of the air as it is being ingested by the motor. For the most part, the colder the better. Upgrading intercoolers, shooting meth, and using insulation will lower this number. No real constant number because it depends on your mods. (@Sid3wayS) Waste Gate Duty Cycle (WGDC): How much your waste gate on the turbo opens and closes. It very basically controls the boost levels by diverting the exhaust air away from the turbo. The more it opens the less air hits the turbo, the more it closes, the more gasses hit the turbo. As more air hits the turbo fins, the faster it spins and more boost is made. This is a percentage from 1-100. 1 is closed and 100 is open. (@Sid3wayS) Everyone can feel free to list the parameters they monitor, what accepted values are, and maybe even what mods you have (or just include in Signature) so that anybody else thinking of adding a mod can know what to expect. I'll conglomerate the information in the OP for easy access. TIS
__________________ TOTS 2012 Mazdaspeed3, CWP, Tech Package. COBB AccessPort V3, AUTOTECH HPFP Internals, JBR 3" Wide-path SRI+TIP, CP-E TMIC, UR 3" Test Pipe, CP-E Triton CBE, FORGE V2 BPV, DENSO ITV22 Plugs, JBR RMM 88a, JBR OCC, JBR RSB Kit, JBR Solid Shifter Bushings, CP-E Tow Plate, CorkSport ECU Relocation, TSW Nurburgring Bronze 18x7.5 ![]() alphasaur: "Fuck I just beat it to surprise tranny porn. Saw the dick right when I came fml" |
| The Following 5 Users Say Thank You to ANITIX87 For This Useful Post: | danny_speed3 (10-22-2019), Digital_Jedi (09-07-2013), Kfunk (06-14-2013), Reggaeboy143 (03-02-2014), texasboy21 (04-02-2015) |
| Not Ranked : 0 score Go for it! |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Not Ranked : 0 score ^^lol
__________________ [01:31 PM] SoAgg159: my dick is called "quarter mile" it's about 1/4" long and i can give about 14secs of pleasure [07:06 PM] DarkHeartMS6: yeah. I actually hope i catch my wife with another dude. gives me an excuse to open the emergency door and bail. LOL [09:13 PM] Pu Manchu: i like to take my gf through the drive thru so i can prove that i can pleasure a woman |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
| Not Ranked : 0 score Does it display Knock Retard, Injector Duty Cycle, Ignition Advance, and WGDC?
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress |
Groans: 93
TIS
__________________ TOTS 2012 Mazdaspeed3, CWP, Tech Package. COBB AccessPort V3, AUTOTECH HPFP Internals, JBR 3" Wide-path SRI+TIP, CP-E TMIC, UR 3" Test Pipe, CP-E Triton CBE, FORGE V2 BPV, DENSO ITV22 Plugs, JBR RMM 88a, JBR OCC, JBR RSB Kit, JBR Solid Shifter Bushings, CP-E Tow Plate, CorkSport ECU Relocation, TSW Nurburgring Bronze 18x7.5 ![]() alphasaur: "Fuck I just beat it to surprise tranny porn. Saw the dick right when I came fml" | |
![]() Join Date: Jul 2011 Location: Plantation, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,748
Groans: 97
| Not Ranked : 0 score Well from my experience and from what I have seen and read from my fellow nator locals, atleast here in south florida: -boost: should be in the negatives(vac) while at idle. With a/c on it will fluctuate a bit as the compressor turns on and off. As you accelerate it will raise closer to zero and eventualy go in to positive numbers(building boost) if you continue to accelerate. -engine temp: I believe normal operating temps are between 180-200 but Ive seen as much as 220 sitting in a parking spot and as low as 160 cruising down the highway on a cold night. -Intake temp: when moving should be at or within a few degrees of ambient. When stopped obviously you're sucking in hot engine bay air so it will raise considerably, but will return to ambient quickly when moving again. -Fuel pressure: at idle will be around 420 give or take 30psi. With a/c on it will fluctuate alot. If you ever see under 100 chances are there is something wrong with the cdfp and you are running off in tank pressure only. At WOT it should never drop under 1600, if it does there is an issue with the cdfp, period. -Afr: stoich is 14.7 and that is what your car is always trying to achieve under normal driving. At wot it will drop generaly around 11.8, it is what most OTS maps shoot for but with tunning can be leaned out further. When you lift your foot off the gas and coast it will normaly jump to 29.xx -maf: very basicly how much air the car is sucking in, changes all the time as you move and unless you are tunning, not realy something you have to monitor. -Engine load: again basicly how hard your motor is working, Ill let someone else with more experience explain it better and it's avearges. - battery voltage: with the stock battery mine is gennaeraly at 13.7, been like that for 2 years now, dont know if that is normal or not. One that you should add is knock retard or kr -kr: in an ideal world should always be zero but with engine noise, shitty roads and a thousand other things you will almost always register something when driving. Generaly as long as it is under 2.0*, not consistant and not during WOT ignore it.
