Like Tree46Likes
 Old 09-25-2014, 08:21 AM   #1
BrownBear
Farhan@DM's Avatar
Posts: 241   (View Stats)
Default Damond Motorsports TB Meth Injection spacer
Need a nice clean setup to inject additional fluid into your air stream? Don't want to tap pipes on your car? Look no further.
The Damond Motorsports Throttle Body Spacer has 6 1/8" NPT ports to hook up whatever you want to inject right before the intake manifold. It sandwiches between your throttle body and intake manifold and allows you to thread in multiple nozzles, lines, or injectors for as much as 800 hp of fuel! The spacer comes with all the hardware you need for an easy install, including bolts, washers, and all the plugs you'll need.
Pricing:
$69 no gaskets
$79 1 OEM TB gasket
$94 2 OEM TB gaskets
USPS Priority shipping is included in the USA 48.
http://damondmotorsports.com/product...-ports-pre-buy
This spacer uses a stock throttle body gasket on each side, so you need 2 total. Please select the option you need for additional gaskets. Supplied gaskets will be OEM gaskets.
Will work with stock TMIC on Mazdaspeed 3 2007-2013 and Mazdaspeed 6 2007. You will need to trim the cold side boost tube 16mm.
Will NOT work with Mazdaspeed6 stock cold pipe.
Injectors and/or nozzles are not included.
Shown with Coolingmist injection nozzles (not included).
Last edited by Matt@DamondMotorsports; 10-28-2014 at 03:34 PM. Reason: add pictarz!
The Following 51 Users Say Thank You to Farhan@DM For This Useful Post:
Agent_Orange (09-25-2014), Alpha (09-25-2014), Bob-o (09-25-2014), breakfstincluded (09-25-2014), Cheapspeed (09-27-2014), Cyclops (09-25-2014), dereeek (09-25-2014), Easter Bunny (09-25-2014), franz (09-25-2014), fredricktsang (09-28-2014), Funkster777 (10-16-2014), gdawg25 (09-25-2014), Gr8Speed (09-25-2014), Hammology (09-25-2014), Hargarbl (09-25-2014), helmetface (09-27-2014), jack_hammer (09-26-2014), JgamB (09-26-2014), joeyspeed3 (09-25-2014), Justin@Freektune (09-25-2014), Kyle Undefined (10-09-2014), LatinKraze (09-25-2014), magicka (09-25-2014), Matt@DamondMotorsports (09-25-2014), Mauro_Penguin (09-26-2014), memin (09-28-2014), Micha (09-25-2014), Mike@Stratified (09-25-2014), Mistersix (10-18-2014), mituc (10-14-2014), ms6mil (09-25-2014), naoandlater (09-25-2014), PapaSmurf (09-25-2014), Poohster (09-27-2014), rfinkle2 (09-25-2014), robertof (09-30-2014), Sergeant_M (10-09-2014), shadesofgray19 (09-25-2014), silvapain (09-28-2014), speed3 britz (09-26-2014), SpeedRebirth (09-25-2014), Swinger13 (09-27-2014), taf0422 (09-25-2014), The Nut (10-09-2014), TiGraySpeed6 (09-25-2014), Vader (09-25-2014), VegasChef (12-07-2014), Voltwings (09-25-2014), WetzMS3 (09-25-2014), YABBAMZR (10-18-2014), [R]usty (09-25-2014)
 Old 09-25-2014, 10:11 AM   #2
lnumbp's Avatar
Posts: 178   (View Stats)
lnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the world
Way cool! Is there a rubber o-ring gasket on both sides of the spacer?
lnumbp is offline   Reply With Quote
 Old 09-25-2014, 10:17 AM   #3
BrownBear
Farhan@DM's Avatar
There is not. The stock gasket is used on both sides. One will be provided with the kit for under $80 total.
The Following User Says Thank You to Farhan@DM For This Useful Post:
lnumbp (09-25-2014)
 Old 09-25-2014, 10:30 AM   #4
Sebs6's Avatar
Posts: 201   (View Stats)
Sebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the world
Any time frame?? Around went is gonna be released.
