![]() Join Date: May 2008 Location: Goldsboro, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20
(Thread Starter) | Not Ranked : 0 score Hello! We are starting a Resource thread for blown engines on both Mazdaspeed 3 and Mazdaspeed 6 2.3L DISI Turbo engines. This is to help gather info so we can try and get down to what is really happening to these engines. Maybe we can find some consistencies and inconsistencies. Things posted will be Mods on the car (piggy back, big turbo, fmic, cai, etc, etc). What cylinder rod (or other damage) blew out. Situation when it happened (miss~shift, low rpm boost creep going up hill in 4th gear, etc, etc). Car build/year. Stuff like that. So if you have any info. Or if you know of anyone that has blown an engine, please post up here and let me know. If you want to remain anonymous, please PM me. I can respect that and will post you up as John Doe 1, John Doe 2, etc. We can even post up pics too. Pics are always cool to look at.. hehe. Any and all advice is welcome. Give me time to get all this setup. And feel free to help out. Thanks in advance.... ~JimmyMac |
(Thread Starter) | Not Ranked : 0 score Currently updating! If you have info on which Rod # goes with what cylinder, please let me know. I'm listing cylinder 1 as passenger side. through cylinder 4 as drivers side. If you have any other idea's on what else to add, let me know. Thanks.
| Banned ![]() Join Date: Mar 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 761
| Not Ranked : 0 score gt3071r turbo @ 18 psi, ms cai, inlet, fmic, turbo mani, bpv, cdfp, catted tbe, semi tuned standback. engine blew with 29,000 total miles and 4500 on the current setup. car blew partial throttle into boost, third gear around 4000-4500 rpms, going up a hill. block cracked up front, hole apperars for now at cylinder 2(4). |
![]() Join Date: Mar 2008 Location: Nashville
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 381
| Not Ranked : 0 score Well, allow me to start it off with my 07 MS3. Was running FMIC, CAI, CDFP, PG manifold, Downpipe and race pipe, 3" straight exhaust, Hybrid BOV, Reworked stock turbo, and a really sweet smelling air freshner. #2 cylinder popped out the bottom front passenger side while in 6th gear cruising at 75 on a flat highway. Was 110 miles into a 112 mile road trip to our lake house when she popped. Thank god for great friends to help me get the car back home for free!
__________________ http://active.com/donate/1soldier Making the world a safer place one Taliban at a time. ![]() Arias 8.8:1 Pistons - Pauter rods - Balance Shaft Delete - ARP Head Studs - Street Unit Rear Motor Mount - TurboXS Hybrid BOV - TurboXS Downpipe - - TurboXS FMIC - CP-E CAI - Custom Built/ported and polished Turbo and Wastegate - CP-E Engine Management - Upgraded high pressure fuel pump - PG Turbo Exhaust manifold - PG Dash mount gauge pod - Cooling Mist Progressive Methanol Injection - Apexi TT - VEI gauges (oil pressure, boost ) - Dashhawk -LaminX Fog lights - H&R Sport Springs - Cobb Rear Sway Bar - Tenzo DC-s wrapped in Nitto InVo's - TWM short throw shifter and bushings |
![]() Join Date: May 2008 Location: Albuquerque NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score I hydrolocked my 07' MS3 in July of last year, I had an MS CAI on. Does that count. |
| Not Ranked : 0 score |
| Not Ranked : 0 score I was stuck between a rock and a hard place, on a two way street and in a down pour of rain. I was going about 25 mph and through about 12" deep gully. I had cars behind me and on the other side I had no choice but to risk it. I did the initial inspection, water in the intercooler and the cylinders mostly in 2 and 4 I think and a little in 1 and 3. I suck out the water and tried to start it nothing. I ended up at the dealer to find out I broke the crank and it imbeded its self into the block causing it to crack. |
![]() Join Date: Mar 2008 Location: glen burnie md
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score ill be number one!!!! sweet it was the one all the way to the right(passenger side) holes in both sides and a cracked oil pan! stock with a ms intake |
![]() Join Date: Mar 2008 Location: abc
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,081
Groans: 147
Groaned at 34 Times in 29 Posts
| Not Ranked : 0 score My dads had a bad 3rd injector. Went lean and spun a bearing, snapped rod, snapped wrist-pin, bent 1 valve and still had a great idle. He was bone stock. |
| I guess jimmy isnt going to update his thread? Im tired of making these things! Im not doing it!
| Not Ranked : 0 score 2007 mazdaspeed 3, 14kmiles mods include: atp 3071r bolt on turbo, mrlilguyCDFP, custom inlet and intake, txs downpipe/racepipe/hybrid bov, no ems. boost level set at 15psi. downshift to 2nd and 8000rpms = boom.
