![]() Join Date: May 2008 Location: Brandon, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 667
Groaned at 7 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score *****Thank you to @Inquisitive; for a 2015 update!****** This thread will be for discussion of motor mounts for the MS3 & MS6. All currently available mounts are listed, relative prices, & links where they can be purchased. Note: you may be able to find them for sale elsewhere, possibly for cheaper. I simply linked them to their own company's site. If you have any questions regarding mounts, want to know which duro is best for you, etc, read thru this thread first! IF and ONLY IF it has not been answered already in this thread, post your new question in this thread. Do NOT create a new one. Most of these if you buy brand new will come with installation instructions, but if you buy used and can't figure it out, or simply want to plan ahead, How-To's may be found in here: MS3 How-To Database MS6 How-To Database One of the first mods almost everybody does is the Rear Motor Mount (RMM). As well you should. The factory bushings are mediocre and allow too much movement. There is a small amount of drivetrain slop and shifting may feel a bit notchy. Upgrading the RMM stiffens up the drivetrain slop quite a bit allowing for smoother shifting for one. The Passenger Side Motor Mount (PMM) & Transmission Mount (TM) are mediocre and are big eye sores to boot. Upgrading the mounts allows for much better shifting response and handling as the engine isn't rocking or being tossed around in the bay, but it comes at the expense of some NVH. Vibrations are felt at idle, tho this can be remedied by raising idle RPM if you have an AP. Vibrations often lessen after several months/several hundred miles of breaking in. Genpu MMs: • JBR RMM 88 & unknown durometer • CP-E RMM Stage 2 • JBR TMM unknown • CorkSport RMM • JBR PMM unknown • JBR RMM 80 • Sure RMM TorqR3 WARNING: read http://www.mazdaspeedforum.org/forum/foru...3/#post1927730 • JBR PMM 80 • JBR RMM 70 • Cobb RMM • CorkSport TMM • Damond Motorsports RMM • JBR PMM 70 & 88 • CP-E TMM • TRZ RMM • CorkSport PMM • Street Unit RMM WARNING: read http://www.mazdaspeedforum.org/forum/foru...3/#post1927730 • Ford Electric Focus RMM (RMM part number CM5Z-6068-A; bolt W500545S900) • Minerva PMM & TMM (probably best to avoid, see Minerva Motorwerkz? ) • Sure PMM & TMM WARNING: read http://www.mazdaspeedforum.org/forum/foru...3/#post1927730 • AWR RMM 88 • Torque Solution RMM • Turbine Tech Front Engine Mount • Turbine Tech Differential Mount Update using 2015 prices: JBR RMM Urethane MS6 MS3 Available from: MS6 JBR RMM Urethane MS6 MS3 JBR RMM Urethane MS3 MS6 (Yes: 80a $105), MS3 1st Gen (Yes: 88a $100, 80a $125, 70a $125), MS3 2nd Gen (Yes: 88a $100, 80a $125, 70a $125) CP-E RMM Stage 2 Rubber MS6 MS3 Available from: MS6 CP-E RMM Stage 2 Rubber MS6 MS3 CP-E RMM Stage 2 Rubber MS3 MS6 (Yes: 70a xFlex) $139, MS3 1st Gen (Not found), MS3 2nd Gen (Yes) $198 JBR TMM Urethane MS6 MS3 Available from: MS6 JBR TMM Urethane MS6 MS3 JBR TMM Urethane MS3 MS6 (Yes: 80a, 70a) $175, MS3 1st Gen (Yes: 88a, 80a, 70a) $185, MS3 2nd Gen (Yes: 88a, 80a, 70a) $185 CorkSport RMM Urethane MS6's Insert MS6's Full Replacement MS3's Insert MS3's Full Replacement MS3's Race Available from: MS6 CorkSport RMM Urethane MS6 MS3 CorkSport RMM Urethane MS3 Gen1 CorkSport RMM Urethane MS3 Gen2 MS6 (Yes, Standard 