![]() Join Date: Nov 2010 Location: rockledge fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,125
(Thread Starter) | Not Ranked : 0 score Made this thread per @Raider; request, in order to help future searchers. Firstly, in order to properly time the engine you will need the timing plate and peg for the 2.3 disi mzr. you can buy one. i purchased this one since it was the best bang for my buck and i know i will use it more than once. @Pseudonym; found this kit which is complete and reasonably priced. In order to do the timing chain you will need the following parts to do the vvt you will need to add the following parts the parts with part numbers need to be replaced. they are one use, torque to yield items, but cannot be found in the diagrams, so you will need to search the part numbers.
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) ![]() |
![]() Join Date: Dec 2009 Location: San Antonio, TX
Rep Power: 5050 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,143
Groans: 146
| Not Ranked : 0 score I know this is in 3/6 land, but the parts are identical for the 6 and Gen1 3? Meaning, these parts are for both models? |
![]() Join Date: Sep 2011 Location: St. Johns, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,014
Groans: 56
| Not Ranked : 0 score Thanks for this; may come in handy in the future.
__________________ 2008.5 CWP: GTX 3071//Rapebuilt EM//Relentless pnp IM//JBR 3.5" WP//TurboXS DP/RP//TR8C/Cobb FMIC//GFS bpv//JBR 88/70/70a//Eibach Pro Kit//Koni Yellows//JBR RSB//RX8's Awaiting Install: DO Stage 2//3 Bar MAP//CPe Safeseals Winter Beater: 96 GMC K1500 5 speed 4x4 Needed: Driver mod [SIGPIC][/SIGPIC] |
Tapatalking
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) ![]() | |
| Not Ranked : 0 score Stuck! |
| Not Ranked : 0 score I just picked up my Speed6 yesterday from a TC/VVT job. Thought I'd add an actual invoice just to verify the list above. There are a few extra things on here that don't need to be part of a core do it yourself kit.
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | xfeejayx (01-27-2015) |
Groans: 146
| Not Ranked : 0 score how the shit did u pull that off on warranty? |
| Not Ranked : 0 score SSP87 baby! Gotta love it!
![]() Join Date: Mar 2010 Location: Des Plaines, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 297
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score "7 years or 70,000, which ever comes first" Fuck i'm at 78xxx
__________________ '06 Mazdaspeed6 Sport | LPM MODS: COBB SF | COBB TIP | SURE RMM | CXRacing FMIC | M2 DP | NGK Laser Iridiums | Magnaflow CB | COBB AP Stg 2 SF+TIH+IC 93 | Autotech FP Internals | JBR SSP, SSB, and Heavy Knob | EBC Ultimax Rotors | EBC Red Stuff Pads | Plastidipped Grill | 20% Tint all around 50% Windshield I'm SO stock it HURTS |
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Not Ranked : 0 score guess ill stock out if i start gettn the rattles
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
(Thread Starter) | Not Ranked : 0 score No reason, it's regular maintenance. Not expensive or hard to do yourself. Took me 4 hours dicking around. Probably could do it in two. Tapatalking
Groans: 128
| Not Ranked : 0 score still 3-400$$
(Thread Starter) | Not Ranked : 0 score If you think that's too much to maintain a car you should be riding a bike. You can't even get tires for less than that. Tapatalking
Groans: 128
| Not Ranked : 0 score if I can get it done for free its just stupid not to.
![]() Join Date: Jun 2008 Location: Faairport NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 205
| Not Ranked : 0 score Called my dealership last fall before i put the car up. I am at 74k. They said they would prorate the job. They all know my car has seen the track and was modded day two. The chain is very loose and i wont drive again till thats sorted. Maybe i will do it myself when my buddy gets home in spring. But like you say. because i have the bulletin on my fridge, if i can get done for free why wouldn't I ? |
| Not Ranked : 0 score Who wants to help me fix my shit? I'm near Des Plaines, IL... I'm a retard when it comes to mechanical things
| Not Ranked : 0 score Is there a NATOR for IL? That's the group you wanna get beer for to be sure
| Not Ranked : 0 score Yea there is! Haha just thought this was the appropriate thread
![]() Join Date: Sep 2012 Location: Buffalo ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score Where did you purchase these parts? |
| Not Ranked : 0 score /there is a guy in VIP we go through. |
![]() Join Date: Oct 2012 Location: San Antonio, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 72
Groaned at 8 Times in 5 Posts
| Not Ranked : 0 score I just placed an order. Thanks for the list. It was super easy to follow. My local dealership confirmed that my VVT and timing chain are bad and said that they have never done one for under $1,200. I was also told that they can not pro rate for warranty work since I have 84xxx miles.
