| Damond Motorsports Welcome to Damond Motorsports, home of Track Tested Driver Trusted performance products. We aim to specialize in reliability and power modifications, for the track and the street. Every product we offer has been put through many hours of both road course and street use, to insure excellent reliability and performance. |
![]() | | #121 | ![]() |
![]() Join Date: Jan 2013 Location: South Boston, MA
Rep Power: 1402 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,475
| Not Ranked : 0 score
__________________ 07 BLACK MICA MS3 PATTY/JEFF BUILT MOTOR BNRS3V2 349/344 VD 93 FREEKTUNE E25 382/375 GSD DynoJet 141020 STOCK BLOCK FREEK KORN TUNE 335whp/356wtq ENM 14 K04 ~ Ordnance, Droppn' Warheads of Foreheads Since 1922 ~ BOSTON STRONG | |
| The Following 3 Users Say Thank You to King Scumbag For This Useful Post: |
![]() | | #122 | ![]() |
![]() Join Date: Mar 2013 Location: North Brunswick, NJ
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,645
Groans: 143
| Not Ranked : 0 score Installation was relatively easy. Getting the bushing carrier into the base was a pain in the ass. Removing the shift cables were also a bit of a pain. And of course I broke the tabs on the lighter colored one trying to remove it. However, once I got the base bolted to the transmission and went to line up the bushing with the chassis bracket, I was pleasantly surprised to find that it lined up perfectly with a little pump of my jack (and the bolt slid right in). The fact that I have the Damond passenger and rear mounts combined with the fact that they hold so well was likely instrumental in making this part so easy. I was surprised when I drove the car that most of what I hear when I accelerate now is just engine noise, not transmission noise. When sitting at a light idling, you would never know the car is fully mounted. It is quite docile until you get it on the highway, then it drones like a motherfucker and the mirrors become useless (mostly the RMM IMO). But at least the constant, loud transmission whine is gone now. It's a much nicer place to live than before. I was very disappointed that my JBR mount was toast. When I went to remove the top nut, it was loose because it was no longer engaged against the top plate. The friction between the nut and the post was the only thing keeping the transmission in my car. To see that edge of the bushing completely obliterated and gone, considering how new it is...very disappointing. I should not have disregarded the warnings I saw on here so readily. Thanks to Farhan for making such a great product here that I know will keep everything both planted and driveable for many miles.
__________________ 2007 Mazdaspeed3 GT |
| The Following 10 Users Say Thank You to MD1032 For This Useful Post: | Deldran (11-02-2015), Easter Bunny (11-01-2015), Farhan@DM (11-01-2015), frothy (11-02-2015), JgamB (11-01-2015), littleloogy (11-01-2015), Matt@DamondMotorsports (11-02-2015), Mauro_Penguin (11-02-2015), MS3Shadow (11-01-2015), WetzMS3 (11-01-2015) |
![]() | | #123 | ![]() |
![]() Join Date: Mar 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46
__________________ 2008 MAZDASPEED3 Black Stratified Tuned / Stage 2 | |
![]() | | #124 | ![]() |
__________________ I hugged rfinkle2 | |
![]() | | #125 | ![]() |
Groans: 143
| Not Ranked : 0 score What's the point in that? The damage is shown clearly in the video, and there's plenty of other examples of the same type of damage out there. I'm not trying to start any drama, just providing information to try to steer people away from the JBR mount (and towards the DM). There weren't any clear signs that it was failing. As I said, it was a shock to find it in this state when I removed it. One other thing I forgot to mention about the Damond Motorsports mount is that my throwout bearing noise at idle is almost completely gone. Again it is just eerily quiet when sitting at a light with the Damond threesome, with no vibes or significant noise whatsoever (until you get moving). I continue to enjoy the reduction in gear noise as well. Overall I am very happy right now with the car. If my car was stock again, I would put this mount combination right behind a Cobb AP as my top priority mod. edit: As an addendum to the JBR mount problem: I am being sent new 80 durometer bushings from JBR. The official explanation is that I have too much power for the 70 durometer bushings.
__________________ 2007 Mazdaspeed3 GT Last edited by MD1032; 11-03-2015 at 02:11 PM. |
| The Following 2 Users Say Thank You to MD1032 For This Useful Post: | Matt@DamondMotorsports (11-02-2015), Mauro_Penguin (11-02-2015) |
![]() | | #126 | ![]() |
![]() | | #127 | ![]() |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
I recently raced my car at Pocono Raceway and it was 38*F. Still no difference.
__________________ www.tunedbynishan.com | |
| The Following 5 Users Say Thank You to ms3blackmica For This Useful Post: | Farhan@DM (11-02-2015), Matt@DamondMotorsports (11-02-2015), Mauro_Penguin (11-03-2015), MD1032 (11-02-2015), WetzMS3 (11-04-2015) |
![]() | | #128 | ![]() |
| Not Ranked : 0 score So i must pick these mount and change my Jbr dogbone rmm ??? isn't it ???
