| Damond Motorsports Welcome to Damond Motorsports, home of Track Tested Driver Trusted performance products. We aim to specialize in reliability and power modifications, for the track and the street. Every product we offer has been put through many hours of both road course and street use, to insure excellent reliability and performance. |
![]() | | #41 | ![]() |
Groans: 793
| Not Ranked : 0 score
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
![]() | | #42 | ![]() |
![]() Join Date: Nov 2013 Location: Delaware
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 228
Groaned at 79 Times in 52 Posts
| Not Ranked : 0 score deleted
__________________ From Delaware Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo Last edited by KevinK2; 01-19-2014 at 11:32 AM. |
| The Following User Says NO Thank You to KevinK2 For This Un-useful Post: | Tokay444 (01-22-2014) |
![]() | | #43 | ![]() |
Groans: 793
| Not Ranked : 0 score i have never said there wasn't vacuum in the intake. that was you, contradicting YOURself.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals Last edited by Tokay444; 01-18-2014 at 07:20 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #44 | ![]() |
| Not Ranked : 0 score You win. I've deleted my posts dealing with you, I suggest you do the same, to keep Matt's great thread on topic.
__________________ From Delaware Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo |
![]() | | #45 | ![]() |
Groans: 793
| Not Ranked : 0 score Matt and myself are friends. if he needs them deleted, i will.
| The Following 3 Users Say Thank You to Tokay444 For This Useful Post: |
![]() | | #46 | ![]() |
| Not Ranked : 0 score You don't want to clean-up Matt's thread about vacuum/pressure measurements. So now some explanation is needed from me. 1) I admit that I caused confusion, when you mentioned putting the VC hose to the intake at the compressor. I took it literally, and talked about the boost control port on the boost side of the compressor, which was wrong. Sorry about that. 2) But before you made one comment/reply, I had made it clear that I thought vacuum in the upgraded intake/filter systems was not likely (#31). 3) But as I read it, you were not consistent about this:
4) Finally, on the later quotes from me that you posted (#43) :
In the first quote, I was saying no vacuum at the VC port, when under boost. In the second, I was talking about the boost control port (my mistake) having pressure in the "vacuum hose" going to the boost controller. .
__________________ From Delaware Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo | |||
![]() | | #47 | ![]() |
| Name is longer than yours ![]() Join Date: Mar 2013 Location: Chicago, IL
Rep Power: 785 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 709
(Thread Starter) | Not Ranked : 0 score I hope this will clear things up a bit, and I've been meaning to update the set-up I'm currently running. To answer your question Kevin... I think this is what you were asking. I did measure the vacuum pulled from a couple intakes during testing. This was at the port on an aftermarket Cobb SRI, a CS TIP, and an HTP full 3.5" intake. I don't believe I posted those reading, I have them in my notes... somewhere. Generally speaking though the intakes which had the PCV port closer to the turbo itself would pull a stronger vacuum as more air rushed in. Pressure/vacuum measured at the crankcase was done via an oil cap I modified. I'm looking to get better testing equipment to measure this, along with possibly tapping the breather box, it see if I can get a better reading from lower in the crankcase. I did have a couple customers run this set-up, with good results.
I've been running this on my car for 7k+ miles so far with no issues, but then again I'm only running 20psi of boost on a K04. I'll be testing this soon on @silvapain; BT MS3, and he has dip stick popping issues. I also have a customer who'll be trying on the CV on his VTA set-up. If this works out well, I'll start selling it as an add-on for ppl looking to modify their existing PCV box, and a kit for the Perm plate as well. Prices would be $25-30 plus shipping most likely. And just to confuse everyone, I have my manifold vacuum source to my OCC via the EGR port: | |
| The Following 7 Users Say Thank You to Matt@DamondMotorsports For This Useful Post: | atvfreek (01-20-2014), btstarcher (01-21-2014), himurax13 (01-21-2014), Hush (01-20-2014), KevinK2 (01-21-2014), silvapain (01-20-2014), torquemaniac (10-07-2016) |
![]() | | #48 | ![]() |
Groans: 793
I never said there wasn't any vacuum in the intake. YOU did. I was speaking TO YOU, and YOUR comment about there NOT being enough vacuum.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals | |
| The Following User Says Thank You to Tokay444 For This Useful Post: | Hammology (01-22-2014) |
![]() | | #49 | ![]() |
| Not Ranked : 0 score I just don't like getting that shit in my intake.
