![]() Join Date: Oct 2011 Location: Murrieta, CA
Rep Power: 2715 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,575
(Thread Starter) | Not Ranked : 0 score Mods, please move to the appropriate forum if necessary. And not sure what is up with the thread title, it was a long day. Ok, you may have seen it before elsewhere, but probably not for our specific application and with current filter technology, so here is some good information for ya. At NATOR today I started talking about oil filters, their construction, and some pros and cons of the different brands (In high school I was using Fram, because I was cheap After an oil change I took off the filter, and the thing rattled like a Maraca, and wasn't even filtering. To find out why I took it apart, which led to cracking damn near every filter I could get my hands on). One thing led to another and I busted out the grinder to show and tell to live it all over again. I just happened to have several oil filters to compare, and below are the results. I dissected a STP, Purolator PureONE (Thanks @TRSpeed ), OEM Mazda, OEM honda Motorcycle and NAPA Silver. Check out the findings. First the STP (AKA AC Delco,) made by Champion Labs. I would not recommend this filter. It uses Nitrile rubber (which is more likely to break down when exposed to high heat, turbo applications anyone?) for its combination Bypass Valve and Anti-Drainback Valve. Also the leaf spring keeping the Paper Media filter in place was very weak. The fins were spaced apart in some locations and compressed in others. Also the fiber board on both ends was easily pried off. Looks like poor quality control. Next is the Purolator PureONE. This is a better filter. It uses a denser Synthetic filter media that used crimped metal to hold it together, which was removed by flicking with my finger, and has a Silicon Anti-Drainback valve (holds up better) and a spring loaded Bypass valve located in the base of the filter. One difference treated rubber gasket, which is supposed to seal better and is supposed to be easier to install, but come on, how hard is it to install a filter. It still uses a leaf spring, which I just do not like. The can was coated in a slip resistant cover, but it was a much thinner wall, my grinder went though it like butter. Next was OEM Mazda. (Made by Tennex when built in USA, Toyo Roko if made in Japan.) This filter was near identical to the Purolator filter. Only difference is the Anti-Drainback valve, was a internal spring and a ball type valve, and non treated gasket. Uses a Rubber bypass valve, and is the same for all 3's NA 2.0 etc. Still used stiff leaf spring. (This filter did work, there was sparkly crap in the fins.) Next was an OEM Honda Motorcycle Filter. (Don't mind the box) I just wanted to show a different type of construction. Notice the 4 pronged leaf spring attached to the Anti-Drainback Valve. Also the fiber caps on the filter media. The gasket is cool though. Finally the Napa Silver. (Gold is similar but if I am not mistaken has Silicone instead of Rubber bypass gasket) Made by Dana/Wix. Notice the strong coil spring instead of the leafs. The Anti-Drainback valve is located on the top of the filter. All around in my opinion the best filter. Some food for thought, The K&N is the same as the Mobil 1 but is usually a couple bucks cheaper. You are paying for a nut, fun fact, made by Champion Labs (same as STP but better quality). It still has a leaf spring and a rubber drainback valve. The bypass valve is in the same location as the Napa. Do your car a favor and stay away from Fram, or anything made by Honeywell (MotorMaster, Pennzoil, Quaker State) That filter is just Chaos, and that is what started this interest in filters. As far as what filter is good for us? I say Napa Gold hands down, just a great filter. It is reasonably priced and goes on sale very couple months (about $5 a piece). I would not use the Silver, or Pro Select in our application due to the Rubber Valve, as well as Gold having a superior center tube and more filter media. Plus the Pro Select is pretty expensive. If Napa is not available in your area you could possibly go with the following. (Not tested personally yet, so no promises) Baldwin, Ryco, Wix, Penske, CarQuest, and Castrol. Although their base lines are rubber not Silicon, easy way to find out, look at the bottom, if the Bypas Valve (the part that is inside the filter visible through the holes) is Orange (or any other color) it is Silicon, black = Rubber. ( I plan on ripping apart a CarQuest next time I go to Walmart, since that is where we usually get out oil anyway, would be nice to save a trip and a couple $$) For all you Amsoil lovers, they recommend WIX filters as well. Hope you found this useful, it was fun making sparks. @Hamilton69 More notes on post #13, #14, and #23. |