__________________ Black Mica '07 Mazdaspeed3 Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing Reppin' ProtegeGarage for life! |
(Thread Starter) | Not Ranked : 0 score Haha, I told you to give me a few days!! I'm in the middle of a Turbo, FMIC, Catback, etc, etc install!! That and work schedule too! Man I tell ya... engine coolant doesn't taste too good!! But give me some time, I'll Get Er Done! |
| Good man!
(Thread Starter) | Not Ranked : 0 score Just letting yall know I'm still here and haven't forgotten this. Installed my CPe fmic without taking off my bumper today! Went to the dealer yesterday to do 3 recalls I never went in to do. Gotta go back tomorrow and get my engine mount bolt replaced. But I still have more work to do to the car..... Anyways, I'll start laying out the failures this weekend. I'm off of work. And we'll get this going soon. I'll start researching other mazda forums. If anyone has any info of other failures on the web, please link me up to the website. Thanks.... |
(Thread Starter) | Not Ranked : 0 score Okay, it's been updated. If there is something you wish to see let me know. If you have links to other blown MS3/6 engines, post them up or PM them to me. This is a work in progress. Thanks. |
| Not Ranked : 0 score hey guys, I got a call late last night from my shop. He has sourced a mazdaspeed3 engine with less than 5K on it for a kick ass price,...right at 2K!!! Unfortunately, I have already purchased my new one or I would have snatched it up. Hell, if it had some extra cash, Id snatch it up for a spare. His name is Thomas and owns a shop called, Modified Imports. 931-645-9007 Give him a shout and grab this quick!
![]() Join Date: Mar 2008 Location: Baltimore
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26
| Not Ranked : 0 score 2007 mazdaspeed 3, 41,218 miles. Mods: MS CAI, corksport TP, rear motor mount(awr). Turbo was going bad waited to long to take it in. Was leaving work going about 5 to 10mph. Jumped timing. Cylinder 3's piston is scrap, nicked 2's a lil bit. No holes in the block but still f***ed Mazda didn't cover any of it. Been 3 months still no car for me. |
![]() Join Date: Mar 2008 Location: Orange County Ca.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,353
| Not Ranked : 0 score mine blew during miss 3500 rpm 5 gear, holes on both sides of the block#4 piston at the time i was running stock boost,cpu ect only performance mods, magna flow eghaust, ms cai, hks bov were on at the time had 20,000 miles and the car is early build ms6.the warrenty was already gone 6 months prior do to to many mods mazda branded car w1. |
![]() Join Date: Mar 2008 Location: sc
| Not Ranked : 0 score BLEW MINE fmic, tbe, pg manifold, mrlilguy cdfp,sri, cpe standback kinda tuned, 19 psi, reworked turbo, 13k on motor, and what warranty? sliped a bearing a put a couple really big holes in my block cyclinder 4 and 3 I was slowly acclerating at 5 mph on my way to my garage, and kaboom
__________________ I hate my mazdaspeed3 more than anything else in this world! |
| Not Ranked : 0 score Thats oil all over the fire wall, its a shame too!! brand new syn oil
(Thread Starter) | Not Ranked : 0 score Damn, that sucks. Makes me scared to punch mine now!! Maybe I'll just keep my boost low..... haha right... Thanks for the info guys. I'll update the page tomorrow when I get home from work.
__________________ 2012 MX-5 SE |
| Not Ranked : 0 score My main question is what is the main problem. My case is simple but, forthose of you guys simply doing 60mph at low rpms and then *BOOM!* its gotte be something. For the guys who are modded a buddy of mine work on at Shop and has a pretty good background with mazdas(and performance imports period.) What he says, and you guys tell me if this is something you agree with or not, is that tuning is the key. Or stock ECU's can adapt to Intake and Exhaust(they must when mazda sells them anyway) but when you go anyfurther than that(FMIC, TB Exhaust, bigger turbo, up the boost, etc you need to re-tune. It's too drastic of a change for it.ts just one possibility of what could be going wrong with the modded cars. I dont know about stock cars its gotta be something that we're just mising. I'm only going off what I am told and he should know. If anybody feels like arguing I don't have the got time for it. I'm Just trowing it out there hoping it sparks ideas of why. |
| Not Ranked : 0 score hey mines a 2007, and yes tuning is important. but at the same time if your a/f are good and safe, why bother. especially for those waiting on a fuel pump!! tuning these cars with out a pump is useless, i tried months ago to get my car tuned. The tuner said he would not even attempt untill he could add fuel when he wanted.