| The Following User Says Thank You to btstarcher For This Useful Post: | Matt@DamondMotorsports (01-22-2014) |
![]() | | #50 | ![]() |
![]() Join Date: Dec 2008 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
__________________ Eric Schlaht - Arizona Phoenix Photographer http://www.esimaging.net - http://www.facebook.com/esimaging [SIGPIC][/SIGPIC] 2007 MS3 Sport, gtx3071r, Full-Race Exhaust Manifold, SP PNP Intake Manifold, SP 88mm Pistons 9:5:1, Manley H Beam Rods, 10mm H11 Head Studs, ARP Main Studs, 4" HTP TIP + Small Battery Tray, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E Nexus CBE, Tokay Injector Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DIY Perm Plate with dual OCC, Corksport Radiator Shroud, Southbend Stage 3 Clutch, DO Stage 2 Meth D10, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **463whp/409lb-ft via Mustang Dyno as of 3/28/14** **9/19/13** Zoom Zoom Boom ** Currently Rebuilding with goal of 475whp **11/19/13** Forged engine built and started up the car for the first time, success! **3/28/14** Dyno results from build 463whp / 409lb-ft Mustang Dyno **6/24/15** Sold the Mazdaspeed 3 **7/4/15** Purchased 2015 F150 Ecoboost Lariat FX4 with Sport Package | |
| The Following User Says Thank You to Matrix311 For This Useful Post: | Matt@DamondMotorsports (01-22-2014) |
![]() | | #51 | ![]() |
![]() Join Date: May 2013 Location: Edmonton,AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 572
Groans: 46
Groaned at 37 Times in 19 Posts
| Not Ranked : 0 score I'm running the 2nd setup you mentioned with the exception of having the VC breather VTA. I get very little amounts of oil and crap in the occ every 1000 kms. And the filter on the breather spits out small amounts of oil all around it. I'm wondering whether my pcv valve is working properly or not since I'm not getting too much crap in the occ. or can my engine be that healthy? Any input is appreciated.
__________________ 06 Liquid Platinum GT COBB AP // 3" ID MAF // 3" HTP TIP // Ebay catless DP // Autotech FPI // DO DVC-30 w/D07 // Grimmspeed EBCS // FORGE V1 BPV // DM OCC // JBR SSP|TIGs|EGR- // SURE RMM|Juggernaught // CP-E TMIC|Rear Diff Mount // Whiteline RSB // ISC N1 Coilovers // 18x8 +45 TSW Nurburgring MisterSix Tuned.. vdyno: 287hp/335tq Uncorrected (2400ft ASL) 303hp/355tq Corrected |
| The Following User Says Thank You to 5LOWMS6 For This Useful Post: | Matt@DamondMotorsports (01-22-2014) |
![]() | | #52 | ![]() |
Your quote of my comment dopped the quotes of you that had been there. I"ll repeat those quotes with inconsistent answers you had given about vacuum in the intake: ~From my post #46 : 3) But as I read it, you were not consistent about this: Originally Posted by Tokay444 put the outlet of the vent right at the compressor housing. as boost increases, so will vacuum on that vent. (#34) Sooo vacuum is applied to the VC vent as boost rises. Thus vacuum must exist in the intake pipe, at the vent line connection? Originally Posted by Tokay444 vent being the valve cover vent, and it's outlet, being the end of the hose you patch into the intake. i'm speaking to you, saying there is no vacuum in the intake. (#39) So you say as boost increases there is vacuum at the VC vent. And you say there is no vacuum in the intake. Both can not be true. .
![]() | | #53 | ![]() |
![]() | | #54 | ![]() |
Groans: 46
Sent from my C6903 using Tapatalk
__________________ 06 Liquid Platinum GT COBB AP // 3" ID MAF // 3" HTP TIP // Ebay catless DP // Autotech FPI // DO DVC-30 w/D07 // Grimmspeed EBCS // FORGE V1 BPV // DM OCC // JBR SSP|TIGs|EGR- // SURE RMM|Juggernaught // CP-E TMIC|Rear Diff Mount // Whiteline RSB // ISC N1 Coilovers // 18x8 +45 TSW Nurburgring MisterSix Tuned.. vdyno: 287hp/335tq Uncorrected (2400ft ASL) 303hp/355tq Corrected | |
![]() | | #55 | ![]() |
Groans: 793
| Not Ranked : 0 score vent being the valve cover vent, and it's outlet, being the end of the hose you patch into the intake. i'm speaking to you, saying there is no vacuum in the intake. (#39) This right here, this was me speaking to YOU when YOU had asked who I was answering. Since no actual question was posed from you, I was not answering anything. I was speaking TO YOU about YOU saying there wasn't any vacuum in the intake. YOU said there wasn't. No me.