| The Following 5 Users Say Thank You to UnknownSuperhero For This Useful Post: | ChaunceyM (11-18-2013), dvswimer (01-02-2018), jbrowntown (12-30-2016), meicalnissyen (01-24-2015), Weazsel (11-25-2012) |
![]() Join Date: Jul 2011 Location: hesperia, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 295
__________________ 2008.05 True Red Mazdaspeed3 Lex Tuned GTX3071r | 38mm Tial WG | Hallman MBC Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod | Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM | Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs |
![]() Join Date: Sep 2011 Location: virginia, portsmouth
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 164
| Not Ranked : 0 score very useful information. thank you
__________________ 2008 MS3 gt mica black EL NATOR DE Virginia/Florida Update: getting that Purple drank in my tank. build block, pnp everything, tr825 core, meth and lots of it. 554whp/546wtq @ 30psi. another build? maybe soon.. b/c race cars need more attention than women. . ![]() ![]() adlpb: ~Fast cars are for straight lines. Corners are for fast drivers.~ #CATBACKEXHAUST |
![]() Join Date: Mar 2010 Location: New Eagle, PA
Rep Power: 2281 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,142
Groans: 324
| Not Ranked : 0 score Just my .02 - The construction isn't the only factor in choosing a filter, but also how well it filters. I have excellent results on oil tests using a Purolator PureOne and the media filters really tiny shit. |
![]() Join Date: Nov 2010 Location: Manchester, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
| Not Ranked : 0 score Cool write up. I always use motorcraft filters on my car. But I work for Ford and have easy access to them. I would assume the motorcraft filter would be similar to the oem Mazda filter. But who knows. Tappin
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
(Thread Starter) | Not Ranked : 0 score If I am not mistaken the Motorcraft filters are made by Purolator, so you have a good filter there and if you can get it for the cheap more power to ya! If you want to have some fun, cut the can off. If there is a string wrapped around the filter media, then it is paper and comparable to a Premium Plus, without it (and a little purple dye on the end caps) it is the same as a PureONE with the synthetic media. |
![]() Join Date: Mar 2011 Location: Shawnee, Ks
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,101
Groans: 48
Groaned at 49 Times in 30 Posts
| Not Ranked : 0 score Thanks for the info. I have been running an OEM but pass a NAPA every work day, time to switch to gold or platinum. Lol at tools of the trade in first pic, grinder safety glasses and beer.
__________________ AP, Corksport SRI/TIP, MD OCC, Autotech internals, CPE stage 2 RMM |
![]() Join Date: Jun 2011 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 50
| Not Ranked : 0 score Nice.good to know. I would second getting the oil tested after running through the filters...to see how good they actually filter. But great write up...and I bet is was fun grinding them all open
__________________ 2011 Liquid Silver Mazdaspeed 3 |
![]() Join Date: Apr 2010 Location: MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 553
| Not Ranked : 0 score IIRC I saw orange through the holes on top of my WIX filters.
__________________ 2008.5 MGM Mazdaspeed 3 GT Cobb AP | cp-e SRI | cp-e TMIC | UR TP | cp-e RMM | JBR SSP | JBR Spherical Shift Knob | JBR RSB | Autotech HPFP | Spin-on |
| Not Ranked : 0 score Thanks, I'll throw msf bucks your way in a bit. I thought I was being called to an epic fail thread. |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 492
| Not Ranked : 0 score WIX has been a really good filter for me the past 5 years. You can also get a box of 12 from Amazon for less than $50!!! It's the cheapest I've found anywhere. |
| Not Ranked : 0 score OP, the guys over @ Bob is the oil guy would love to see your post. Those guys dislike Fram as well, give high marks for the Napa Gold (rebranded wix), and actually like the filtering capability of the Purulator Pure one from their testing (much like Mizzle's UOA confirms). In any case, Fram sucks and thanks for taking the time to write this up / hack up some filters. Very cool. @Tokay444 and @Lex are always into oil / oil filter discussions and would probably like to see this thread. |
Groans: 793
| Not Ranked : 0 score I'm a big non supporter of fram. Unfortunately, it's them or oem for me. I don't have a problem spending the 13 bucks on the oem filter over the $7 fram though. I cut all my used filter, not necissarlily to inspect the filter myself, but to see if there's anything glaringly wrong going on with my motor.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
Groans: 793
| Not Ranked : 0 score I should mention that I'm using a cartridge element. Not a spin on. Gonna see what napa has to offer up here. The oem cartridge comes with both rubber seals and a new crush washer for the drain plug.
