 Old 07-25-2011, 08:30 AM   #1
Originally Posted by Culls17 View Post
Ok so mazda is rejecting any claims on the engine failure... 45K complete engine failure...are there any good attornys invlved now? Like a class action...how have you guys got this covered by mazda?
In most cases it's out of pocket - especially if the vehicle has been modified. Look for a used engine.
Lex is offline
 Old 07-25-2011, 08:58 PM   #2
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
First post and it's about a blown engine. THAT sucks.
"Exclusivity" - CP-enis
Demodded.
The Seals
Tokay444 is offline
 Old 07-26-2011, 01:21 AM   #3
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
Too late now, but anyone who blows up should read "Get Your Blown Motor Replaced Under Warranty!!!" BEFORE you go to the dealer, and BEFORE you post a fucking thing in the public section of a forum that has more private venues........
Good Luck.
Suspension:
FreeFlyFreak is offline
 Old 09-07-2011, 04:45 PM   #4
RED DEMON's Avatar
Posts: 26   (View Stats)
RED DEMON is a glorious beacon of lightRED DEMON is a glorious beacon of lightRED DEMON is a glorious beacon of lightRED DEMON is a glorious beacon of lightRED DEMON is a glorious beacon of lightRED DEMON is a glorious beacon of light
Default Vibrating Clutch Pedal = Bend Rod?
hi i just came across this thread, last week i took my speed 3 to the dealer coz there's a vibration coming from the clutch pedal, they said it was a bad pressure plate so they replaced that under the 60K power train warranty. however, i pick up my car today the clutch paddle still vibrate when i lightly rest my foot on it... and there's a continuous (*thum noise) coming for the block....could it be like what you guys been talking about (bend rod? or the engine is on its way out?)
my car is bone stock with only MS CAI and 51K on it... if its really the bended rod, will it still be cover by the 60k warranty??? should i take it to another mazda dealer to them take a look?? or go back to the one that worked on my car??/
i'm desperate as hell right now....
RED DEMON is offline
 Old 09-08-2011, 07:17 PM   #5
The Kamikaze King!
Groans: 754
Keep taking it ack to the same place for the same problem ASAP.
Then when (not if) it blows you have a record of
a) a reported problem
b) you tried to get it fixed.
Take it in ASAP
and as often as possible until either
a) it is fixed
or
b) it blows up
Suspension:
 Old 09-12-2008, 09:31 AM   #6
chrakaknox's Avatar
Posts: 12   (View Stats)
chrakaknox is an unknown quantity at this point
I actually just put my car for sale on cars.com because of all of this bullshit. I can't have my '07 with 5,000 miles blow a motor and because of a few mods be spanked with a $7k bill for non warranty motor work - it's my DD. Mazda FTL
chrakaknox is offline
 Old 09-12-2008, 09:32 PM   #7
JimmyMac's Avatar
Posts: 558   (View Stats)
JimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the world
Gotta be willing to pay if you want to play. My 07 that I got back in December of 06 has been modded since January of 07. And the first mod was the XEDE which gave it huge gains (in the seat of my pants). Now I'm running a GT2871R at 20psi and no problems (so far).
2012 MX-5 SE
JimmyMac is offline
 Old 09-13-2008, 12:46 AM   #8
Did you keep the Xede or change? If so how come you changed? I like the unit and would like to know if there are any downsides.
Lex is offline
 Old 09-13-2008, 11:08 PM   #9
JimmyMac's Avatar
Actually, I wished I kept it. But I sold it. I'm running the Standback right now. The Standback does more in terms of tuning. And controlling boost is alot easier by setting each psi setting for given rpm vs (whatever setting) you want. But using the software is alittle more tricky than using the XEDE software. From the get go, the XEDE came with a powerful tune. But changing the boost setting was a little more intimidating because you didn't set the boost with boost targets, you set it by guessing on the wastegate duty cycles. So it was a hit or miss thing. That was my only real gripe tuning with the XEDE. I sold it to try something different. I wanted to get a feel for what other options other products provided. I may sell the SB if/when Cobb offers the tuner software for the AP (if they haven't already, I don't read their forums any.) I'll try that out and go from there. I'm not loyal to any one brand. I just want what's best for me and how I do things. So it'll cost me $$ till I find one that suits me. Even if it means going back and purchasing something I've had in the past.
But going back to the XEDE, you basically just tune 4 maps. 1.MAF. 2. MAP. 3.Timing. 4.Boost Solenoid. If you don't mind playing with duty cycles instead of boost pressures, then it should be no problem for you. Also, you have to hardwire the unit in. I would stay away from the connectors that come with the XEDE and direct solder everything. Unless of course if you bought the PG PnP wiring harness. Then you just solder into that. You would also need a cheap serial to usb adapter to tune it. But that's only like $7.