Sebs6 is offline   Reply With Quote
 Old 09-25-2014, 11:52 AM   #5
BrownBear
Farhan@DM's Avatar
Best case, shipping in 1-2 weeks.
If beta testers find problems, that moves out. We will not release a product that we and our beta testers are not happy with, so please be patient if it comes to that. We're confident in an October release even with a redesign, if needed.
The Following 6 Users Say Thank You to Farhan@DM For This Useful Post:
Easter Bunny (09-25-2014), JgamB (09-27-2014), kbz0129 (09-25-2014), Mauro_Penguin (09-26-2014), Poohster (09-27-2014), WetzMS3 (09-25-2014)
 Old 09-25-2014, 12:04 PM   #6
Novej's Avatar
Posts: 354   (View Stats)
Novej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the world
Can you get it with a single nozzle?
2007 Mazdaspeed 3 400.32whp 375.14wtq (STD) BNR STAGE 3 Stratified by Lex
Of all the military achievements I've accomplished my first 10 years of service (made MSGT/E-7 at age 29), the one that makes me most proud is simply being able to serve my country during her darkest hour...NEVER FORGET those who made the ultimate sacrifice doing the same....I SALUTE ALL OUR FALLEN
Novej is offline   Reply With Quote
 Old 09-25-2014, 12:09 PM   #7
BrownBear
Farhan@DM's Avatar
Nozzles are not included. You can run 1 to 4 nozzles of your choosing. Plugs will be provided for the other ports you don't use.
rfinkle2, Mauro_Penguin and Ms3544 like this.
The Following 18 Users Say Thank You to Farhan@DM For This Useful Post:
Chuthor (09-25-2014), Code Monkey (09-25-2014), Easter Bunny (09-25-2014), Gr8Speed (09-25-2014), Hammology (09-25-2014), impossible (02-25-2016), Justin@Freektune (09-25-2014), kbz0129 (09-25-2014), Mauro_Penguin (09-26-2014), memin (09-28-2014), Novej (09-25-2014), Poohster (09-27-2014), rfinkle2 (09-25-2014), Sergeant_M (10-09-2014), silvapain (09-28-2014), The Nut (10-09-2014), WetzMS3 (09-25-2014), Yatta (09-25-2014)
 Old 09-25-2014, 12:15 PM   #8
PUGENE, WetzMS3 and Farhan@DM like this.
The Following 10 Users Say Thank You to rfinkle2 For This Useful Post:
Chuthor (09-25-2014), Easter Bunny (09-25-2014), Farhan@DM (09-25-2014), Gr8Speed (09-25-2014), Jtaylor (09-25-2014), Mauro_Penguin (09-26-2014), Micha (09-25-2014), PUGENE (10-23-2014), silvapain (09-28-2014), WetzMS3 (09-25-2014)
 Old 09-25-2014, 12:29 PM   #9
[R]usty's Avatar
Posts: 2,204   (View Stats)
I think I speak for everyone when i say...
Ms3544 likes this.
2010 Mazdaspeed3 w/tech
The Following 5 Users Say Thank You to [R]usty For This Useful Post:
Chuthor (09-25-2014), Farhan@DM (09-25-2014), Jtaylor (09-25-2014), Pointless (10-08-2014), rfinkle2 (09-25-2014)
 Old 09-25-2014, 12:42 PM   #10
Micha (09-25-2014), rfinkle2 (09-25-2014)
 Old 09-25-2014, 03:56 PM   #11
Novej's Avatar
Sorry I didn't mean nozzles I meant the pre drilled holes for the nozzles. Nevertheless you answered my question so thank you If its not too early go a head and put me down for the first batch when we can order them!..............I'm serious!