![]() | | #56 | ![]() |
![]() Join Date: Feb 2011 Location: florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 110
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score I have a similar concerns. So I modified the pcv plate from my back up motor and use a pcv from a Nissan 300 zx turbo tap into the intake. |
| The Following 4 Users Say Thank You to lito37 For This Useful Post: | btstarcher (01-21-2014), Matt@DamondMotorsports (01-22-2014), Mauro_Penguin (01-22-2014), redboat (03-14-2014) |
![]() | | #57 | ![]() |
| Not Ranked : 0 score I'm going to run a air pump out of a s10 as a vacuum pump with a pressure switch set at 2psi |
| The Following 3 Users Say Thank You to lito37 For This Useful Post: |
![]() | | #58 | ![]() |
| Not Ranked : 0 score Tokay, you also said this, which was not an answer to my prior question to Matt regarding his measurments.
__________________ From Delaware Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo Last edited by KevinK2; 01-21-2014 at 02:49 PM. | |
![]() | | #59 | ![]() |
| Not Ranked : 0 score What, why wouldn't it? Air is moving through the intake faster, ergo more vacuum.
| The Following 3 Users Say Thank You to btstarcher For This Useful Post: |
![]() | | #60 | ![]() |
| Not Ranked : 0 score I used a special vacuum gauge to measure the intake on the tracked Rx7, and after eliminating restrictions, the vacuum was negligable. You have a point though. Just need to do a bernulli calc for the change from static atmospheric (neglecting ram, worst case) and then high flow in the ~3.5" intake.
| The Following User Says Thank You to KevinK2 For This Useful Post: | btstarcher (01-21-2014) |
| The Following User Says NO Thank You to KevinK2 For This Un-useful Post: | Tokay444 (01-21-2014) |
![]() | | #61 | ![]() |
Now if you gut the PCV valve and turn it into an elbo (like Matt said) and use a CV, more flow is likely to the OCC. When you have standard PCV valve routing, you have IM vacuum at idle and at speed as well ... even when the turbo is producing low boost on the highway. The IM will show vacuum, but the charged pipe/hose has pressure, so you get that v8 feel on the highway, with instant boost at tip in, for stock or +1 turbo. .
| The Following 2 Users Say Thank You to KevinK2 For This Useful Post: | 5LOWMS6 (01-21-2014), btstarcher (01-21-2014) |
![]() | | #62 | ![]() |
Groans: 793
| Not Ranked : 0 score I stand by that statement.
| The Following User Says Thank You to Tokay444 For This Useful Post: | Matt@DamondMotorsports (01-22-2014) |
![]() | | #63 | ![]() |
![]() Join Date: Sep 2012 Location: West Palm Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 115
__________________ 2008 MS3 GT GTX//Relentless Customs//Voltron Approved//Nishan Tuned [SIGPIC][/SIGPIC] | |
| The Following User Says Thank You to mtosofsky For This Useful Post: | Matt@DamondMotorsports (01-22-2014) |
![]() | | #64 | ![]() |
(Thread Starter) | Not Ranked : 0 score The VC baffling does a pretty good job at this. Unless you have higher amounts of pressure in the crankcase. The main reason I use check valves in my kits, is to prevent BOOST from entering the crankcase, via the prone to leaking PCV valve. So on most applications it works well to keep pressure out of the crankcase, in turn keeping shit out of the intake. However, one you start upping the BOOOOOOOST, or have more blow-by(larger ring gap, worn rings, broken ringlands, holes in pistons, etc.) then you'll see more pressure in the crankcase, and in turn the intake may get a tad oily. My TIP is bone dry at 20psi... tehehe
http://i797.photobucket.com/albums/y...psb22cc64d.png
Most of what the OCC will capture is determined by your driving habits, and the temperature of your environment. Lots of WOT, you'll get more oil. Lots of light cursing and idling you'll get more condensation. In the cold, you'll collect more condensation. If your OCC isn't baffled, some of the oil, fuel, condensation may find it's way back in the intake. If you're using a low flowing check valve, or a secondary PCV valve, you way not be pulling a good enough vacuum to evacuate crankcase gasses.
