 Old 03-11-2010, 02:32 PM   #1
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
mhmm...my understanding of ngks is that we use 6510 for 1 step colder. not that part number.
phillyb is offline
 Old 02-15-2011, 11:08 PM   #2
speed3willie's Avatar
Posts: 19   (View Stats)
speed3willie will become famous soon enough
just ordered my spark plus got them for 7.89 a plug got the ngk 6510 can't wait to install these..
speed3willie is offline
 Old 03-11-2010, 02:56 PM   #3
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
http://www.mazdaspeedforum.org/forum/foru...ge-1-2-a-5692/
hnda etr is offline
 Old 03-11-2010, 03:31 PM   #4
phillyb's Avatar
Groans: 1,940
nah, you're fine.
stock gap is recommended to be within .028-.032
ngk 6510's come pregapped at like .042 or some shit like that so they need to be regapped to be in spec.
i think that guy was also confused about his stock plugs.
phillyb is offline
 Old 03-11-2010, 03:51 PM   #5
shpankey's Avatar
Posts: 496   (View Stats)
Cool thanks. I found the stock heat range part number. Heat range 6. NGK 3787 just in case anyone needs those too. 1 step colder is Heat range 7, but I know most of you already knew that. My only question is, do I need 1 step colder? I tried the Denso's 1 step colder and they fouled out quickly. I don't think I've added over 75 chp yet (?).
09 Speed 3 GT
shpankey is offline
 Old 03-11-2010, 03:58 PM   #6
phillyb's Avatar
Groans: 1,940
idk man. there are people who will say that when you raise boost, you should go one step colder.
there are people that go one step colder with an intake and upgraded ic i think.
so i'm really not too sure.
i've been running step colder plugs for a while.
but idk how "necessary" they are.
phillyb is offline
 Old 04-12-2010, 10:51 PM   #7
c.a.t.a.p's Avatar
Posts: 67   (View Stats)
c.a.t.a.p is a name known to allc.a.t.a.p is a name known to allc.a.t.a.p is a name known to allc.a.t.a.p is a name known to allc.a.t.a.p is a name known to allc.a.t.a.p is a name known to all
that last post helped me out alot thanks
c.a.t.a.p is offline
 Old 05-09-2010, 07:12 AM   #8
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
Ok, at what point do you need 2 step colder plugs???
 Old 05-09-2010, 07:25 AM   #9
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
Default Re: Spark Plug Database - Colder Than Stock ( Stage 1&2 )
Good question. I should prolly replace my spark plugs soon.
2012 WRX HB w/mudflaps yo!
spnkr21 is offline
 Old 06-22-2010, 04:00 PM   #10
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
Update to this thread.
Autolite makes Iridium plugs now. Plug numbers are XP5364 (Heat Range 4 - stock heat range) and XP5263 (Heat Range 3 - 1 step colder). I know most will turn their nose up to Autolite compared to NGK's and Denso's, but I don't think they're a bad plug. They're $6.49 each at Autozone and I just picked up a set to try out. They are supposedly gapped at .051. I'll have to confirm this, but if so, you'll have to tighten them up a bit. From what I can see, they look like they can be tightened up without bending them too much since they almost have a negative bend to them.
EDIT: The good thing about these is that it seems most Autozones and Advance Auto Parts stock them regularly whereas the NGK's and Denso's are usually special order through these places and cost more unless you get them online. You may want to spend a few bucks more per plug to get the NGK's or Denso's, but if you're in a pinch, run to Autozone and pick a set of these up. Besides, Autolite is an official NASCAR sponsor buddy.... yeeehaaw.
EDIT #2: I've been running these plugs for a few thousand miles now and the car runs just fine on them. I'll pull them out in a month or two and see how they look.