__________________ Power: Corksport FMIC, TMIC location intake, TIP, Cobb AP, FP internals Suspension: Mazdaspeed coil-overs, Whiteline lower control arm bushings, StreetUnit side motor mounts Braking: front>Centric drilled & slotted rotors, Porterfield R4-S front brake pads, Wearever blank rotors, Wearever Gold ceramic pads <rear |
![]() Join Date: Oct 2012 Location: Aurora Ontario Canada
Rep Power: 0 ![]() ![]() Thanks: 2
Groaned at 9 Times in 4 Posts
| Not Ranked : 0 score Have to get this done for a buddy of mine... So thanks for the list Sent from my SGH-I747M using Tapatalk 2 |
![]() Join Date: Mar 2010 Location: Grand Rapids, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,370
| Not Ranked : 0 score Just picked mine up today. $1349.71. No chance to wait to do it later.
__________________ Funkster777 2010 Black Cherry Metallic Mazda 6 DD (well as needed) ![]() 2006 Black Mica Mazdaspeed6 Sport ![]() Originally fixed by IL NATOR. Rear Diff, TC, & PS cooler replaced due to MI NATOR. Rebuilding a MS6 one part at a time.Performance: GTX3076r~Molnar rods~Wiseco pistons~Grimm EBCS~3-bar MAP~Autotech Internals~HTP 3.5" intake~GFB BPV~TR8 intercooler w/2.5" piping~Cobb AP v3~Freak Tune in progress (need to quit breaking things)~eBay catless DP~CS CBE~JBR RMM~ACT HD 6 puck sprung w/prolite~JBR SSP & weight~TWM Stage 2 SS w/BB & boot~Maisonvi Shift Knob~AE Tower Strut Bar~Rear Interior Brace~CP-e Rear Diff mount~Replacement Rear Diff & TC, MD PS cooler, CS Front & Rear Sway Bar~H&R Springs~Bilstein HD shocks~SS brake lines~FI Grounding Kit~EBC Yellows~Potenza RE970AS Exterior: 6000k HIDs low beams~8000k HIDs fog lights~Luminics Ultra White Bulb high beams~HD lip~Speedline Emblemless Grill~Blacked out rear emblems~Smoked Rear & Side Markers with LEDs~15% back & windshield top tint~35% front~Sharkfin Antenna~Tower II LEDs for parking lights~CAR-LED tails Interior: UV & purple LEDs~Blackvue DR400G-HD~Escort Redline up high w/mute~NeoPro Link iPod Connection~ProSport Premium Boost Gauge w/Vent Dual gauge pod Waiting to Install/ Buy: SS clutch, oil pressure gauge, CP-e EWG setup/ Wheels (likely)?, Summer tires?, EVO Brembos?, Meth setup-5/6th port? [SIGPIC][/SIGPIC] |
![]() | | #24 | ![]() |
![]() Join Date: Feb 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score What do you guys think of this sound? vvt? i just bought the car, first mazda. I come from diesels so hearing this out of a car just doesnt sound right to me. watcha think? |
![]() | | #25 | ![]() |
__________________ Funkster777 2010 Black Cherry Metallic Mazda 6 DD (well as needed) ![]() 2006 Black Mica Mazdaspeed6 Sport ![]() Originally fixed by IL NATOR. Rear Diff, TC, & PS cooler replaced due to MI NATOR. Rebuilding a MS6 one part at a time.Performance: GTX3076r~Molnar rods~Wiseco pistons~Grimm EBCS~3-bar MAP~Autotech Internals~HTP 3.5" intake~GFB BPV~TR8 intercooler w/2.5" piping~Cobb AP v3~Freak Tune in progress (need to quit breaking things)~eBay catless DP~CS CBE~JBR RMM~ACT HD 6 puck sprung w/prolite~JBR SSP & weight~TWM Stage 2 SS w/BB & boot~Maisonvi Shift Knob~AE Tower Strut Bar~Rear Interior Brace~CP-e Rear Diff mount~Replacement Rear Diff & TC, MD PS cooler, CS Front & Rear Sway Bar~H&R Springs~Bilstein HD shocks~SS brake lines~FI Grounding Kit~EBC Yellows~Potenza RE970AS Exterior: 6000k HIDs low beams~8000k HIDs fog lights~Luminics Ultra White Bulb high beams~HD lip~Speedline Emblemless Grill~Blacked out rear emblems~Smoked Rear & Side Markers with LEDs~15% back & windshield top tint~35% front~Sharkfin Antenna~Tower II LEDs for parking lights~CAR-LED tails Interior: UV & purple LEDs~Blackvue DR400G-HD~Escort Redline up high w/mute~NeoPro Link iPod Connection~ProSport Premium Boost Gauge w/Vent Dual gauge pod Waiting to Install/ Buy: SS clutch, oil pressure gauge, CP-e EWG setup/ Wheels (likely)?, Summer tires?, EVO Brembos?, Meth setup-5/6th port? [SIGPIC][/SIGPIC] | |
![]() | | #26 | ![]() |
Tapatalking
