View Poll Results: What color would you prefer, or think is best?
Black 13 46.43%
Gold 9 32.14%
NCE cant see it 6 21.43%
Voters: 28. You may not vote on this poll
Like Tree13Likes
  • 6 Post By Matt@DamondMotorsports
  • 2 Post By Farhan@DM
  • 1 Post By Micha
  • 2 Post By neganox
  • 2 Post By neganox
 Old 09-23-2015, 02:54 PM   #1
Name is longer than yours
Posts: 209   (View Stats)
Default Damond Motorsports PCV plate
We're happy to announce that we're coming out with a PCV plate soon. Along with a whole mess of OCC and dual OCC options, so you can crank your case til there's no oil left.
Key features:
-Main thing with our PCV plate is that it can use an OEM PCV valve. We designed the PCV valve port to the exact dimensions of the OEM PCV box, allowing for a perfect fitment of the factory PCV valve and o-ring. The main reason to use a PCV valve is to meter the amount of air pulled from the crankcase under vacuum, keeping it as a sustained level, especially under WOT to closed throttle transitions and engine braking, where manifold vacuum is at its highest.
-OEM Gasket, you can reuse yours, or opt to have one included
-Two 3/8" NPT ports for fittings, plugs, checkvalves
-Anodized with engraved DM logo
Price is TBA, but it won't break the bank. And there will be options, to add a PCV valve or use the one you have, plugs, fittings, gaskets, checkvalves, whatevs.
I'm going to be working on a full blog/forum post on different PCV and OCC configurations, and updating the ones I have, so keep an eye out for that.
We're getting them anodized, and we'd like to hear y'all's opinion on what color you'd prefer or feel looks best. Hence the poll.
The Following 17 Users Say Thank You to Matt@DamondMotorsports For This Useful Post:
5doorsoffury (09-23-2015), CMajor (09-23-2015), Code Monkey (09-23-2015), davychronic (09-24-2015), g00s3y (09-23-2015), Justin@Freektune (09-25-2015), lolwrx (09-23-2015), macdiesel (09-23-2015), Mauro_Penguin (09-23-2015), Micha (09-26-2015), MS3Shadow (09-23-2015), nekret (09-24-2015), Poohster (09-29-2015), sho (09-23-2015), SpeedRebirth (09-23-2015), Turbo_Steve (09-23-2015), WetzMS3 (09-23-2015)
 Old 09-23-2015, 03:38 PM   #2
Ginger Red.
It'll be sexy in any color man!
macdiesel (09-23-2015), monkey.bones.007 (09-23-2015)
 Old 09-23-2015, 03:44 PM   #3
Gold or Blue would be nice.
I was looking into a dual OCC from you.
sent from my HTC One M9
xfeejayx (09-23-2015)
 Old 09-23-2015, 06:42 PM   #4
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
I'm so glad I've not bought a perm plate yet.
tapatalk, it sucks
 Old 09-23-2015, 07:52 PM   #5
Mauro_Penguin's Avatar
Posts: 1,997   (View Stats)
Groans: 171
As long as it's cheaper than the damn perm plate.
I'm glad you're going to be able to put to use all the data you've gathered on the PCV system over the years.
You haven't found any problems with the PCV valve binding or getting stuck while being sideways?
 Old 09-23-2015, 07:59 PM   #6
BrownBear
Farhan@DM's Avatar
Posts: 241   (View Stats)
Have had one running for months. No issues thus far.
Mauro_Penguin and WetzMS3 like this.
The Following 4 Users Say Thank You to Farhan@DM For This Useful Post:
Mauro_Penguin (09-23-2015), monkey.bones.007 (09-23-2015), MS3Shadow (09-23-2015), WetzMS3 (09-24-2015)
 Old 09-23-2015, 09:21 PM   #7
macdiesel's Avatar
Posts: 825   (View Stats)
Can't not offer gold.
 Old 09-24-2015, 08:02 AM   #8
Feline Führer
neganox's Avatar
Posts: 1,790   (View Stats)
This is how I'm planning on running the plate I have now.
How would one utilize a 3rd port on the new plate?
 Old 09-24-2015, 08:22 AM   #9
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
How do you plan on preventing the intake leak that will happen then you route the hose from intake to vta can?
neganox (09-24-2015)
 Old 09-24-2015, 08:25 AM   #10
Feline Führer
neganox's Avatar
Theres a checkvalve under the breather on the can. Forgot to draw that in. Good catch!
Easter Bunny (09-24-2015), jdmage_mx5 (09-24-2015), Mauro_Penguin (09-24-2015), MS3Shadow (09-24-2015), WetzMS3 (09-28-2015)
 Old 09-24-2015, 08:29 AM   #11
nekret's Avatar
Posts: 421   (View Stats)
nekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the world
Black please!
