![]() Join Date: Apr 2011 Location: Nahant, MA
| Not Ranked : 0 score Any feedback on J Barone TMM??? |
![]() Join Date: Jun 2011 Location: Bowling Green, KY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 528
| Not Ranked : 0 score get used to gear noise with the JBR TMM, and plastic vibes from the JBR PMM
__________________ 2011 Blue Mica 50% E85 COBB: AP, DP, SRI, TIP, OCC // Blitz Steel Mesh Filter // SURE: RMM, Boost Tubes, Counter Weight, Shift Anchors, AGS Knob // JBR: Tranny Mount, Passenger Mount// PT-P: HPFP, Rail Valve // PCV Vent // Forge BPV V1 // ETS 3.5" TMIC // NGK IXs // EGR Delete // Resonator Delete // FoMoCo Gear Oil // Castrol Syn Power 5w-40 // Koni Yellows // H&R Sport Springs // SPC Camber Arms// Spec: Stage 3+ SR Clutch, 12lb Flywheel 13.2@113mph |
![]() Join Date: Jun 2011 Location: Parkville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 33
| Not Ranked : 0 score Shit, my TRZ dogbone has the plastic vibrating already and after ~8k miles it's still annoying. What duro JBR TMM/PMM did you go with? I'm thinking of doing 70 for the TMM/PMM and replacing the TRZ with the JBR dogbone... |
![]() Join Date: Jan 2012 Location: San Diego, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 124
| Not Ranked : 0 score I spent 1 hour last night and 3 hours today reading about RMM since I've only modified my MS3 with gauges, wheels, and yellow fog lights. For those considering the job - a simple vid showing where and what needs to be unbolted: Here's the best post I could find (IMHO): Rear motor mount And all these conversations were damn useful: CP-E Rear Motor Mount Install Corksport motor mount inserts INSTALLED! Rear motor mount Rear Stock motor mount mod What motor mount should I get? http://www.mazdaspeedforum.org/forum/foru...bushing-51562/ CP-E RMM in stock MM inserts http://www.mazdaspeedforum.org/forum/foru...p-first-21818/ My summary of all that great MSF feedback?
There, I hope I just saved all future MS3 noobs like me 4 hours of their life. It helped me make up my mind... Update from June 2012.... I've got over 1000 miles on the CP-E 75 durometer and the vibes are nothing to think about. I don't notice them much anymore unless I use my AC. Raising idle to 1000 RPM would completely remove them. That said, vibes or no vibes, the mod is amazing. the car scoots and stays planted. I'm now able to spin the tires at will and can now feather the throttle to get the acceleration I want and even when shifting into 3rd (though I have no-season tires on, so take that FWIW). The differential is working more now and acceleration through turns is amazingly improved. I still remain shocked at how cool (and cheap) a mod this is. A MUST DO MOD! 5
__________________ Forget coffee...I get my morning boost in 4th at 5K! 2008 Black Mica MS3 Mazda RX-8 50mm ET 18"x8" Dupli-color Graphite/Clear with 245/40/18 Continental DWS No-season Tires CS SRI | CS TIP | TMIC | HPFP CP-E RMM JBR SSP (30%) | JBR SSB | JBR RSB Koni Yellows on stock springs |
| The Following 2 Users Say Thank You to rednofive For This Useful Post: | Cheapspeed (02-13-2013), Strangel (09-29-2013) |
![]() Join Date: Nov 2011 Location: Corona, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 220
| Not Ranked : 0 score Answer is easier. Just get 88 durameter dogbone. Once it settles after a couple of hundred miles or so, the vibes are barely noticeable. I hardly feel any change when A/C kicks in/out. If there are strong vibes after it settles, that means the bolts need to be re-torqued. My daily commute is 40 miles each way and I would not use the dogbone if the vibes bothered me. And jbr install instructions cover everything you need to know. There are only five bolts involved.
__________________ 2012 mazdaspeed 3, black mica w/ tech package, AFE drop in dry filter, Autotech internals and CS rmm inserts. . |
![]() Join Date: Mar 2011 Location: Kenosha, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,298
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score lol not much love for the TRZ up there; "hundred bux ea. here's a pic." then again I'm biased and love mine. Good thread though and thank you for another "definitive" thread. I think the summary that was provided a few posts up was very useful too (or would be to someone looking to purchase mounts).