![]() | | #24 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
| Not Ranked : 0 score I would like to know what manifold and what RPM the motors let go at. It looks like my speculation on the cyl 1 and 2 have been confirmed by the motors that have blown. I have another idea on the RPM, I think there is a bad resonant spot in our motors that seems to be an issue with guys loosing there motors are low RPM non boosted applications. If you could add these to the list it might help narrow down the problem. Thanks. |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score Gotcha....
![]() | | #26 | ![]() |
| Not Ranked : 0 score Thank you. The non boost applications are landing in the area that the bad spot is. 3k to 3.4k is where we are seeing issues. I have to borrow some testing equipment but if I fiind anything that jumps out at me I will post it up. |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score I've been kind of slack on researching the other boards for more blown motors. I'm sure there's plenty more out there. But I should be on it soon once a few things are finished around here. Good to see you are looking into this issue. Thanks. I'm kinda scared to turn the boost up on my GT28. So far I'm just keeping it from boost cut. But I think this weekend I'm gonna install my map clamp and let her rip.... Not R.I.P. I hope haha. But I take my normal precaustions when driving. Stay out of low rpm boost. And only get on it at 4000rpms. We got 6 gears, so why not use them to their efficiency. No need for power through the whole rpm band. I also prefer to shift around 4000 rpms or more under normal driving. I dunno if that'll help any. But let's see what you come up with.
![]() | | #28 | ![]() |
| Not Ranked : 0 score DAMN! how bout this....I purchased a speed3 motor the tuesday after memorial day and the guy just called me this week and said that when they pulled it from the original car that they found a damn crack in the block!!!! He's refunding me, but NOW i have to find another block somewhere! UGGGGGGGGGGGGg
![]() | | #29 | ![]() |
![]() Join Date: Jul 2008 Location: Saint Louis, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 98
| Not Ranked : 0 score Hate to dig up something without any action in a while, but has there been any other blown engines lately? I'm kind of curious because i have pretty much the same mods as a couple of guys up there and i guess that i am more than a little concerned about this problem... Thanks... |
![]() | | #30 | ![]() |
![]() Join Date: Apr 2008 Location: Arid Zona
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score This whole deal has me scratching my head esp. with guys breaking rods under normal use conditions. I wonder if there's some fatigue mechanism at work where the rods get stressed, cracks form, and the cracks grow even under normal loads until suddenly poof! Any engineer types want to weigh in on the fracture mechanics of connecting rods?
__________________ All your boost are belong to us. |
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score There has been a Speed6 that has blown with a GT35 turbo (I believe) recently. And there are many more that I haven't listed yet or found (a lot of hearsay). Finding time to research and post info up is hard for me right now. I think there are many factors in why these motors are blowing. Or I should say, each case is a different story. I'm currently running a GT2871R at 20psi and no issues (watch, I'll blow my motor tomorrow for saying this haha). But then again, I just started running at 20psi a few weeks ago. So only time will tell in my case. Anyways, so far it seems that the majority of blown engines is from the rods. But why??? We can only speculate. If anyone has any info on this, please post up. If you know someone who has blown a motor, let me know so I can post it. Thanks....
