![]() Join Date: May 2008 Location: Brandon, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 667
Groaned at 7 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score *****Thank you to @Inquisitive; for a 2015 update!****** This thread will be for discussion of motor mounts for the MS3 & MS6. All currently available mounts are listed, relative prices, & links where they can be purchased. Note: you may be able to find them for sale elsewhere, possibly for cheaper. I simply linked them to their own company's site. If you have any questions regarding mounts, want to know which duro is best for you, etc, read thru this thread first! IF and ONLY IF it has not been answered already in this thread, post your new question in this thread. Do NOT create a new one. Most of these if you buy brand new will come with installation instructions, but if you buy used and can't figure it out, or simply want to plan ahead, How-To's may be found in here: MS3 How-To Database MS6 How-To Database One of the first mods almost everybody does is the Rear Motor Mount (RMM). As well you should. The factory bushings are mediocre and allow too much movement. There is a small amount of drivetrain slop and shifting may feel a bit notchy. Upgrading the RMM stiffens up the drivetrain slop quite a bit allowing for smoother shifting for one. The Passenger Side Motor Mount (PMM) & Transmission Mount (TM) are mediocre and are big eye sores to boot. Upgrading the mounts allows for much better shifting response and handling as the engine isn't rocking or being tossed around in the bay, but it comes at the expense of some NVH. Vibrations are felt at idle, tho this can be remedied by raising idle RPM if you have an AP. Vibrations often lessen after several months/several hundred miles of breaking in. Genpu MMs: • JBR RMM 88 & unknown durometer • CP-E RMM Stage 2 • JBR TMM unknown • CorkSport RMM • JBR PMM unknown • JBR RMM 80 • Sure RMM TorqR3 WARNING: read http://www.mazdaspeedforum.org/forum/foru...3/#post1927730 • JBR PMM 80 • JBR RMM 70 • Cobb RMM • CorkSport TMM • Damond Motorsports RMM • JBR PMM 70 & 88 • CP-E TMM • TRZ RMM • CorkSport PMM • Street Unit RMM WARNING: read http://www.mazdaspeedforum.org/forum/foru...3/#post1927730 • Ford Electric Focus RMM (RMM part number CM5Z-6068-A; bolt W500545S900) • Minerva PMM & TMM (probably best to avoid, see Minerva Motorwerkz? ) • Sure PMM & TMM WARNING: read http://www.mazdaspeedforum.org/forum/foru...3/#post1927730 • AWR RMM 88 • Torque Solution RMM • Turbine Tech Front Engine Mount • Turbine Tech Differential Mount Update using 2015 prices: JBR RMM Urethane MS6 MS3 Available from: MS6 JBR RMM Urethane MS6 MS3 JBR RMM Urethane MS3 MS6 (Yes: 80a $105), MS3 1st Gen (Yes: 88a $100, 80a $125, 70a $125), MS3 2nd Gen (Yes: 88a $100, 80a $125, 70a $125) CP-E RMM Stage 2 Rubber MS6 MS3 Available from: MS6 CP-E RMM Stage 2 Rubber MS6 MS3 CP-E RMM Stage 2 Rubber MS3 MS6 (Yes: 70a xFlex) $139, MS3 1st Gen (Not found), MS3 2nd Gen (Yes) $198 JBR TMM Urethane MS6 MS3 Available from: MS6 JBR TMM Urethane MS6 MS3 JBR TMM Urethane MS3 MS6 (Yes: 80a, 70a) $175, MS3 1st Gen (Yes: 88a, 80a, 70a) $185, MS3 2nd Gen (Yes: 88a, 80a, 70a) $185 CorkSport RMM Urethane MS6's Insert MS6's Full Replacement MS3's Insert MS3's Full Replacement MS3's Race Available from: MS6 CorkSport RMM Urethane MS6 MS3 CorkSport RMM Urethane MS3 Gen1 CorkSport RMM Urethane MS3 Gen2 MS6 (Yes, Standard 70a) $115.99, MS3 1st Gen (Yes: Insert 70a $39.99, Standard 80a $99.99, Race 80a $125.99), MS3 2nd Gen (Yes: Insert 70a $39.99, Standard 80a $99.99, Race 80a $125.99) JBR PMM Urethane MS6 MS3 Available from: MS6 JBR PMM Urethane MS6 MS3 JBR PMM Urethane MS3 MS6 (Yes: 80a, 70a) $175, MS3 