__________________ 2008 MAZDASPEED3 Black Stratified Tuned / Stage 2 Last edited by Atomic41; 11-03-2015 at 06:00 AM. |
![]() | | #129 | ![]() |
| BrownBear ![]() Join Date: Apr 2014
Rep Power: 632 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 468
| Not Ranked : 0 score You guys are too nice. Appreciate all the feedback.
__________________ |
| The Following 2 Users Say Thank You to Farhan@DM For This Useful Post: | Chuthor (11-15-2015), Matt@DamondMotorsports (11-03-2015) |
![]() | | #130 | ![]() |
![]() Join Date: May 2013 Location: CO
Rep Power: 2407 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,487
| Not Ranked : 0 score Everyone that has sat in my car in Colorado has forgotten I'm fully mounted until i remind them. That's how good they are. tapatalk, it sucks |
| The Following 4 Users Say Thank You to monkey.bones.007 For This Useful Post: | Mastermind46 (11-04-2015), Matt@DamondMotorsports (11-03-2015), Mauro_Penguin (11-03-2015), MD1032 (11-04-2015) |
![]() | | #131 | ![]() |
![]() Join Date: Mar 2013 Location: Woodland Park, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,456
__________________ 2010 Mazdaspeed 3 - TR8 - HTP Under Route - Custom Cold Side - CS TP - HTP 3.5" Intake - Cobb AP V3 - DM Full Motor Mount Set - Forge V2 BPV - Autotech Internals - JBR Solid Shifter Bushings - CS DP (terMINATOR style) - Custom CBE - Whiteline RSB - Koni Sports - Eibach Springs - SPC Camber Arms - StopTech SS Lines and Pads - ATE Fluid - 55W DDM Tuning 6000K Lows - JBR OCC - DM SSP - CS LED Fogs - Maisonvi EGR Delete - DM FoST Intake Manifold - BNR S4 IWG - Winter Beater/Exploration: 1998 Isuzu Rodeo Autocross: 1992 Miata | |
![]() | | #132 | ![]() |
| Not Ranked : 0 score |
| The Following User Says Thank You to monkey.bones.007 For This Useful Post: | Mastermind46 (11-04-2015) |
![]() | | #133 | ![]() |
| Not Ranked : 0 score We suck. I forgot to sit in your car last night... Haha. Next meet!
![]() | | #134 | ![]() |
![]() | | #135 | ![]() |
Groans: 189
| Not Ranked : 0 score Nope. Not a good comparison.
![]() | | #136 | ![]() |
![]() Join Date: Jun 2012 Location: Mesa, Arizona
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,244
| Not Ranked : 0 score Small update from me I had a jbr pmm, tmm and rmm all highest duro (also have a bsd) Swapped in DM tmm and pmm, and the results are absolutely amazing. The vibes are cut in half, if not more. And that was before breaking in the mounts. They're also holding the beating I'm giving them recently. Love the mounts. I say its a must for any DD racecars, especially with a bsd. tapatalkin
__________________ Fastest GTX3076r, T3 twinscroll, built block, D14 meth spraying gen1 on the internet! |
| The Following 3 Users Say Thank You to mr.speedy3 For This Useful Post: |
![]() | | #137 | ![]() |
| Not Ranked : 0 score So... I bought all three and currently have a jbr 88duro rmm installed. Are there any useful videos or testing left? A specific install order? Sent from my SM-G920V using Tapatalk
![]() | | #138 | ![]() |
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken | ||
| The Following User Says Thank You to MS3Shadow For This Useful Post: | Mauro_Penguin (11-30-2015) |
![]() | | #139 | ![]() |
| Not Ranked : 0 score I assumed that was for install lol Sent from my SM-G920V using Tapatalk
![]() | | #140 | ![]() |
![]() Join Date: Apr 2013 Location: GA
Rep Power: 0 ![]() ![]() Thanks: 18
| Not Ranked : 0 score Gen 1 and 2 TMM are the same?
__________________ JBR SRI // TIP // RMM 88 DURO // AT INTERNALS // AP V3 // STRATIFIED OTS STAGE 1 // NGK SPARK PLUGS // 50% 93 OCTANE 50% E-85 // H&R SPRINGS // SPC REAR CAMBER ARMS // 5000K DDM HID'S // 35% FRONT 15% REAR CERAMIC WINDOW TINTS // CPE TOW PLATE // ZAPTEK PAINT PROTECTION // |
![]() | | #141 | ![]() |
| They should be the same. Sent from my Pixel XL using Tapatalk
| The Following User Says Thank You to MS3Shadow For This Useful Post: | Farhan@DM (10-12-2017) |
| Display Modes | |
| Bag's 6 build diary | rtabagaboy | MazdaSpeed 3/6 - Build Diaries | 16 | 09-17-2016 02:04 AM |
| Dear diary... | udntknw | MazdaSpeed 3/6 - Build Diaries | 11 | 09-09-2015 07:36 PM |
| Diary Testing | sgtiger2 | 2010 MS3 - Build Diaries | 2 | 07-08-2012 06:21 PM |
