![]() | | #161 | ![]() |
![]() Join Date: Nov 2010 Location: Rochelle,il
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 196
| Not Ranked : 0 score |
![]() | | #162 | ![]() |
![]() Join Date: Aug 2008 Location: Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 438
Groaned at 81 Times in 33 Posts
| Not Ranked : 0 score At the price of the Ultimate Racing axleback, you may as well pick up the magnaflow catback it seems.
__________________ Mike 2008.5 CWP Mazda CX-7 Sport FWD - hers 2008.5 CWP Mazdaspeed 3 GT - traded 2011 LSM Mazdaspeed 3 Sport w/tech pkg - sold |
![]() | | #163 | ![]() |
![]() Join Date: May 2011 Location: Maryland
| Not Ranked : 0 score going with corksport. Just cat back. Any problems with aftermarket down pipes causing boost creep? |
![]() | | #164 | ![]() |
![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40,628
Groans: 386
| Not Ranked : 0 score If you go no cats, you will overboost. |
![]() | | #165 | ![]() |
![]() Join Date: Dec 2010 Location: Bloomington, Illinois
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 156
(Thread Starter) | Not Ranked : 0 score I just wanted to give my .02 on the magnaflow exhaust. I need to install my downpipe still but I didnt want to mess with that today. Overall it is a nice exhaust. I have used magnaflow in the past and the one thing that pissed me off about this particular system is the slip fit. I didnt test fit the pieces before installation (wish I had) the rear section would not go together. I ended up having to use some vice grips to open it up a little to get the two pieces to slide together. That isnt really a big deal, but If I am buying a "bolt-on" exhaust I expect the shit to bolt-on without having to dick with it. finkle had mentioned having an exhaust leak at the cat. Mine went together perfectly and does not leak (there) BUT I do not have my downpipe installed and I am not running a testpipe.... I will update whenever I get around to installing the downpipe. I DO have a small leak at one of the midpipe connections... I tried to get it to stop but couldnt so I will probably take it to an exhaust shop if I cant fix it. I didnt really like the way the kit was sectioned either. It was 4 pieces total, The resonator replacement being 1, the midpipe, and the piece that goes over the suspension to meet the rear section. I think it would have been a little easier to install had it been 3 pieces. It was just a pain in the butt to snake the smaller piece through. For the price it is a great exhaust. It is extremely quiet which I am happy about. Hopefully it is still fairly quiet after I put the downpipe on. My car no longer has the cheap "airy" sound the stock exhaust produces. Instead it is extremely deep and even though it is quiet, you can tell there is an aftermarket exhaust installed. scale of 1-10 for the exhaust in general I would give it a 7.5 or 8 would I buy it again? yes.
__________________ Daily - 2007 True Red Mazdaspeed3 GT. Jack Stand Race Car - 1991 Aquamarine Pearl MR2. |
![]() | | #166 | ![]() |
| Not Ranked : 0 score The above is all spot on, as far as my impressions of the Magnaflow also. To be fair to both Magnaflow (exhaust) and Ultimate Racing (test pipe), there isn't any guarantee that individual parts from different manufacturers are going to fit perfectly together. If the Magnaflow had been loud enough for me, it looked nice, and could have been fixed easily by a qualified exhaust shop @ the leak that I described and my slow1 referred to. |
![]() | | #167 | ![]() |
Groans: 386
| Not Ranked : 0 score I have finkle's exhaust now, and I agree with both of them. I have stock dp/rp for now, and I can't really tell any difference in sound from the stock exhaust. The tips look great though! I had to open up all of the slip joints, but I assume it is because it was used, and they had already been compressed when finkle installed them. Hopefully when I get my dp on, it will make it a little more noticeable. |
![]() | | #168 | ![]() |
![]() Join Date: Mar 2011 Location: Hampton, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,760
| Not Ranked : 0 score Just got my Corksport exhaust installed today. The audio on my video camera sucks. So rather than shooting a video clip, I took some audio recordings using a digital field recorder. First is a recording of stock, then the Corksport. Stock downpipe and race pipe. See signature for other mods. EDIT: Added a short in-car video clip.
__________________ 2011 MAZDASPEED 3 BNR: 352 hp / 342 ft-lbs K04: 296 hp / 343 ft-lbs BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges |
![]() | | #169 | ![]() |
![]() Join Date: Nov 2010 Location: Lakeland, WA
Rep Power: 1231 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 875
Groans: 266
| Not Ranked : 0 score I just want to let everyone know that magnaflow exhaust is not a 3inch exhaust. After the 3inch flange that hooks to the DP it bottle necks down to what magnaflow says is 2.5 inch but what i measured as id of 2 1/4 inches. So everyone that didnt fix this you have a more restrictive exhaust than stock. For my fix i bought a new 3 inch flange (since no muffler shops carries them) then I will cut of the old flange at the bottle neck. Then weld new piece of stainless steele that flares a little to fit my cp-e dp. Now I will have a real 3inch magnaflow cat back. I will let you know how this goes later this week once I get the 3 inch flange delivered.
