![]() Join Date: Apr 2008 Location: Utah
Rep Power: 573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 120
(Thread Starter) | Not Ranked : 0 score Cobb recently released the ability to change the targeted fuel pressure in the ECU. Silverdemon and PTP are both working on upgraded fuel rail pressure relief valves which will allow us to run higher pressures with out hitting the stock valve which opens at ~1875 psi The problem now is the stock high pressure fuel sensor maxes out at ~140 BAR or 2030 psi. So if your fuel pressure goes higher than this, the ECU cannot correctly measure fuel pressure which it uses to calculate the proper injector duty cycle, causing it to run super rich. I did some looking around on our forum and someone pointed out an identical sensor that reads 250 BAR but it uses a different connector though other than that it is physically the same. I made some calls and a complete plug and play adapter harness can be made so the upgraded sensor can be used without hacking into the stock wiring harness! All we need now is the ability to rescale for the higher reading sensor via reflashing the ECU (Cobb Accessport) or piggyback (CP-e Standback). Stock 140 BAR Sensor Bosch Part Number: 0261545006 Upgraded 250 BAR Sensor Bosch Part Number: 0265005303 I also found out that same upgraded bosch sensor is already used on a Mercedes Benz vehicle with the part number of 0025400917 Attached are the Bosch datasheets in .PDF for both the stock and 250 bar sensors. (REFER TO NEW DRAWINGS BELOW FOR WIRING) New Information from JumpingJackson I have been working with BMotorsports, you can now order a preassembled adapter harness from them http://www.bmotorsports.com/shop/pro...oducts_id/2118 SUPERSKATERS TESTING: i just purchased my sensor today from here All European search for the Mercedes PN or u can use the Bosch PN. make sure you tell them you saw it online to get the $122 price. i ordered the harness from here. it was free because you can ask to view "samples" of the products. www.te.com i also found the connector for the stock harness so you can make this 100% PNP. (note the first 3 parts in the list are put together in a "kit" which is what the last item is) incase you cant see the PN's they are in order: CONN-11555 CONN-10555 CONN-56057 CONN-75598p HERE IS HOW YOU NEED TO WIRE THIS BECAUSE THE DATA SHEET IS WRONG!!!!!!! PNP Harness: Please note the picture below is not wired correctly because i took it before i figured out the wiring was backwards. If you want to refer to it just swap the position of the yellow and blue wires ON THE SENSOR SIDE OF THE HARNESS INSTALL: I Also found it is EXTREMELY easy to swap the sensor out when your ready to do this. You dont need to remove anything at all!!! you will need a deep 24mm (for the new sensor) and deep 27mm (for the stock sensor) socket to get these out. i bought them at pepboys for a total of like 13 bucks. all you need to do is put them on a swivel and there should be plenty of room in there to slip it over the sensor (after you have unclipped the harness of course) and get them out. I did not use thread sealant on the threads because i was swapping sensors so often for testing that i just forgot about it but there is a taper on the end of the sensor which is really whats doing the sealing. Also you only need very little torque to get this thing tight and to seal good. something like 5-10 ft-lbs at MOST. |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
| Not Ranked : 0 score im in.. how much?
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
(Thread Starter) | Not Ranked : 0 score Harness would be 25-50$ for 1 at a time. If we could get a group buy im sure we could get better pricing. Im not sure how much the sensor is going to be.. I would assume getting it as the Mercedes Benz part would be ass-rape. The same company that would be making the harnesses is checking on the price for the sensor for me as well.
__________________ 2006 Titanium Gray MS6 Mods: DCR - Built Longblock with Pauter Rods , Wiseco 8.9:1 Pistons, Stiffer Valvesprings, P&P Head Upgraded VVT Actuator Cobb AccessPort + 3 Bar Map Sensor CP-E TIP , RMM Aquamist HFS-4 WMI Injection System Bullseye - T3 .55AR S259 Turbo Synapse - BOV Custom - Ceramic Coated T3 Exhaust Manifold , 3" T3 Downpipe, 3"-2.5" Dual Catback Exhaust, 3" MAF SRI, FMIC PT-P CDFP + Walbro 255 Intank Pump + Fuelabs Adj. FPR + -6 AN Feed/Return Turbine Tech / Street Unit - Front & Rear Diff Mount eDesign Audio - NINe.2x 760W AMP , 2x 11Kv.2 10" Subwoofers |
| Not Ranked : 0 score but this item is useless until we get some ecu support from cobb or cpe?