1st Gen (Yes: 80a, 70a) $185, MS3 2nd Gen (Yes: 80a, 70a) $185 Cobb RMM Available from: Cobb RMM MS3 MS6 (Not found), MS3 1st Gen (Yes) $159, MS3 2nd Gen (Yes) $159 CorkSport TMM Insert Polyurethane MS6 MS3 Available from: MS6 CorkSport TMM Insert Polyurethane MS6 MS3 CorkSport TMM Insert Polyurethane MS3 MS6 (Yes) $54.99, MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $39.99 Damond Motorsports RMM Available from: Damond Motorsports RMM MS3 MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $145 in black or gold mount and black or red bushing CP-E TMM Available from: CP-E TMM MS3 MS6 (Not found), MS3 1st Gen (Yes, 75a) $271.30, MS3 2nd Gen (Yes, 75a) $271.30 TRZ RMM Available from: TRZ RMM MS3 MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $100 CorkSport PMM Available from: CorkSport PMM MS3 MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $229.99 Ford Electric Focus RMM (RMM part number CM5Z-6068-A; bolt W500545S900) Available from: local Ford dealership MS6 (Not confirmed), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $43.92 + $1.10 AWR RMM Urethane MS6 MS3 Available from: MS6 AWR RMM Urethane MS6 MS3 AWR RMM Urethane MS3 MS6 (Yes: 95a, 80a, 70a) $82, MS3 1st Gen (Yes: 95a, 80a, 70a) $95, MS3 2nd Gen (Yes: 95a, 80a, 70a) $95 AWR PMM Urethane MS6 MS3 Available from: MS6 AWR PMM Urethane MS6 MS3 AWR PMM Urethane MS3 MS6 (Yes: 95a, 80a, 70a) $172, MS3 1st Gen (Yes: 95a, 80a, 70a) $172, MS3 2nd Gen (Yes: 95a, 80a, 70a) $172 AWR TMM Urethane MS6 MS3 Available from: MS6 AWR TMM Urethane MS6 MS3 AWR TMM Urethane MS3 MS6 (Yes: 95a, 80a, 70a) $140, MS3 1st Gen (Yes: 95a, 80a, 70a) $225, MS3 2nd Gen (Yes: 95a, 80a, 70a) $225 Torque Solution RMM Polyurethane Available from: Torque Solution RMM Polyurethane MS3 MS6 (Not found), MS3 1st Gen (Yes, 75a) $134.99, MS3 2nd Gen (Yes, 75a) $134.99 TRZ TMM Available from: TRZ TMM MS3 MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $100 Damond Motorsports PMM Available from: Damond Motorsports PMM MS3 MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $225 in black or gold mount and black or red bushing Turbine Tech Front Engine Mount MS6 MS3 Gen 1 MS3 Gen 2 Available from: MS6 Turbine Tech Front Engine Mount MS6 MS3 Gen 1 Turbine Tech Front Engine Mount MS3 Gen 1 MS3 Gen 2 Turbine Tech Front Engine Mount MS3 Gen 2 MS6 (Yes) $359, MS3 1st Gen (Yes) $399, MS3 2nd Gen (Yes) $379 Turbine Tech Differential Mount Available from: Turbine Tech Differential Mount MS6 MS6 (Yes) $289, MS3 1st Gen (Not found), MS3 2nd Gen (Not found)
__________________ 2007 MS6 - broked & gone 2006 MS6 - less broked Last edited by Raider; 02-17-2015 at 07:49 AM. Reason: 2015 update |
| The Following User Says Thank You to RhoadBlock For This Useful Post: | joemd (02-10-2018) |
(Thread Starter) | Not Ranked : 0 score Will tidy it up tomorrow. I may add the diff mounts for the MS6 later, but I already made a diff mount thread too. If anybody knows of any mounts I left out or any recommendations/suggestions let me know. Any grammar Nazis speak up too. But for now, here you go. |
| Not Ranked : 0 score Badass! Nice work! Corksport has rmm inserts for ms3. CORKSPORT Rear Motor Mount Insert For Mazdaspeed 3 |
![]() Join Date: Feb 2011 Location: Rosemount, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 189
__________________ New: 2012 Mazda MX5 Miata True Red |
| Not Ranked : 0 score Nice job Rhoad! Didn't see the RMM that I have installed- the StreetUnit original- MAZDASPEED 6 Motor Mount
| Two nuns and a pack mule ![]() Join Date: Jan 2010 Location: Virginia Beach, VA
Rep Power: 595 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 459
| Not Ranked : 0 score Tt makes a front engine mount for the gen one ms3.