Frequentflyer is offline
 Old 01-30-2011, 10:38 AM   #11
qwerty4550's Avatar
Posts: 62   (View Stats)
qwerty4550 has a spectacular aura aboutqwerty4550 has a spectacular aura about
Have you pulled them to see how they look? I have had Denso ITV22's in for 15k miles now and need to pull them and see how they look.
qwerty4550 is offline
 Old 01-30-2011, 02:20 PM   #12
Nope. I ordered a Corksport topmount intercooler, so when I get it in March, I'll probably pull the plugs. They're working fine with no misfires running 19 psi, so if it's not broken, I don't fix it. I was kinda pissed a few weeks ago when I put a new downpipe in and had the TMIC pulled off, but forgot to pull the plugs to look at the them while I had it off.
 Old 06-02-2011, 09:12 PM   #13
2008MS3H's Avatar
Posts: 492   (View Stats)
2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world
i know this is an older thread but i am curious if you ever pulled the plugs and what they looked like? what mileage did you pull them.....if you remember.
also, what did you end up gapping them at?
let me know
2008 MS3:
MAISONVI PISTON SHIFT KNOB - AUTOTECH INTERNALS
SURE COUNTERSHIFT - SURE SHORTCUT - SURE ANCHORS
JBR TRILOGY - JBR RSB - JBR TUBING - JBR TIP - JBR SRI - JBR EGR DELETE
HYPNOTIC TUNED
2008MS3H is offline
 Old 12-27-2010, 10:17 AM   #14
justint5387's Avatar
Posts: 608   (View Stats)
Why does the Denso plugs foul up so easily? Are the NGK for durable?
justint5387 is offline
 Old 01-31-2011, 04:29 PM   #15
Jsn_Rob's Avatar
Posts: 116   (View Stats)
Jsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond repute
Getting ready to change my spark plugs in the next couple of days. I recall reading that it might be neccesary to stretch the coil from the wire that connects to the spark plug. hHas any else ever heard of this?
Silver 08 MS3-
Purple Drank Racing Tune l CXRACING FMI l DO Methanol Injection l JBR 3.5 intake l Turbo XS DP, TP l ProSport Boost Gauge l HKS TT l Cobb AP l Cobb RMM l H&R Springs l Turbo Smart BPV l WOT Box l JBR side mounts l KMD internals l BNR Stage 1 turbo l Protegegarage SS l VTCS Delete | TB Spacer | CPE Injector Seals l BSD l 3 port EBC l Bosch 3bar MAP.
Jsn_Rob is offline
 Old 01-31-2011, 04:37 PM   #16
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
Very old info, but stretching the springs a little on both ends helps with some peoples problems. Stretching the middle doesn't do anything because the spring holder is shaped for it and compresses it back.
jmhinkle is offline
 Old 01-31-2011, 04:44 PM   #17
Jsn_Rob's Avatar
Thanks jmhinkle.
Silver 08 MS3-
Jsn_Rob is offline
 Old 02-10-2011, 09:08 PM   #18
Texas Speed Demon Fag's Avatar
Posts: 527   (View Stats)
Texas Speed Demon Fag has a reputation beyond reputeTexas Speed Demon Fag has a reputation beyond reputeTexas Speed Demon Fag has a reputation beyond reputeTexas Speed Demon Fag has a reputation beyond reputeTexas Speed Demon Fag has a reputation beyond reputeTexas Speed Demon Fag has a reputation beyond reputeTexas Speed Demon Fag has a reputation beyond reputeTexas Speed Demon Fag has a reputation beyond reputeTexas Speed Demon Fag has a reputation beyond reputeTexas Speed Demon Fag has a reputation beyond reputeTexas Speed Demon Fag has a reputation beyond repute
I got the 6510's...some shops say .22, some .28 for gap. My gapper shows stockers at a gap of .24-.25...so which is it? I assume .28 will be fine...I have the auto gapper that shops use so it wont break the electrode or the tip...and also creates a perfect level tip to electrode which is supposed to prevent hot spots in the piston area when firing...any help appreciated.
Texas Speed Demon Fag is offline
 Old 02-10-2011, 09:48 PM   #19
Keeping stock taking 6510's back, after reading only use if making over 100HP more than stock...no need for me...not gonna risk it.
