![]() | | #41 | ![]() |
![]() Join Date: May 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
| Not Ranked : 0 score |
![]() | | #42 | ![]() |
| Not Ranked : 0 score I cant get the 2nd or 4th torx screw off. If I pull on the fuel rail I know they will come off the injectors but is that bad. Is there a clip holding the injector on the rail or is this ok. |
![]() | | #43 | ![]() |
![]() Join Date: Sep 2008 Location: Soledad, CA
Rep Power: 446 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 393
Groaned at 5 Times in 2 Posts
| Not Ranked : 0 score SPD6TUNER, I am also replacing my injector seals right now, you need at T41 (not a T40) for your torx soquet to take off the little brackets that hold the injectors in place. I twisted two off my T41 torx soquets because they were a cheapy kind but I'm buying a good one tomorrow. |
![]() | | #44 | ![]() |
| Not Ranked : 0 score my bad i meant you need a T40 soquet (which you have), but make sure to get a good solid one. |
![]() | | #45 | ![]() |
![]() | | #46 | ![]() |
| Not Ranked : 0 score I'm having trouble removing mine as well, I'll let you know what works for me today! |
![]() | | #47 | ![]() |
| Not Ranked : 0 score I think I am just going to cut a slot into mine and remove them with a flathead screwdriver cause mine are already stripped so I have no other choice. Then I will go to mazda and pick up new ones. |
![]() | | #48 | ![]() |
| Not Ranked : 0 score I just the impact gun today with the T40 and all the brackets came out. Sorry to hear yours stripped man. |
![]() | | #49 | ![]() |
![]() Join Date: Dec 2009 Location: Middle Earth
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| Not Ranked : 0 score Snap-On?
__________________ 09 Speed 3 GT |
![]() | | #50 | ![]() |
![]() Join Date: Jan 2009 Location: DC
Rep Power: 228 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 408
| Not Ranked : 0 score Is there a specific orientation for the throttle body gasket? |
![]() | | #51 | ![]() |
![]() Join Date: Jan 2011 Location: San Francisco, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 76
| Not Ranked : 0 score Another great thread gone to shit because people think that Photobucket is good for some reason. Jesus tapdancing fucking christ people, STOP USING PHOTOBUCKET.
__________________ 2007 Velocity Red Mazdaspeed 6 | SURE Dreadnought Rear Diff Mount | CP-E WishBone Motor Mount | AutoMeter 5777 Boost Gauge | Cobb SRI | RPM Sport Springs | JBR Stage 1 SSP | JBR Heavy Shift Knob | Type-M V2 18x8 rims | Hankook V12 235/40/18 tires | Hypertech Tune | Dashhawk V2 |
![]() | | #52 | ![]() |
![]() Join Date: Sep 2008 Location: Phoenix, AZ
Rep Power: 1352 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 813
![]() How To CPE Injector Seals + Studs + EGR Delete
__________________ Some things. | |
![]() | | #53 | ![]() |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
| Not Ranked : 0 score Subbed so I can see the pics at home.
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress |
![]() | | #54 | ![]() |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
| Not Ranked : 0 score you aren't going to see shit b/c the pics are all removed. to get to the seals, follow the various "how to" threads. like this one: How-To: Injector & Intake Manifold Removal How To CPE Injector Seals + Studs + EGR Delete you could also follow JBR's guide to do the TIG. this will get you 90% of the way there. http://jamesbaroneracing.com/support...structions.pdf and if you're doing the injector seals, you might as well clean the valves as well. i want you to feel like you contributed, though, so i won't link all the how tos for that.
__________________ it's fun to do bad things |
![]() | | #55 | ![]() |
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
| Discuss Here: Injector Seals Replaced
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
| Display Modes | |
| injector seals help | mczimer | Mazdaspeed3/6 General Discussion | 16 | 07-27-2012 10:21 AM |
| Injector Seals Replaced | aaronc7 | MazdaSpeed 3 - Engine, Transmission & Driveline | 53 | 06-18-2012 12:52 PM |
| CP-e Injector Seals | ak_spray | Revolution Performance Motorsports | 11 | 01-25-2012 10:20 PM |
