| Damond Motorsports Welcome to Damond Motorsports, home of Track Tested Driver Trusted performance products. We aim to specialize in reliability and power modifications, for the track and the street. Every product we offer has been put through many hours of both road course and street use, to insure excellent reliability and performance. |
![]() | | #81 | ![]() |
Groans: 793
| Not Ranked : 0 score
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
![]() | | #82 | ![]() |
![]() Join Date: Nov 2013 Location: Delaware
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 228
Groaned at 79 Times in 52 Posts
| Not Ranked : 0 score On the subject of vacuum in the intake, I checked the vacuum based on stagnent air (no ram velocity) entering a 3" dia intake. Assumed 29 psi boost, .85 VE, 390 CFM into intake, and no pressure drop at filter or MAF. The vacuum was .135 psi, or .27 " HG. Very low. Unless those pressure drops are high, the CC does more pushing than the intake pulls at the TIP. dP =.5 x p/g x V^2 dP = pressure drop, PSF (converted to psi) p = air density, PCF g = constant, 32.2 ft/sec^2 V = air velocity in intake, ft/sec As I posted before, and others concur, close to the compressor inlet, there is a transition from the small opening in the casting to the larger bore of the inlet pipe. There the vacuum will be stronger. .
__________________ From Delaware Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo Last edited by KevinK2; 01-25-2014 at 08:01 PM. |
![]() | | #83 | ![]() |
Groans: 793
| Not Ranked : 0 score I know.
![]() | | #84 | ![]() |
| Name is longer than yours ![]() Join Date: Mar 2013 Location: Chicago, IL
Rep Power: 785 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 709
![]() On the two stock turbo intakes I tested, a cobb vs a CS, the cobb pulled around 1-3in/HG, and the CS pulled 4-6in/HG, at full gallop. The cobb has the PCV port right behind the MAF, similar to the OEM mazda intake port. The CS on the other hand, has the PCV port on the inlet pipe, much closer to the turbo. On the BT car tested with a 3.5" HTP full intake, it was 4-6in/HG, since the PCV port is closer to the turbo, like the CS one. The turbo on this car was either a GT30 or 35, so it'll move more air, hence why the reading was similar on a bigger dia intake. I'm not 100% sure that CC and VC pressure would be the same, as all of that air has to travel via the oil galleys in the head and timing cover. I've mainly measure pressure at the VC, but I will be adding a port on mah modified breather box, to see if there is a variance is CC pressure vs VC pressure. I doubt it though. I have thought about testing the VTA add-in set up at the VC as well, to see if the PCV valve is too much of a restriction. However, there is generally a vacuum present in that connection, under conditions where CC pressure is common. If that is the case, the valve won't really open.
The new check valve I will be using for a "retrofit VTA kit" has basically no cracking pressure, so it should be able to vent crankcase pressures super easily as long as it can overcome the PCV valve restriction VS how much pressure is in the crankcase. | ||
| The Following 6 Users Say Thank You to Matt@DamondMotorsports For This Useful Post: | bob^3 (01-29-2014), CosmicArkie (01-28-2014), jk_ms3 (01-28-2014), KevinK2 (01-28-2014), Nliiitend1 (01-28-2014), silvapain (01-28-2014) |
![]() | | #85 | ![]() |
Also, based on some one-way pcv valves that I tested, the restriction is variable. When you have high vacuum in the IM, the flow area is small. But installed per the illustration, the pressure drop across the valve is much smaller, and the opening in it is relatively big for cc venting purposes. Is that still too restrictive? . .