70a) $115.99, MS3 1st Gen (Yes: Insert 70a $39.99, Standard 80a $99.99, Race 80a $125.99), MS3 2nd Gen (Yes: Insert 70a $39.99, Standard 80a $99.99, Race 80a $125.99) JBR PMM Urethane MS6 MS3 Available from: MS6 JBR PMM Urethane MS6 MS3 JBR PMM Urethane MS3 MS6 (Yes: 80a, 70a) $175, MS3 1st Gen (Yes: 80a, 70a) $185, MS3 2nd Gen (Yes: 80a, 70a) $185 Cobb RMM Available from: Cobb RMM MS3 MS6 (Not found), MS3 1st Gen (Yes) $159, MS3 2nd Gen (Yes) $159 CorkSport TMM Insert Polyurethane MS6 MS3 Available from: MS6 CorkSport TMM Insert Polyurethane MS6 MS3 CorkSport TMM Insert Polyurethane MS3 MS6 (Yes) $54.99, MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $39.99 Damond Motorsports RMM Available from: Damond Motorsports RMM MS3 MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $145 in black or gold mount and black or red bushing CP-E TMM Available from: CP-E TMM MS3 MS6 (Not found), MS3 1st Gen (Yes, 75a) $271.30, MS3 2nd Gen (Yes, 75a) $271.30 TRZ RMM Available from: TRZ RMM MS3 MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $100 CorkSport PMM Available from: CorkSport PMM MS3 MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $229.99 Ford Electric Focus RMM (RMM part number CM5Z-6068-A; bolt W500545S900) Available from: local Ford dealership MS6 (Not confirmed), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $43.92 + $1.10 AWR RMM Urethane MS6 MS3 Available from: MS6 AWR RMM Urethane MS6 MS3 AWR RMM Urethane MS3 MS6 (Yes: 95a, 80a, 70a) $82, MS3 1st Gen (Yes: 95a, 80a, 70a) $95, MS3 2nd Gen (Yes: 95a, 80a, 70a) $95 AWR PMM Urethane MS6 MS3 Available from: MS6 AWR PMM Urethane MS6 MS3 AWR PMM Urethane MS3 MS6 (Yes: 95a, 80a, 70a) $172, MS3 1st Gen (Yes: 95a, 80a, 70a) $172, MS3 2nd Gen (Yes: 95a, 80a, 70a) $172 AWR TMM Urethane MS6 MS3 Available from: MS6 AWR TMM Urethane MS6 MS3 AWR TMM Urethane MS3 MS6 (Yes: 95a, 80a, 70a) $140, MS3 1st Gen (Yes: 95a, 80a, 70a) $225, MS3 2nd Gen (Yes: 95a, 80a, 70a) $225 Torque Solution RMM Polyurethane Available from: Torque Solution RMM Polyurethane MS3 MS6 (Not found), MS3 1st Gen (Yes, 75a) $134.99, MS3 2nd Gen (Yes, 75a) $134.99 TRZ TMM Available from: TRZ TMM MS3 MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $100 Damond Motorsports PMM Available from: Damond Motorsports PMM MS3 MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $225 in black or gold mount and black or red bushing Turbine Tech Front Engine Mount MS6 MS3 Gen 1 MS3 Gen 2 Available from: MS6 Turbine Tech Front Engine Mount MS6 MS3 Gen 1 Turbine Tech Front Engine Mount MS3 Gen 1 MS3 Gen 2 Turbine Tech Front Engine Mount MS3 Gen 2 MS6 (Yes) $359, MS3 1st Gen (Yes) $399, MS3 2nd Gen (Yes) $379 Turbine Tech Differential Mount Available from: Turbine Tech Differential Mount MS6 MS6 (Yes) $289, MS3 1st Gen (Not found), MS3 2nd Gen (Not found)
__________________ 2007 MS6 - broked & gone 2006 MS6 - less broked Last edited by Raider; 02-17-2015 at 07:49 AM. Reason: 2015 update |
| The Following User Says Thank You to RhoadBlock For This Useful Post: | joemd (02-10-2018) |
| The Motor Mount Thread | RhoadBlock | MazdaSpeed 3 - Engine, Transmission & Driveline | 341 | 06-30-2018 02:45 PM |
| Motor Mount Inserts vs. Rear Motor Mount Pro's n Con's | Dre | 2010 MS3 - Engine, Transmission & Driveline | 23 | 05-21-2016 08:47 AM |
| Motor mount thread issue | ziwang55 | MazdaSpeed 3 - Engine, Transmission & Driveline | 39 | 04-04-2012 06:29 PM |