The Following 2 Users Say Thank You to Novej For This Useful Post:
Farhan@DM (09-26-2014), rfinkle2 (09-25-2014)
 Old 09-25-2014, 04:55 PM   #12
kbz0129's Avatar
Posts: 986   (View Stats)
Damn, 4 nozzles!
2010 Ms3 PD Tuned
2006 Ms6 GT-Stock
 Old 09-25-2014, 07:15 PM   #13
cciepunk's Avatar
Posts: 181   (View Stats)
cciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the world
Groaned at 43 Times in 42 Posts
Just another product I need to buy from DM.
cciepunk is offline   Reply With Quote
The Following 2 Users Say Thank You to cciepunk For This Useful Post:
 Old 09-25-2014, 07:33 PM   #14
chapdawg's Avatar
Posts: 291   (View Stats)
chapdawg has a reputation beyond reputechapdawg has a reputation beyond reputechapdawg has a reputation beyond reputechapdawg has a reputation beyond reputechapdawg has a reputation beyond reputechapdawg has a reputation beyond reputechapdawg has a reputation beyond reputechapdawg has a reputation beyond reputechapdawg has a reputation beyond reputechapdawg has a reputation beyond reputechapdawg has a reputation beyond repute
Groaned at 4 Times in 1 Post
i need to get on this beta tester list… its nice to see companies breathing life back into the platform
2011 CBM Speed 3 // Turbosmart Dual port BOV // KMD HPFP internals // CNT 3" Catless downpipe // CorkSport StageII Intake // Cobb AP V2 - FREEKTUNE //
chapdawg is offline   Reply With Quote
The Following 2 Users Say Thank You to chapdawg For This Useful Post:
Alpha (09-25-2014), Farhan@DM (09-26-2014)
 Old 09-25-2014, 08:21 PM   #15
Alpha's Avatar
Posts: 3,711   (View Stats)
Mmmm.... This + EFR + Aquamist =
WetzMS3 (09-27-2014)
 Old 09-25-2014, 09:51 PM   #16
LatinKraze's Avatar
Posts: 804   (View Stats)
Make this spacer for Bosch injectors
2016 CX-5 GT AWD
 Old 09-25-2014, 10:43 PM   #17
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
Would this work with a TMIC? Or is it designed to be used with a FMIC?
 Old 09-27-2014, 08:11 AM   #18
This fits on the stock manifold and easily works with TMIC.
Ask me how I know
Farhan@DM (09-29-2014), twenty5psi (09-28-2014)
 Old 09-27-2014, 08:57 AM   #19
Poohster's Avatar
Posts: 353   (View Stats)
Poohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the world
I guess that all hardware includes longer bolts for installation? Just asking. Great product!
06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP
RPM: Sport Springs, Shark Fin, LED side markers
CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount
Poohster is offline   Reply With Quote
 Old 09-27-2014, 09:04 AM   #20
Ask me how I know
How do you know?
Micha (10-01-2014), WetzMS3 (10-17-2014)
 Old 09-27-2014, 10:00 AM   #21
How do you know?
Farhan@DM likes this.
The Following 7 Users Say Thank You to WetzMS3 For This Useful Post:
Darth_Nuruodo (09-28-2014), Easter Bunny (09-27-2014), Farhan@DM (09-27-2014), memin (09-28-2014), Micha (10-01-2014), ms6mil (09-27-2014), [R]usty (09-30-2014)
 Old 09-27-2014, 03:09 PM   #22
BrownBear
Farhan@DM's Avatar
Update.
With stock manifold and tmic, you're able to use the two ports facing down, or at least one port facing up depending on your nozzle setup. It was evident that bottom or top + side ports couldn't be used with stock mating parts. So we're doing the sensible thing and adding 2 more ports on a third side. You'll be able to get 2 down + 1 or 2 up on stock mating parts, and the side if you have aftermarket manifold (and the TB rotated).
We're sticking with the price we committed to.
rfinkle2 and WetzMS3 like this.