Hope that helps. You could try some of the Aussie forums that are out there. They love the thing and could answer your questions better.
2012 MX-5 SE
JimmyMac is offline
 Old 09-17-2008, 10:22 PM   #10
JimmyMac's Avatar
I added Oil to the list. So if you remember what oil you were running when it blew, please post up.
2012 MX-5 SE
JimmyMac is offline
 Old 10-10-2008, 07:03 PM   #11
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
when i first fucked my car up, i took it to a shop called turbo performance inc in van nuys, ca. they had another ms3 they were working on.
they made an fmic, 3" tbe, and a turbosmart mbc.
i went there to pick up something for my car and this is what i see...
phillyb is offline
 Old 10-10-2008, 07:08 PM   #12
JimmyMac's Avatar
Good pics. Any info on how it happened?
2012 MX-5 SE
JimmyMac is offline
 Old 10-10-2008, 07:14 PM   #13
phillyb's Avatar
Groans: 1,940
piston, rods, idk really what that is...but that's what they muttered. i don't know if there's a gauge in the car, and i don't know the boost, but i'm assuming it's a lot. i would hope it's not WAY TOO MUCH.
i would like to contact him, but don't necessarily want to take business away from the shop. hahah
phillyb is offline
 Old 11-11-2008, 06:55 PM   #14
JimmyMac's Avatar
I added myself and IDRVSLO to the list.
2012 MX-5 SE
JimmyMac is offline
 Old 11-12-2008, 09:29 AM   #15
JimmyMac's Avatar
My problem might of occurred about a week or two ago. I had a spike of 30.8psi for some odd reason. Never done that before. So this might of been the catalyst of my ticking. I can only speculate. But anyways, I have my own thread for my troubles. I'll know more as I pull the engine apart.
2012 MX-5 SE
JimmyMac is offline
 Old 11-13-2008, 01:08 PM   #16
ASIC_BSEE's Avatar
Posts: 164   (View Stats)
ASIC_BSEE has a reputation beyond reputeASIC_BSEE has a reputation beyond reputeASIC_BSEE has a reputation beyond reputeASIC_BSEE has a reputation beyond reputeASIC_BSEE has a reputation beyond reputeASIC_BSEE has a reputation beyond reputeASIC_BSEE has a reputation beyond reputeASIC_BSEE has a reputation beyond reputeASIC_BSEE has a reputation beyond reputeASIC_BSEE has a reputation beyond reputeASIC_BSEE has a reputation beyond repute
Groaned at 9 Times in 3 Posts
So with woosh, darksun, laloosh all running fine with tons of power and lead feet, is the key to drive the car hard ? Just kidding, but think about it, those that have blown have been easing into the throttle, maybe hitting the throttle hard forces the ECU to ramp up the fpr faster, injector duty cycle faster, and get into richer territory faster. It seems a little strange that these cars aren't blowing at WOT, but are at minimal throttle. Also, I bet most cars that blew had a recently reset ECU or reflash.
It's got to be the closed loop to open loop transition and pre-ignition and/or detonation. On a newly reset ECU, the fuel trims aren't adjusted enough to keep the car rich under boost, even mild boost. As soon as you start pushing the gas pedal its still at stoic, especially if you haven't given the car enough ignition cycles and driving time to get the trims right. Look at the dyno graphs for a car that was just reset, AFR reacts so damn slow, that it doesn't even get to 12.5 til 3500-4500 rpms WAY after full boost has kicked in. Take this and a newly reset ECU and you get pre-ignition one time, you just broke a rod.
Lean AFR, hot engine, can ignite the gas at BDC. Maybe even throw in a burnt valve or improperly seated exhaust valve to supply the ignition source. Hell, maybe even all the carbon build-up on the intake valves is acting as a glow plug.
I really don't think it can be the balance shaft. If anything, the balance shaft connection is creating a hard point at cylinder #3. If it has to go somewhere it will go in the spot with the least give. The balance shaft is creating a torsional force against the crankshaft.