 Old 02-11-2011, 07:53 AM   #20
halfdead's Avatar
Posts: 10   (View Stats)
halfdead is a splendid one to beholdhalfdead is a splendid one to beholdhalfdead is a splendid one to beholdhalfdead is a splendid one to beholdhalfdead is a splendid one to beholdhalfdead is a splendid one to beholdhalfdead is a splendid one to behold
So from what I've read and also talked to a lot of mechanics, you should try to keep your plugs as cold as possible without them fouling out, the plugs clean themselves with heat, (like self cleaning ovens, or propane grills) now going too hot on a plug will cause the fuel/air to detonate premature, causing knock and power loss, even at extreme sometimes melt. higher pressure(boost) or compression lowers the detonation point of the fuel/air. so if you dont mind changing plugs, go cold, then step it up a heat range till you find the plug best for YOUR car.
halfdead is offline
 Old 02-11-2011, 07:39 PM   #21
Axle Breaker
jmhinkle's Avatar
Groans: 162
It never hurts to go 1 step colder from factory even with a stock car. Never go hotter.
jmhinkle is offline
 Old 06-02-2011, 09:21 PM   #22
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
Bump
2008 MS3 gt
470hp/463tq on GT35r at 29psi
burn813 is offline
 Old 06-02-2011, 09:27 PM   #23
Axle Breaker
jmhinkle's Avatar
Groans: 162
I can tell you from personal experience that the Autolite plugs have to bent a lot and not just your regular bending. The are gapped HUGE! You actually need to carefully pull the groundstrap back and then compress it down so the angle is decent. Make sure those strange dots they have on the ground strap line up with the electrode as well. If you are in a bind which a local guy definitely was, they will do ok, but they really aren't much cheaper than a plug that works properly if you don't need them immediately.
jmhinkle is offline
 Old 06-03-2011, 06:30 AM   #24
2008MS3H's Avatar
ok thanks for the advice.
i took a look online and i think they are gapped at .051 which really threw me off. i might just go with the ngk's since that seems to be standard for most people here. i dont know how comfortable i feel having to bend a plug that much - doesn't seem natural.
2008 MS3:
HYPNOTIC TUNED
2008MS3H is offline
 Old 11-04-2011, 03:26 PM   #25
I've been running the Autolite plugs for over 30k miles with no issues. Of course, when I replace them, I'll probably go with the Denso's again.
 Old 05-07-2012, 07:04 PM   #26
Spectrum24x's Avatar
Posts: 276   (View Stats)
Spectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond repute
Sorry to revive the dead but what's the best practice for ungapping the plugs? I just got NGK 6510 and they are set around .040 I was going to set them at .031 but I can't get the metal to bend down.. I'm afraid to give it to much an breaking it
2007 TRUE RED MS3 GT
RX-8 WHEELS/DRILLED & SLOTTED ROTORS
KONI YELLOW/COBB SPRINGS/JBR RSB/HOTCHKIS FSB
COBB OTS STAGE 2 MAP
RMM/COBB INTAKE/COBB TIH/ETS TMIC
OBX TEST PIPE/AUTOTECH INTERNALS/FORGE BPV V2
Spectrum24x is offline
 Old 05-07-2012, 10:43 PM   #27
Axle Breaker
jmhinkle's Avatar
Groans: 162
That would not be ungapping, that would be gapping. You need to aim for .028 anyway. Use a bench vise for the most precise compression, or carefully push them against soft wood. Never tap them against anything. You would be risking cracking either ceramic piece.
jmhinkle is offline
 Old 05-07-2012, 09:08 PM   #28
theurgy's Avatar
Posts: 2,580   (View Stats)
Just lightly tap it against a table.
theurgy is offline
 Old 06-05-2012, 04:42 PM   #29
dead-zone's Avatar
Posts: 442   (View Stats)
dead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the world
Groaned at 53 Times in 17 Posts
From reading all the post I am in a big delema between the NGKs and Densos and dono which ones to get. I know that Densos the spring has to be stretched. How about the NGKs?