The VTA valve and fittings too are bulky and huge since I used plastic components. | ||||
| The Following 2 Users Say Thank You to Matt@DamondMotorsports For This Useful Post: | btstarcher (01-22-2014), himurax13 (01-22-2014) |
![]() | | #65 | ![]() |
![]() | | #66 | ![]() |
| Not Ranked : 0 score Ye. But make sure you get the one from Napa part # 2-9303 it was $9.73 with tax. The one from Auto Zone and Discount auto leaks and to top it off when I try to explain it to the counter person he told me was nothing wrong with that. That way it was only 3.99. |
![]() | | #67 | ![]() |
I finally get it. Your sentence could have 2 meanings, as it is not correctly written. I confimed this with an english teacher I know. It could mean: i'm speaking .... saying there is no vacuum in the intake or i'm speaking to you, who is saying there is no vacuum in the intake I assumed the 1st version, you meant the 2nd version. Despute Closed. Cause of misunderstanding: Tokay's inability to write a sentence with correct grammer. But to answer your fowl mouthed bashes on my intellegence, you who could not write a correct sentence, feel free to challenge my knowledge on any mechanical subject in the car world or outside. As one example of MY work, I did the structural design of a light weight, aerodynamic, 3 spoked carbon fiber/epoy bicycle wheel that was used in many pro races. It was used in every time-trial that Lance Armstrong did in all his Tour-de-France victories. Even though I did the work in 1990, it was still used in the TDF bya recent winner .... Cadel Wiggens. Wiggen's TT Bike Hed-3 3 Spoke Wheel, aka Specialized tri-spoke wheel .
__________________ From Delaware Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo Last edited by KevinK2; 01-22-2014 at 12:36 PM. | |
| The Following 3 Users Say NO Thank You to KevinK2 For This Un-useful Post: |
![]() | | #68 | ![]() |
Groans: 793
| Not Ranked : 0 score You are clearly a fucking retard. I was about to get angry, since all you're doing is talking in circles with me, but it would be unbecoming of me to be upset at the mentally challenged. I stand by my post about vaulcuum increasing at the compressor inlet, as boost rises. I never stated there wasn't vacuum in the intake. That was you who stated that. I provided a contradictory statement to YOU about YOUR statement. I haven't on e contradicted myself. Only you. I'll reword this statement for you to better understand. You had asked "who are you answering?..." And I wrote Originally Posted by Tokay444 vent being the valve cover vent, and it's outlet, being the end of the hose you patch into the intake. i'm speaking to you, saying there is no vacuum in the intake. (#39) What I should have written was, "I'm answering you, even though you hadn't posed a question yet, regarding your statement that there is no vacuum in the intake. I oppose your statement."
| The Following User Says Thank You to Tokay444 For This Useful Post: | Mauro_Penguin (01-23-2014) |
![]() | | #69 | ![]() |
![]() Join Date: Nov 2010 Location: Manchester, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
| Not Ranked : 0 score WOW
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
| The Following 3 Users Say Thank You to atvfreek For This Useful Post: |
![]() | | #70 | ![]() |
| Not Ranked : 0 score [quote Tokay] ... What I should have written ...... regarding your statement that there is no vacuum in the intake. ...." I NEVER made that definitive statement. This is what I asked Matt about: [quote Kevin] Have you done any intake measurments to see if there really is a vacuum? With most MS3's and MS6's in this crowd having CAI's and open filters, I thought it would be unlikely for an intake vacuum to exist to help pull out crankcase vapors.[/quote]. I asked Matt for a definitive answer based on measurments, and I let him know what I had though, knowing that if he did measure it ( or did a CFD run ), then the intake did have vacuum in it. Learn English so you don't keep twisting the truth. .
| The Following 2 Users Say NO Thank You to KevinK2 For This Un-useful Post: | Mauro_Penguin (01-23-2014), Tokay444 (01-22-2014) |
![]() | | #71 | ![]() |
| Not Ranked : 0 score Well done on your sealed PCV system, good for 27psi plus. Dual CC's, connected like Matt's last configuration, is the way to go. .
| The Following User Says Thank You to KevinK2 For This Useful Post: | atvfreek (01-22-2014) |
![]() | | #72 | ![]() |
Groans: 793
Does the wheel have dimples, like a golfball?