__________________ From Delaware Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo | ||
![]() | | #86 | ![]() |
I did measure the flow of vacuum pulled after an OEM DISI PCV valve, at different vacuums, a long long long time ago, and the PCV valve was a large restriction. But it needs to be, so you don't pull too much of a vacuum on the crankcase. Though the opening of the valve may seem large, the innards are quite small, and don't allow for much of an opening. | |
![]() | | #87 | ![]() |
![]() Join Date: Sep 2012 Location: West Palm Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 115
| Not Ranked : 0 score @Damond Motorsports; Matt, say we wanted to run the modded stock pcv box like what you posted on page 2 (check valve attached to new port on box). If we utilize a very low pressure cracking CV, whats to keep that valve from opening up really really easily (i guess thats saying we have bad crank case pressure) and spraying any potential blow-by out of that CV rather than running through the seal catch can that i have utilizing the standard occ layout. I guess im saying whats to stop the blow by from taking the path of least resistance and making a mess. Maybe we'd have to throw a vented occ onto that line?
__________________ 2008 MS3 GT GTX//Relentless Customs//Voltron Approved//Nishan Tuned [SIGPIC][/SIGPIC] |
![]() | | #88 | ![]() |
The times the VTA valve will open are when there is pressure inside the crankcase. Generally there is little to no pressure, where there is a vacuum present in the manifold. When the sealed OCC set-up sees boost, the CV in the sealed set-up will close. If there is pressure in the crankcase, surpassing the vacuum pulled from the intake via the valve cover, it will go the path of least resistance, via the VTA valve. However, the PCV breather box and the engine block, have a slight amount of baffling in them, basically plates the oily air has to travel around, which allows the oil vapours to collect, and not make their way out of the VTA valve, leaving an oily mess everywhere. You could throw a vented OCC onto the VTA valve, if there were to be copious amounts of blow-by coming out of the valve. However, there really isn't enough crankcase pressure being made on the stock turbo, to release blow by oil everywhere. I'm sure on a BT car, adding a VTA OCC would be beneficial to collecting the oily blow-by coming out of the valve. I have a tiny filter on my VTA valve, and it has collected a little bit of oil, but not enough to leave traces of oil or make a mess anywhere on the front of my engine. | |
| The Following User Says Thank You to Matt@DamondMotorsports For This Useful Post: | jtday (02-11-2014) |
![]() | | #89 | ![]() |
| Not Ranked : 0 score Based on his response to my questions, the kit he spoke about adds a "T" to the basic set-up like yours, with a new check valve to a VTA filter. This extra line is so when boosting, the pcv valve can vent cc pressure through the VTA and filter. He supplies an extra cv at the manifold port to prevent boosted air from going through the new VTA he added. There is no extra hole in the PCV valve box. As he told me, adding a new vent from the block or the VC is another option he is currently testing. Note, This slow, distracted poster finished this post before I saw Matt's new reply. .
![]() | | #90 | ![]() |
![]() | | #91 | ![]() |
![]() Join Date: Jan 2011 Location: Indianapolis, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 232
I've been playing with different options, but if you've got a kit ready to go I'd love to try it out.
__________________ 2008.5 MS3 GT | Forged | Self-Built, Self-Tuned | E85 | Torque (lots of it) | |
| The Following User Says Thank You to crutch77 For This Useful Post: | jtday (02-11-2014) |
![]() | | #92 | ![]() |
![]() Join Date: May 2013 Location: Edmonton,AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 572
Groans: 46
Groaned at 37 Times in 19 Posts
PCV>OCC>Cobb Intake Port, VC>VTA
__________________ 06 Liquid Platinum GT COBB AP // 3" ID MAF // 3" HTP TIP // Ebay catless DP // Autotech FPI // DO DVC-30 w/D07 // Grimmspeed EBCS // FORGE V1 BPV // DM OCC // JBR SSP|TIGs|EGR- // SURE RMM|Juggernaught // CP-E TMIC|Rear Diff Mount // Whiteline RSB // ISC N1 Coilovers // 18x8 +45 TSW Nurburgring MisterSix Tuned.. vdyno: 287hp/335tq Uncorrected (2400ft ASL) 303hp/355tq Corrected | |
![]() | | #93 | ![]() |
| Not Ranked : 0 score Why would that have anything to do with how much your OCC collects?