(Thread Starter) | Not Ranked : 0 score Thats correct, until its supported there is no use for it. (it wont work properly until they can rescale it) I suspect with a piggyback it could be done fairly easy. Someone with a standback should call CP-e and ask.
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45885 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,982
| Not Ranked : 0 score In actual operation it would appear that the ECU is capable of reading 2073.9 off of the stock sensor. This is what I was able to log on my car using two different stock sensors (on both the dashsaq and the AP. The AP would only display 2030, but the logs would show 2073.9). I believe SSInstaller indicated that when logging through his SB, he can get readings much higher off the stock sensor (2100+ and he had seen others higher.) |
![]() Join Date: Dec 2009 Location: Denver, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29,434
Groans: 40
| Not Ranked : 0 score This item is useless until we get a High Pressure Release Valve (which is being working on) since the stock valve opens at 1850psi. Once we have the upgraded unit available then we would need this.
__________________ | Steedspeed Top Mount Mani | Precision BB 5857 | Perm Tuning 3.5" Intake | Perm Tuning 2 Piece DP | Perm Tuning PCV Plate and Vented Catch Can | Mishimoto Catch Can | Weisco Pistons | Pauter Rods | AWR Tranny Mount | CP-e RMM | Turbinetech FMM | Turbinetech FDM | CP-e RDM | CX Racing FMIC | TWR Short Shifter | JBR SSP | AP w/ Base Map | BLOWN MOTOR | | 1974 Nova | SBC 350 | TH350 | Weiand Team G | Edelbrock 1406 | Aluminum 4 Core Radiator | Pro Comp HEI Distributor | |
(Thread Starter) | Not Ranked : 0 score Yes I noted that in my original post. Also, i sent an email to to Christian @ Cobb. He put in a request to add that functionality to rescale the sensor.
Groans: 40
| Not Ranked : 0 score I swear I read everything in the OP, apparently I skipped the third and forth lines haha
![]() Join Date: Aug 2009 Location: Trevose, PA
Rep Power: 7488 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,940
Groans: 224
| Not Ranked : 0 score Subbed for win.
__________________ MS3 has been retired to daily duty Project 1G; 1991 Eagle Talon TSi. 63MM Borg Warner Powered, Corn-Fed, 2.4L Long Rod Monster Under Construction Stock Turbo-Stock Engine Grand Champion of the World! 501WHP & 569WTQ (PERM Tuned, 93 OCTANE PUMP GAS K04 W/N2O!!) NATOR PA |
![]() Join Date: May 2009 Location: Little Neck, NY
Rep Power: 3771 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,108
Groans: 326
| Not Ranked : 0 score this is excellent has anyone done any testing to see how these higher pressures will effect injector longevity? |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
Groans: 105
| Not Ranked : 0 score doesn't anyone work at napa that could buy these for us at a discount? alternatively, if they are available at like autozone - you can order a few of them and use the ubiquitous 20% off coupons. what MB vehicle are these used on? |
| Not Ranked : 0 score You don't necessarily haaave to have sensor scaling to make it work.. You could just tell the ecu to target much lower pressure with ATR.
![]() ![]() Join Date: Jun 2009 Location: PDX
Rep Power: 5715 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,677
Groans: 90
| Not Ranked : 0 score i'm feeling a little dense right now, since i haven't driven my car in a week i think i'm losing touch lol... how is it that on some logs, people have shown fuel pressure spikes of 2100+ psi if the sensor only reads up to ~2030 psi? Or is this a separate sensor?