Reference:
Detonation vs. Pre-Ignition - 3000GT/Stealth International Message Center
2007 Cosmic Blue Mazdaspeed 3 GT
Mods: Mazdaspeed Cold Air Intake, Mazdaspeed Cat-Back Exhaust, Defi BF Amber Boost Gauge in Driver's Vent
ASIC_BSEE is offline
 Old 11-15-2008, 04:04 AM   #17
phantom3's Avatar
Posts: 1,223   (View Stats)
Groans: 190
I`d like to see boost PSI at time of break down added to the list.... Just for arguments sake.
phantom3 is offline
 Old 11-15-2008, 11:49 AM   #18
With these weird vibrations people had before blowing up, and then doing so at low load, could it be something in the rotating assembly falling out of place? Anyone considering the balance shaft assembly as a possible culprit ... something "stalling" the crank?
Lex is offline
 Old 11-15-2008, 06:48 PM   #19
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
all i know is that the balance shaft is on the 3rd cyl
Carry on citizens....
10.7 @ 133 auto 1G DSM
Darksun280 is offline
 Old 11-15-2008, 08:11 PM   #20
oskinosmee's Avatar
Posts: 743   (View Stats)
oskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant future
BSR might be a good prevention maybe? If so i needs it lol
Gotta Love The Turbocharged Wagon
oskinosmee is offline
 Old 11-15-2008, 08:43 PM   #21
Fux Wit It
Darksun280's Avatar
Groans: 175
from what I understand incar vibes might be a bit much for most people
 Old 11-15-2008, 09:02 PM   #22
oskinosmee's Avatar
I wouldn't care if the bsr was a slight chance to help the engine stay intact
 Old 11-15-2008, 09:07 PM   #23
Renzokuken's Avatar
Posts: 900   (View Stats)
Renzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the world
<----35k 18-20 PSI since the first month of owning the car TBE/FMIC/I/ still no problems. But I do knock like hell when Im not on the 100 octane.
1990 Totoya Corrolla DX TRD limited edition w/ Back to the future Delorian body kit/ K&N snorkel inlet ram-air intake/ Mazdaspeed T3/T4 turbo-supercharged hybrid 5 PSI and many more mods. 11.92 @120 MPH
Renzokuken is offline
 Old 11-16-2008, 07:56 AM   #24
CMESCOOT's Avatar
Posts: 429   (View Stats)
CMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the world
If i'm not mistaken, All of the big turbo guys on here are using the standback.
And as far as the rpms flying off the charts, that has nothing to do with it. Myself as well as a few others who have popped their motors, did it while at highway speeds at low rpms. I personally was going 75 miles an hour on cruise control on a completely flat road in 6th gear, then BOOM! There was a hole the size of my fist on both sides of cylinder 1, and a chunk of it tore into the coil of my alternator, busted a hole in my radiator, and cut a hose. From what I've read, there is a problem with resonance in the motor at low, constant rpm's that is making the rods snap.
Someone correct me if I'm wrong.
http://active.com/donate/1soldier
Making the world a safer place one Taliban at a time.
Arias 8.8:1 Pistons - Pauter rods - Balance Shaft Delete - ARP Head Studs - Street Unit Rear Motor Mount - TurboXS Hybrid BOV - TurboXS Downpipe - - TurboXS FMIC - CP-E CAI - Custom Built/ported and polished Turbo and Wastegate - CP-E Engine Management - Upgraded high pressure fuel pump - PG Turbo Exhaust manifold - PG Dash mount gauge pod - Cooling Mist Progressive Methanol Injection - Apexi TT - VEI gauges (oil pressure, boost ) - Dashhawk -LaminX Fog lights - H&R Sport Springs - Cobb Rear Sway Bar - Tenzo DC-s wrapped in Nitto InVo's - TWM short throw shifter and bushings
CMESCOOT is offline
 Old 11-17-2008, 02:30 PM   #25
ASIC_BSEE's Avatar
Vibes in the clutch pedal are from an offset balance on the crank shaft caused by a bent rod. Rod being slightly shorter offsets the balance of the crank. Eventually the rod will break.
Bent rods are from Pre-ignition close to BDC when engine is hot, AFR is lean and boost is rolling on.
 Old 11-20-2008, 04:37 AM   #26
JimmyMac's Avatar
Updated, more info to come soon.
2012 MX-5 SE
JimmyMac is offline
 Old 11-20-2008, 04:48 AM   #27
ASIC_BSEE's Avatar
So, I was at Milam Mazda in puyallup, WA yesterday and asked why the Black MS3 with a front mount IC was there. The service manager said it had a hole in the block. I know the guy is military and deployed and his friend had it towed there for him. He also said it happened while driving under a bridge; just oil light came on and car stopped. Anyone know who this guy is? Like to get him added to the list.
 Old 11-20-2008, 05:16 AM   #28
Fux Wit It
Darksun280's Avatar
Groans: 175
Christ imagine how many blown motors there are out there that arent reported ont he forum......