__________________ |
![]() Join Date: Jul 2010 Location: Leesburg, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,641
Groaned at 56 Times in 37 Posts
| Not Ranked : 0 score I haz vibezzzzzzzzz
__________________ cobb ap v3 // RICHTUNE // autotech fpi // sp63 afc // cp-e nano // htp tip // nator dc fmic // nator dc PnP intake mani // hks ssqv *vta* // cs dp // su tp jbr rmm(88duro) // jbr pmm(80duro) // cpe tm(75duro) // act 6-puck // act streetlite fw // jbr egr delete // md occ // sure ssb // nator dc sts // jbr hw shift knob ebc red // rx-8s wrapped in conti dws 235/40s (winter) evo Xs wrapped in conti dw 235/40s (summer) www.sonictuning.com 311 whp - 345 lb/ft : Dynojet @ Moore Automotive *93 pump [4/13/13 MNM] 12.94 @ 109.00 @ Capitol Raceway *18' ASL [11/07/14] |
(Thread Starter) | Not Ranked : 0 score Updated. I added a bit of general info on upgrading the mounts to the OP. I'd like to get some discussion going on their reviews of the mounts. How was install? How is NVH now? How is NVH after the mount has been broken in? How much of an improvement was the mount/mounts to you? It's great to have all the available mounts listed, but newbs are still gonna be asking "Which one is best?" etc. Let's get some feedback going so we don't have to keep seeing new Mount Threads popping up. |
| v8 convert ![]() Join Date: Sep 2009 Location: (actually in) Tampa, FL
Rep Power: 1203 ![]() Thanks: 2,634
Groans: 220
| Not Ranked : 0 score |
![]() Join Date: May 2009 Location: Scottsdale, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,450
| Not Ranked : 0 score I would add a sidenote about using red loctite for the CPE trans mount, in case anyone buys a used one without instructions. Avoid that whole fiasco again. Any info on engine dampers (NRG, Ignalls, etc)? As far as reviews, I have the original Street Unit RMM. After 1000 miles it was broken in and never really vibrated too much even from day one. Edit: The TRZ MS3 rmm is available in two bushings - poly (street) and delrin (track). Also, if you run a Turbine Tech MS3 front mount, you probably won't be able to fit a FMIC.
__________________ 2009 MS3 sport MGM |
| Not Ranked : 0 score I'd offer the exact same review about my SU RMM as well, adding only that it simply did it's job and improved shifting quite a bit by controlling engine movement.
![]() Join Date: May 2011 Location: Chicago, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 186
| Not Ranked : 0 score +1 on what Ti said. Vibs are not noticable, but it controls the engine movement and improves shifting.
__________________ MazdaSpeed 6 DashHawk, CorkSport TIP & SRI, CorkSport TMIC, SU RMM, CPE rear diff mount, Perrin EBCS, TurboSmart BPV, TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, JBR EGR deletion & TIG, silicone boost tubes, Bilstein HD shocks, LED light bulbs, TRS clear projectors, 35W DDM Tuning HID foglights, Hawks HPS brake pads, Amsoil in the rear diff, pto & trans, factory navi, XCarLink USB. |
Also, I don't know anything about the engine dampers you speak of. I can haz infoes pleeze? | |
![]() Join Date: Nov 2008 Location: Hutto, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
Reviews and thoughts on the MM's I've used. TRZ RMM & TMM: I had these on my '08, put them both on at the same time so I can't speak directly on one or the other. TONS of noise & vibes. Seriously, I thought we'd F'd something up royally!! I got used to the vibes & noise, but never much liked it. CorkSport RMM Inserts: Probably better than folks give them credit for being. Got light mod's and don't want noise & vibes? Get these, you can find 'em used for $20-30. I had them on my Stage 2 car for several weeks without any troubles. JBR RMM Billet in 80 duro: Quite a bit of vibes, I didn't like it. The bolt that came with mine (it was a lightly used piece) was only a Grade 2 bolt and snapped before I got to the recommended 120#, spend an extra $4 and get a Grade 8 bolt. Mine also seemed to fit a bit loose and clunked when I went on/off throttle. I checked the bolts numerous times and they were all tight. *EDIT* See JBR response below. I did buy mine used and the bolt I got was definitely a Grade 2 bolt, seller may have done a switcharoo on me. CP-e 60 TMM & 75 RMM: I had the TMM for one day before I got the RMM. VERY nice piece, vibes & noise non-existent. RMM I got was used and already broken in, again it's a super nice piece with little to no noise & vibes. Want top shelf quality and can deal with very slight (if any??) vibes & noise? Get these. If/When I swap the passenger side MM, I won't won't look at anything other than the CP-e piece! My ONLY complaint, there wasn't a sticker in the box to put on my toolbox!! CP-e Stage 2 RMM: I had the Stage-1 75 duro mount in my car for a while, but still was getting some nasty wheel-hop. I found a new-open-box Stage 2 on another site that I got a good deal on. I've only made a couple of pulls but my wheel-hop seems gone now. The Stage-2 RMM does add some vibes & noise over the Stage-1 mount, but still less than I found on competitor's urethane based RMM's, I suspect they'll settle some with use.