__________________ TEAM LUXURY |
| The Following 2 Users Say Thank You to Sid3wayS For This Useful Post: | danny_speed3 (10-22-2019), Reggaeboy143 (03-02-2014) |
Groans: 93
(Thread Starter) | Not Ranked : 0 score Thanks for this post, man. Mad props. Mind if I copy some of the information into my OP for easy reference if Raider turns it into a sticky? Also, the UltraGauge will not monitor KR as far as I know. I'll have to wait and save up for an AccessPort for that, I guess. TIS
![]() Join Date: Oct 2011 Location: Richmond Hill
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 93
| Not Ranked : 0 score Shoulda gone DH bro!
__________________ 2007 Mazdaspeed 3 -CP-e CATTED DP-PTP HPFP-COBB SRI-COBB TIP-COBB XLE-COBB AP FREEKTUNE-DENSO ITV24-JBR CHROME MOLLY-JBR PMM-JBR TMM-JBR OCC-JBR RSB-RALLY ARMOR-DASHHAWK-E4P STS-DEFI GAUGES-RL COILOVERS- |
Groans: 97
| Not Ranked : 0 score No please by all means. And Dh does not work with the genpu
| Banned ![]() Join Date: Sep 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 155
| Not Ranked : 0 score I monitor ltft on mine FWIW. |
| Not Ranked : 0 score Really? Wasn't aware.
Groans: 97
| Not Ranked : 0 score Yeah you can plug it in and it will read maybe 1 or 2 things but nothing that is mazda specific. No afr, kr, lfts, sfts, boost, bats, iat, fuel pressure, wgdc, inj cycle, nada. It's a giant $200 paper weight for the gen pu.
![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 546
| Not Ranked : 0 score on my main screen I monitor LTFT, Fuel pressure, ECT, intake temp, manifold pressure and AFR. I really primarily only pay attention to LTFT and fuel pressure, but I will notice if my other parameters are off.
__________________ 2008 Cosmic Blue Mazdaspeed3 1986 Mazda RX7 2002.5 Sunlightsilver Protege5 (sold 12/26/09) Hey you should read this: http://www.mazdaspeedforum.org/forum/foru...ler-you-58361/ |
Groans: 97
| Not Ranked : 0 score And what are the readings you normaly have for those parameters.
![]() Join Date: Feb 2012 Location: San Bernardino, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,954
| Not Ranked : 0 score Scan gauge works on the pu and reads knock... I went that route but sideways pretty much coveted what I knew
__________________ 2010 velocity red mica ms3 AP/AT internals JBR 3.5" whale peen (non rubber for more feeling) JBR SSP/bushings JBR RMM JBR tigs/ egr delete/ coolant bypass JBR stage 2 OCC CS test pipe Turbosmart BPV (stocker currently on) SS lines/super blue/stoptech pads |
| Not Ranked : 0 score LTFT fluctuates and depends on your mods and if youre tuned or not. Ideally you dont want to see anything +/- 8 on any tune, but with a good maf cal it should always be around +/-2 ECT will depend on whether you have a front mount or not. Now that my front mount is off, I never see it over 200, whereas with my front mount seeing high 190s to low 200s was pretty common Intake temps depend on your local ambient temperatures fuel pressure is 420ish at idle and 1600+ at WOT manifold pressure and AFR idk off the top of my head, I dont really pay attention to them. in fact, im not even sure if I still have AFR on my main screen still.
Groans: 93
(Thread Starter) | Not Ranked : 0 score God I am such a noob. What are all of these (and associated values)? That's another reason I am aiming to make this a "holy Grail" thread for car parameters. Because I am sure there are others like me who don't know this shit at all! TIS Tapatalkative.
| Not Ranked : 0 score There arent really specific values for some of these parameters. Its sort of more knowing the range the values should be in, and the conditions that surround what causes them to be off. Everyones Long term fuel trims and short term fuel trims are going to be different.. so its not really so much about making sure values match or are specific, but understanding what youre monitoring. understanding what youre monitoring and knowing what the values should be sort of go hand in hand. There isnt a specific value that STFT should be at, but for both short term and long term trims, you always want them as close to 0 as possible.
