 Old 04-09-2011, 06:22 PM   #1
indianaryan's Avatar
Posts: 496   (View Stats)
Groans: 39
Originally Posted by xsilent13x View Post
I think when the ECU sees the fuel pressure goes down it adds more fuel to protect itself explaining the richness. I think I read this somewhere.....I'll try and dig it up again.
Yes I've read that also. What confuses me is that it added a bunch fuel before the fp drop.
2010 Silver Mazdaspeed3
indianaryan is offline
 Old 04-09-2011, 07:25 PM   #2
Nataphen's Avatar
Posts: 2,704   (View Stats)
Try changing your load table AFRs and see if that helps. I haven't had this problem, so I wonder if the boost tune is still leaning on the load tables somewhat. I have raised my load AFRs, and I haven't encountered a problem. Since the ECU is designed around load tuning, it may be contradicting your OL fueling table targets. I changed mine from ~1.40 calculated load to 12.00 to match my OL fueling targets. Be safe, but give it a shot and see what happens.
EDIT: Sorry about seeming redundant there. I'd had a few beers last night and I was trying to make sure that I got my point across. Now that I look at it today, it looks like I'm trying to explain something to a down's syndrome kid.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
Nataphen is offline
 Old 04-11-2011, 08:28 AM   #3
I think that Nate may be right on target here. I have seen a big spike in afr (turns ultra rich totally ignoring the max enrichment table) when my calculated load differs from my load in the throttle required - x gear normal bat tables.
I know I am like a broken record, but they are supposed to be within .05 what is seen in atr in your logs.
FWIW, I've been adjusting my wgdc tables, and nearing the load targets (more boost) seen in atr in my logs.
Mine is / was way worse than yours probably is @indianryan , btw.
The boost on the stage 2 tune comes in way sooner than a stage 1 tune, and imo, my wgdc's are way off. It could be that I am still running the stock airbox that compounds the problem, although it is a stage 2 tune for the stock airbox.
rfinkle2 is offline
 Old 04-11-2011, 08:42 AM   #4
Groans: 39
Alright thanks. I appreciate the help. I'll try changing the load AFR's and see what happens.
Thanks. I'll take a look at the load tables and see if they're far off. I don't what to do if they're off lol, but I'll look into it. You know, it seems like when the fuel pressure drops, it's when I'm going up an on-ramp or uphill. I wonder if that has anything to do with it.
 Old 01-15-2012, 10:22 PM   #5
ms3j's Avatar
Posts: 26   (View Stats)
ms3j has a spectacular aura aboutms3j has a spectacular aura aboutms3j has a spectacular aura about
i just installed autotech internal, i have a cobb tih sri
my noob question is can i run a stage 2 map with out a dp
thanks for the help
ms3j is offline
 Old 01-15-2012, 10:36 PM   #6
TriO's Avatar
Posts: 676   (View Stats)
TriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the world
Think you need atleast a test pipe before running stage 2.
TriO is offline
 Old 01-17-2012, 08:55 PM   #7
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
403whp/451ft/lb Dry Shot
Bucker is offline
 Old 07-21-2012, 04:46 PM   #8
Illusion's Avatar
Posts: 123   (View Stats)
Illusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant future
Groaned at 34 Times in 12 Posts
well the way i see it $350 for an upgraded fuel pump is a pretty good deal it also gives you peace of mind that you know you can mod it safely to your hearts content.
Illusion is offline
 Old 09-19-2012, 02:05 PM   #9
708
Erich's Avatar
Posts: 4,274   (View Stats)
Discuss here:
http://www.mazdaspeedforum.org/forum/foru...closely-69969/
2 years after hitting 700hp and still running strong. Happy to see others joining the club.
Erich is offline
 Old 03-17-2011, 12:48 PM   #10
dizzydtrain's Avatar
Posts: 2,476   (View Stats)
Groans: 64
When we first looked @ this (dizzy, Indian Ryan etc.), although I didn't want to jump to conclusions, I was afraid this was going to happen.