__________________ "Also you cannot do anything "like a boss" in a srt4. If you ever get a job where the boss drives a neon, go somewhere else. Apparently that job has no future." - themytb Oh you mean dogs. Yeah I like dogs. I drive a Hyundai. |
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score I am looking at upgrading the RMM on my MS6 come spring. Looking at CP-E and SURE. Can't decide between the CP-E rubber and the SURE urethane. Thoughts? |
![]() Join Date: May 2008 Location: Brandon, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 667
Groaned at 7 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score Torque Solution MS3 RMM added to OP. Be sure to mention me if you feel anything should ever be added to the OP. |
![]() Join Date: Feb 2012 Location: Alexandria, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 862
| Not Ranked : 0 score opinions on Sure vs JBR RMM? besides $135 vs $90. which is "better," more effective, more dependable?
__________________ 1996 Miata SOLD 2006 Black Cherry Mica MS6 Grand Touring #00584CP-E 3" Straight Pipe Exhaust. CP-E TMIC. StreetUnit TP. Street Unit RMM. HTP 3" TIP. Custom 3.5" MAF SRI. PTP HPFP Internals. Cobb AP. RichTuned. Denso ITV22. Forge V1 BPV. Blox Shift Knob. VEI Boost Gauge. 18x8.75 +33 XXR 530. Nitto Motivo 225/40/18. Megan Racing Springs. SOLD: 2009 Mazda 6i GT. 6-Speed MT. [SIGPIC][/SIGPIC] ![]() |
| Not Ranked : 0 score to follow up on this...i ended up going with SU RMM 62 duro i believe. got it for free from the previous owner of my car. vibrations are very very minimal.
| Not Ranked : 0 score both great companies, both great products heck you could choose by color, or by throwing darts, and you couldn't go wrong between those two. You'll be pleased by the improvement regardless of the decision.
![]() Join Date: Mar 2010 Location: New Eagle, PA
Rep Power: 2281 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,142
Groans: 324
| Not Ranked : 0 score JBR has 3 different duro's for the transmission mount now. |
![]() Join Date: Dec 2010 Location: Kettering, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 132
| Not Ranked : 0 score Just finished installing AWR 88 durometer mounts all the way around. Install very easy, no hangups and took around 2 total hours. Increased vibrations at idle a lot, 1K - 2.5K RPM also vibrates a ton in all gears. Hope it smooths out after a few thousand miles. All in all, completely confident know with motor movement. |
Groans: 324
| Not Ranked : 0 score Uh, 70 ft. lbs. on the JBR (it's a SS bolt now so it's about a Grade 5,) and the vibes are negligible. my .02 |
![]() Join Date: Nov 2008 Location: Hutto, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
"Place a flat washer, lock washer and nut on to the supplied stainless bolt. Tighten and torque to 120 foot-pounds using a 19mm socket, socket wrench, torque wrench and closed end wrench."
__________________ 2012 Black Mica with Tech package. Chock full of goodies and Dizzy tuned | |
| Approved MSF Vendor ![]() Join Date: Sep 2009
Rep Power: 7118 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,203
| Not Ranked : 0 score Always has been a stainless bolt, same bolt included with the CP-E or any other billet style mount and as mentioned, not a grade 2 bolt. Whomever the mount was purchased from sold it to you with a crap bolt. Thanks, Jamie |
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score just trying to get any follow up input from those with the SURE RMM (street). has the vibration dissipated at all? or have you gotten used to it? thanks in advance. |
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 7
| Not Ranked : 0 score Great thread. I haven't done anything on my car yet (tint doesn't count IMO), but the engine mount issue is well documented and discussed, so it's something I've thought about frequently. I am fairly (maybe a bit generous) good with easy-ish car repairs and what-not... can anyone tell me (generally speaking) what tools I should have on hand to swap out the engine mounts? Thanks in advance.. |
'merica | |
![]() Join Date: May 2011 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
Groaned at 340 Times in 107 Posts
| Not Ranked : 0 score dSt DIYMMI Do It Yourself Motor Mount Inserts - Liquid Urethane nN control of duromoeter rating though. Still probably better than neoprene. |
| Not Ranked : 0 score That's not for ms3... |
| Not Ranked : 0 score sez universal. replaces the neoprene in any motor mount. |
| Not Ranked : 0 score you can read? |
![]() | | #24 | ![]() |
| Not Ranked : 0 score |
![]() | | #25 | ![]() |
| Not Ranked : 0 score Somebody double-check me here- I thought this stuff was the kind you shoot into the voids of the mount to fill em up and solidify the mount. Works on any mounts with void area. Not personally a fan of the concept, it's just a band-aid fix at best, and for the time/effort involved you get better performing, longer lasting results from a "real" replacement mount.