__________________ ![]() [SIGPIC][/SIGPIC] |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Not Ranked : 0 score this is great |
| Not Ranked : 0 score Were those logs from standbacks? Based on SSInstaller's responses in my thread I think the sensor it self is capable of reading higher pressures, but for some reason the ECU is clamped at 2073.9. |
| Not Ranked : 0 score The 2030 psi # is probably speculation, dunno where it was chosen from. My guess is it'll read closer to 2100+. Someone could simply put 5 volts on the sensor line and see what # they get on a DH for fuel pressure, and call that the stock sensor limit. Here's some data points i took a while back:
(Thread Starter) | Not Ranked : 0 score According to the data sheet, the sensor clamps its output at 4.5V
| Not Ranked : 0 score Link to datasheet?
(Thread Starter) | Not Ranked : 0 score Post #1
| Not Ranked : 0 score derp derp lol.
| Not Ranked : 0 score Shit this looks easy. Thanks for the leg work Phil. I'll be ordering one very soon to play with ![]() sorry for not reading the op lol. Sometimes i just skim at work cause i'm so fucking busy.
![]() | | #24 | ![]() |
| Not Ranked : 0 score |
![]() | | #25 | ![]() |
| Not Ranked : 0 score its intercepting the signal, not interpreting it from the ecu amiright?
![]() | | #26 | ![]() |
Groans: 40
| Not Ranked : 0 score Maybe the ECU is programmed to limit what it reads. That would make since due to the fact that in an un modded car, it would most likely never see anything higher than that.
![]() | | #27 | ![]() |
| Not Ranked : 0 score Yeah, that is kind of what I was trying to get at. It would seem as if the ECU isn't using the full range as provided by the sensor. Maybe Mazda figured ~10% above the crack pressure of the RV was sufficient to account for in their programming? |
![]() | | #28 | ![]() |
Groans: 60
O=max range, U=min range The upper range for sensor output is 4.8v... Which should be around 160bar or ~2350psi... I think the sensor limit seen by the ap and dahdaq is just a PID limitation, in normal operation a value greater than ~2000psi would never need to be displayed... Just like the AP boost display limitation that was just fixed with the NEW AP.. Regardless, great job finding this sensor.. As soon as we geat an upgraded rail valve this thing will be very useful... with both data sheets it'll be easy to adjust the FP with both the AP or the SB to account for the extra sensor range...
The SB intercepts the signal directly from the sensor, the AP , DH, and dashdaq, read the ECM output via the canbus..
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | ||
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score I wonder if internally the ECU can understand 4.8V but the OBD2 PID is clamped at 4.5V, Much like before Cobb fixed the 3 bar map sensor support, the ECU could read the sensor fine if you altered the settings in ATR, just the OBD2 PID's werent working properly.
![]() | | #30 | ![]() |
| Not Ranked : 0 score sounds plausible to me but who just said that the AFR goes way rich when you hit peak pressure?
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score Your not taking into account all possibilities A. Sensor is putting out somewhere imbetween 4.5V and 4.8V causing the OBD2 PID to display incorrectly but internally for fueling calculations the ECU still reads it fine. B. Sensor is putting out somewhere imbetween 4.5V and 4.8V causing the OBD2 PID to display incorrectly AND the ECU doesnt like anything north of 4.5V causing it to run rich. C. Sensor is maxed out at 4.8V which will definatly cause the ECU to run rich. So depending on how high your fuel pressure is you could run into one of those cases.