Groans: 97
| Not Ranked : 0 score Ltft & stft: basicly how much fuel your motor takes and adds to reach your targeted afr. These numbers vary but on an ots map should be +/- 8 of each other, on a custom tune will be generaly +/- 4. The closer these numbers are the better because your ecu is not going crazy trying to keep things in check. Envirment, wether and fuel quality are just some things that affect the numbers. Bats: the temperature of the air as it is being ingested bu the motor. Gor the most art the colder the better. Upgrading intercoolers, shooting meth and using insulation will lower this number. No real constant number because it depend on your mods. Iat: is the temp of the air getting sucked in. Explained up top Wgdc: is how much your waste gate on the turbo opens and closes. It very basicly controls the boost levels by diverting the exahuat gases away from the turbo, more it opens the less gasses hit the turbo, the more it closes, the more gasses hit the turbo. The more gas that hots the fins the faster it spins and more boost is made. This is a percenatge from 1-100. 1 is open and 100 is closed. Again these are very vague refrences and are just to give a basic idea of what each value is and represents. Like @NCZ13 knowing what they mean and having a general idea of the values go hand in hand and take alot of reading.
| Not Ranked : 0 score $10,000,000 sent to OP to maintain this thread. |
Groans: 93
A quick question about the WGDC. Since the car runs a BPV stock, I should expect somewhere close to 100% for this, right? And without a tune, one should continue running a BPV (or a BOV/BPV that has a full-recirc) because of the MAF? Thanks. I'll definitely keep this thread on-track and informative. I got a stupid fucking question though. What can we do with MSF Bucks other than making our usernames look pretty or donating/stealing MSF Bucks to/from others? TIS
Groans: 97
| Not Ranked : 0 score Sorry I wrote that late last night, its the other way around. No it closes when you are building boost to control the levels. At full Wot it should be fairly constant. This fully depends on your tune. For instance mine is set at 70% when at full boost. The reason we have bpv is because we have a recirc system, the air once sucked in is accounted for and a percentage of fuel is calculated for that metered air. ShoulD it be expelled from the system, a bov, that air is not missing and your afr now has to much fuel causing a rich condition which is the black smoke/backfire that people not tuned for bov get. Msf bucks can be used to join raffles.
Groans: 93
Also, what about other parameters like: EGT Oil Temp Coolant Temp And any others anyone else thinks would be useful, whether Stock or Tuned... TIS
![]() | | #24 | ![]() |
Groans: 97
| Not Ranked : 0 score The waste gate and blow off valve are 2 different things. The waste gate is attatched to the exhasht side/hotside of the turbo either either internaly or externaly. When it diverts the gasses it dumps it in to the DP. A bov/bpv is there to release the pressure on the intake side/cold side of the turbo. When you build boost it flows thru piping, past the throttle body and into the motor. When that throttle plate closes(because you stop accelerating) there is air trapped in the piping that has to go some where, the bov/bpv releases this air wether back into the intake or vta. With out a bpv/bov the pressure will travel backwards towards the turbo(because it is the only way out) and cause compressor surge. The wgdc only has to do with the wg.
![]() | | #25 | ![]() |
| Not Ranked : 0 score |
![]() | | #26 | ![]() |
| Not Ranked : 0 score Thanks for doing this OP. I'm sure this will help many more people than it currently seems in this thread. Keep it up!
![]() | | #27 | ![]() |
Groans: 93
(Thread Starter) | Not Ranked : 0 score Bump for more input to help more noobs! What is a normal range of values for: EGT Oil Temp Coolant Temp And please list and indicate normal values for any other important parameters not already listed in the OP. TIS
![]() | | #28 | ![]() |
Groans: 97
| Not Ranked : 0 score What you have set as engine temp is coolant temp.
![]() | | #29 | ![]() |
![]() Join Date: Mar 2012 Location: Toronto,Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,065
| Not Ranked : 0 score What would be considered a BAT that is too high?