__________________ 2012 Black Mica with Tech package. Chock full of goodies and Dizzy tuned | |
| The Following 2 Users Say Thank You to TheRealDefman For This Useful Post: | Cheapspeed (02-13-2013), Strangel (09-29-2013) |
| Not Ranked : 0 score If anyone can snag the Turbine Tech products for a good price, do it. They are top quality so you get what you pay for. I have the front engine mount for the MS6, and now my engine and I are one. Shift thump, gone.
![]() Join Date: Nov 2010 Location: Manchester, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
| Not Ranked : 0 score I have cs Rmm inserts and they work pretty good. Basically no additional vibes. I also just purchased a jbr 80 duro and took it out after 150 miles. A little too harsh for my taste and DD. Might through it back in and try breaking it some to see, but for now the cs inserts it is. Tappin
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
![]() Join Date: May 2011 Location: Chicago Illinois
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 508
__________________ 2013 Velocity red Mazdaspeed 3 tech. BT 2011 Velocity red Mazdaspeed 3-SOLD. FreeKtuned fitty fitty | |
| Not Ranked : 0 score Much better than stock. With the inserts we got a video of my car on the dyno, and the motor didnt move at all. I'm sure a hard shift or launch it'll move. But for DD and some spirited driving the inserts work great
![]() Join Date: May 2012 Location: Bangor,WA
Rep Power: 100 ![]() Thanks: 0
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
![]() Join Date: Mar 2010 Location: New Eagle, PA
Rep Power: 2281 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,142
Groans: 324
| Not Ranked : 0 score There's a MS6 thing mixed in with the MS3 stuff. |
(Thread Starter) | Not Ranked : 0 score @Mizzle It's gotta be a mixed up link cause everything else is good, no? Which link was screwy? Sent from my iPhone using Tapatalk |
![]() | | #24 | ![]() |
Groans: 324
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score I was a retard last night. Def looked right over that. The bushings fit the MS6 too, but I changed the link to read MS3 instead of MS6. |
![]() | | #26 | ![]() |
Groans: 220
| Not Ranked : 0 score getting the RMM finally for my MS6. cannot decide whether to get 70 or 88 Duro for the AWR RMM. I'd like effectiveness, but without rattling my teeth out. |
![]() | | #27 | ![]() |
| Not Ranked : 0 score reference point- stock rmm duro is about -10 (yes, minus ten) used bubble gum would work better. based on your selections and criteria, get the 70. -however- if you drive like an animal (LC & FFS, drag or autocross), and you can raise your idle a bit (if you haven't already), get the 88.
![]() | | #28 | ![]() |
Groans: 220
Yeah my idle is raised a fuck-ton to try and combat smoking.... doesn't really help but i like the idle anyways. | |
![]() | | #29 | ![]() |
Groans: 220
![]() Also, i bought the AWR RMM. You HAVE to cut off those stupid prongs. I tried bending them away and that resulted in a ton of fail. (one of the ends of the prongs are welded on.) Pulled out my multi-tool and cut the metal away in less time than it took to debate whether or not to keep bending/prying vs cutting. That metal is relatively soft. Once that was put in, put everything back up and drove it down the road. LOVED it. soooo smooth. and NVH was NOTHING. I mean, the tiny ass amount of vibes was so little. I am really disappointed that people were telling me to go softer. too soft. Seriously, pussy. Now that i put 60 miles on it, i barely feel it anymore and i kinda wish i went with a higher durometer count than that... ![]() As far as the mount itself, if you really feel that you dont care (and have the means) about cutting the prong-things at the frame and would like to save a few bucks, go the AWR mount route. get a higher durometer count. 88 is really just minimum you should go at all. i would love to jump up to 95 DM ![]() Other than that, go the sure/cpe/SU RMM route... it's brain-dead easy. | |
![]() | | #30 | ![]() |
![]() Join Date: Apr 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 110
![]() | | #31 | ![]() |
| patrick failman ![]() Join Date: Mar 2009
Rep Power: 2905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,275
Groans: 74
| Not Ranked : 0 score gold star! go trz if you're okay with vibes. the ladies will thank you.