BTW, nice thread!
dead-zone is offline
 Old 06-05-2012, 05:06 PM   #30
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
Ummm, why not use a spark plug gapping tool that will bend it for you?
Sent from my LG-MS690 using Tapatalk 2
it's fun to do bad things
jack_hammer is offline
 Old 06-05-2012, 08:05 PM   #31
dead-zone's Avatar
Nice!!
BTW, this tool costs just a couple of bucks(around $3), just go for it guyz.
 Old 06-05-2012, 09:08 PM   #32
Axle Breaker
jmhinkle's Avatar
Groans: 162
Because we are already gapping below the recommended distance causing the arm to lean in and be angled towards the electrode. I have found that when you use a vise the arm stays more true. Also, those gapping tools suck ass. The .99 disc type that has a hole to open with works better IMHO
jmhinkle is offline
 Old 06-06-2012, 07:07 AM   #33
Groans: 549
i have found a big variation in the accuracy those disc types. what is .30 on one might be .25 on another. i like the wires because they are consistent, at least in my experience. but you might have a point about the vise for closing the gap. you're still in need of another tool if you close it too much.
 Old 06-05-2012, 05:30 PM   #34
I'm not disagreeing with JMhinkle or Bronco in the least, but I can see where people would get the idea to tap the strap down to regap.
NGK.com
rfinkle2 is offline
 Old 06-05-2012, 08:12 PM   #35
Groans: 549
NGK.com
that's awesome, until you accidentally close it too much! haha
 Old 06-06-2012, 07:26 AM   #36
This is getting more technical than I think it was intended, but gathering all of this info I think I would:
-use a feeler gauge
-close the gap with a vise to be sure the strap and its orientation to the electrode is consistent
-open the gap (if necessary with a plug specific gapping tool)
The tool that you posted Bronco sometimes are hard to find with a measure ring that is <.030.
I would like to have one of those because feelers are hard to use sometimes, but I need to find one with a gap as low as .026.
rfinkle2 is offline
Truguy86 (04-03-2017)
 Old 06-06-2012, 08:35 AM   #37
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
-use a feeler gauge
I would like to have one of those becuase feelers are hard to use sometimes, but I need to find one with a gap as low as .026.
It had always been my understanding that using anything besides a wire style gauge was bad for precious metal plugs. true false?
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
smoogs12 is offline
 Old 06-06-2012, 08:39 AM   #38
I've read to use a feeler gauge only on the precious metal plugs. LOL.
I guess it depends on the source. Denso says not to gap their plugs (iridium) due to the efficiency of iridium being able to overcome any gap error and NGK would have you tapping the strap. HAHA!!!
I know that using a traditonal slide around copper plug gapper is a definite no - no.
I would think that the picture posted of the guage above and a feeler gauge would be safe as long as we are not reckless / rough on the electrode.
rfinkle2 is offline
 Old 06-06-2012, 09:58 AM   #39
I tapped mine down to .28 and used a standard gapper...no issues, but lately I have started feeling a smal miss after 5,000 miles and I am thinking its time to check for fouling. Will also get one of those wire ones if I can find one with the smaller gap like the last guy stated.
 Old 07-16-2012, 11:46 PM   #40
Bump. Updated. If you have other plugs to be listed, reply here. Thanks
Haltech is offline
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 3/6 - ECU Computer Tuning 74 08-02-2019 08:18 AM
Spark Plug Database - Gen2 Haltech 2010 MS3 - Engine, Transmission & Driveline 23 09-27-2017 05:09 PM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 6 - Engine, Transmission & Driveline 41 05-05-2016 08:49 AM
Spark Plug Database - Gen2 Haltech 2010 MS3 - ECU Computer Tuning 3 02-27-2016 04:53 PM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 3 - Engine, Transmission & Driveline 205 09-22-2015 06:52 PM
Page generated in 0.63738 seconds with 41 queries