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals Last edited by Tokay444; 01-22-2014 at 04:52 PM. Reason: MSF Database - Automerged Doublepost | |||
![]() | | #73 | ![]() |
Groans: 793
| Not Ranked : 0 score Takes Internet posts to English teach. Wants respect. Daduq you think this is?
| The Following 2 Users Say Thank You to Tokay444 For This Useful Post: | Mauro_Penguin (01-23-2014), mrmonk7663 (01-22-2014) |
![]() | | #74 | ![]() |
If you could write a correct sentence, 2 pages would not have been wasted with your foul posts based on a vague comment of yours. Have a grade school teacher show you that your comment was ambiguous.
Talks to himself ........ you need help. I had to defend my integrity after your crude attack:
![]() | | #75 | ![]() |
Groans: 793
| Not Ranked : 0 score You were the only one who had a problem deciphering my statement.
![]() | | #76 | ![]() |
Here it sounds like the closer to the compressor inlet, the more the influence of the relatively small inducer dia, relative to the larger funnel section where the inlet coupling hose attaches. So there is some higher velocity flow in this transition, that would drop the ambient air to a vacuum. Do you remember what the highest vacuum readings were? Regarding vc and cc pressures, would they be the same, due to the volumes being connected at the timing chain location? Lastly, rather than adding an extra vented line to the pcv box, add it to the VC that combines with the oem vc line, and to another CC then to the TIP. This would allow a closed system with high boost and low cc pressure. Similar to atvfreek's set-up: atvfreek's dual can set-up .
| The Following User Says Thank You to KevinK2 For This Useful Post: | Matt@DamondMotorsports (01-28-2014) |
![]() | | #77 | ![]() |
Groans: 793
| Not Ranked : 0 score Mazda has already moved the port for the valve cover vent from just aft of the maf housing, to turbo inlet pipe to pull more vacuum on the block and help with smoking turbo syndrome. the system you just posed, is what I have been telling people to run, for a long time now.
| The Following User Says Thank You to Tokay444 For This Useful Post: | Matt@DamondMotorsports (01-28-2014) |
![]() | | #78 | ![]() |
| Not Ranked : 0 score I guess we agree with vtafreek's sealed system, with an extra vc vent and both going to another occ before connecting to the TIP. Both Matt's newest version, with an extra CC VTA, and vtafreek's set-up, provides extra venting compared to his 4th & last design shown on page 1, that had reduced cc pressure to .5 to 1.0 psi @ 28 psi on a BT. Hope he can do more measurements with a 3rd line to vent the cc ... both his open system and vtafreek's sealed system. Either way, there should be baffeling inboard of the new vent. .
__________________ From Delaware Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo Last edited by KevinK2; 01-24-2014 at 01:18 PM. |
![]() | | #79 | ![]() |
![]() | | #80 | ![]() |
![]() Join Date: Jun 2008 Location: Harrison, AR Heart of the Ozarks
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32,768
| Not Ranked : 0 score Matt, Have you gotten a chance to put together the retrofit VTA kits yet? Do you have a feel for the actual volume of air being moved from the VC to the TIP in the case of the stock/sealed system? TIA
__________________ "I only do what the voices in my wife’s head tell her to tell me to do" |
| The Following User Says Thank You to CosmicArkie For This Useful Post: | Matt@DamondMotorsports (01-28-2014) |
| Pressure testing a silicone TIP? | Todd98SE | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 7 | 03-13-2013 03:07 PM |
| Crankcase relief | jpshotya | 2010 MS3 - Engine, Transmission & Driveline | 3 | 10-18-2012 05:40 AM |
| Gen 1 MS3/6 Build/Diaries | Haltech | MazdaSpeed 3/6 - Build Diaries | 6 | 04-07-2011 12:47 AM |
| GenPu Build Diaries | Haltech | 2010 MS3 - Build Diaries | 1 | 03-21-2011 04:31 AM |
| Negative Crankcase Pressure | kore2000 | MazdaSpeed 6 - Engine, Transmission & Driveline | 3 | 03-16-2010 07:56 AM |