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
With that said, I've used STP strictly..not to say they are much better than FRAM..if at all. But I'll look into NAPA and see what they have to offer us, non-spin'on'ers
__________________ | |
(Thread Starter) | Not Ranked : 0 score After doing a bit more research. The PureONE's synthetic media does filter smaller particles than the NAPA Gold due to being denser. Denser media will restrict flow but they added more media to offset this issue. From what I have read, the Gold does flow with less restriction. I don't have the ability to test them on anything other than construction. Although due to them being mounted upside down instead of sideways, we don't really have to worry about the bypass valve location, oil is not going to drain out of the filter. One concern about the PureONE is the stiffness of the spring, it was very rigid, they may as well have put washers in there. Also if you ever have to last resort (screwdriver through the can) on a PureONE, I am pretty sure your couch is fucked with the soft thin metal. There is a Napa Platinum filter that has a wire-backed synthetic media that would be comparable to the PureONE, but at a cost, those Platinum filters are in the K&N price range. (They also made the can stronger for some reason) Fun fact about K&N filters, even in their oil filters the media is dyed red. Its funny how even Fram says they have 20% more filtering capability than OEM.
I guess it all boils down to convenience and cost. If you are close to a Napa or drive by one every once in a while, keep an eye out for their 40% off sales, then stock up. Silver, for Dino Oil applications, Gold for Synthetic, Platinum if your rich and want synthetic filtering media. If you are close to a Pep Boys the PureONE is still a good filter, and (from what I have heard) one of the best for filtering particles, (Claimed 99.9% of >20 microns but doesnt go into more detail). The Napa Platinum captures 99% >10 microns, 98% > 8 microns, and 95% > 5 microns. (This information available through their sites if you dig.) I just really like Napa's Construction. I pity the foo that spends the $$ for PP or T6 and uses a shit filter. | |
Groans: 793
| Not Ranked : 0 score I work beside a Mazda dealer and live close to a NAPA. No pep boys in Canada.
| I <3 your mom ![]() ![]() Join Date: Jul 2008 Location: Long Beach, CA.
Rep Power: 14358 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,316
Groans: 293
| Not Ranked : 0 score Been running Mazda filters since I did my spin on conversion 3 years ago. They work great and they're short enough to clear the engine tray if you're running a sandwich plate for gauges. I'll have to try NAPA. They're a lot closer than the dealer and probably a lot cheaper. |
| Not Ranked : 0 score If you guys want to try the Napa Gold filters, they are re-branded Wix. Wix sells to a lot of local independents and you can search by your zip code here: They have Canadian distributors as well. WIX filters, WIX oil filters, WIX air filters, WIX fuel filters, WIX Heavy Duty Oil Filters : Where to Buy |
Groans: 324
| Not Ranked : 0 score I'm still waiting for someone to do a spin-on conversion with a remote-location filter... and then a filter the size of my thigh lol. |
![]() Join Date: May 2010 Location: Belle Vernon Pa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 35
| Not Ranked : 0 score I've been using the motorcraft filters since I've had the car, can't beat the price either at wallyworld. I have some used ones in the garage I'll cut open when I get a chance. |
![]() | | #24 | ![]() |
![]() Join Date: Aug 2011 Location: Goffstown,NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,292
| Not Ranked : 0 score Awesome thread props on the info. I personally use Wix.
__________________ 2010 black mica ~GTX2867~ Auto tech internals--UR DP--UR res TP--bosch 3 bar map--HTP 3.5" intake--GFB dual port bpv--Cobb fmic--Cobb AP--GS EBCS-- --JBR fully mounted --JBR OCC--JBR TB TIG--JBR 51r battery tray--JBR RSB--JBR rear camber arms --Stratified extended shifter-- Freektuned333hp/354tq @ gsd (without meth) |
![]() | | #25 | ![]() |
![]() Join Date: Jan 2012 Location: Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 595
| Not Ranked : 0 score i used k&n on my 2.3T sedan. will likely use the OE on the speed3 for now. MODS:the thread title has a typo LOL "how what is the best oil filter" |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score Haha yeah it does, no idea what the hell I was trying, maybe so what is the best . . . . I saw that after and tried to change it. Somthing like Oil Filters? Class is in session. |
![]() | | #27 | ![]() |
![]() Join Date: Sep 2009 Location: salem oregon
Rep Power: 187 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
| Not Ranked : 0 score Good read thanks! My only problem with the Purolator PureOne is ive read on other forums about ppl complaining how it restricts the flow and isnt ideal for high boost cars as if can increase oil pressure. Most of us are already running thicker oil and adding a restrictive filter may not be ideal.
__________________ Boobs.....because you can't motorboat a personality. |
![]() | | #28 | ![]() |
| patrick failman ![]() Join Date: Mar 2009
Rep Power: 2905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,275
Groans: 74
| Not Ranked : 0 score ^^^ i had heard that too, but ended up switching from the mobil 1 to pureone big spin on. they rub on the undertray. couldn't imagine a k&n with that nut.