The Following 12 Users Say Thank You to Farhan@DM For This Useful Post:
cshunter (09-27-2014), Easter Bunny (09-28-2014), Funkster777 (10-16-2014), Hammology (09-27-2014), jack_hammer (09-27-2014), memin (09-28-2014), Micha (10-01-2014), ms6mil (09-27-2014), Pointless (10-08-2014), rfinkle2 (09-28-2014), WetzMS3 (09-27-2014), [R]usty (09-30-2014)
 Old 09-27-2014, 03:38 PM   #23
Poohster's Avatar
I have a MS6 2006 cold pipe that wraps to the TB. How is the fitment? I can't be certain, but the space between the TB and the cold pipe may not be much. Thanks.
The Following User Says Thank You to Poohster For This Useful Post:
 Old 09-27-2014, 03:42 PM   #24
BrownBear
Farhan@DM's Avatar
Sorry, you'll need a new cold pipe and boost tube.
 Old 09-27-2014, 04:17 PM   #25
BrownBear
Farhan@DM's Avatar
Prebuy is on! Come get some.
Mazdaspeed 3/6 TB spacer with injection ports PRE-BUY | Damond Motorsports
The Following 9 Users Say Thank You to Farhan@DM For This Useful Post:
Chuthor (09-27-2014), Easter Bunny (09-28-2014), JgamB (09-28-2014), Matt@DamondMotorsports (09-28-2014), ms6mil (09-28-2014), rfinkle2 (09-28-2014), sidekick (09-27-2014), WetzMS3 (09-28-2014), [R]usty (09-30-2014)
 Old 09-27-2014, 04:28 PM   #26
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
paypal sent can't wait.
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
The Following User Says Thank You to ms6mil For This Useful Post:
 Old 09-28-2014, 03:13 PM   #27
Putin 2.3T's Avatar
Posts: 1,040   (View Stats)
Ordered. Can't wait for release.
2011 Mazdaspeed 3 [Sold]
 Old 09-28-2014, 06:22 PM   #28
Easter Bunny (09-28-2014), Farhan@DM (09-28-2014), Matt@DamondMotorsports (09-28-2014), WetzMS3 (09-28-2014)
 Old 09-28-2014, 06:55 PM   #29
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
damn, 6 ports? Just curious, why so many?
 Old 09-28-2014, 06:59 PM   #30
Because all of the meths!!! Right @rfinkle2;???
Mostly for mounting options and flexibility depending on the setup
Easter Bunny (09-28-2014), Farhan@DM (09-29-2014), Matt@DamondMotorsports (09-28-2014), rfinkle2 (09-28-2014), silvapain (09-28-2014)
 Old 09-29-2014, 12:09 AM   #31
shane5747's Avatar
Posts: 74   (View Stats)
shane5747 has a reputation beyond reputeshane5747 has a reputation beyond reputeshane5747 has a reputation beyond reputeshane5747 has a reputation beyond reputeshane5747 has a reputation beyond reputeshane5747 has a reputation beyond reputeshane5747 has a reputation beyond reputeshane5747 has a reputation beyond reputeshane5747 has a reputation beyond reputeshane5747 has a reputation beyond reputeshane5747 has a reputation beyond repute
Pre-Order placed. I've been waiting for something like this. I really did not want to drill in to my cobb coldpipe, or add a tap in the silicone.
2013 LSM Mazdaspeed3 Non-Tech
Currently Installed:
| JBR WidePath 3.5" Intake | JBR Coolant Bypass & EGR Delete | JBR Shift Weight | JBR RMM 88dm | Cobb APV2 | Cobb 3Port EBCS | Ebay Catless DP | Corksport CBE | JBR OCC S2 | HKS SSQV4 | Autotech Internals | NGK Step Colder Plugs | Cobb FMIC | 3-BAR MAP Sensor | DNP Turbo Manifold | ATP GT3076R | Tial 38mm EWG |
Next In Line:
| Build a motor fund for gofasts |
shane5747 is offline   Reply With Quote
The Following User Says Thank You to shane5747 For This Useful Post:
Farhan@DM (09-30-2014)
 Old 10-06-2014, 08:56 PM   #32
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
I was wondering if something like this existed... looks good!