![]() | | #26 | ![]() |
| Not Ranked : 0 score Yeah, we did that crap in the 3rd Gen Proteges with epoxy. Works for a couple years, then breaks loose. |
![]() | | #27 | ![]() |
| Not Ranked : 0 score I have an unusual amount of "clunk" at low speed driving, especially on less-than-perfect roads, and from what I have read on MSF it sounds like my RMM could be the culprit. I had the dealership give the car a once over right before my 40k warranty was up (several times before as well) and mentioned I thought I heard quite a bit of "clunking", but each time they said all was well. This is my DD and I put a lot of highway miles on it, along with occasional spirited driving, and I just cannot decide of I should go with the CS inserts or something like a 70A JBR. I have some simple mods planned (SRI, short shift kit, tune, maybe some suspension upgrades) so I would rather touch the RMM only once if possible. Anyone want to share some wisdom with me? I should probably mention this is for my '09 MS3... Thanks for reading! |
![]() | | #28 | ![]() |
![]() Join Date: May 2012 Location: Bangor,WA
Rep Power: 100 ![]() Thanks: 0
| Not Ranked : 0 score i pretty sure if you read the previous post it pretty much sums up everything you need to know....just saying |
![]() | | #29 | ![]() |
Additionally, I completely understand the arguments made regarding "the higher the better" in terms of DM count. However, and I feel this bears reiterating so someone can offer a HELPFUL opinion, I am on the highway the majority of the time and only occasionally put my foot in the car. I am prepared to replace the RMM (or go the CS inserts route) and I would like to hear from anyone who might have had experience in both, and what their driving impressions were. I have read through this thread in detail (I ain't got shit else to do right now - my left knee is toast and I'm counting money I haven't made yet ) and I have to say, unless I missed someone's post earlier about the two specific solutions I discussed, I'd say I satisfied my duty in reading. Just saying | |
![]() | | #30 | ![]() |
![]() | | #31 | ![]() |
![]() Join Date: Dec 2011 Location: Irvine, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,122
Groaned at 22 Times in 12 Posts
| Not Ranked : 0 score Well fuck, so I pop the hood today to finish cleaning up a wiring project after running the car hard as fuck last night on the freeway, and I see this oily shit all over the place that looks like its coming from the valve cover gasket right by the passenger side motor mount. Wiped it down, started the motor, reved it, let it run, no oil comes out. I noticed this oily shit is pooling in the little rubber dish that is the motor mount. Took a real good look and it look like the mount was ripped, pushed down on it and a thick gooey oil started pouring out. Sooo I take it the passenger side mount is supposed to be fluid filled? Just ordered a new CPE mount cause its ripped regardless but are they supposed to be fluid filled?
__________________ - - -2007 MS3 - Sold - -2015 BMW m235i - Painfully stock and incredibly comfortable. |
![]() | | #32 | ![]() |
![]() Join Date: Nov 2010 Location: northwest arkansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,067
Groans: 103
__________________ 2008 ms3 mit: hypertech tune, pg sri, corksport tip, jbr(80 tmm, 88 rmm, 80 pmm), jbarone bushings + heavy shift knob, diy sts, sure ssp, sensen shocks, jbr rsb, ford transfluid, aura 5 channel amp, jbl gt speakers, 6" bazooka sub, diy mudflaps, DDM 3000k HID fog kit, 6000k lows [SIGPIC][/SIGPIC] | |
![]() | | #33 | ![]() |
| Not Ranked : 0 score Suweeet. If I like this mount I'll get all 3
![]() | | #34 | ![]() |
Groans: 103
| Not Ranked : 0 score that is the only mount on mine that is stock, and i modified it with some aluminum to reduce its movement.. i am surprised you don't have a RMM, they're usually the first to be replaced. i love the car with a TMM and RMM. it just feels so much tighter, more connected.. you get the idea. motor mount upgrades in this car make such a huge difference, especially since they improve shifting, which is the one weak point i found with my stock car. have fun!