__________________ 2007 Mazdaspeed 6 Black Mica Richtuned ~Some things have been bolted on~ [SIGPIC][/SIGPIC] |
![]() | | #30 | ![]() |
Groans: 93
(Thread Starter) | Not Ranked : 0 score My UltraGauge came today. A few questions about some of the parameters. WGDC: I don't see anything called this, but there is "EGR Percentage" and "Evaporative Purge Percentage" and I am curious if either of those is the WGDC or not. Input from anybody? Also, does our car have fuel injector cutoff on coasting or engine braking? I didn't see my fuel pressure drop to zero on throttle lift-off, and I figure it should if injector cutoff is enabled, no? TIS
![]() | | #31 | ![]() |
![]() Join Date: Feb 2012 Location: so cal
Rep Power: 1301 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 649
| Not Ranked : 0 score Subbed my ug dosnt have kr, bat, wg.. Switched from scan gauge because I wanted the faster refresh rate, blah Sent from my dizzLe using RaWr powers!
__________________ Sold: 2010 MS3 siLver. E85(25%) - Stratified DynoJet - 307//357 Suspension: H&R springs//Sensen Mazda5 struts; TB Performance TractionBar//Trunk Brace Brakes: CorkSport Pads; Centric Blanks Other: UltraGaugeEM; JBR 88D Rmm; JBR SSP//Bushings; EGR unplug;CF 3m vinal on trim in side car Official 60-100mph Times Official Video battles Official Youtube Channels
:-( 2014 - Dodge Dart.. (Blue Turtle) | |
![]() | | #32 | ![]() |
Groans: 97
| Not Ranked : 0 score This is hard to say because there are many variables that go into bats. Ambient temps, mods, speed and time that the car is running all play a role. Generally the closer you are to ambient the better. For example with my sig I usually see about 12* above ambient in stop and go traffic, about 8-10 on the highway. Stock cars ive seen as much as 40* above in stop and go. Its one of those things you have to observe to find out what is normal for your situation. Asking locals with simular mods is a good average.
If your fuel pressure ever reads 0 while your motor is running you have major problems. No matter what the circumstances your injectors are always spraying fuel, the amount is what changes. At Wot the pressures should always be above 1600psi, during engine brake and coast the pressure will drop drasticly but should never be any where near zero.
__________________ TEAM LUXURY | |
![]() | | #33 | ![]() |
![]() | | #34 | ![]() |
Groans: 93
TIS Tapatalkative.
![]() | | #35 | ![]() |
| Not Ranked : 0 score Hey @Sid3wayS so I watched the bats and they were around 120f but when I parked at work after stop and go traffic it was at 160-169 but the intake air temp was roughly the same..is that normal?
![]() | | #36 | ![]() |
Groans: 97
__________________ TEAM LUXURY | ||
![]() | | #37 | ![]() |
Groans: 93
I can't think of another reason for our fuel economy going to an indicated 99.9 on our car computers if the injectors aren't cutting off (though, to be fair, it does the same thing when switching to neutral, so maybe the computer automatically defaults to 99.9 when no throttle is used). Tapatalkative.
![]() | | #38 | ![]() |
![]() Join Date: Jun 2012 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 201
| Not Ranked : 0 score Great thread! I'm currently monitoring and logging with torque (until I get my AP) and this has and im sure will continue to give some great info on what I should be keeping an eye on. Thanks!
__________________ 2012 MazdaSPEED 3 - Crystal White Pearl Performance - Precision 5858 - Built motor (K1 Rods / Wiseco Pistons / ARP main studs / Stock head bolts) - Cobb V3 AccessPORT - PERM 5th port kit, PERM Plate - HTP 3.5" Intake (Powder Coated Pure Orange) - Autotech HPFP Internals – CPE Vband Exhaust Manifold - Kozmic Vband Downpipe, Dumptube, Oil feed / Return lines, Vented OCC, Primary EGR delete – Ultimate Racing Catback, FMIC modified for 5th port by Kozmic Motorsports - Turbosmart dual port , 45mm EWG - JBR Coolant Bypass, EGR Delete, Throttle body TIG, Dogbone RMM, Transmission Mount, Sealed OCC - Grimmspeed EBCS - NGK plugs - Bosch 3.5 Bar MAP w/MattJackson86 PnP Harness – Ported Intake manifold with VCTS delete, 1/8" Intake manifold TIG by Zack - Spec Stage 3+ Clutch and flywheel Tuned by Voltwings (OLD k04 SET UP ) 374.5 WHP 447.2 WTQ with stock K04 - 1-17-14 Dynocom dyno (New BT numbers soon) ~487WHP 455wtq Virtual Dyno and out of fuel... moar injectors! Looks - Pure Orange Powder Coated Gen Pu Stockers - Muteki SR48 Lugs - 5k HIDs / 3K HID Fogs |
![]() | | #39 | ![]() |