![]() | | #32 | ![]() |
![]() Join Date: Feb 2010 Location: Killeen TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
| Not Ranked : 0 score I used to drive my MS3 like a rent-a-car ![]() , and I have never had an issue with it. I already spent a lot of money on parts including a gt3076r, and I am waiting for the fuel pump to arrive, so I can start putting stuff on and tuning. I am really worried about blowing my engine up, and I am wandering if the problem that every body that blown his engine had good lubrication. Did they change the oil when they were supposed to? Were they monitoring oil pressure? Was the engine receiving enough fuel? Every body is talking about what happened, but no one have given those details yet. When I say monitoring I am not talking about a dash-hawk. Did anybody have gauges to monitor that? Did they look at them, or they just had them because they look cool on the dash? ![]() To be honest I have a lot of things to install, and all I have is a boost gauge for right now. I am wandering if a good stand-back tune would prevent me from having that issue. |
![]() | | #33 | ![]() |
| Not Ranked : 0 score well, i think that when i get back to st. louis i am just going to have to get new pistons and rods... thanks for the excuse! |
![]() | | #34 | ![]() |
![]() Join Date: Aug 2008
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score could it be becuase some people dont let there engine sit for 30 sec or so to cool down the turbo and the oil burns and turn into slush? then when the car trys to pass the thick burnt oil it brakes the rod. i read a lot of people saying that they had no oil when they checked after blown engine. cuz oil can not just vanish from your car. |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score I've also read that when people blow their engine, they leave behind a trail of oil because they have holes in their block......
![]() | | #36 | ![]() |
![]() | | #37 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
There is a local speed3 that has seen a lot of testing and dyno tuning with the AP and has yet to have an issue. Cobb's car has been pounded on and has yet to blow a motor. I think a proper reflash is key. Some may get away with a piggyback, but a reflash is the way to go, IMO. It would be nice to know if the blown motors had the TSB issued for their car and whether or not it was performed, whether it be the reflash, pump, or both. Discouraging to read, nonetheless.
__________________ Corksport downpipe, race pipe, and motor mount inserts. Cobb AP tuned by Surgeline, SRI, STS. TWM shifter bushings. Forge BPV. WOT box w/ 2 step. CP-E FMIC. CDFPI. H&R coilovers. SPC camber links. -Long gone, sold to some punk bitch 1991 Galant VR4 - Garrett FP HTA3076R @ 557awhp on ethanol. Full weight and daily driven at 440awhp on 92. | |
![]() | | #38 | ![]() |
![]() Join Date: May 2008 Location: nyc
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 102
| Not Ranked : 0 score i know i'm late to the thread.. but i blew my motor back in oct. of 07 with 11k miles and just an MSCAI... dealer stated that because it was hydrolock my insurance will have to cover it... even tho i brought the car with the CAI, i felt it should have been covered under warranty... statefarm did... with no charge.. the has car has got 21k miles on it now about 10k on the new block, and some mods and an AP later, after reading this thread i'm very concerned to why our bottom ends keep giving way so frequently....??? scary !
__________________ first MS3 dynoed@1320performance in jersey (rockon) cobb ap stage 2+ maps-mscai-h&r race springs-katz hidkit-forge bpv(blue/2shims)-turbo xs dp/tp-autometer c/f boost guage-235/40/18 falken azenis-ngk colder step plugs-just getting started... |
![]() | | #39 | ![]() |
![]() Join Date: Jun 2008 Location: Sarasota FL
| Not Ranked : 0 score On most cars rod bearings die before the rods themselves. I don't hear of anyone that has actually lost bearings, only rods. Any thoughts ? Harry
__________________ Z32 Specialist 07 Sport Cobb AP - V103f map Cobb Sri ETS 3.25 TMIC Vibrant Catted midpipeback exhaust Forge BPV CS inserts Dashhawk logger Soon to follow SSR Wheels and wider tires CS downpipe Check out http://ztuner.com/newdyno.htm |
![]() | | #40 | ![]() |
![]() Join Date: Mar 2008 Location: Miami, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 61
| Not Ranked : 0 score I'm not sure it's a good idea for people to be posting about hydro lock. That will kill any engine. That deserves it's own thread imo. TENCms3, when you say your turbo was going bad, did you hear it or was it because of smoke?
__________________ Cobb SRI // Cobb Shifter Weight // TWM Bushings // TWM STS // TWM type R weighted shift knob // Medieval Rear Mount // Darkstar Passenger Mount |
| Display Modes | |
| MazdaSpeed 2.3L DISI Turbo Blown Engine Resource Thread | JimmyMac | MazdaSpeed 3 - Engine, Transmission & Driveline | 1441 | 06-25-2019 06:11 PM |
| Mazdaspeed 2.3L DISI Turbo Blown Engine Resource Thread | Kennosuke | MazdaSpeed 6 - Engine, Transmission & Driveline | 1 | 04-27-2009 01:26 AM |
