![]() Join Date: Jul 2012 Location: Tampa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,432
| Not Ranked : 0 score What do you recommend on a stock motor? Would I see any benefits running a 1 step colder plug or should I just stick with OEM specs? |
| Not Ranked : 0 score |
| Not Ranked : 0 score 10-4, thanks for the input. Followup question: Which brand? I hear good things on this forum about NGK and Denso so I assume they're both comparable? |
The NGK will need to be regapped because the out of the box gap is a bit large for the ms3. | |
| lulz @Raider ![]() Join Date: Jun 2010 Location: St Louis Mo
Rep Power: 3779 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,132
| Not Ranked : 0 score I hate to say it rob, but the matte black wrap you have on your car looks DOPE..... how much did it end up costing you?
__________________ 2008 MS3 gt 470hp/463tq on GT35r at 29psi Wiseco Pistons/Molar Rods/ACT 6 Puck/ARP Head Studs/TurboXS FMIC DP and RP/TurboSmart BOV/Tial 38mm EWG/PERM 5th/6th port injectors HKS CBE/ Koni Yellows and H&R springs/ HTP Whale Penis Intake/ PTP Fuel internals/SteedSpeed Mani/CP-E SafeSeals/E85 Hypnotic Tuned |
![]() Join Date: Sep 2009 Location: Surburban Detroit Michigan
Rep Power: 2266 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,223
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score I am running stock boost...for now with step colder NKG's...no issues |
| Not Ranked : 0 score What brand and did you have to regap them? Sent from my iPhone using Tapatalk
__________________ '08 Speed3 - Cobb sri/cp-e rmm/18x8 RX-8 rims (DynoJet @ 254 whp/295 wtq) '99 Miata - Ground Control coilovers/Bilstein Sports/Racing Beat F&R sway bars/Go Miata strut tower brace/Jackson Racing header/MSM muffler/15x7 Kudo Racing wheels |
| Not Ranked : 0 score I have NKG and gapped to .030, I will be running 19.5lbs when I retune. |
| Not Ranked : 0 score @rfinkle2 answer my question mang
Groans: 136
| Not Ranked : 0 score Only use plug gapper tools to open up the plug gap; not to actually measure the gap. Use a set of feeler gauges to measure gap properly. Tapadatass
__________________ |
![]() Join Date: Jun 2012 Location: Severn MD
Rep Power: 0 ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score From reading the thread, since I currently only have a cobb sri and I am running stock boost levels should I go 1 step colder or just stick with the stock heat range. Also have the denso problems been worked out? Thanks |
![]() Join Date: Nov 2010 Location: northwest arkansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,067
Groans: 103
maybe it is time to work on the comprehension part of reading?
__________________ 2008 ms3 mit: hypertech tune, pg sri, corksport tip, jbr(80 tmm, 88 rmm, 80 pmm), jbarone bushings + heavy shift knob, diy sts, sure ssp, sensen shocks, jbr rsb, ford transfluid, aura 5 channel amp, jbl gt speakers, 6" bazooka sub, diy mudflaps, DDM 3000k HID fog kit, 6000k lows [SIGPIC][/SIGPIC] | |
| Not Ranked : 0 score thanks for your input. but also some of the people that are on stock boost are running one step colder and was hoping to hear from them on there opinions of how the car is running with them. i do comprehend reading thru posts and searching before I post. that is the reason that i donated to help the forum stay up and running for me to gain knowledge as everyone else. fyi... ..has never been in my system. |
![]() Join Date: Jul 2008 Location: Ottawa, ON Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,005
| Not Ranked : 0 score I'm currently running ITV-22's while I'm in between tuning solutions at the moment. I am currently still on stock tune and boost and it runs fine.
__________________ 2008 Cosmic Blue Mica Mazdaspeed 3. BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob. To be installed: SS Brake Lines. |
![]() Join Date: Feb 2011 Location: Waterford,CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,169
Groans: 423
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts |
| The Following User Says Thank You to smoogs12 For This Useful Post: | Truguy86 (04-03-2017) |
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
| Display Modes | |
| Spark Plug Database - Colder Than Stock ( Stage 1&2 ) | Haltech | MazdaSpeed 3/6 - ECU Computer Tuning | 74 | 08-02-2019 08:18 AM |
| Spark Plug Database - Gen2 | Haltech | 2010 MS3 - Engine, Transmission & Driveline | 23 | 09-27-2017 05:09 PM |
| Spark Plug Database - Colder Than Stock ( Stage 1&2 ) | Haltech | MazdaSpeed 6 - Engine, Transmission & Driveline | 41 | 05-05-2016 08:49 AM |
| Spark Plug Database - Gen2 | Haltech | 2010 MS3 - ECU Computer Tuning | 3 | 02-27-2016 04:53 PM |
| Spark Plug Database - Colder Than Stock ( Stage 1&2 ) | Haltech | MazdaSpeed 3 - Engine, Transmission & Driveline | 205 | 09-22-2015 06:52 PM |