__________________ Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next. |
![]() | | #170 | ![]() |
| Not Ranked : 0 score From what I understood, the exhaust (at the catalytic converter) is necked down to 2.5". It then expands immediately to 3". Is this not correct??
![]() | | #171 | ![]() |
I dont think a 2" section of smaller pipe will make that big of a difference, but I will probably have mine cut out as well.
__________________ Daily - 2007 True Red Mazdaspeed3 GT. Jack Stand Race Car - 1991 Aquamarine Pearl MR2. | |
![]() | | #172 | ![]() |
Groans: 266
| Not Ranked : 0 score once it bottle necks than what ever comes after it can only flow as much as that. Are you talking about stock or Cp-e dp, a cat will cause some slow up but that unavoidable, this bottle neck i can avoid.
![]() | | #173 | ![]() |
| Not Ranked : 0 score I'm talking about the Magnaflow CBE. Stock is 2.5", Magnaflow is 3" except for where it connects to the stock cat, it necks down to 2.5" for stock.
![]() | | #174 | ![]() |
Groans: 266
| Not Ranked : 0 score So once it does bottleneck down to 2.5 than the exhaust is a 2.5. And I measured the id its 2 1/4. I have a 3inch dp, I want a true 3inch exhaust.
![]() | | #175 | ![]() |
![]() Join Date: Mar 2011 Location: Lubbock,TX
| Not Ranked : 0 score [QUOTE=skeurton;851876]Just got my Corksport exhaust installed today. The audio on my video camera sucks. So rather than shooting a video clip, I took some audio recordings using a digital field recorder. First is a recording of stock, then the Corksport. Stock downpipe and race pipe. See signature for other mods. Glad to see you got it ok. Enjoy it. I loved the sound, but it was a bit loud for me.
__________________ [SIGPIC][/SIGPIC] Xmotorsports.com 806-771-0205 |
![]() | | #176 | ![]() |
__________________ 2011 MAZDASPEED 3 BNR: 352 hp / 342 ft-lbs K04: 296 hp / 343 ft-lbs BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges | |
![]() | | #177 | ![]() |
| Not Ranked : 0 score Lol, it was the only box I had that the exhaust would fit in.
![]() | | #178 | ![]() |
So you're saying the Magnaflow cbe starts at 2.25" at the factory cat, then quickly expands to 2.50"? Where does it become 3" then? Not to sound like a douche but, you sure you didn't get the 2010 MZ3 kit instead?
__________________ Mike 2008.5 CWP Mazda CX-7 Sport FWD - hers 2008.5 CWP Mazdaspeed 3 GT - traded 2011 LSM Mazdaspeed 3 Sport w/tech pkg - sold | |
![]() | | #179 | ![]() |
![]() Join Date: Feb 2011 Location: Bellingham WA
Rep Power: 0 ![]() ![]() Thanks: 49
| Not Ranked : 0 score When i was installing my Magnaflow CBE i didn't even notice the bottle neck part that connects to the DP. I was in a hurry at my friends shop putting it on and it got busy real quick so i rushed it. When i put my SU RP on i will certainly look and take pics as soon as i get my car back from the shop. That bottle neck could explain why the magnaflow sounds similair to the factory exhaust. If it is 2.5" or less i'm gonna have it cut down and made 3"... The magnaflow cbe i rate 7/10 because of it was a bitch to bolt up properly. No matter what i did one muffler stuck out almost an inch more than the other and it pisses me off.. It's good for the money though if you plan on mating it with the rest of the exhaust fo sho.
__________________ BNRs3 Turbo--SU RMM--CS Intake w/ TIP--CS STB--CS Radiator--TurboSmart DP BOV--ATP TBE-- Autotec HPFP--CP-e TMIC--v2 Cobb AP-- Stratified Tune--JBR Boost tubes--SURE rear Sway Bar-- Tanabe Front Chassis Brace-- GT Spec H brace-- JVC Double DIN Nav-- JBL p660s front/rear-- RF P3 10" Sub--3 Amps 1200w RMS total System powa!-- |
![]() | | #180 | ![]() |
| Not Ranked : 0 score ^^^ post up a vid when ya get that rp in. |
![]() | | #181 | ![]() |
I noticed where it necked down, but there is no way the ID was 2.25". I dont think it was as bad as what is pictured above. When I do my downpipe I will pull that piece off and measure the ID.