Did you mention to CP-E that others are running the same map, with Autotech Internals, and maintaining good pressure?
I had a feeling that when Christian didn't reply to the second request on the specific log (datalog #4), that their was an issue that somehow needs resolving.
I did mention it but I have not received a response regarding that yet. I guess this leaves me somewhat stranded for the time being until I can somehow get a replacement or upgrade my medium pressure fuel pump with some autotech internals...
dizzydtrain is offline
 Old 03-17-2011, 12:52 PM   #11
What really sucks is I sent my pump in with 2,000 miles on it, shining and new, and have a "medium pressure" , lets say greater than 2,000 mile fuel pump.
You go on the record as coining the phrase "medium pressure fuel pump". LOL!
rfinkle2 is offline
 Old 03-17-2011, 12:57 PM   #12
Groans: 39
I'm a fan of CP-E because they put out quality products. What I don't understand is what makes their pump any better than the stock pump in this situation, and why can't they back their product when it obviously isn't doing what it was meant for?
I assume there are others that have had no issues with the CP-E HPFP, so maybe there is a valid explanation for it not holding the fp above 1600 psi in Dizzy's situation. But I don't think it's fair for CP-E to only guarantee that it will keep the fp above 1600 psi ONLY for a stock tune.
I guess it is possible that there is a problem with Cobb's map. I'll stay tuned and hope that either CP-E or Cobb comes up with an answer.
 Old 03-17-2011, 01:02 PM   #13
Indianryan, I am just shooting my opinions out there...
I don't know what flashing to the stock map does in CP-E's favor, given CP-E knows why we purchased these pumps, and that certainly was not to run the stock map.
CP-E, Cobb and Ecutek are the only companies yet to crack this ECU (or bother), and surely they know the ECU's behavior @ stock and more agressive tuning levels.
rfinkle2 is offline
 Old 03-17-2011, 01:08 PM   #14
Groans: 39
Agreed.
The stage1 is hardly an aggressive tune, which makes me wonder how far the CP-E pump was actually designed to go...
It's hard not to jump to conclusions at this point, but maybe there's more to this than what we know now.
 Old 03-17-2011, 01:12 PM   #15
Agreed.
What bugs me is the willingness of Christian to alter the tune (@ least offer suggestive help), and the perception I get of Cp-e's answer to Dizzy.
The first thing Christian / Cobb wants to do is help correct the problem, where as the first thing Cp-e does is blame Cobb (albeit indirectly).
rfinkle2 is offline
 Old 03-17-2011, 01:19 PM   #16
Groans: 64
Agreed.
I agree, I have not been able to find any other instances of fuel pressure dropping with the cp-e pump which really puts me in a bind. It's actually ironic at this point because the reliability and quality of this product makes it very tough to proof any faults (if in fact there are any).
 Old 03-17-2011, 01:45 PM   #17
Sorry to double post, but the ability of the pump to maintain the target psi is just as important as not dropping into the 1400's.
I am interested in how the ecu acts, what the effects on afr targets are etc. if the pump falls below the ap's targets Christian posted in the last page of this thread. (very close to the ~1700 range @ all points wot. )
rfinkle2 is offline
2010+ Mazdaspeed 3, I recommend to monitor your fuel pumps closely Nataphen 2010 MS3 - Fuel, Nitrous & Water Injection 508 07-06-2013 11:44 AM
Fuel Pumps - Gen 1 & Gen 2 MS3&MS6 whitewater 2010 MS3 - Fuel, Nitrous & Water Injection 6 05-24-2012 02:43 AM
recommend me a fuel pump (08ms3) blue_train MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 2 01-05-2012 03:09 PM
If Fuel Pumps are necessary, why no TSB? Silver Ecstasy 2010 MS3 - Fuel, Nitrous & Water Injection 52 09-07-2011 07:19 PM
Cp-e or PTP fuel pumps? manelscout4life MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 99 06-09-2010 05:32 PM
Page generated in 0.57050 seconds with 29 queries