![]() | | #94 | ![]() |
For the extra new cc/vc port, it should have some baffeling to reduce the liquid flow. .
| The Following User Says Thank You to KevinK2 For This Useful Post: | atvfreek (02-11-2014) |
![]() | | #95 | ![]() |
Groans: 46
| Not Ranked : 0 score I think my current setup isn't providing enough vacuum.
![]() | | #96 | ![]() |
| Not Ranked : 0 score There's not much vacuum there anyway. The only thing that would make a difference would be a better flowing turbo or a narrower diameter intake. But the narrower diameter intake is counterproductive to higher HP.
![]() | | #97 | ![]() |
You don't get much oil in that can, since the intake manifold vacuum is much greater than a TIP port, and you pluged the IM port. As Matt said, the PCV valve has a lot of flow resistance. .
__________________ From Delaware Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo Last edited by KevinK2; 02-11-2014 at 02:47 PM. | |
| The Following User Says Thank You to KevinK2 For This Useful Post: | btstarcher (02-13-2014) |
![]() | | #98 | ![]() |
| The Following 2 Users Say Thank You to KevinK2 For This Useful Post: | btstarcher (02-13-2014), Mauro_Penguin (02-13-2014) |
![]() | | #99 | ![]() |
Groans: 46
| Not Ranked : 0 score @Damond Motorsports; would it be possible for you to test a 3" HTP inlet on a k04 to see how much vacuum it pulls since the port is very close to the turbo just like the CS TIP ? Thanks.
| The Following User Says Thank You to 5LOWMS6 For This Useful Post: | redboat (03-14-2014) |
![]() | | #100 | ![]() |
![]() Join Date: Dec 2012 Location: Portland, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 800
| Not Ranked : 0 score Matt, you should include in your kits silicone port adapters. This allow those with silicone TIP to create a vacuum port much closer to the turbo inlet for a high rate of vacuum. Their about $22 on eBay for a large 1\2 size one with NPT interior thread. I'm getting one so I can actually run a OCC instead of just catching everything in a Gatorade bottle since my intake doesn't have a VC port. http://www.ebay.com/itm/191089222289...ht_1831wt_1153 Also anyone try to drill/tap the oil fill cap as a secondary VC port? I know Matt used it for testing, I don't think it would need a baffle Last edited by redboat; 03-15-2014 at 07:34 PM. |
![]() | | #101 | ![]() |
| Not Ranked : 0 score Would more vacuum at the valvecover port be beneficial? In boost, wouldn't it help with piston ring seating?
![]() | | #102 | ![]() |
![]() Join Date: Jun 2008 Location: Harrison, AR Heart of the Ozarks
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32,768
Nator Valve Cover Breather Tutorial You can always go retro and get a similar cap from back in the day that has a 90 degree 5/8 inch nipple for the hose which used to run from the valve cover to the air cleaner on those cars. Just tee it into the TIP or OCC.
__________________ "I only do what the voices in my wife’s head tell her to tell me to do" | |
| The Following User Says Thank You to CosmicArkie For This Useful Post: | redboat (03-15-2014) |
![]() | | #103 | ![]() |
![]() Join Date: Jun 2013 Location: Marseilles, Illinois
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 271
| Not Ranked : 0 score I'm really interested in the two can set up like atvfreek has do you offer this @Damond Motorsports; ? Double tappin' the Moto
__________________ 2013 VRM MS3 |
![]() | | #104 | ![]() |
| Not Ranked : 0 score Matt would you know the cracking pressure of the PCV is? Would it be safe to run CC w/out a PCV or Check vavle straight into a vacuum sourced OCC? |
![]() | | #105 | ![]() |
![]() Join Date: Apr 2011 Location: Chesapeake,VA
Rep Power: 901 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 672
__________________ | |
| The Following User Says Thank You to 2.0t03speed For This Useful Post: | redboat (03-17-2014) |
![]() | | #106 | ![]() |
| Not Ranked : 0 score Then what about when it's under boost? Positive pressure into the CC is no bueno. Unless I'm misunderstanding you.