![]() | | #182 | ![]() |
![]() Join Date: Jan 2011 Location: Indianapolis, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21
![]() | | #183 | ![]() |
Groans: 266
Definitive Exhaust Thread
__________________ Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next. | |
![]() | | #184 | ![]() |
![]() | | #185 | ![]() |
Groans: 266
| Not Ranked : 0 score Magnaflow says the bottle neck is 2.5, I measured the id from the top at 2 1/4.
![]() | | #186 | ![]() |
![]() Why the fuck would Magnaflow do that?? That seriously pisses me off. What kind of sense does it make going even smaller than stock??
![]() | | #187 | ![]() |
Groans: 266
| Not Ranked : 0 score Idk, I tried taking pictures of the id but the flash kept reflecting off the tape measure. It is not even close to 2.5. The rest is 3 inches though, And the only one that is released as of the date is the speed version MagnaFlow Exhaust Products - For Trucks, Suv's, American Muscle, Diesel, & Sport Compact Vehicles
![]() | | #188 | ![]() |
![]() Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,682
Groans: 278
this is why cobbs dp tapers down to 2.5 at the cbe flange side. b.c its not going to restrict that far down the exhaust
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" | |
![]() | | #189 | ![]() |
| Not Ranked : 0 score So if it's not restrictive, why even bother with the neck down then?
![]() | | #190 | ![]() |
Groans: 266
| Not Ranked : 0 score that far down? it the start of the cat back. CS, Cp-e exhaust dont do that
![]() | | #191 | ![]() |
Groans: 278
| Not Ranked : 0 score cobb tapers it down ON THE DP. they usually do this to mat to the stock exhausts. but from what i was told. you wont see restriction out of the exhaust until around 500hp
![]() | | #192 | ![]() |
(Thread Starter) | Not Ranked : 0 score so it mates well with the stock cat.
![]() | | #193 | ![]() |
| Not Ranked : 0 score True. For the money, Magnaflow seems best. UR's axleback doesn't fit very clean.. I didn't like pictures I seen on nyspeed.com.
![]() | | #194 | ![]() |
![]() Join Date: Feb 2011 Location: San Antonio Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Had the Rez removed yesturday, 2% improvement. I say this because it really isn't much louder. But in my opinion the sound quality (the note and tone) is improved. So from here I want to modify the muffler set up. |
![]() | | #195 | ![]() |
![]() Join Date: Feb 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,452
Groans: 82
| Not Ranked : 0 score Get a test pipe? It'll be cheaper than getting the muffler removed/replaced, and will sound pretty good. There's a clip of how it sounds at the beginning of the thread here I think. |
![]() | | #196 | ![]() |
| MS3 Abuser ![]() Join Date: Aug 2009 Location: Dirty Jersey (Jersey City, NJ)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 119
| Not Ranked : 0 score UR FTW. It's 3", all the way through.
__________________ 12.653 @ 109.90mph, Stock K04 2010 MS3 |
![]() | | #197 | ![]() |
Groans: 266
| Not Ranked : 0 score Alright so here how it went. They guy charged me $60 bucks for install and modification of the pipe. So, not that bad. total cost for me was 400+100 (cost of not selling testpipe)+60= 560. This pictures is of the maganflow pipe that connects to the dp where the restriction is, next to it is my corksport test pipe. So the guy cut off the flared part of the testpipe and cut off the top flange. He welded them together and we used the cs flange and this was created. Here is it hooked up to the dp. From the side Underneath Back So at idle and cruising it is no louder than stock (with a dp) At wot it it has a much louder and deeper growl. This is everything I wanted so I am very pleased. As for the video...maybe tomorrow, i tired from work and need to do data logs.
![]() | | #198 | ![]() |
Groans: 278
| Not Ranked : 0 score that weld looks like poop
![]() | | #199 | ![]() |
Groans: 266
| Not Ranked : 0 score Hes old, his hand shakes a little lol. no leaks, no one will see it.
![]() | | #200 | ![]() |
Groans: 278
| Not Ranked : 0 score well on that note...that weld looks like that bee nees
| Definitive Exhaust Thread | myslow1 | 2010 MS3 - Engine, Transmission & Driveline | 1040 | 02-02-2018 09:12 PM |
| MS6 Exhaust Thread | RhoadBlock | MazdaSpeed 6 - Engine, Transmission & Driveline | 86 | 04-05-2017 05:42 PM |
| My exhaust manifold thread!! | spiker98 | MazdaSpeed 3 - Engine, Transmission & Driveline | 56 | 09-11-2009 08:28 PM |