![]() | | #32 | ![]() |
| Not Ranked : 0 score Ahh a ressurection of my original infos from the original rail pressure thread. The stock sensor reads 2300+ net psi. It is bolt on, and its around $350 iirc. Pressure Sensor Fluid PSS-250R This sensor is designed to measure the pressure of media in relation to the ambient pressure (e.g. Diesel, gasoline, water, engine oil, transmission oil or air). The sensor is available for two different supply voltage ranges. The sensor uses stainless steel measuring cells with piezo-resistive measuring bridges in thin layer technique, which are hermetically welded together with stainless steel pressure ports. This guarantees a complete media compatibility. The main benefit of this sensor is the high quality of a production part at a low price. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~ Application Application 0 … 250 bar (r) Pressure Reference Type relative Max. Pressure 500 bar Operating Temp. Range [1] -40 … 125 °C (140 °C) [2] -40 … 125 °C Media Temp. Range [1] -40 … 125 °C (140 °C) [2] -40 … 125 °C Storage Temp. Range -20 … 50 °C Bio fuel compatibility - Max. Vibration 100 m/s2 rms @ 10 … 2,000 Hz ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Electrical Data: Power Supply US [1] 4.75 … 5.25 V [2] 8 ... 30 V Max Power Supply Us max ± 30 V Full Scale Output UA [1] 10 … 90 % US ratiometric [2] 0.5 … 4.5 V non-ratiometric Current IS 8 mA ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~ Mechanical Data Male Thread M10x1 Wrench Size 17 mm Installation torque 15 Nm Weight w/o Cable 45 g Sealing O-ring 7.65 x 1.63 mm Characteristic Response Time T10/90 [1] 1.5 ms [2] 1.0 ms Compensated Range 0 … 90 °C Tolerance (FS) @ US = 5 V ± 0,1 bar Tolerance (FS) ± 1 % Sensitivity: [1] 16 mV/bar @ US = 5 V [2] 16 mV/bar Offset: [1] 500 mV @ US = 5 V [2] 500 mV ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~ Connectors and Wires Connector Bosch Compact Mating connector [1] D 261 205 339 [2] D 261 205 334 Pin 1 GND Pin 2 SIG Pin 3 US Pin 4 - Pin 5 - Sleeve DR-25 Wire size AWG 24 Wire length L 13 … 95 cm Various motorsport and automotive connectors are available on request. Please specify the required wire length with your order. Part Number: PSS-250R [1] B 261 209 965-01 PSS-250R [2] B 261 209 067-01
![]() | | #33 | ![]() |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Well, speaking of possibilities, here's an important one to consider: D. Sensor is maxed out at either 4.5v or 4.8V (either one), but the ECU is commanding higher pressure yet.... and fuel rail explodes. This is a legitimate concern with a maxed out sensor. And even if there has to be some level of "intentional fudging" of target pressures to use the new valve... at least it prevents a clipped sensor. intentional fudging would be targeting like 900psi at wot with the new sensor, cause you know that the voltage corresponding to 900psi = 2100 psi in real life, or something to that effect. Oh, and IIRC sumark had a 12 volt line shorted to the fuel pressure sensor, and his ecu reported up to like 6500 psi or something ridiculous like that. So, afaik, there's no limit to the ECU's interpretation or reporting of fuel pressure. Lemme see if i can find some posts from when that happened to him.
![]() | | #35 | ![]() |
| Driver ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1986 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,158
Groans: 44
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- | |
![]() | | #36 | ![]() |
| Not Ranked : 0 score Thats good, cause i can't find any logs, pm's, email's or posts stating it specifically... lol
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score Was that a dashhawk/obd2 reading 9000 psi or a standback? Remember just because the standback reads 12V as 9000 PSI doesnt mean the stock ECU does. 06speed6 does that sensor fit our rail? Because the one i linked is indentical. That one looks quite a bit different
![]() | | #38 | ![]() |
| Not Ranked : 0 score IIRC it was DH, but shit... those memories were in the cobweb part of my brain. Easy enough to check though, i'll try to do it some time after the holidays.
![]() | | #39 | ![]() |
| Not Ranked : 0 score this thread is pure win...its fun to set back and watch the gears turning in you guys' heads..
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 |
![]() | | #40 | ![]() |
| Not Ranked : 0 score ha i answered a question before ssinstaller... can i be in the msf smartypants club? keep that brain juice flowing
| Display Modes | |
| Fuel Rail High Pressure Sensor Upgrade | JumpingJackson | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 234 | 10-25-2014 01:54 AM |
| Possible Fuel Rail Pressure sensor failure? | AFcadet | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 0 | 07-06-2012 04:17 PM |
| fuel rail pressure sensor | Skup1993 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 3 | 02-05-2011 09:14 PM |
| where can i find a mazdaspeed 3 fuel rail pressure sensor? | Skup1993 | MazdaSpeed 6 - Engine, Transmission & Driveline | 8 | 02-05-2011 08:29 PM |