 Old 10-08-2014, 06:16 PM   #33
ms6mil's Avatar
Groans: 307
@Farhan@DM; Any word on a ship date yet? the suspense is killing me!!!
rfinkle2 and Farhan@DM like this.
PTE5862 - TBD
The Following 4 Users Say Thank You to ms6mil For This Useful Post:
Easter Bunny (10-08-2014), Matt@DamondMotorsports (10-08-2014), rfinkle2 (10-17-2014), WetzMS3 (10-09-2014)
 Old 10-08-2014, 06:33 PM   #34
BrownBear
Farhan@DM's Avatar
All I'm promising is by month end, but realistically will probably be around the 24th. I want to make sure the function is solid as well as the form.
The Following 3 Users Say Thank You to Farhan@DM For This Useful Post:
Matt@DamondMotorsports (10-08-2014), ms6mil (10-08-2014), SpeedRebirth (10-08-2014)
 Old 10-08-2014, 06:40 PM   #35
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
I'll be buying one even though i don't have a WMI system Getting this spacer will push me to actually buy one
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
The Following 2 Users Say Thank You to SpeedRebirth For This Useful Post:
Farhan@DM (10-08-2014), rfinkle2 (10-17-2014)
 Old 10-08-2014, 06:46 PM   #36
BrownBear
Farhan@DM's Avatar
You and me both.
Get your order in soon. Hopefully we'll guess right at how many extra we should get, but no guarantees if you don't preorder.
The Following 2 Users Say Thank You to Farhan@DM For This Useful Post:
rfinkle2 (10-17-2014), SpeedRebirth (10-08-2014)
 Old 10-08-2014, 09:00 PM   #37
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
You and me both.
Is this a one time order for you guys? Or just saying you'll probably sell out and have to wait for the next order to be cut?
it's fun to do bad things
The Following User Says Thank You to jack_hammer For This Useful Post:
Farhan@DM (10-09-2014)
 Old 10-08-2014, 09:47 PM   #38
tikous360's Avatar
Posts: 182   (View Stats)
there's any gain on use this without WMI, just as a TB spacer?
 Old 10-08-2014, 10:37 PM   #39
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
I can't see the original picture for some reason, but is there any chance you'd be selling it with a TB TIG? Seems like a good opportunity for people to install a TB tig since the TB has to come out.
tapatalkin
 Old 10-08-2014, 10:43 PM   #40
Name is longer than yours
Posts: 209   (View Stats)
The later, more or less. We do plan on always stocking them though.
TB spacers on carbureted and TBI cars can help to mix the air and fuel mixture. On a EFI port or, in our cases, direct injected engine, they have no real effect. It adds a little bit of plenum volume, but it's so small it's insignificant.
It'll add to the butt dyno though, so in that sense, you should buy one
The Following 6 Users Say Thank You to Matt@DamondMotorsports For This Useful Post:
Easter Bunny (10-09-2014), Farhan@DM (10-09-2014), Kyle Undefined (10-09-2014), mr.speedy3 (10-09-2014), rfinkle2 (10-17-2014), tikous360 (10-09-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f661/damond-motorsports-tb-meth-injection-spacer-177745/
Meth injection throttle body spacers This thread Pingback 09-25-2014 03:23 PM
Damond Motorsports MS3 PMM Matt@DamondMotorsports Damond Motorsports 141 10-16-2019 05:40 AM
Introducing the all new Damond Motorsports OCC Matt@DamondMotorsports Damond Motorsports 85 08-10-2015 07:24 PM
Damond Motorsports OCC V1 review Justus Damond Motorsports 5 10-15-2013 07:02 PM
Welcome Damond Motorsports Haltech Damond Motorsports 46 08-25-2013 09:56 AM
Page generated in 0.58275 seconds with 45 queries