![]() | | #27 | ![]() |
| Not Ranked : 0 score haha it was the vvt, i got it replaced last week. no warenty im at 120k |
![]() | | #28 | ![]() |
![]() Join Date: Mar 2012 Location: Burnsville, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 215
| Not Ranked : 0 score Thanks for the list. I've put about a good 40 hrs of tool time on my buddies msp I think it's time to repay it
__________________ SOLD - 2007 Mazdaspeed3 210k Current - 2007 Mazdaspeed6 |
![]() | | #29 | ![]() |
![]() Join Date: Feb 2013 Location: Brookfield, Ct
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 98
| Not Ranked : 0 score what website is the op screenshot from? |
![]() | | #30 | ![]() |
| Not Ranked : 0 score does this look complete? |
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score Onlinemazdaparts.com
![]() | | #32 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 315
__________________ 304whp/360tq Vdyno 1.01 CF Cobb AP, Sure 3" Full3 Aeros Intake, Autotech Internals, M2 DP, 3" CP-E Single Exit (w/resonator), 3.25" ETS, PnP'ed IM w/VTCS removed, 1/16"Sure TIG spacer Synapse BPV, AWR 70 Duro RMM, JBR 70 Duro TMM, Denso 1-Step Colder Plugs, TWM Shifter Bushings, SM OCC, Custom Shift Knob, Custom Shifter Weight, SURE Shorcut, H&R Springs, Tenzo DC-6 Wheels | |
![]() | | #33 | ![]() |
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
![]() | | #34 | ![]() |
| Not Ranked : 0 score Well either way, its a nice option and thank you very much for youre list.
![]() | | #35 | ![]() |
| Not Ranked : 0 score I think I'd pick up a new chain tensioner as well, but otherwise the kit does seem complete- nice find!
![]() | | #36 | ![]() |
![]() Join Date: Nov 2010 Location: Kaunas, Lithuania
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 144
| Not Ranked : 0 score I'd so prefer my buy list to get shorter than longer lol |
![]() | | #37 | ![]() |
![]() Join Date: Aug 2012 Location: Hartland, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,583
Groans: 42
| Not Ranked : 0 score EDIT: Meant to post this in NATOR WI Boards. FML. Pulled the valve cover today to investigate the rattle that I hear on part throttle. Timing chain is stretched. Check out the wear marks on the valve cover. What sucks is that I have a roadtrip next week to New Jersey and we are taking the Speed. Planned on tackling this myself after the road trip with the help of @Opdahl; and his air tools. Should cost around $400. Now I need to take it in sometime next week to Mazda and they quoted me $650 just for labor. And the coup d' grace: |
![]() | | #38 | ![]() |
__________________ '06 Mazdaspeed6 Sport | LPM MODS: COBB SF | COBB TIP | SURE RMM | CXRacing FMIC | M2 DP | NGK Laser Iridiums | Magnaflow CB | COBB AP Stg 2 SF+TIH+IC 93 | Autotech FP Internals | JBR SSP, SSB, and Heavy Knob | EBC Ultimax Rotors | EBC Red Stuff Pads | Plastidipped Grill | 20% Tint all around 50% Windshield I'm SO stock it HURTS | |
![]() | | #39 | ![]() |
![]() Join Date: Sep 2011 Location: SCOTLAND
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 469
| Not Ranked : 0 score Is it best to order these parts from onlinemazdaparts?
__________________ Cpe tmic&sri, 3" HTP tip, 3" ebay downpipe, BNR stage1, Autotech internals, Snow stage 2 meth with Aqaumist jet/parts, GoFastBits Respons BOV, Grimmspeed ebcs 3-port, Turbinetech diff mount, Cpe diff brace, Whiteline rarb, Bilstein B8's, Eibach springs, NGK iridium IX plugs, Corksport Mods, JBR mods... 324whp 361lb/ft Tuned with by |
![]() | | #40 | ![]() |
Groans: 42
| Not Ranked : 0 score Check eBay for complete VVT replacement kits. |
| Display Modes | |
| Timing chain/VVT replacement parts list | chuckms6 | Mazdaspeed3/6 General Discussion | 103 | 05-16-2019 05:38 PM |
| Timing Chain Replacement | FluffySheepBoy | MazdaSpeed 6 - Engine, Transmission & Driveline | 2 | 01-26-2014 08:00 PM |
| timing chain and vvt replacement | mikecrpntr | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 11-15-2013 04:21 PM |