Groans: 93
(Thread Starter) | Not Ranked : 0 score Hi, all. I've been monitoring more and more and playing with my Ultra Gauge a ton. I wanted to throw a few more questions out that have emerged and that I've seen elsewhere on the forums. I have gotten confirmation that our car does have fuel injector cutoff when coasting in gear. I also got a great lesson on AFR and its significant from @Wicked (quoted from MPG Tooning with ATR ): (Talking about the Ultra Gauge parameter called "AFR Command Ratio", which is also called "AFR Lambda") Essentially, stoich (14.7 in a gasoline fueled motor) = 1.000 in Lambda. Multiply 14.7 by whatever your "AFR COMMAND RATIO" reads at WOT and you get your actual WOT AFR. So at cruise/idle you should be 1.000 lambda. Using Lambda is invaluable when mixing E85 with gas. Our native wideband reads lambda, then converts that numeric value to AFR in gasoline by the formula of 14.7 * X where X = the lambda value. Why is this important? Well when you mix E85 with gasoline, it changes stoich. Stoich for E85 (from my past use of E85 in my Cobalt) is 10.4 AFR. This means that as long as the car is reading a lambda value, it can calculate the AFR, and read it to us regardless of the fuel type. It will, however, display it in gasoline AFR per the parameters of the car's sensor readout. This is not an issue because .75 lambda is still .75 lambda regardless. I had an awesome autometer wideband in my Cobalt that allowed my to display my stoich in what ever ratio I wanted. So my saw 10.4ish at idle and 8.0 at wot, my true E85 AFR. If you ran straight E85 on the MS3, since you can't change the readout, it will show 14.7 as stoich. Again, not an issue because that is 1.0 Lambda. This is why E85 takes about 30% more fueling to reach same targeted Lambda value. However, after reading this I had more questions. My AFR COMMAND RATIO was around 1.000 at cruise (as expected) and around 0.750 at WOT (equivalent to an AFR of 11). However, when cruising in gear when the fuel injectors should shut off, the AFR should, theoretically, be infinite. But my Lambda was never going above 1.003 or so. I decided to monitor another parameter I found in the Ultra Gauge called "O2 BANK 1 OXYGEN SENSOR." At WOT, the value is somewhere around 0.950. When coasting in gear (again, the fuel injectors should be off at this point), the value of this parameter falls to 0.000 immediately. However, I have NO idea what this parameter indicates because I can't see how an O2 voltage relates to AFR. Tonight, I will change the gauge again, to one calleed Bank 1 O2 Sensor Lambda (which the UG manual claims exists, but that I don't remember seeing in my list of gauges). If I can find it, I will monitor this instead, and hope that the values line up more exactly with what I expected from the AFR COMMAND RATIO gauge. I will report back here, and hopefully @Wicked and the other guys in the thread I mentioned can give their expertise. TL;DR: Thanks to @Wicked for some good info on AFR. Will update OP with information. Question for the experts: How can the O2 voltage relate to AFR, and why wasn't my AFR COMMAND RATIO parameter going high when coasting in gear? Another question: Do our cars send out a parameter for oil temperature and/or oil pressure through the ODBII port? I haven't found any way of monitoring this using my Ultra-Gauge, but maybe it's possible using other scan tools? I know the UG can't do BATs, which is quite annoying. TIS
![]() | | #40 | ![]() |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f628/ultimate-guide-parameter-monitoring-125065/ | ||||
| mikey32235 everything is broken - Page 9 | This thread | Refback | 11-30-2012 03:35 AM | |
| mikey32235 everything is broken - how to set a car on fire - Page 9 | This thread | Refback | 11-29-2012 10:57 AM | |
| Ultimate Guide to Parameter Monitoring? | ANITIX87 | Gen2 MS3 General Discussion | 50 | 11-19-2012 12:24 PM |
| EGT monitoring | shifter48 | 2010 MS3 - ECU Computer Tuning | 2 | 01-18-2012 04:26 AM |
| How to Change a Flat Tire: The Ultimate Guide | Haltech | Automotive News | 0 | 06-14-2010 02:10 PM |
| Autoblog's Ultimate Toyota Recall Guide | Haltech | Automotive News | 0 | 02-01-2010 10:20 AM |
| STOCK engine parameter recordings | RocketScientist | MazdaSpeed 3/6 - ECU Computer Tuning | 0 | 12-29-2009 10:43 AM |