 Old 11-20-2008, 10:57 AM   #29
mouse0330's Avatar
Posts: 1,104   (View Stats)
mouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the world
wow, can't believe that many motor is blown, just want to know the people that had their engine blown are telling the truth about their mod. Lets not forget that our engine is still consider new technology. This is not like the r32 engine that you can mod all you want and get outrageous hp. We are still test rats in this market for our 2.3 disi turbo engine. Haven't heard of any regular 2.3 non turbo engine blowing up yet. Have anybody? There are heavily tune engine out there with no problem. Mine isn't even modded that much, and I drive like crazy, hit a huge dip on the road without know it was there, that was how fast I was going, even hit curb hard during purring rain, replace 2 bad wheels, one was bent. I still drive it hard, almost everyday, I hit into 3 digits when there is no car car around
mouse0330 is offline
 Old 12-07-2008, 06:17 AM   #30
ptperformance's Avatar
Posts: 4,123   (View Stats)
I know this guy and have talked to him a few times. He was running 25 + psi on the stock fuel pump with full bolt on's. I forget his name but I did tell him to take it to the dealer, hope they cover it for him.
ptperformance is offline
 Old 12-07-2008, 08:06 AM   #31
Fux Wit It
Darksun280's Avatar
Groans: 175
And that guy though his was was running good? I guess now he knows he wasn't.
 Old 11-20-2008, 12:43 PM   #32
JimmyMac's Avatar
The anonymous one is an over seas MS3. Meaning, not North American. I'll update later tonight when I get home from work.
2012 MX-5 SE
JimmyMac is offline
 Old 11-20-2008, 02:14 PM   #33
bf360's Avatar
Posts: 2,069   (View Stats)
funny i go to get my car towed to a shop from where it was at the dealership and i look at a cx7 there working on and the heads on the floor and i was looking at the pistons lol
bf360 is offline
 Old 02-04-2009, 07:11 PM   #34
mlassek's Avatar
Posts: 200   (View Stats)
mlassek is a name known to allmlassek is a name known to allmlassek is a name known to allmlassek is a name known to allmlassek is a name known to allmlassek is a name known to all
add me to the list of shame.
bent #3 rod while shifting into 3rd at 3-4k rpms mid boost.
mods are listed in sig but with pg intake rather than the txs listed.
only seen mobil 1 oil until i put royal purple in last week (5-30)
bent rod
mlassek is offline
 Old 12-07-2008, 09:47 AM   #35
boosted3's Avatar
Posts: 855   (View Stats)
boosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the world
yea im going meth also seems liek people wiht meth havent blown there motor at all.a good tune wiht the meth at lower boost levels should give us the upper hand on the popped motors.Darksun big turbo most likely goign on after the holidays
boosted3 is offline
 Old 12-07-2008, 09:50 AM   #36
Fux Wit It
Darksun280's Avatar
Groans: 175
Good I was starting to feel lonely with Chris leaveing
 Old 01-20-2009, 10:49 AM   #37
mouse0330's Avatar
I still don't know about that, there are a lot of ms3 out there and only a few/ very few that run meth. So odds are favorable with meth users but there are tons of ms3 out there that are running fine without a problem/blown engine. Can we find out how many ms3 are sold since 2007, I think we need a consensus going if one haven't done one yet, I know we have one for blown engine.
 Old 12-07-2008, 10:01 AM   #38
oskinosmee's Avatar
I think my motor might be gone. I have Meth and a tune
 Old 12-07-2008, 10:38 AM   #39
badams118's Avatar
Posts: 821   (View Stats)
badams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the world
Groaned at 126 Times in 71 Posts
Fuel pump? What PSI/turbo?
2011 WRX | Cobb AP | Cobb DP | SPT CBE | AEM CAI
Whiteline F/R Sways | SPT SSK | TWM M1 Abrams
badams118 is offline
 Old 12-07-2008, 04:14 PM   #40
oskinosmee's Avatar
Im not blown yet i think Darksun is right about the injectors.
but yes i have looshs fuel pump, 20 psi stock turbo. Snow meth kit
MazdaSpeed 2.3L DISI Turbo Blown Engine Resource Thread JimmyMac MazdaSpeed 3 - Engine, Transmission & Driveline 1441 06-25-2019 06:11 PM
Mazdaspeed 2.3L DISI Turbo Blown Engine Resource Thread Kennosuke MazdaSpeed 6 - Engine, Transmission & Driveline 1 04-27-2009 01:26 AM
Page generated in 1.04371 seconds with 39 queries