__________________ 2012 ingot silver mustang gt w/ 6 speed, 3.73 rear end, bama 93 tune, cat deletes, boss 302 oil cooler, roush cai, dynotech aluminum driveshaft, ford racing strut tower brace, dampers & springs, boss 302 sway bars, gt500 strut mounts, lower control arms & axle backs, j&m adjustable panhard bar, steeda upper control arm & 3 point braces, jlt catch can, barton short shifter & shift bracket |
![]() | | #29 | ![]() |
![]() Join Date: Nov 2010 Location: Ottawa
Rep Power: 0 ![]() ![]() ![]() Thanks: 23
| Not Ranked : 0 score K&N fits fine on GenPu, might try out the Wix though. A little cheaper I would imagine. |
![]() | | #30 | ![]() |
![]() Join Date: Mar 2012 Location: Burlington, WI
| Not Ranked : 0 score I would stay away from Baldwin filters also, they built a filter for the Detroit Diesel DD15 engine and the glue was coming off of the filter and plugging up the piston cooling nozzles(oil squirters) causing cylinder meltdowns. I had to do a warranty engine overhaul because of this, thanks for the great R&D Baldwin. |
![]() | | #31 | ![]() |
![]() Join Date: Mar 2012 Location: Blairsville, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 602
Groans: 30
| Not Ranked : 0 score Anyone have any info on Bosch filters?
__________________ Thanks 4G63 for the avatar!!!
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score From what I have read, somewhere around the turn of the century Bosh split ways with champion labs (range from shit to ok) and joined up with Purolator (so far decent). So the bosh platinum will be similar to the Purolator PureOne but without the Silicone anti drainback valve and the filtering media is a blend instead of synthetic. I put it between the Purolator Premium plus and the PureOne. |
![]() | | #33 | ![]() |
Groans: 324
| Not Ranked : 0 score Wix, Purolator Premium Plus or PureOne. End of thread. |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Win is aka Napa and was already proved to be one of the best if not that best. And Pureone is OK. Sent from my DROID4 using Tapatalk
![]() | | #35 | ![]() |
Groans: 324
| Not Ranked : 0 score |
![]() | | #36 | ![]() |
![]() Join Date: Apr 2011 Location: Weston, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,511
Groans: 39
| Not Ranked : 0 score I was using a mobil 1, bosch but fuck paying $13 for a filter. Purolator pure one for me $6 at the local pepboys.
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score In b4 unicorn oil filter |
![]() | | #38 | ![]() |
| Not Ranked : 0 score Not Unicorn but Canton billet spin ons are close to it if you want to pay over $100 for a filter. https://www.cantonracingproducts.com...&category=2501
![]() | | #39 | ![]() |
![]() Join Date: Dec 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score Mobil1 filter.... Good or bad? |
![]() | | #40 | ![]() |
![]() Join Date: Apr 2012 Location: Minoa, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,172
| Not Ranked : 0 score Anyone have any luck with the royal purple filter???
__________________ 2012 Black Mica Mods CS catless DP, CS RP Magnaflow CBE Autotech HPFP NGK Plugs CS RMM JBR PMM CS Short Shit Kit and Shifter Bushings Cobb SRI and TIP CS TMIC SU Boost Tubes JBR Reticulation Tube Cobb AP v2 H&R springs JBR Rear Sway Bar Self Built 3 Port EBCS maisonvi Shift Knob Tuned on 93 and corn [SIGPIC][/SIGPIC] |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f629/oil-covered-now-what-best-oil-filter-125119/ | ||||
| Comprehensive Oil Filter Dissection Thread - RX7Club.com | This thread | Refback | 09-07-2013 04:55 PM | |
| Comprehensive Oil Filter Dissection Thread - RX7Club.com | This thread | Refback | 09-01-2013 12:07 AM | |
| Oil is covered, NOW what is the best oil filter? | UnknownSuperhero | 2010 MS3 - Engine, Transmission & Driveline | 99 | 05-21-2018 01:02 PM |
| ETS has your suspension needs covered! | ETS Michael | [ETS] Extreme Turbo Systems | 19 | 12-12-2015 02:39 AM |
| We obsessively covered Day Two of the... | Haltech | Automotive News | 0 | 11-03-2010 07:30 PM |
| We Obsessively Covered Day One of the... | Haltech | Automotive News | 0 | 11-03-2010 12:27 AM |