![]() | | #35 | ![]() |
| Not Ranked : 0 score I had the street unit RMM, and it was driving me crazy. I drive 85% solid traffic back and forth to work. The stock mounts allow you to be significantly more lazy with the clutch pedal. The OEM mount is just begging to burst again so I wanted something solid without oil in it.
![]() | | #36 | ![]() |
![]() Join Date: Sep 2011 Location: Atlanta, Georgia
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score Ordering the JBR 80a RMM today. Any thoughts/impressions about this particular one?
__________________ -------------------------------------------------------------------------------------- 2008 Sunlight Silver MS3 GT // Because racecar SOLD Cobb AP || Autotech Internals || CP-e Safe Seals || Bosch 3Bar|| Godspeed FMIC with Godspeed piping || ATP catless downpipe || GT3076R || 3" HTP Intake/Inlet || Turbo Smart Dual Port running in 50/50 || SI Boost Tubes || JBR RMM 80a || JBR SSP || JBR Shifter Bushings || EGR Delete || Corksport LED Lighting || Apexi auto timer || Eibach PK || 18x8 Motegi SP10s || 225/40/18 Nitto NT555 || NGK 1 Step Colder plugs Dynojet 7/6/2013 349.71whp 333lb tq Dynojet 8/2/2013 378.26whp 384lb tq Dynojet 8/31/2013 392.14whp 397lb tq PERM Tuned by Alan and DJ |
![]() | | #37 | ![]() |
![]() Join Date: Jun 2012
| Not Ranked : 0 score Either brilliant or incredibly stupid question incoming: Should winter weather be included in my considerations for RMM, and if so in what regard? -- I'm just getting into modding my MS3 and as recommended will be doing this first. I want to thank everyone who's contributed so much helpful information here, and OP for consolidating it all to the top. I'm still not sure which brand to get; however, I do feel confident that whichever I decide upon I will likely be happier with the results than stock. -- I haven't seen much information during my research about a Sure or a Torque RMM. |
![]() | | #38 | ![]() |
__________________ 2012 mazdaspeed 3, black mica w/ tech package, AFE drop in dry filter, Autotech internals and CS rmm inserts. . | |
![]() | | #39 | ![]() |
Rep Power: 0 ![]() ![]() Thanks: 3
| Not Ranked : 0 score Great sticky. I have an mz3 and my PMM broke....AGAIN. Looking to replace it and thinking about the AWR one. Anyone who's been riding with it for awhile care to comment? I saw the post with the guy showing his broken one and the install already. |
![]() | | #40 | ![]() |
![]() Join Date: Jun 2012 Location: East Bay, CA
| Not Ranked : 0 score just installed the CPE second generation RMM for my 2012 MS3, it was simple and there are obvious improvements as as a result and the machining of the two piece mount is really great. A very good mod BUT you need two people to install this, although it is simple, one person lines up the bolts, the other pushes the engine. This wasn't made clear in any directions. The install guide just talks about needing to fiddle with the engine a little, shows just one set of hands, etc. |
| Display Modes | |
| The Motor Mount Thread | RhoadBlock | MazdaSpeed 3 - Engine, Transmission & Driveline | 341 | 06-30-2018 02:45 PM |
| Motor Mount Inserts vs. Rear Motor Mount Pro's n Con's | Dre | 2010 MS3 - Engine, Transmission & Driveline | 23 | 05-21-2016 08:47 AM |
| Motor mount thread issue | ziwang55 | MazdaSpeed 3 - Engine, Transmission & Driveline | 39 | 04-04-2012 06:29 PM |