![]() | | #107 | ![]() |
| The Following 2 Users Say Thank You to 2.0t03speed For This Useful Post: | btstarcher (03-17-2014), redboat (03-17-2014) |
![]() | | #108 | ![]() |
| Not Ranked : 0 score That's not much of a vacuum source.....
![]() | | #109 | ![]() |
My concern is, if I remove the PCV from CC, and run a hose from CC to OCC, with a strong vacuum source from TIP. would this be a problem? or just leave PCV in place? | |
![]() | | #110 | ![]() |
| Not Ranked : 0 score Ok but from the factory the only place the block see's vac while under boost is from the top of the vc at the most remote point from where the pressure is being created. i don't expect hooking up the pcv to the intake while under load is going to hurt things.
![]() | | #111 | ![]() |
But what I think he is saying, is that you'll get a stronger source of vacuum from a closer point on the TIP near the turbine inlet of the turbo. | |
![]() | | #112 | ![]() |
| Not Ranked : 0 score I'm still curious about using a pump of some sort. Then a vent at the valvecover.
![]() | | #113 | ![]() |
| Not Ranked : 0 score Yep that's why I have a htp intake and a oil cap breather. I don't need any crank case pressure issues. Also from what I've read at higher boost levels the stock pcv will leak some pressure in the crankcase. But it think that varies from car to car. Sent from my Nexus 5 using Tapatalk
| The Following User Says Thank You to 2.0t03speed For This Useful Post: | btstarcher (03-17-2014) |
![]() | | #114 | ![]() |
Groans: 793
| Not Ranked : 0 score The block does not see vacuum under boost, with the oem vent setup. That's why it sucks.
| The Following 2 Users Say Thank You to Tokay444 For This Useful Post: | 2.0t03speed (03-18-2014), btstarcher (03-18-2014) |
| The Following User Says NO Thank You to Tokay444 For This Un-useful Post: | nattun (04-19-2014) |
![]() | | #115 | ![]() |
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress | |
| The Following 3 Users Say Thank You to btstarcher For This Useful Post: |
![]() | | #116 | ![]() |
| Not Ranked : 0 score It would be nice to figure out a way to have the strong IM vacuum source during idle and low load, but also have the vacuum source from the TIP during boost. I think it would take at least 2 check valves to make it work right though. If the check valves didn't work damn near perfect, you could end up with a recirculating boost leak from the IM to the TIP under boost. |
![]() | | #117 | ![]() |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress | |
![]() | | #118 | ![]() |
| Not Ranked : 0 score Or a pump.
![]() | | #119 | ![]() |
Only problem depends on what type of TIP you have. HTP is the only brand I know of, that includes a secondary vacuum port near the turbo inlet with a 3"+ intakes/TIP's. I have a 3" Silicone TIP, with a custom intake set up with NO vacuum port. After some searching I stumbled on to one of these and ordered one for my solution. I'll place close to the inlet of my turbo for a go strength vacuum. Once it arrives with my OCC, I'll do a write up. Silicone Port System | eBay | |
![]() | | #120 | ![]() |
| Not Ranked : 0 score |
| Pressure testing a silicone TIP? | Todd98SE | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 7 | 03-13-2013 03:07 PM |
| Crankcase relief | jpshotya | 2010 MS3 - Engine, Transmission & Driveline | 3 | 10-18-2012 05:40 AM |
| Gen 1 MS3/6 Build/Diaries | Haltech | MazdaSpeed 3/6 - Build Diaries | 6 | 04-07-2011 12:47 AM |
| GenPu Build Diaries | Haltech | 2010 MS3 - Build Diaries | 1 | 03-21-2011 04:31 AM |
| Negative Crankcase Pressure | kore2000 | MazdaSpeed 6 - Engine, Transmission & Driveline | 3 | 03-16-2010 07:56 AM |