2011 Mazdaspeed3 non-tech package
Drivetrain
CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune
Chassis
JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace
Rice
LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers
nekret is offline   Reply With Quote
 Old 09-25-2015, 10:01 AM   #12
UnknownReagent's Avatar
Posts: 26   (View Stats)
UnknownReagent is a name known to allUnknownReagent is a name known to allUnknownReagent is a name known to allUnknownReagent is a name known to allUnknownReagent is a name known to allUnknownReagent is a name known to all
I think black is the obvious choice, but using the same gold as the mounts would be nice, if you're going to offer options.
UnknownReagent is offline   Reply With Quote
 Old 09-25-2015, 11:02 AM   #13
Yeah we're going to do both. It doesn't matter all too much what color it is, cause it's hardly visible.
 Old 09-26-2015, 12:42 PM   #14
Micha's Avatar
Posts: 3,436   (View Stats)
PINK!!!
Easter Bunny likes this.
The Following 3 Users Say Thank You to Micha For This Useful Post:
Easter Bunny (09-28-2015), neganox (09-26-2015), WetzMS3 (09-28-2015)
 Old 09-26-2015, 01:01 PM   #15
superman's Avatar
Posts: 288   (View Stats)
superman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond repute
Black. Looking forward to seeing the occ setups you have in the works
Sent from my ONE A2005 using Tapatalk
Power: Powered by Purple Drank, BNRS3, JBR 3.5, Grimspeed EBCS, 3-bar map, CP-e FMIC, Autotech HPFP, Forge V2 BPV, VTCS delete, DM OCC, Empire water pump pulley, BSD, JBR pan baffle, ebay downpipe, CP-e CBE, NGK step colder plugs, TIGs, CP-E Safe seals, DM EGR delete, etc. Handling: Eibach prokit, SPC camber arms, RX8 wheels, 235/40/18, Goodridge Stainless brake lines, EBC redstuff, mazda 5 rear brakes, Custom mid chasis brace, WR front strut brace, TB traction bar, TB trunk brace, JBR rear sway bar, Moog links, DM RMM, OEM poly filled PMM, CS TMM insert, JBR solid shifter bushings, AP shift hammer, Other: Android Stereo running torque pro, MZ style lip, Corksport LED lights, HIDs, lots of other random stuff
superman is offline   Reply With Quote
The Following User Says Thank You to superman For This Useful Post:
BeastlyZoomZoom (09-15-2016)
 Old 09-28-2015, 11:03 AM   #16
Feline Führer
neganox's Avatar
HEY. You answer my question right meow.
 Old 09-28-2015, 11:32 AM   #17
Easter Bunny (09-28-2015), Mauro_Penguin (09-28-2015), MS3Shadow (09-29-2015)
 Old 09-28-2015, 11:35 AM   #18
Feline Führer
neganox's Avatar
WetzMS3 and MS3Shadow like this.
 Old 09-28-2015, 11:40 AM   #19
 Old 09-29-2015, 08:24 AM   #20
BrownBear
Farhan@DM's Avatar
There are multiple answers to this, and how you use it is completely up to you.
We consider the stock PCV valve as a way to meter air, in addition to it's function as a check valve. We generally don't like a wide open path from the crankcase to an IM under relatively high vacuum. Therefore, the recommendation would be to utilize the normal function of the PCV valve and system, and use an additional port for added venting. You've then effectively addressed crankcase venting issues in boost, and in vacuum.
There do exist the minority for whom that isn't enough venting. They will see benefit from a third port. You don't need a valve cover breather, a new hole in the valve cover, or any other added port. It's already there. If desired, put a check valve on it, and run a hose to wherever you want to vent it.
Of course, for those who prefer the PCV valve left out, the plate can be the normal, dual vent plate.
All the options, fittings, etc. will be available with this.
IMASA (09-29-2015), Mauro_Penguin (09-29-2015), MS3Shadow (09-29-2015), neganox (09-29-2015)
 Old 09-29-2015, 08:56 AM   #21
Feline Führer
neganox's Avatar
Soooo.
monkey.bones.007 (09-29-2015), Speed3Pedro (05-21-2016)
 Old 09-29-2015, 09:20 AM   #22
BrownBear
Farhan@DM's Avatar
Soooo.
I may, or may not have made this suggestion to a test car.
Remember that some/most/all drag strips will frown on what might result from that.
Mauro_Penguin (09-29-2015), monkey.bones.007 (09-29-2015), MS3Shadow (09-29-2015), neganox (09-29-2015)
 Old 09-29-2015, 10:46 AM   #23
Feline Führer
neganox's Avatar
INB4 DM names this product "Spy Hunter Mode"
Mauro_Penguin (09-29-2015), monkey.bones.007 (09-29-2015), MS3Shadow (09-29-2015), WetzMS3 (09-29-2015), Yatta (09-29-2015)
Damond Motorsports MS3 PMM Matt@DamondMotorsports Damond Motorsports 141 10-16-2019 05:40 AM
Damond Motorsports - What the f*ck? ItsNox Damond Motorsports 3 12-02-2014 12:31 PM
Welcome Damond Motorsports Haltech Damond Motorsports 46 08-25-2013 09:56 AM
Page generated in 0.44345 seconds with 33 queries