__________________ 2012 ingot silver mustang gt w/ 6 speed, 3.73 rear end, bama 93 tune, cat deletes, boss 302 oil cooler, roush cai, dynotech aluminum driveshaft, ford racing strut tower brace, dampers & springs, boss 302 sway bars, gt500 strut mounts, lower control arms & axle backs, j&m adjustable panhard bar, steeda upper control arm & 3 point braces, jlt catch can, barton short shifter & shift bracket |
![]() | | #32 | ![]() |
| Not Ranked : 0 score sounds like time for the bnoon bolt. when I was running the oem dp I consistently whined about not wanting to take a chance on starving the turbo of oil. Amazing how going catless and becoming the city mosquito fogging service can changes your perceptions and attitudes on such things...... some due diligence later, i was unable to find any reports of oil starvation, or any damage for that matter, as a result of using the bolt. Indeed, I learned that the specs bnoon uses are considered to be standard for many turbos. After installing the bolt, I've been able to drop my idle to 850 and still have about 98% of my smoking issue resolved. I am a fan, and encourage it's use when needed.
![]() | | #33 | ![]() |
| Not Ranked : 0 score The only thing I really know about ETD's is that they are usually only compatible with stock passenger mounts. Here is a link to one on Street Unit: Stiffy ETD, 2004-09 Mazda 3 & Mazdaspeed3
![]() | | #34 | ![]() |
Has an IRL person ever bought one for the MS3?? If we find one person who has I'll add it to the OP. Until then I won't worry about it. I've never even heard of it and I've been around the DISI forums for 5 years now. If someone really wants it there tho, let me know. I'll put it in OP. | |
![]() | | #35 | ![]() |
![]() Join Date: Jul 2010 Location: Arlington, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score Guess I neeed to hit up the gym...I could not get the three bolts off to install my CP-e RMM yesterday. I may have torn my nut sakz. |
![]() | | #36 | ![]() |
| Not Ranked : 0 score Air tools are so much win. Took forever installing the RMM on my MS3, the 3 bolts had 332545342 lbs of torque at the factory. In installing a RMM on an MS3 the other day, impact gun bussed them off in .23 seconds. Take it to a mechanic, pay $10 for it to go up on a lift and have them removed with impact, then torqued to 70 lbs, or just have them install the mount, using blue loctite on the bolt threads at reinstall. |
![]() | | #37 | ![]() |
| Not Ranked : 0 score ^ Since I am a Army Civilian I can go over to the Ft. Myer Auto Shop...$6/hr for lift and all tools you need. I put coilovers on my old Saabaru for $12 |
![]() | | #38 | ![]() |
(Thread Starter) | Not Ranked : 0 score Damn I would KILL to have a good shop around here that rents lifts/tools. I've got the tools but I need a lift so bad. Would make my build a million times easier. But every shop I've asked won't rent lifts for liability/insurance reasons. But damn they'd make a killing off myself alone if they did. |
![]() | | #39 | ![]() |
| Not Ranked : 0 score Ft. Myer is a Army base here in Arlington, VA. I work for the Army as a civilian so I have access to the base's auto shop. |
![]() | | #40 | ![]() |
![]() Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,682
Groans: 278
| Not Ranked : 0 score @RhoadBlock you forgot to add the Torque Solution RMM, they are coming with the other mounts too. Love my TS. can be bought through MAPerformance
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" |
| Display Modes | |
| The Motor Mount Thread | RhoadBlock | MazdaSpeed 3 - Engine, Transmission & Driveline | 341 | 06-30-2018 02:45 PM |
| Motor Mount Inserts vs. Rear Motor Mount Pro's n Con's | Dre | 2010 MS3 - Engine, Transmission & Driveline | 23 | 05-21-2016 08:47 AM |
| Motor mount thread issue | ziwang55 | MazdaSpeed 3 - Engine, Transmission & Driveline | 39 | 04-04-2012 06:29 PM |
